PSMN4R3-40MLH
N-channel 40 V, 4.3 mΩ, logic level MOSFET in LFPAK33
using NextPower-S3 technology
27 April 2020
Product data sheet
1. General description
95 A, logic level N-channel enhancement mode MOSFET in 175 °C LFPAK33 package using
advanced TrenchMOS Superjunction technology. This product has been designed and qualified for
high efficiency applications at high switching frequencies.
2. Features and benefits
Avalanche rated, 100% tested
NextPower-S3 technology delivers 'superfast switching with soft body-diode recovery'
Low QRR, QG and QGD for high system efficiency, especially at high switching frequencies
Low spiking and ringing for low EMI designs
High reliability clip bonded and solder die attach Mini Power SO8 package; no glue, no wire
bonds, qualified to 175 °C
Exposed leads can be wave soldered, visual solder joint inspection and high quality solder
joints
Low parasitic inductance and resistance
3. Applications
Secondary side synchronous rectification
DC-to-DC converters
Brushless DC motor drive
LED lighting
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
25 °C ≤ Tj ≤ 175 °C
40
V
ID
drain current
VGS = 10 V; Tmb = 25 °C; Fig. 2
95
A
Ptot
total power dissipation
Tmb = 25 °C; Fig. 1
90
W
Tj
junction temperature
-55
175
°C
VGS = 10 V; ID = 25 A; Tj = 25 °C;
Fig. 10
3.4
4.3
mΩ
VGS = 4.5 V; ID = 20 A; Tj = 25 °C;
Fig. 10
4.4
5.5
mΩ
ID = 25 A; VDS = 20 V; VGS = 4.5 V;
Fig. 12; Fig. 13
1
3.3
6.6
nC
9
14
nC
[1]
Static characteristics
RDSon
drain-source on-state
resistance
Dynamic characteristics
QGD
gate-drain charge
QG(tot)
total gate charge
[1]
95A Continuous current has been successfully demonstrated during application tests. Practically the current will be limited by PCB,
thermal design and operating temperature.
PSMN4R3-40MLH
Nexperia
N-channel 40 V, 4.3 mΩ, logic level MOSFET in LFPAK33 using NextPower-S3 technology
5. Pinning information
Table 2. Pinning information
Pin
Symbol
Description
Simplified outline
Graphic symbol
1
S
source
2
S
source
3
S
source
G
4
G
gate
mbb076
mb
D
Mounting base; connected
to drain
D
1
2
3
S
4
LFPAK33 (SOT1210)
6. Ordering information
Table 3. Ordering information
Type number
Package
PSMN4R3-40MLH
Name
Description
Version
LFPAK33
Plastic, single ended surface mounted package (LFPAK33); 8
leads; 0.65 mm pitch
SOT1210
7. Marking
Table 4. Marking codes
Type number
Marking code
PSMN4R3-40MLH
4H3L40
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
25 °C ≤ Tj ≤ 175 °C
40
V
VDSM
peak drain-source
voltage
tp ≤ 20 ns; f ≤ 500 kHz; EDS(AL) ≤ 200 nJ;
pulsed
45
V
VDGR
drain-gate voltage
25 °C ≤ Tj ≤ 175 °C; RGS = 20 kΩ
40
V
VGS
gate-source voltage
-20
V
Ptot
Tmb = 25 °C; Fig. 1
90
W
ID
drain current
95
A
VGS = 10 V; Tmb = 100 °C; Fig. 2
69
A
pulsed; tp ≤ 10 µs; Tmb = 25 °C; Fig. 3
392
A
[1]
IDM
peak drain current
Tstg
storage temperature
-55
175
°C
Tj
-55
175
°C
Tsld(M)
peak soldering
temperature
260
°C
95
A
Source-drain diode
IS
PSMN4R3-40MLH
Product data sheet
source current
Tmb = 25 °C
All information provided in this document is subject to legal disclaimers.
27 April 2020
Nexperia B.V. 2020. All rights reserved
2 / 12
PSMN4R3-40MLH
Nexperia
Symbol
Parameter
Conditions
Min
Max
Unit
ISM
peak source current
392
A
Avalanche ruggedness
EDS(AL)S
IAS
[1]
[2]
ID = 32.6 A; Vsup ≤ 40 V; RGS = 50 Ω;
non-repetitive drainsource avalanche energy VGS = 5 V; Tj(init) = 25 °C; unclamped;
tp = 117 µs
[2]
99
mJ
ID = 25 A; Vsup ≤ 40 V; RGS = 50 Ω;
tp = 204 µs
[2]
132
mJ
[2]
70
A
non-repetitive avalanche Vsup ≤ 40 V; VGS = 5 V; Tj(init) = 25 °C;
current
RGS = 50 Ω
Protected by 100% test
03aa16
120
aaa-029734
100
ID
(A)
Pder
(1)
80
80
60
40
40
Fig. 1.
100
150
Tmb (°C)
Fig. 2.
