TSC741CZ C0G
TSC741CZ C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    TRANSISTOR, NPN, 450V, 2.5A, 18A
TSC741CZ C0G 数据手册
TSC741 Taiwan Semiconductor High Voltage Fast-Switching NPN Power Transistor FEATURES ● ● ● ● KEY PERFORMANCE PARAMETERS High Voltage Capability Fast Switching Speed Pb-free plating RoHS compliant APPLICATION VALUE UNIT BVCEO 450 V BVCBO 1050 V IC 2.5 A 0.5 V VCE(SAT) Electronic Ballast Switch mode power supply IC=0.7A, IB=0.14A en de d ● ● PARAMETER mm TO-220 eco Notes: Moisture sensitivity level: level 3. Per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT VCBO 1050 V Collector-Emitter Voltage @ VBE=0V VCES 450 V Emitter-Base Voltage VEBO 15 V Collector Current IC 2.5 A Collector Peak Current (tp
TSC741CZ C0G 价格&库存
很抱歉,暂时无法提供与“TSC741CZ C0G”相匹配的价格&库存,您可以联系我们找货
