TIP32C
TIP32C
    L3HARRIS
    TO-220-3
    3A, 100V, PNP SILICON TRANSISTOR
TIP32C 数据手册
TIP32 / TIP32A / TIP32C PNP Epitaxial Silicon Transistor Features • Medium Power Linear Switching Applications • Complementary to TIP31 Series TO-220 1 1.Base 2.Collector 3.Emitter Ordering Information Part Number Top Mark Package Packing Method TIP32 TIP32 TO-220 3L (Single Gauge) Bulk TIP32A TIP32A TO-220 3L (Single Gauge) Bulk TIP32ATU TIP32A TO-220 3L (Single Gauge) Rail TIP32C TIP32C TO-220 3L (Single Gauge) Bulk TIP32CTU TIP32C TO-220 3L (Single Gauge) Rail Absolute Maximum Ratings Stresses exceeding the absolute maximum ratings may damage the device. The device may not function or be operable above the recommended operating conditions and stressing the parts to these levels is not recommended. In addition, extended exposure to stresses above the recommended operating conditions may affect device reliability. The absolute maximum ratings are stress ratings only. Values are at TC = 25°C unless otherwise noted. Symbol VCBO Parameter Collector-Base Voltage Value TIP32 -40 TIP32A -60 TIP32C -100 TIP32 -40 TIP32A -60 TIP32C -100 Unit V VCEO Collector-Emitter Voltage VEBO Emitter-Base Voltage -5 V IC Collector Current (DC) -3 A ICP Collector Current (Pulse) -5 A IB Base Current -3 A TJ Junction Temperature 150 °C -65 to 150 °C TSTG Storage Temperature Range © 2000 Fairchild Semiconductor Corporation TIP32 / TIP32A / TIP32C Rev. 1.1.0 V www.fairchildsemi.com TIP32 / TIP32A / TIP32C — PNP Epitaxial Silicon Transistor November 2014 Values are at TC = 25°C unless otherwise noted. Symbol PC Parameter Value Collector Dissipation (TA = 25°C) 2 Collector Dissipation (TC = 25°C) 40 Unit W Electrical Characteristics Values are at TC = 25°C unless otherwise noted. Symbol Parameter Conditions Collector-Emitter Sustaining Voltage(1) TIP32A IC = -30 mA, IB = 0 TIP32C ICEO ICES Collector Cut-Off Current Collector Cut-Off Current IEBO Emitter Cut-Off Current hFE DC Current Gain(1) VCE(sat) VBE(on) fT Max. -60 V -100 TIP32 / TIP32A VCE = -30 V, IB = 0 -0.3 TIP32C VCE = -60 V, IB = 0 -0.3 TIP32 VCE = -40 V, VEB = 0 -200 TIP32A VCE = -60 V, VEB = 0 -200 TIP32C VCE = -100 V, VEB = 0 -200 VEB = -5 V, IC = 0 (1) Collector-Emitter Saturation Voltage Unit -40 TIP32 VCEO(sus) Min. -1 VCE = -4 V, IC = -1 A 25 VCE = -4 V, IC =- 3 A 10 mA μA mA 50 IC = -3 A, IB = -375 mA -1.2 V Base-Emitter On Voltage VCE = -4 V, IC = -3 A -1.8 V Current Gain Bandwidth Product VCE = -10 V, IC = -500 mA, f = 1 MHz (1) 3.0 MHz Note: 1. Pulse test: pw ≤ 300 μs, duty cycle ≤ 2%. © 2000 Fairchild Semiconductor Corporation TIP32 / TIP32A / TIP32C Rev. 1.1.0 www.fairchildsemi.com 2 TIP32 / TIP32A / TIP32C — PNP Epitaxial Silicon Transistor Thermal Characteristics VBE(sat), VCE(sat)[mV], SATURATION VOLTAGE 1000 hFE, DC CURRENT GAIN VCE = -4V 100 10 1 -1 -10 -100 -1000 -10000 IC/IB = 10 -1000 VBE(sat) -100 VCE(sat) -10 -1 -10000 -10 -1000 -10000 IC[mA], COLLECTOR CURRENT IC[mA], COLLECTOR CURRENT Figure 1. DC Current Gain Figure 2. Base-Emitter Saturation Voltage and Collector-Emitter Saturation Voltage -10 50 IC(MAX) (PULSE) 45 IC(MAX) (DC) s 1m PC[W], POWER DISSIPATION 100μs s 5m