Product data sheet
25
50
75
100
125
150 175
Tmb (°C)
200
VGS ≥ 10 V
(1) 95A continuous current has been successfully
the current will be limited by PCB, thermal design
Normalized total power dissipation as a
function of mounting base temperature
PSMN4R3-40MLH
Continuous drain current as a function of
27 April 2020
3 / 12
PSMN4R3-40MLH
Nexperia
ID
(A)
aaa-031181
103
Limit RDSon = VDS / ID
102
tp = 10 µs
DC
100 µs
10
1 ms
1
10 ms
100 ms
10-1
10-1
1
10
102
VDS (V)
Tmb = 25 °C; IDM is a single pulse
Fig. 3.
Safe operating area; continuous and peak drain currents as a function of drain-source voltage
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Min
Typ
Max
Unit
Rth(j-mb)
thermal resistance from Fig. 4
junction to mounting
base
Conditions
1.48
1.67
K/W
Rth(j-a)
thermal resistance from Fig. 5
junction to ambient
Fig. 6
50
K/W
130
K/W
aaa-029737
10
Zth(j-mb)
(K/W)
1
δ = 0.5
0.2
0.1
P
10-1 0.05
0.02
10-2
10-6
Fig. 4.
single shot
10-5
δ=
10-3
10-2
T
t
tp
10-4
tp
T
10-1
tp (s)
1
Transient thermal impedance from junction to mounting base as a function of pulse duration
PSMN4R3-40MLH
Product data sheet
27 April 2020
4 / 12
PSMN4R3-40MLH
Nexperia
aaa-028025
aaa-028026
Copper area 25.4 mm x 25.4 mm; 70 µm thick on
FR4 board
Fig. 5.
PCB layout for thermal resistance from junction
to ambient
70 µm thick copper on FR4 board
Fig. 6.
PCB layout with minimum footprint for thermal
resistance from junction to ambient
10. Characteristics
Table 7. Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
drain-source
breakdown voltage
ID = 250 µA; VGS = 0 V; Tj = 25 °C
40
V
ID = 250 µA; VGS = 0 V; Tj = -55 °C
36
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS=VGS; Tj = 25 °C
1.45
1.77
2.15
V
ΔVGS(th)/ΔT
voltage variation with
temperature
25 °C ≤ Tj ≤ 150 °C
-4.2
mV/K
IDSS
drain leakage current
VDS = 32 V; VGS = 0 V; Tj = 25 °C
0.01
1
µA
VDS = 32 V; VGS = 0 V; Tj = 125 °C
1.2
µA
VGS = 16 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -16 V; VDS = 0 V; Tj = 25 °C
2
100
nA
Fig. 10
3.4
4.3
mΩ
VGS = 10 V; ID = 25 A; Tj = 175 °C;
Fig. 11
9.4
mΩ
Fig. 10
4.4
5.5
mΩ
VGS = 4.5 V; ID = 20 A; Tj = 175 °C;
Fig. 11
12
mΩ
f = 1 MHz; Tj = 25 °C
0.3
0.8
2
Ω
Fig. 12; Fig. 13
9
14
nC
ID = 25 A; VDS = 20 V; VGS = 10 V;
Fig. 12; Fig. 13
43
nC
ID = 0 A; VDS = 0 V; VGS = 10 V
16.6
nC
V(BR)DSS
IGSS
RDSon
RG
gate leakage current
resistance
gate resistance
QG(tot)
total gate charge
PSMN4R3-40MLH
Product data sheet
27 April 2020
5 / 12
PSMN4R3-40MLH
Nexperia
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
QGS
gate-source charge
3.4
5.6
8.4
nC
QGS(th)
pre-threshold gatesource charge
Fig. 12; Fig. 13
2
3.3
4.9
nC
QGS(th-pl)
post-threshold gatesource charge
1.4
2.3
3.5
nC
QGD
gate-drain charge
1
3.3
6.6
nC
VGS(pl)
gate-source plateau
voltage
ID = 25 A; VDS = 20 V; Fig. 12; Fig. 13
2.8
V
Ciss
input capacitance
1395
2148
3007
pF
Coss
output capacitance
VDS = 20 V; VGS = 0 V; f = 1 MHz;
Tj = 25 °C; Fig. 14
354
546
764
pF
Crss
reverse transfer
capacitance
24
81
178
pF
td(on)
turn-on delay time
14
ns
tr
rise time
16
ns
td(off)
turn-off delay time
15
ns
tf
fall time
Qoss
output charge
VDS = 20 V; RL = 0.8 Ω; VGS = 4.5 V;
RG(ext) = 5 Ω
9.3
ns
VGS = 0 V; VDS = 20 V; f = 1 MHz;
Tj = 25 °C
17
nC
Source-drain diode
VSD
source-drain voltage
IS = 25 A; VGS = 0 V; Tj = 25 °C; Fig. 15
0.83
1
V
trr
reverse recovery time
26
ns
recovered charge
IS = 25 A; dIS/dt = -100 A/µs; VGS = 0 V;
VDS = 20 V; Fig. 16
[1]
Qr
nC
ta
reverse recovery rise
time
15
ns
tb
reverse recovery fall
time
10
ns
[1]
includes capacitive recovery
aaa-029858
120
ID
(A)
3.5 V
4.5 V
90
aaa-029859
16
RDSon
(mΩ)
12
10 V
VGS = 3 V
60
8
2.8 V
30
4
2.6 V
2.4 V
Fig. 7.
