TS13002ACT A3G
TS13002ACT A3G
    TAIWANSEMICONDUCTOR(台半)
    TO92-3
    TRANSISTOR, NPN, 400V, 0.3A, 20A
TS13002ACT A3G 数据手册
TS13002A High Voltage NPN Transistor TO-92 Pin Definition: 1. Emitter 2. Collector 3. Base PRODUCT SUMMARY BVCEO 400V BVCBO 700V IC 0.3A 1.5V @ IC / IB = 200mA / 20mA en de d VCE(SAT) Features Block Diagram ● High Voltage ● High Speed Switching ● Silicon Triple Diffused Type ● NPN Silicon Transistor Ordering Information Package Packing TS13002ACT B0G TO-92 1Kpcs / Bulk TS13002ACT A3G TO-92 2Kpcs / Ammo eco Part No. mm Structure Note: “G” denote for Green Product Absolute Maximum Rating (Ta = 25°C unless otherwise noted) Symbol Limit Unit VCBO 700V V Collector-Emitter Voltage VCEO 400V V Emitter-Base Voltage VEBO 9 V Parameter tR Collector-Base Voltage No Collector Current DC IC Pulse 0.3 0.5 A Collector Power Dissipation PD 0.6 W Operating Junction Temperature TJ +150 °C TSTG - 55 to +150 °C Symbol Limit Unit RӨJA 122 °C/W Operating Junction and Storage Temperature Range Thermal Performance Parameter Junction to Ambient Thermal Resistance Document Number: DS_P0000252 1 Version: F15 TS13002A High Voltage NPN Transistor Electrical Specifications (Ta = 25°C unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit Static IC = 1mA, IB = 0 BVCBO 700 -- -- V Collector-Emitter Breakdown Voltage IC = 10mA, IE = 0 BVCEO 400 -- -- V Emitter-Base Breakdown Voltage IE = 1mA, IC = 0 BVEBO 9 -- -- V Collector Cutoff Current VCB = 700V, IE = 0 ICBO -- -- 1 uA Emitter Cutoff Current VEB = 7V, IC = 0 IEBO -- -- 1 uA DC Current Gain Dynamic -- 0.2 0.4 IC / IB = 100mA / 10mA VCE(SAT)2 -- 0.45 1 IC / IB = 200mA / 20mA VCE(SAT)3 -- 1 1.5 V IC / IB = 50mA / 10mA VBE(SAT)1 -- -- 1 IC / IB = 100mA / 10mA VBE(SAT)2 -- -- 1.2 VCE = 10V, IC = 10mA hFE1 15 -- 40 VCE = 10V, IC = 100mA hFE2 25 -- 40 VCE = 10V, IC = 280mA hFE3 12 -- 24 fT 4 -- -- MHz Cob -- 21 -- pF tr -- 1.1 -- uS tSTG -- 2 4 uS tf -- 0.2 0.7 uS VCE = 10V, IC = 0.1A VCB = 10V, f = 0.1MHz e co Frequency Output Capacitance de VCE(SAT)1 mm Base-Emitter Saturation Voltage IC / IB = 50mA / 10mA en Collector-Emitter Saturation Voltage d Collector-Base Voltage V Resistive Load Switching Time (Ratings) VCC = 125V, IC = 100mA, Rise Time Fall Time tp = 25uS tR Storage Time IB1 = IB2 = 20mA, Duty Cycle ≤1% No Note : pulse test: pulse width ≤ 5mS, duty cycle ≤10% Document Number: DS_P0000252 2 Version: F15 TS13002A High Voltage NPN Transistor Electrical Characteristics Curve (Ta = 25°C, unless otherwise noted) Figure 2. DC Current Gain en de d Figure 1. Static Characteristics Figure 4. Power Derating No tR e co mm Figure 3. VCE(SAT) v.s. VBE(SAT Figure 5. Reverse Bias SOA Document Number: DS_P0000252 Figure 6. Safety Operating Area 3 Version: F15 TS13002A High Voltage NPN Transistor TO-92 Mechanical Drawing d tR e co mm en A B C D E F G H de DIM TO-92 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 4.30 4.70 0.169 0.185 4.30 4.70 0.169 0.185 13.53 (typ) 0.532 (typ) 0.39 0.49 0.015 0.019 1.18 1.28 0.046 0.050 3.30 3.70 0.130 0.146 1.27 1.31 0.050 0.051 0.33 0.43 0.013 0.017 No Marking Diagram Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug Y =Nov Z =Dec W =Sep X =Oct L = Lot Code Document Number: DS_P0000252 4 Version: F15 TS13002A No tR e co mm en de d High Voltage NPN Transistor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000252 5 Version: F15
TS13002ACT A3G 价格&库存
很抱歉,暂时无法提供与“TS13002ACT A3G”相匹配的价格&库存,您可以联系我们找货