IC[A], COLLECTOR CURRENT -100 -1 TIP32 VCEO MAX. TIP32A VCEO MAX. TIP32B VCEO MAX. TIP32C VCEO MAX. 40 35 30 25 20 15 10 5 -0.1 0 -10 -100 0 50 75 100 125 150 175 200 o VCE[V], COLLECTOR-EMITTER VOLTAGE TC[ C], CASE TEMPERATURE Figure 3. Safe Operating Area © 2000 Fairchild Semiconductor Corporation TIP32 / TIP32A / TIP32C Rev. 1.1.0 25 Figure 4. Power Derating www.fairchildsemi.com 3 TIP32 / TIP32A / TIP32C — PNP Epitaxial Silicon Transistor Typical Performance Characteristics TIP32 / TIP32A / TIP32C — PNP Epitaxial Silicon Transistor Physical Dimensions Figure 5. TO-220, MOLDED, 3LEAD, JEDEC VARIATION AB © 2000 Fairchild Semiconductor Corporation TIP32 / TIP32A / TIP32C Rev. 1.1.0 www.fairchildsemi.com 4 TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. F-PFS¥ FRFET® SM Global Power Resource GreenBridge¥ Green FPS¥ Green FPS¥ e-Series¥ Gmax¥ GTO¥ IntelliMAX¥ ISOPLANAR¥ Making Small Speakers Sound Louder and Better™ MegaBuck¥ MICROCOUPLER¥ MicroFET¥ MicroPak¥ MicroPak2¥ MillerDrive¥ MotionMax¥ MotionGrid® MTi® MTx® MVN® mWSaver® OptoHiT¥ OPTOLOGIC® AccuPower¥ Awinda® AX-CAP®* BitSiC¥ Build it Now¥ CorePLUS¥ CorePOWER¥ CROSSVOLT¥ CTL¥ Current Transfer Logic¥ DEUXPEED® Dual Cool™ EcoSPARK® EfficientMax¥ ESBC¥ ® Fairchild® Fairchild Semiconductor® FACT Quiet Series¥ FACT® FAST® FastvCore¥ FETBench¥ FPS¥ OPTOPLANAR® ® PowerTrench® PowerXS™ Programmable Active Droop¥ QFET® QS¥ Quiet Series¥ RapidConfigure¥ ¥ Saving our world, 1mW/W/kW at a time™ SignalWise¥ SmartMax¥ SMART START¥ Solutions for Your Success¥ SPM® STEALTH¥ SuperFET® SuperSOT¥-3 SuperSOT¥-6 SuperSOT¥-8 SupreMOS® SyncFET¥ Sync-Lock™ ®* ® TinyBoost TinyBuck® TinyCalc¥ TinyLogic® TINYOPTO¥ TinyPower¥ TinyPWM¥ TinyWire¥ TranSiC¥ TriFault Detect¥ TRUECURRENT®* μSerDes¥ UHC® Ultra FRFET¥ UniFET¥ VCX¥ VisualMax¥ VoltagePlus¥ XS™ Xsens™ ௝❺™ * Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. TO OBTAIN THE LATEST, MOST UP-TO-DATE DATASHEET AND PRODUCT INFORMATION, VISIT OUR WEBSITE AT HTTP://WWW.FAIRCHILDSEMI.COM. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in cause the failure of the life support device or system, or to affect its accordance with instructions for use provided in the labeling, can be safety or effectiveness. reasonably expected to result in a significant injury of the user. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation's Anti-Counterfeiting Policy. Fairchild's Anti-Counterfeiting Policy is also stated on our external website, www.fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufacturers of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed applications, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild's quality standards for handling and storage and provide access to Fairchild's full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address any warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Advance Information Formative / In Design Preliminary First Production No Identification Needed Full Production Obsolete Not In Production Definition Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I72 © Fairchild Semiconductor Corporation www.fairchildsemi.com
TIP32C 价格&库存
很抱歉,暂时无法提供与“TIP32C”相匹配的价格&库存,您可以联系我们找货
