TSM60N600CI C0G
TSM60N600CI C0G
    TAIWANSEMICONDUCTOR(台半)
    TO-220-3
    MOSFET N-CH 600V 8A ITO220AB
TSM60N600CI C0G 数据手册
TSM60N600 Taiwan Semiconductor N-Channel Power MOSFET 600V, 8A, 0.6Ω FEATURES KEY PERFORMANCE PARAMETERS ● Super-Junction technology ● High performance due to small figure-of-merit ● High ruggedness performance ● High commutation performance PARAMETER VALUE UNIT VDS 600 V RDS(on) (max) 0.6 Ω Qg 13 nC APPLICATION ● Power Supply ● Lighting ITO-220 TO-251 (IPAK) TO-252 (DPAK) Notes: MSL 3 (Moisture Sensitivity Level) for TO-252 (D-PAK) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL ITO-220 IPAK/DPAK UNIT Drain-Source Voltage VDS 600 V Gate-Source Voltage VGS ±30 V Continuous Drain Current Pulsed Drain Current TC = 25°C (Note 1) 8 ID TC = 100°C (Note 2) IDM Total Power Dissipation @ TC = 25°C PDTOT A 4.8 24 32 A 83 W Single Pulsed Avalanche Energy (Note 3) EAS 100 mJ Single Pulsed Avalanche Current (Note 3) IAS 2 A TJ, TSTG - 55 to +150 °C Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER SYMBOL ITO-220 IPAK/DPAK UNIT Junction to Case Thermal Resistance RӨJC 3.9 1.5 °C/W Junction to Ambient Thermal Resistance RӨJA 62 °C/W Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. RӨJA shown below for single device operation on FR-4 PCB in still air. Document Number: DS_P0000122 1 Version: C1706 TSM60N600 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER Static CONDITIONS SYMBOL MIN TYP MAX UNIT (Note 4) Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 600 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 2.0 3.0 4.0 V Gate Body Leakage VGS = ±30V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 600V, VGS = 0V IDSS -- -- 1 µA Drain-Source On-State Resistance VGS = 10V, ID = 4A RDS(on) -- 0.49 0.6 Ω Qg -- 13 -- Qgs -- 3 -- Qgd -- 4 -- Dynamic (Note 5) Total Gate Charge VDS = 380V, ID = 8A, Gate-Source Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 100V, VGS = 0V, Ciss -- 743 -- Output Capacitance f = 1.0MHz Coss -- 66 -- Gate Resistance F = 1MHz, open drain Rg -- 3.2 -- td(on) -- 21 -- tr -- 15 -- td(off) -- 40 -- tf -- 9 -- Switching nC pF Ω (Note 6) Turn-On Delay Time VDD = 380V, Turn-On Rise Time RGEN = 25Ω, Turn-Off Delay Time ID = 8A, VGS = 10V, Turn-Off Fall Time Source-Drain Diode ns (Note 4) Forward On Voltage IS = 8A, VGS = 0V VSD -- -- 1.4 V Reverse Recovery Time VR=200V, IS = 4A trr -- 185 -- ns Reverse Recovery Charge dIF/dt = 100A/μs Qrr -- 1.4 -- μC Notes: 1. Current limited by package 2. Pulse width limited by the maximum junction temperature 3. L = 50mH, IAS = 2A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2% 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. o Document Number: DS_P0000122 2 Version: C1706 TSM60N600 Taiwan Semiconductor ORDERING INFORMATION PART NO. PACKAGE PACKING TSM60N600CI C0G TSM60N600CH C5G ITO-220 50pcs / Tube TO-251 (IPAK) 75pcs / Tube TSM60N600CP ROG TO-252 (DPAK) 2,500pcs / 13” Reel Note: 1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC 2. Halogen-free according to IEC 61249-2-21 definition Document Number: DS_P0000122 3 Version: C1706 TSM60N600 Taiwan Semiconductor ELECTRICAL CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics On-Resistance vs. Drain Current Gate-Source Voltage vs. Gate Charge On-Resistance vs. Junction Temperature Document Number: DS_P0000122 Source-Drain Diode Forward Current vs. Voltage 4 Version: C1706 TSM60N600 Taiwan Semiconductor ELECTRICAL CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Capacitance vs. Drain-Source Voltage BVDSS vs. Junction Temperature Maximum Safe Operating Area (DPAK/IPAK) Maximum Safe Operating Area (ITO-220) Document Number: DS_P0000122 5 Version: C1706 TSM60N600 Taiwan Semiconductor ELECTRICAL CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Normalized Effective Transient Thermal Impedance Normalized Thermal Transient Impedance, Junction-to-Case (DPAK/IPAK) 101 100 10-1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single pulse 10-2 10-3 10-4 10-7 10-6 10-5 10-4 10-3 10-2 10-1 100 101 Square Wave Pulse Duration (s) Normalized Effective Transient Thermal Impedance Normalized Thermal Transient Impedance, Junction-to-Case (ITO-220) 10 0 100 10-1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single pulse 10-2 10-3 10-4 10-7 10-6 10-5 10-4 10-3 10-2 10-1 100 101 Square Wave Pulse Duration (s) Document Number: DS_P0000122 6 Version: C1706 TSM60N600 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) ITO-220 MARKING DIAGRAM G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code Document Number: DS_P0000122 7 Version: C1706 TSM60N600 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TO-251 (IPAK) MARKING DIAGRAM Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) Document Number: DS_P0000122 8 Version: C1706 TSM60N600 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TO-252 (DPAK) SUGGESTED PAD LAYOUT MARKING DIAGRAM Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) Document Number: DS_P0000122 9 Version: C1706 TSM60N600 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000122 C1706 10 Version:
TSM60N600CI C0G 价格&库存
很抱歉,暂时无法提供与“TSM60N600CI C0G”相匹配的价格&库存,您可以联系我们找货
TSM60N600CI C0G
    • 140+6.34602
    库存:2000
