TSM10N80CI C0G
TSM10N80CI C0G
    TAIWANSEMICONDUCTOR(台半)
    TO-220-3
    MOSFET N-CH 800V 9.5A ITO220AB
TSM10N80CI C0G 数据手册
TSM10N80 Taiwan Semiconductor N-Channel Power MOSFET 800V, 9.5A, 1.05Ω FEATURES KEY PERFORMANCE PARAMETERS Low RDS(ON) 1.05Ω (Max.) Low gate charge typical @ 53nC (Typ.) Improve dV/dt capability Pb-free plating Compliant to RoHS Directive 2011/65/EU and in accordance to WEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 definition APPLICATION ● Power Supply ● Lighting VALUE UNIT VDS 800 V RDS(on) (max) 1.05 Ω Qg 53 nC mm ITO-220 eco TO-220 PARAMETER en de d ● ● ● ● ● ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) SYMBOL TO-220 ITO-220 UNIT Drain-Source Voltage VDS 800 V Gate-Source Voltage VGS ±30 V tR PARAMETER No Continuous Drain Current (Note 1) TC = 25°C TC = 100°C Pulsed Drain Current (Note 2) 9.5 ID IDM Total Power Dissipation @ TC = 25°C PDTOT A 5.7 38 290 A 48 W Single Pulsed Avalanche Energy EAS 267 mJ Single Pulsed Avalanche Current IAS 10 A TJ, TSTG - 55 to +150 °C SYMBOL TO-220 ITO-220 UNIT Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER Junction to Case Thermal Resistance RӨJC Junction to Ambient Thermal Resistance RӨJA 0.43 2.6 °C/W 62.5 °C/W Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. RӨJA shown below for single device operation on FR-4 PCB with minimum recommended footprint in still air. Document Number: DS_P0000022 1 Version: D15 TSM10N80 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT VGS = 0V, ID = 250µA BVDSS 800 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 2.0 -- 4.0 V Gate Body Leakage VGS = ±30, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 800V, VGS = 0V IDSS -- -- 10 µA Drain-Source On-State Resistance VGS = 10V, ID = 4.75A RDS(on) -- 0.9 1.05 Ω Forward Transconductance VDS = 30V, ID = 4.75A gfs -- 6.3 -- S VDS = 640V, ID =9.5A, VGS = 10V Total Gate Charge Gate-Source Charge Input Capacitance Output Capacitance Reverse Transfer Capacitance Switching VDS = 25V, VGS = 0V, f = 1.0MHz (Note 5) Turn-On Delay Time Turn-Off Fall Time VDS = 400V, VGS = 10V RG = 25Ω, ID = 9.5A e co Turn-On Rise Time Turn-Off Delay Time -- 53 -- Qgs -- 10 -- Qgd -- 23 -- Ciss -- 2336 -- Coss -- 214 -- en Gate-Drain Charge Qg mm Dynamic (Note 4) d Drain-Source Breakdown Voltage de Static (Note 3) Crss nC pF 29 td(on) -- 63 -- tr -- 62 -- td(off) -- 256 -- tf -- 72 -- VSD -- -- 1.5 V trr -- 450 -- ns Qrr -- 5.3 -- µC ns Source-Drain Diode (Note 3) Reverse Recovery Time Reverse Recovery Charge Notes: IS = 9.5A, VGS = 0V tR Forward On Voltage IS = 9.5A, VGS = 0V dIF/dt = 100A/μs Current limited by package. 2. Pulse width limited by the maximum junction temperature. 3. L = 5mH, IAS = 10A, VDD = 50V, RG = 25Ω, Starting TJ = 25oC No 1. 100% Eas Test Condition: L = 5mH, IAS = 5A, VDD = 50V, RG = 25Ω, Starting TJ = 25°C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2%. 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. Document Number: DS_P0000022 2 Version: D15 TSM10N80 Taiwan Semiconductor ORDERING INFORMATION PACKAGE PACKING TSM10N80CZ C0G TO-220 50pcs / Tube TSM10N80CI C0G ITO-220 50pcs / Tube No tR e co mm en de d PART NO. Document Number: DS_P0000022 3 Version: D15 TSM10N80 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Transfer Characteristics en de d Output Characteristics Gate Charge tR e co mm On-Resistance vs. Drain Current On-Resistance vs. Junction Temperature No Source-Drain Diode Forward Voltage Document Number: DS_P0000022 4 Version: D15 TSM10N80 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) BVDSS vs. Junction Temperature en de d Drain Current vs. Case Temperature Capacitance vs. Drain-Source Voltage No tR e co mm Maximum Safe Operating Area Maximum Safe Operating Area (ITO-220) Document Number: DS_P0000022 5 Version: D15 TSM10N80 Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) en de d Normalized Thermal Transient Impedance, Junction-to-Ambient No tR e co mm Normalized Thermal Transient Impedance, Junction-to-Ambient(ITO-220) Document Number: DS_P0000022 6 Version: D15 TSM10N80 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) en de d TO-220 MARKING DIAGRAM mm = Halogen Free Product = Year Code = Week Code (01~52) = Factory Code No tR e co G Y WW F Document Number: DS_P0000022 7 Version: D15 TSM10N80 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) en de d ITO-220 MARKING DIAGRAM mm = Halogen Free Product = Year Code = Week Code (01~52) = Factory Code No tR e co G Y WW F Document Number: DS_P0000022 8 Version: D15 TSM10N80 No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000022 9 Version: D15
TSM10N80CI C0G 价格&库存
很抱歉,暂时无法提供与“TSM10N80CI C0G”相匹配的价格&库存,您可以联系我们找货
