TSM320N03CX
Taiwan Semiconductor
N-Channel Power MOSFET
30V, 5.5A, 32mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive losses
● Low gate charge for fast power switching
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VDS
30
V
RDS(on)
VGS = 4.5V
32
(max)
VGS = 2.5V
40
mΩ
Qg
8.9
nC
APPLICATIONS
● Battery Power Management
● ORing FET/Load Switch
SOT-23
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
PARAMETER
VDS
30
V
Gate-Source Voltage
VGS
±12
V
Continuous Drain Current
(Note 1)
TC = 25°C
ID
TA = 25°C
Pulsed Drain Current
Total Power Dissipation
IDM
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
PD
PD
5.5
4
22
1.8
0.4
1
0.2
A
A
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
70
°C/W
Junction to Ambient Thermal Resistance
RӨJA
124
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is
determined by the user’s board design.
1
Version: C1811
TSM320N03CX
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
30
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
0.4
0.75
0.9
V
Gate-Source Leakage Current
VGS = ±12V, VDS = 0V
IGSS
±100
nA
1
100
27
32
32
40
gfs
9.5
Qg
8.9
Qg
5.1
Qgs
1.5
Qgd
2
Ciss
792
Coss
53
Crss
21
Rg
1
td(on)
5.8
tr
32
td(off)
19
tf
28
VSD
1
V
VGS = 0V, VDS = 30V
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 30V
TJ = 125°C
Drain-Source On-State Resistance
VGS = 4.5V, ID = 4A
(Note 2)
VGS = 2.5V, ID = 4A
Forward Transconductance
Dynamic
(Note 2)
RDS(on)
VDS = 5V, ID = 4A
µA
mΩ
S
(Note 3)
VGS = 4.5V, VDS = 15V,
Total Gate Charge
ID = 4A
Total Gate Charge
VGS = 2.5V, VDS = 15V,
Gate-Source Charge
ID = 4A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 15V
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Gate Resistance
Switching
f = 1.0MHz
nC
pF
Ω
(Note 3)
Turn-On Delay Time
Turn-On Rise Time
VGS = 10V, VDS = 15V,
Turn-Off Delay Time
ID = 4A, RG = 2Ω,
Turn-Off Fall Time
ns
Source-Drain Diode
Forward Voltage
(Note 2)
VGS = 0V, IS = 4A
Reverse Recovery Time
IS = 4A ,
trr
8
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
3.3
nC
Notes:
1. Silicon limited current only.
2. Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
3. Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
ORDERING CODE
TSM320N03CX RFG
PACKAGE
PACKING
SOT-23
3,000pcs / 7” Reel
2
Version: C1811
TSM320N03CX
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
10
VGS=4.5V
VGS=4V
VGS=3.5V
VGS=3V
VGS=2.5V
VGS=2V
8
6
ID, Drain Current (A)
10
VGS=1.6V
4
2
VGS=1.4V
8
6
25℃
4
-55℃
2
150℃
VGS=1.3V
2
3
4
5
3
4
5
Gate-Source Voltage vs. Gate Charge
4.5
0.04
VGS, Gate to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
On-Resistance vs. Drain Current
0.035
0.03
VGS=2.5V
0.025
VGS=4.5V
0.02
0.015
0.01
4
6
8
10
VDS=15V
ID=4A
3.6
2.7
1.8
0.9
On-Resistance vs. Junction Temperature
RDS(on), Drain-Source On-Resistance (Ω)
VGS=4.5V
ID=4A
1.6
1.4
1.2
1
0.8
0.6
-75
-50
-25
50
75
6
8
10
On-Resistance vs. Gate-Source Voltage
2
1.8
4
Qg, Gate Charge (nC)
(Normalized)
2
VDS, Drain to Source Voltage (V)
100 125 150
0.06
0.05
0.04
0.03
ID=4A
0.02
0.01
1.5
2
2.5
3
3.5
4
4.5
TJ, Junction Temperature (°C)
3
Version: C1811
TSM320N03CX
BVDSS vs. Junction Temperature
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
C, Capacitance (pF)
1200
1000
CISS
800
600
400
200
COSS
CRSS
ID=1mA
1.1
1
0.9
0.8
5
10
15
30
-75
Maximum Safe Operating Area, Junction-to-Case
-25
50
75
100 125 150
Source-Drain Diode Forward Current vs. Voltage
100
IS, Reverse Drain Current (A)
100
RDS(ON)
-50
10
1
0.1
SINGLE PULSE
RӨJC=70°C/W
TC=25°C
10
-55℃
25℃
150℃
1
0.1
0.01
0.1
1
10
0.2
100
0.4
0.6
0.8
1
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=70°C/W
1
0.1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.01
0.001
0.0001
0.001
0.01
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.1
1
10
t, Square Wave Pulse Duration (sec)
4
Version: C1811
TSM320N03CX
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOT-23
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
32 = Device Code
Y = Year Code
M = Month Code
O =Jan P =Feb
S =May T =Jun
W =Sep X =Oct
L = Lot Code
Q =Mar
U =Jul
Y =Nov
R =Apr
V =Aug
Z =Dec
5
Version: C1811
TSM320N03CX
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C1811