2
3
VDS (V)
4
6
8
10
12
14
VGS (V)
16
Tj = 25 °C
Tj = 25 °C; ID = 25 A
Output characteristics; drain current as a
Fig. 8.
function of drain-source voltage; typical values
Drain-source on-state resistance as a function
of gate-source voltage; typical values
PSMN4R3-40MLH
Product data sheet
27 April 2020
6 / 12
PSMN4R3-40MLH
Nexperia
aaa-031183
120
ID
(A)
aaa-029861
16
RDSon
(mΩ)
90
2.8 V
3V
12
3.5 V
60
8
4.5 V
30
4
175°C
2
25°C
3
VGS = 10 V
4
VGS (V)
VDS = 8 V
Fig. 9.
a
60
80
100
ID (A)
120
Tj = 25 °C
Transfer characteristics; drain current as a
function of gate-source voltage; typical values
Fig. 10. Drain-source on-state resistance as a function
of drain current; typical values
aaa-030384
2.4
VGS
(V)
2
aaa-031182
10
8
1.6
6
32 V
1.2
20 V
4
0.8
VDS = 8 V
2
0.4
-30
60
90
120 150
Tj (°C)
10
15
30
QG (nC)
35
Fig. 11. Normalized drain-source on-state resistance
factor as a function of junction temperature
PSMN4R3-40MLH
Product data sheet
Fig. 12. Gate-source voltage as a function of gate
charge; typical values
27 April 2020
7 / 12
PSMN4R3-40MLH
Nexperia
aaa-029863
104
C
(pF)
VDS
ID
Ciss
103
VGS(pl)
Coss
VGS(th)
VGS
QGS2
QGS1
QGS
102
QGD
QG(tot)
Crss
003aaa508
10
10-1
Fig. 13. Gate charge waveform definitions
1
10
VDS (V)
102
Fig. 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
IS
(A)
003aal160
aaa-031184
102
ID
(A)
trr
ta
tb
0.25 IRM
175°C
1
0.4
0.6
Tj = 25°C
0.8
1
VSD (V)
IRM
t (s)
1.2
VGS = 0 V
Fig. 16. Reverse recovery timing definition
Fig. 15. Source-drain (diode forward) current as a
function of source-drain (diode forward)
PSMN4R3-40MLH
Product data sheet
27 April 2020
8 / 12
PSMN4R3-40MLH
Nexperia
11. Package outline
Plastic single ended surface mounted package (LFPAK33); 8 leads
E
A
e1
A
c1
b1
L1
SOT1210
D2
mounting
base
D1
(D)
H
E1
L
1
4
b
e
w
A
A1
C
X
c
Lp
y C
detail X
5 mm
scale
Dimensions
Unit(1)
mm
A
A1
b(1)
max 0.90 0.10 0.35
nom
min 0.80 0.00 0.25
b1(1)
c
c1
2.4
0.20 0.30
2.2
0.10 0.20
D ref
2.60
D1
2.35
1.90
D2
0.50
E(1)
E1
3.40 2.45
3.20 2.00
e
e1
0.65 0.65
H
L
L1
Lp
3.40
0.65 0.25 0.50
3.20
0.45 0.13 0.30
w
0.20 0.10
Note
1. Plastic or metal protrusions of 0.15 mm per side are not included.
Outline
version
sot1210_po
References
IEC
JEDEC
y
JEITA
European
projection
Issue date
14-04-25
16-08-09
SOT1210
Fig. 17. Package outline LFPAK33 (SOT1210)
PSMN4R3-40MLH
Product data sheet
27 April 2020
9 / 12
PSMN4R3-40MLH
Nexperia
12. Soldering
Footprint information for reflow soldering of LFPAK33 package
SOT1210
2.35
2.25
0.635 0.617
0.05 (all around)
0.75 0.62
1.05
1.91
2.47
0.51
3.9
0.51
0.6
0.83
0.4 (x8)
solder land
occupied area
solder paste
aperture
0.65 (x6)
0.3 (x8)
0.25 (x6)
Notes : 1. Dimensions in mm
solder resist
sot1210_fr
Fig. 18. Reflow soldering footprint for LFPAK33 (SOT1210)
PSMN4R3-40MLH
Product data sheet
27 April 2020
10 / 12
PSMN4R3-40MLH
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
13. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
PSMN4R3-40MLH
Product data sheet
27 April 2020
11 / 12
PSMN4R3-40MLH
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................2
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 2
9. Thermal characteristics............................................... 4
10. Characteristics............................................................ 5
11. Package outline.......................................................... 9
12. Soldering................................................................... 10
13. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 27 April 2020
PSMN4R3-40MLH
Product data sheet
27 April 2020
12 / 12
