BC847BQCZ
BC847BQCZ
    NEXPERIA(安世)
    XDFN3
    BC847BQC/SOT8009/DFN1412D-3
BC847BQCZ 数据手册
BC847xQC series 45 V, 100 mA NPN general-purpose transistor Rev. 1 — 4 January 2021 Product data sheet 1. General description NPN general-purpose transistor in an ultra small DFN1412D-3 (SOT8009) leadless SurfaceMounted Device (SMD) plastic package with side-wettable flanks. Table 1. Product overview Type number Package BC847AQC PNP complement: Nexperia JEDEC SOT8009 MO-340CA BC857AQC BC847BQC BC857BQC BC847CQC BC857CQC 2. Features and benefits • • • • • High power dissipation capability Suitable for Automatic Optical Inspection (AOI) of solder joint Smaller footprint compared to conventional leaded SMD packages Low package height of 0.5 mm AEC-Q101 qualified 3. Applications • • General-purpose switching and amplification Space restricted applications 4. Quick reference data Table 2. Quick reference data Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit VCEO collector-emitter voltage open base - - 45 V IC collector current - - 100 mA ICM peak collector current single pulse; tp ≤ 1 ms - - 200 mA hFE DC current gain VCE = 5 V; IC = 2 mA 110 - 220 BC847BQC 200 - 450 BC847CQC 420 - 800 BC847AQC BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 5. Pinning information Table 3. Pinning Pin Symbol Description 1 B base 2 E emitter 3 C collector Simplified outline 1 Graphic symbol C 2 B 3 E sym021 Bottom view 6. Ordering information Table 4. Ordering information Type number Package BC847AQC BC847BQC BC847CQC Name Description Version DFN1412D-3 plastic, leadless ultra small outline package with sidewettable flanks (SWF); 3 terminals; 0.8 mm pitch; 1.4 mm x 1.2 mm x 0.48 mm body SOT8009 7. Marking Table 5. Marking Type number Marking code BC847AQC 9C BC847BQC 9D BC847CQC 9E BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 2 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 8. Limiting values Table 6. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Max Unit VCBO collector-base voltage open emitter - 50 V VCEO collector-emitter voltage open base - 45 V VEBO emitter-base voltage open collector - 6 V IC collector current - 100 mA ICM peak collector current single pulse; tp ≤ 1 ms - 200 mA IBM peak base current single pulse; tp ≤ 1 ms - 100 mA Ptot total power dissipation Tamb ≤ 25 °C [1] - 360 mW [2] - 450 mW Tj junction temperature - 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C [1] [2] Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided 35 µm copper; tin-plated and standard footprint. Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided 70 µm copper; tin-plated and standard footprint. aaa-032914 500 Ptot (mW) (1) 400 (2) 300 200 100 0 -75 -25 25 75 125 175 Tamb (°C) (1) FR4 PCB; single-sided 70 µm copper, standard footprint (2) FR4 PCB; single-sided 35 µm copper, standard footprint Fig. 1. Power derating curves DFN1412D-3 (SOT8009) BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 3 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 9. Thermal characteristics Table 7. Thermal characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air [1] [2] Min Typ Max Unit [1] - - 348 K/W [2] - - 278 K/W Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided 35 µm copper; tin-plated and standard footprint. Device mounted on an FR4 Printed-Circuit-Board (PCB); single-sided 70 µm copper; tin-plated and standard footprint. aaa-032915 103 Zth(j-a) (K/W) duty cycle = 1 0.50 102 0.75 0.33 0.20 0.10 0.05 10 0.02 0.01 0 1 10-5 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB; single-sided 35 µm copper, standard footprint Fig. 2. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-032916 103 Zth(j-a) (K/W) duty cycle = 1 102 0.50 0.75 0.33 0.20 0.10 0.05 10 0.01 1 10-5 0.02 0 10-4 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB; single-sided 70 µm copper, standard footprint Fig. 3. