TSC966CW RPG
TSC966CW RPG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-223
    TSC966CW RPG
TSC966CW RPG 数据手册
TSC966CW Taiwan Semiconductor NPN Silicon Planar High Voltage Transistor FEATURES ● ● ● ● KEY PERFORMANCE PARAMETERS High BVCEO, BVCBO High current gain Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC Halogen-Free according to IEC 61249-2-21 VALUE UNIT BVCEO 400 V BVCBO 600 V IC 300 mA 0.5 V VCE(SAT) APPLICATION ● ● PARAMETER IC=50mA, IB=5mA Lighting Switch mode power supply SOT-223 Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Collector-Base Voltage VCBO 600 V Collector-Emitter Voltage VCES 600 V Collector-Emitter Voltage @ VBE=0V VCES 400 V Emitter-Base Voltage VEBO 7 V 0.3 A 1 A DC Collector Current IC Pulse Power Total Dissipation @ TA=25ºC PDTOT Maximum Operating Junction Temperature W +150 o TSTG -55 to +150 o SYMBOL LIMIT RӨJA 91 o 25 o TJ Storage Temperature Range 1 C C THERMAL PERFORMANCE PARAMETER Junction to Ambient Thermal Resistance Junction to Case Thermal Resistance RӨJC 1 UNIT C/W C/W Version: F1801 TSC966CW Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Static CONDITIONS SYMBOL MIN TYP MAX UNIT (Note 1) Collector-Base voltage IC =50μA BVCBO 600 -- -- V Collector-Emitter Saturation Voltage IC =100μA, VBE =0 BVCES 600 -- -- V Collector-Emitter breakdown voltage IC =1mA BVCEO 400 -- -- V Emitter-Base breakdown voltage IE =50μA BVEBO 7 -- -- V Emitter cut-off current VEB =7V IEBO -- -- 1.5 µA Collector cut-off current VCB =600V ICBO -- -- 0.5 µA Collector-Emitter Cutoff Current VCE =400V ICEO -- -- 1 µA Collector-Emitter saturation voltage IC =50mA, IB =5mA VCE(SAT) --- -- 0.5 V Base-Emitter saturation voltage IC =50mA, IB =5mA VBE(SAT) -- -- 1 V VCE =5V, IC =1mA hFE1 100 -- -- VCE =5V, IC =20mA hFE2 90 -- 300 DC Current Gain Transition Frequency VCE = 10V, IE =20mA fT 50 -- -- MHz Output Capacitance VCB =20V, f =1MHz Cob -- -- 7 pF Notes: 1. Pulse test: ≤ 380µs, duty cycle ≤ 2% 2. For DESIGN AID ONLY, not subject to production testing. ORDERING INFORMATION PART NO. PACKAGE PACKING TSC966CW RPG SOT-223 2,500pcs / 13”Reel 2 Version: F1801 TSC966CW Taiwan Semiconductor Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) Figure 1. Static Characteristics Figure 2. DC Current Gain Figure 3. DC Current Gain Figure 4. VCE(sat) vs Ic Figure 5. VBE(sat) vs Ic Figure 6. Safety Operation Area 3 Version: F1801 TSC966CW Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) SOT-223 SUGGESTED PAD LAYOUT (Unit: Millimeters) Marking Diagram Y M L = Year Code = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec = Lot Code 4 Version: F1801 TSC966CW Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: F1801
TSC966CW RPG 价格&库存
很抱歉,暂时无法提供与“TSC966CW RPG”相匹配的价格&库存,您可以联系我们找货
TSC966CW RPG
  • 1+4.880041+0.63167
  • 10+3.7451510+0.48477
  • 25+3.1777025+0.41132
  • 100+2.47058100+0.31979
  • 500+2.39201500+0.30962
TSC966CW RPG
  • 1+6.356961+0.82285
  • 10+3.9135410+0.50657
  • 100+2.50924100+0.32480
  • 500+1.90350500+0.24639
  • 1000+1.708231000+0.22112
库存:330
TSC966CW RPG
  • 2500+1.496462500+0.19371
  • 5000+1.365465000+0.17675
  • 7500+1.298697500+0.16811
  • 12500+1.2236712500+0.15839
  • 17500+1.1792417500+0.15264
  • 25000+1.1360425000+0.14705
库存:330
TSC966CW RPG
  • 1+4.52649
  • 10+3.47482
  • 25+2.94898
  • 100+2.29139
  • 500+2.21593
