TSM150P04LCS
Taiwan Semiconductor
P-Channel Power MOSFET
-40V, -22A, 15mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive losses
● Logic level
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VDS
-40
V
RDS(on)
VGS = -10V
15
(max)
VGS = -4.5V
21
mΩ
Qg
23
nC
APPLICATIONS
● POL
● Load Switch
● Motor Drives
SOP-8
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
TC = 25°C
(Note 1)
Pulsed Drain Current
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
LIMIT
UNIT
VDS
-40
V
VGS
±20
V
ID
TA = 25°C
SYMBOL
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
-22
-9
A
IDM
-88
A
IAS
EAS
-27
109
A
mJ
PD
PD
12.5
2.5
2.2
0.4
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
10
°C/W
Junction to Ambient Thermal Resistance
RӨJA
57
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is
determined by the user’s board design.
1
Version: A1611
TSM150P04LCS
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = -250µA
BVDSS
-40
V
Gate Threshold Voltage
VGS = VDS, ID = -250µA
VGS(TH)
-1
-1.65
-2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
-1
-100
11
15
15
21
gfs
29
Qg
48
Qg
23
Qgs
9
Qgd
8.5
Ciss
2783
Coss
269
Crss
142
Rg
2
6
12
td(on)
7
tr
45
td(off)
67
tf
59
VSD
-1
V
VGS = 0V, VDS = -40V
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = -32V
TJ = 125°C
Drain-Source On-State Resistance
VGS = -10V, ID = -9A
(Note 3)
VGS = -4.5V, ID = -8A
Forward Transconductance
Dynamic
(Note 3)
RDS(on)
VDS = -5V, ID = -9A
µA
mΩ
S
(Note 4)
VGS = -10V,
Total Gate Charge
VDS = -20V, ID = 9A
Total Gate Charge
VGS = -4.5V,
Gate-Source Charge
VDS = -20V, ID = -9A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = -20V
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Gate Resistance
Switching
f = 1.0MHz
nC
pF
Ω
(Note 4)
Turn-On Delay Time
Turn-On Rise Time
VGS = -10V, VDS = -20V,
Turn-Off Delay Time
ID = -9A, RG = 2Ω,
Turn-Off Fall Time
ns
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = -9A
Reverse Recovery Time
IS = -9A ,
trr
19
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
11
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = -10V, VDD = -25V, RG = 25Ω, IAS = -27A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
TSM150P04LCS RLG
PACKAGE
PACKING
SOP-8
2,500pcs / 13” Reel
2
Version: A1611
TSM150P04LCS
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
30
VGS=-10V
VGS=-7V
VGS=-5V
VGS=-4.5V
VGS=-4V
VGS=-3.5V
24
18
-ID, Drain Current (A)
30
VGS=-3V
12
6
24
18
25℃
12
6
150℃
-55℃
2
3
4
On-Resistance vs. Drain Current
3
4
Gate-Source Voltage vs. Gate Charge
0.025
0.02
VGS=-4.5V
0.015
0.01
VGS=-10V
0.005
VDS=-20V
ID=-9A
8
6
4
2
12
18
24
10
VGS=-10V
ID=-9A
1.4
1.2
1
0.8
0.6
-75
-50
-25
50
75
30
40
50
On-Resistance vs. Gate-Source Voltage
100
125
150
RDS(on), Drain-Source On-Resistance (Ω)
On-Resistance vs. Junction Temperature
1.6
Qg, Gate Charge (nC)
1.8
(Normalized)
2
10
0.03
-VGS, Gate to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
1
-VDS, Drain to Source Voltage (V)
TJ, Junction Temperature (°C)
0.05
0.04
0.03
0.02
ID=-9A
0.01
4
5
6
7
8
9
10
3
Version: A1611
TSM150P04LCS
BVDSS vs. Junction Temperature
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
4000
C, Capacitance (pF)
3500
3000
CISS
2500
2000
1500
1000
500
COSS
CRSS
1.2
ID=-1mA
1.1
1
0.9
0.8
40
-75
-50
50
75
100 125 150
Maximum Safe Operating Area, Junction-to-Case
Source-Drain Diode Forward Current vs. Voltage
100
-IS, Reverse Drain Current (A)
100
RDS(ON)
-25
10
1
SINGLE PULSE
RӨJC=10°C/W
TC=25°C
10
150℃
25℃
1
-55℃
0.1
0.1
0.1
1
10
0.2
100
0.4
0.6
0.8
1
1.2
-VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=10°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
0.01
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.1
1
10
t, Square Wave Pulse Duration (sec)
4
Version: A1611
TSM150P04LCS
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOP-8
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
150P04L
YML
Y = Year Code
M = Month Code
O =Jan P =Feb
S =May T =Jun
W =Sep X =Oct
L = Lot Code (1~9, A~Z)
Q =Mar
U =Jul
Y =Nov
R =Apr
V =Aug
Z =Dec
5
Version: A1611
TSM150P04LCS
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: A1611