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 4 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 10. Characteristics Table 8. Characteristics Tamb = 25 °C unless otherwise specified. Symbol Parameter Conditions Min Typ Max Unit V(BR)CBO collector-base breakdown voltage IC = 100 µA; IE = 0 A 50 - - V V(BR)CEO collector-emitter breakdown voltage IC = 2 mA; IB = 0 A 45 - - V V(BR)EBO emitter-base breakdown voltage IE = 100 µA; IC = 0 A 6 - - V ICBO collector-base cut-off current VCB = 30 V; IE = 0 A - - 15 nA VCB = 30 V; IE = 0 A; Tj = 150 °C - - 5 μA IEBO emitter-base cut-off current VEB = 5 V; IC = 0 A - - 100 nA hFE DC current gain VCE = 5 V; IC = 2 mA 110 - 220 BC847BQC 200 - 450 BC847CQC 420 - 800 - - 200 mV BC847AQC VCEsat collector-emitter saturation voltage IC = 10 mA; IB = 0.5 mA IC = 100 mA; IB = 5 mA [1] - - 400 mV VBE base-emitter voltage VCE = 5 V ; IC = 2 mA [2] 580 - 700 mV VCE = 5 V ; IC = 10 mA [2] - - 770 mV - 760 - mV - 900 - mV VBEsat base-emitter saturation IC = 10 mA ; IB = 0.5 mA voltage IC = 100 mA ; IB = 5 mA [1] fT transition frequency VCE = 5 V; IC = 10 mA; f = 100 MHz 100 - - MHz Cc collector capacitance VCB = 10 V; IE = ie = 0 A; f = 1 MHz - - 1.5 pF Ce emitter capacitance VEB = 0.5 V; IE = ie = 0 A; f = 1 MHz - 11 - pF NF noise figure VCE = 5 V; IC = 200µA; RS = 2 kΩ; f = 1 kHz; B = 200 Hz - - 10 dB [1] [2] pulsed; tp ≤ 300 μs; δ ≤ 0.02 VBE decreases by about 2 mV/K with increasing temperature. BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 5 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor mgt723 400 hFE (1) 300 mgt724 1200 VBE (mV) 1000 (1) 800 (2) (2) 200 600 100 (3) 400 (3) 200 0 10- 1 1 10 102 I C (mA) 0 10- 1 103 VCE = 5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 4. 1 10 102 I C (mA) 103 VCE = 5 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC847AQC: DC current gain as a function of collector current; typical values mgt725 103 VCEsat (mV) Fig. 5. BC847AQC: Base-emitter voltage as a function of collector current; typical values mgt726 1200 VBEsat (mV) 1000 (1) 800 102 (2) 600 (1) (3) (2) 400 (3) 200 10 10- 1 Fig. 6. 1 10 102 I C (mA) 103 0 10- 1 1 10 102 I C (mA) 103 IC/ IB= 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C IC/ IB= 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC847AQC: Collector-emitter saturation voltage Fig. 7. as a function of collector current; typical values BC847AQC: Base-emitter saturation voltage as a function of collector current; typical values BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 6 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor mgt727 600 hFE 500 400 mgt728 1200 VBE (mV) 1000 (1) 800 (1) (2) 300 600 (2) 200 (3) 100 0 10-1 1 10 200 102 I C (mA) 0 10- 2 103 VCE = 5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 8. (3) 400 10- 1 1 102 103 I C (mA) 10 VCE = 5 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C BC847BQC: DC current gain as a function of collector current; typical values mgt729 104 VCEsat (mV) Fig. 9. BC847BQC: Base-emitter voltage as a function of collector current; typical values mgt730 1200 VBEsat (mV) 1000 (1) 103 800 (2) 600 (3) 102 400 (1) 200 (3) (2) 10 10- 1 1 IC/ IB= 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C 10 102 I C (mA) 103 0 10- 1 1 10 102 I C (mA) 103 IC/ IB= 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Fig. 10. BC847BQC: Collector-emitter saturation voltage Fig. 11. BC847BQC: Base-emitter saturation voltage as a function of collector current; typical values as a function of collector current; typical values BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 7 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor mgt731 1200 hFE 1000 (1) 800 (1) 800 (2) (2) 600 400 600 (3) 400 (3) 200 0 10- 1 mgt732 1200 VBE (mV) 1000 200 1 10 102 I C (mA) 103 VCE = 5 V (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C 0 10- 2 10- 1 1 102 103 I C (mA) 10 VCE = 5 V (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C Fig. 12. BC847CQC: DC current gain as a function of collector current; typical values mgt733 104 VCEsat (mV) Fig. 13. BC847CQC: Base-emitter voltage