TIP42C
TIP42C
    L3HARRIS
    TO-220-3
    TRANS PNP 100V 6A TO220-3
TIP42C 数据手册
TIP42/TIP42A/TIP42B/TIP42C PNP Epitaxial Silicon Transistor Features • Medium Power Linear Switching Applications • Complement to TIP41/TIP41A/TIP41B/TIP41C TO-220 1 1.Base Absolute Maximum Ratings Symbol 2.Collector 3.Emitter TA=25°C unless otherwise noted Parameter Value Units VCBO Collector-Base Voltage : TIP42 : TIP42A : TIP42B : TIP42C - 40 - 60 - 80 - 100 V V V V VCEO Collector-Emitter Voltage : TIP42 : TIP42A : TIP42B : TIP42C - 40 - 60 - 80 - 100 V V V V VEBO Emitter-Base Voltage -5 V IC Collector Current (DC) -6 A ICP Collector Current (Pulse) -10 A IB Base Current -2 A PC Collector Dissipation (TC=25°C) 65 W Collector Dissipation (TA=25°C) 2 W TJ Junction Temperature 150 °C TSTG Storage Temperature - 65 to 150 °C © 2009 Fairchild Semiconductor Corporation TIP42/TIP42A/TIP42B/TIP42C Rev. B0 www.fairchildsemi.com 1 TIP42/TIP42A/TIP42B/TIP42C — PNP Epitaxial Silicon Transistor December 2009 TA=25°C unless otherwise noted Symbol Parameter VCEO(sus) * Collector-Emitter Sustaining Voltage : TIP42 : TIP42A : TIP42B : TIP42C ICEO Test Condition IC = -30mA, IB = 0 Min. Max. -40 -60 -80 -100 Units V V V V Collector Cut-off Current : TIP42/42A : TIP42B/42C VCE = -30V, IB = 0 VCE = -60V, IB = 0 -0.7 -0.7 mA mA Collector Cut-off Current : TIP42 : TIP42A : TIP42B : TIP42C VCE = -40V, VEB = 0 VCE = -60V, VEB = 0 VCE = -80V, VEB = 0 VCE = -100V, VEB = 0 -400 -400 -400 -400 μA μA μA μA IEBO Emitter Cut-off Current VEB = -5V, IC = 0 -1 mA hFE * DC Current Gain VCE = -4V, IC = -0.3A VCE = -4V, IC = -3A ICES 30 15 75 VCE(sat) * Collector-Emitter Saturation Voltage IC = -6A, IB = -600mA -1.5 V VBE(sat) * Base-Emitter Saturation Voltage VCE = -4V, IC = -6A -2.0 V fT Current Gain Bandwidth Product VCE = -10V, IC = -500mA, f = 1MHz 3.0 MHz * Pulse Test: PW≤300μs, Duty Cycle≤2% © 2009 Fairchild Semiconductor Corporation TIP42/TIP42A/TIP42B/TIP42C Rev. B0 www.fairchildsemi.com 2 TIP42/TIP42A/TIP42B/TIP42C — PNP Epitaxial Silicon Transistor Electrical Characteristics VBE(sat), VCE(sat)[V], SATURATION VOLTAGE 1000 hFE, DC CURRENT GAIN VCE = -4V 100 10 1 -0.01 -0.1 -1 -10 -2.0 IC/IB = 10 -1.6 VBE(sat) -1.2 -0.8 VCE(sat) -0.4 -0.0 -0.01 -0.1 IC[A], COLLECTOR CURRENT -10 -100 IC[A], COLLECTOR CURRENT Figure 1. DC current Gain Figure 2. Base-Emitter Saturation Voltage Collector-Emitter Saturation Voltage 100 PC[W], POWER DISSIPATION -100 IC(MAX) (PULSE) -10 ms 0.5 s 5m IC(MAX) (DC) s 1m IC[A], COLLECTOR CURRENT -1 -1 TIP42 TIP42A TIP42B TIP42C -10 40 20 0 -100 25 50 75 100 125 150 175 o TC[ C], CASE TEMPERATURE VCE[V], COLLECTOR-EMITTER VOLTAGE Figure 3. Safe Operating Area Figure 4. Power derating © 2009 Fairchild Semiconductor Corporation TIP42/TIP42A/TIP42B/TIP42C Rev. B0 60 0 -0.1 -1 80 www.fairchildsemi.com 3 TIP42/TIP42A/TIP42B/TIP42C — PNP Epitaxial Silicon Transistor Typical Performance Characteristics TIP42/TIP42A/TIP42B/TIP42C — PNP Epitaxial Silicon Transistor Mechanical Dimensions TO-220 Dimensions in Millimeters © 2009 Fairchild Semiconductor Corporation TIP42/TIP42A/TIP42B/TIP42C Rev. B0 www.fairchildsemi.com 4 TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. AccuPower¥ Auto-SPM¥ Build it Now¥ CorePLUS¥ CorePOWER¥ CROSSVOLT¥ CTL™ Current Transfer Logic™ EcoSPARK® EfficentMax™ EZSWITCH™* ™* ® Fairchild® ® Fairchild Semiconductor FACT Quiet Series™ FACT® ® FAST FastvCore¥ FETBench¥ FlashWriter®* FPS¥ F-PFS¥ FRFET® SM Global Power Resource Green FPS¥ Green FPS¥ e-Series¥ Gmax™ GTO¥ IntelliMAX¥ ISOPLANAR¥ MegaBuck™ MICROCOUPLER¥ MicroFET¥ MicroPak¥ MillerDrive™ MotionMax™ Motion-SPM™ OPTOLOGIC® ® OPTOPLANAR ® PDP SPM™ Power-SPM¥ PowerTrench® PowerXS™ Programmable Active Droop¥ QFET® QS¥ Quiet Series¥ RapidConfigure¥ ™ Saving our world, 1mW/W/kW at a time™ SmartMax™ SMART START¥ SPM® STEALTH™ SuperFET¥ SuperSOT¥-3 SuperSOT¥-6 SuperSOT¥-8 SupreMOS™ SyncFET™ Sync-Lock™ ® * The Power Franchise® TinyBoost¥ TinyBuck¥ TinyCalc¥ TinyLogic® TINYOPTO¥ TinyPower¥ TinyPWM¥ TinyWire¥ TriFault Detect¥ TRUECURRENT¥* PSerDes¥ ® UHC Ultra FRFET¥ UniFET¥ VCX¥ VisualMax¥ XS™ * Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation's Anti-Counterfeiting Policy. Fairchild's Anti-Counterfeiting Policy is also stated on our external website, www.fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufacturers of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed applications, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild's quality standards for handling and storage and provide access to Fairchild's full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address any warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Advance Information Formative / In Design Preliminary First Production No Identification Needed Full Production Obsolete Not In Production Definition Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I41 © 2008 Fairchild Semiconductor Corporation www.fairchildsemi.com
TIP42C 价格&库存
很抱歉,暂时无法提供与“TIP42C”相匹配的价格&库存,您可以联系我们找货
