TSM3N90CZ C0G
TSM3N90CZ C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    1个N沟道 耐压:900V 电流:2.5A
TSM3N90CZ C0G 数据手册
TSM3N90 900V N-Channel Power MOSFET TO-220 ITO-220 PRODUCT SUMMARY Pin Definition: 1. Gate 2. Drain 3. Source VDS (V) RDS(on)(Ω) ID (A) 900 5.1 @ VGS =10V 1.25 General Description TO-251 (IPAK) The TSM3N90 TO-252 (DPAK) N-Channel Power MOSFET is produced by new advance planar process. This en de d advanced technology has been especially tailored to minimize on-state resistance, provide superior switching performance, and withstand high energy pulse in the avalanche and commutation mode. Block Diagram Features Low RDS(ON) 4.3Ω (Typ.) Low gate charge typical @ 17nC (Typ.) Low Crss typical @ 8.7pF (Typ.) mm ● ● ● Ordering Information Part No. Package Packing TO-251 TSM3N90CP ROG TO-252 2.5Kpcs / 13” Reel TO-220 50pcs / Tube TSM3N90CZ C0G 75pcs / Tube eco TSM3N90CH C5G TSM3N90CI C0G ITO-220 Note: “G” denotes for Halogen Free N-Channel MOSFET 50pcs / Tube Parameter tR Absolute Maximum Rating (Ta = 25oC unless otherwise noted) No Drain-Source Voltage Gate-Source Voltage Continuous Drain Current Tc = 25ºC Tc = 100ºC Symbol Limit IPAK/DPAK ITO-220 TO-220 Unit VDS 900 V VGS ±30 V 2.5 A 1.6 A ID Pulsed Drain Current * IDM 10 A Single Pulse Avalanche Energy (Note 2) EAS 10 mJ Avalanche Current (Repetitive) (Note 1) IAR 2.5 A Repetitive Avalanche Energy (Note 1) EAR 9.4 mJ dv/dt 4.5 V/ns Peak Diode Recovery dv/dt (Note 3) o Total Power Dissipation @ TC = 25 C Operating Junction Temperature Storage Temperature Range PTOT TJ TSTG 94 32 150 -55 to +150 94 W ºC o C Note: Limited by maximum junction temperature Document Number: DS_P0000085 1 Version: D15 TSM3N90 900V N-Channel Power MOSFET Thermal Performance Symbol IPAK/DPAK ITO-220 TO-220 Thermal Resistance - Junction to Case RӨJC 1.33 1.33 3.9 Thermal Resistance - Junction to Ambient RӨJA 110 Parameter Unit o C/W 62.5 Electrical Specifications (Ta = 25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit 900 -- -- V -- 4.3 VGS = 0V, ID = 250uA BVDSS Drain-Source On-State Resistance VGS = 10V, ID = 1.25A RDS(ON) 5.1 Ω Gate Threshold Voltage VDS = VGS, ID = 250uA Zero Gate Voltage Drain Current VDS = 900V, VGS = 0V Gate Body Leakage VGS = ±30V, VDS = 0V Forward Transfer Conductance VDS = 30V, ID = 1.25A 2.0 -- 4.0 V IDSS -- -- 10 uA IGSS -- -- ±100 nA gfs -- 3 -- S Qg -- 17 -- Qgs -- 2.4 -- Qgd -- 6.6 -- Ciss -- 748 -- Coss -- 55 -- Crss -- 8.7 -- td(on) -- 16 -- VGS = 10V, ID = 2.5A, tr -- 25 -- VDD = 450V, RG = 25Ω td(off) -- 63 -- tf -- 31 -- IS -- -- 2.5 en VGS(TH) VDS = 720V, ID = 2.5A, Gate-Source Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 25V, VGS = 0V, Output Capacitance Turn-On Delay Time Turn-On Rise Time tR Turn-Off Delay Time f = 1.0MHz e co Reverse Transfer Capacitance Switching mm Dynamic Total Gate Charge d Drain-Source Breakdown Voltage de Static Turn-Off Fall Time nC pF nS Source-Drain Diode Ratings and Characteristic Source Current Integral reverse diode in A ISM -- -- 10 A Diode Forward Voltage IS = 2.5A, VGS = 0V VSD -- -- 1.5 V Reverse Recovery Time VGS = 0V, IS =2.5A, tfr -- 355 -- nS dIF/dt = 100A/us Reverse Recovery Charge Qfr -1.8 -Note 1: Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature Note 2: Max Rating EAS Test Condition: VDD = 50V, IAS=2A, L=5mH, RG =25Ω, Starting TJ=25ºC Guaranteed 100% EAS Test Condition: VDD = 50V, IAS=2A, L=1mH, RG =25Ω, Starting TJ=25ºC Note 3: ISD≤2.5A, di/dt≤200A/uS, VDD≤BVDSS, Starting TJ=25ºC Note 4: Pulse test: pulse width ≤300uS, duty cycle ≤2% Note 5: Essentially Independent of Operating Temperature uC No Source Current (Pulse) the MOSFET Document Number: DS_P0000085 2 Version: D15 TSM3N90 900V N-Channel Power MOSFET tR e co mm Resistive Switching Test Circuit & Waveform en de d Gate Charge Test Circuit & Waveform No EAS Test Circuit & Waveform Document Number: DS_P0000085 3 Version: D15 TSM3N90 900V N-Channel Power MOSFET No tR e co mm en de d Diode Reverse Recovery Time Test Circuit & Waveform Document Number: DS_P0000085 4 Version: D15 TSM3N90 900V N-Channel Power MOSFET Electrical Characteristics Curve (Tc = 25oC, unless otherwise noted) Transfer Characteristics en de d Output Characteristics Gate Charge tR e co mm On-Resistance vs. Drain Current Source-Drain Diode Forward Voltage No On-Resistance vs. Junction Temperature Document Number: DS_P0000085 5 Version: D15 TSM3N90 900V N-Channel Power MOSFET Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) BVDSS vs. Junction Temperature en de d Drain Current vs. Case Temperature Capacitance vs. Drain-Source Voltage tR e co mm Maximum Safe Operating Area No Maximum Safe Operating Area (ITO-220) Document Number: DS_P0000085 6 Version: D15 TSM3N90 900V N-Channel Power MOSFET Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) en de d Normalized Thermal Transient Impedance, Junction-to-Ambient No tR e co mm Normalized Thermal Transient Impedance, Junction-to-Ambient (ITO-220) Document Number: DS_P0000085 7 Version: D15 TSM3N90 900V N-Channel Power MOSFET tR Marking Diagram Unit: Millimeters e co mm en de d TO-220 Mechanical Drawing No Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr V =Aug S =May T =Jun U =Jul W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000085 8 Version: D15 TSM3N90 900V N-Channel Power MOSFET Unit: Millimeters tR e co mm en de d ITO-220 Mechanical Drawing Marking Diagram = Halogen Free = Year Code = Week Code by Calendar Year = Factory Code No G Y WW F Document Number: DS_P0000085 9 Version: D15 TSM3N90 900V N-Channel Power MOSFET tR Marking Diagram Unit: Millimeters e co mm en de d TO-251 Mechanical Drawing No Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr V =Aug S =May T =Jun U =Jul W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000085 10 Version: D15 TSM3N90 900V N-Channel Power MOSFET Unit: Millimeters e co Marking Diagram mm en de d TO-252 Mechanical Drawing No tR Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr V =Aug S =May T =Jun U =Jul W =Sep X =Oct Y =Nov Z =Dec L = Lot Code Document Number: DS_P0000085 11 Version: D15 TSM3N90 No tR e co mm en de d 900V N-Channel Power MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000085 12 Version: D15
TSM3N90CZ C0G 价格&库存
很抱歉,暂时无法提供与“TSM3N90CZ C0G”相匹配的价格&库存,您可以联系我们找货
TSM3N90CZ C0G
  • 1+18.52997
  • 5+16.68535
  • 25+14.75690
  • 100+13.27162
TSM3N90CZ C0G
  • 1+19.976851+2.58770
  • 5+17.970445+2.32780
  • 25+15.8768025+2.05660
  • 100+14.30656100+1.85320