as a function of collector current; typical values mgt734 1200 VBEsat (mV) 1000 (1) 103 800 (2) 600 (3) 102 400 (1) 200 (3) (2) 10 10- 1 1 10 102 I C (mA) 103 0 10- 1 1 10 102 I C (mA) 103 IC/ IB= 10 (1) Tamb = -55 °C (2) Tamb = 25 °C (3) Tamb = 150 °C IC/ IB= 20 (1) Tamb = 150 °C (2) Tamb = 25 °C (3) Tamb = -55 °C Fig. 14. BC847CQC: Collector-emitter saturation voltage Fig. 15. BC847CQC: Base-emitter saturation voltage as a function of collector current; typical values as a function of collector current; typical values 11. Test information Quality information This product has been qualified in accordance with the Automotive Electronics Council (AEC) standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in automotive applications. BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 8 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 12. Package outline DFN1412D-3: plastic, leadless extremely thin small outline package with side-wettable flanks (SWF); 3 terminals; 0.8 mm pitch; 1.4 mm x 1.2 mm x 0.48 mm body A1 SOT8009 C X Seating plane detail X y C pin 1 index area (1) (1) (2) B v w b (2x) y1 C (4x) C A B C e 1 2 L (2x) K (2x) e1 E e2 E1 Gx45° 3 u C (1) (2x) (1) D A D1 A u C T (4x) (2x) 0 1 mm scale Dimensions (mm are the original dimensions) Unit mm A max 0.50 nom 0.47 min 0.44 A1 b D D1 E E1 0.04 0.30 0.25 0.22 1.4 1.25 1.20 1.17 1.2 0.55 0.50 0.47 e e1 e2 0.8 0.71 0.26 G 0.09 (ref) K L T 0.35 0.22 0.30 0.16 0.25 0.27 0.10 u 0.05 v w y 0.1 0.05 0.05 0.05 Note 1. Side Wettable Flank, protrusion max. 0.02 mm. 2. Visible depend upon used manufacturing technology. Dimension A and T are including plating thickness. Outline version SOT8009 sot8009_po References IEC y1 JEDEC JEITA European projection Issue date 19-12-04 19-12-06 MO-340CA Fig. 16. Package outline DFN1412D-3 (SOT8009) BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 9 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 13. Soldering Footprint information for reflow soldering of DFN1412D-3 package SOT8009 1.7 0.5 0.3 0.4 0.4 0.3 0.8 0.65 0.55 0.45 0.3 0.4 0.4 2.0 0.6 0.7 0.95 0.85 0.75 0.25 0.25 1.2 1.3 1.4 recommended stencil thickness: 0.1 mm occupied area solder resist solder land solder paste Dimensions in mm Issue date 20-03-23 sot8009_fr Fig. 17. Reflow soldering footprint for DFN1412D-3 (SOT8009) BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 10 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor 14. Revision history Table 9. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes BC847XQC_SER v.1 Product data sheet - - BC847XQC_SER Product data sheet 20210104 All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 11 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer's own risk. 15. Legal information Data sheet status Document status [1][2] Product status [3] Definition Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use in automotive applications — This Nexperia product has been qualified for use in automotive applications. Unless otherwise agreed in writing, the product is not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 12 / 13 BC847xQC series Nexperia 45 V, 100 mA NPN general-purpose transistor Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 4 10. Characteristics............................................................ 5 11. Test information.......................................................... 8 12. Package outline.......................................................... 9 13. Soldering................................................................... 10 14. Revision history........................................................11 15. Legal information......................................................12 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 4 January 2021 BC847XQC_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 4 January 2021 © Nexperia B.V. 2021. All rights reserved 13 / 13
BC847BQCZ 价格&库存
很抱歉,暂时无法提供与“BC847BQCZ”相匹配的价格&库存,您可以联系我们找货
BC847BQCZ
  • 30000+0.2731630000+0.03551
