1N5236D
1N5236D
    ROCHESTER(罗切斯特)
    DO-35(DO-204AH)
    DIODE ZENER 7.5V 500MW DO35
1N5236D 数据手册
MOTOROLA SEMICONDUCTOR TECHNICAL DATA 1N5221B SERIES 500 mW DO-35 Glass Zener Voltage Regulator Diodes 500 mW DO-35 GLASS GENERAL DATA APPLICABLE TO ALL SERIES IN THIS GROUP 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes GLASS ZENER DIODES 500 MILLIWATTS 1.8–200 VOLTS Specification Features: • Complete Voltage Range — 1.8 to 200 Volts • DO-204AH Package — Smaller than Conventional DO-204AA Package • Double Slug Type Construction • Metallurgically Bonded Construction Mechanical Characteristics: CASE 299 DO-204AH GLASS CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES: 230°C, 1/16″ from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily solderable leads POLARITY: Cathode indicated by color band. When operated in zener mode, cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea MAXIMUM RATINGS (Motorola Devices)* Rating Symbol DC Power Dissipation and TL ≤ 75°C Lead Length = 3/8″ Derate above TL = 75°C Value Unit 500 4 mW mW/°C – 65 to +200 °C PD Operating and Storage Temperature Range TJ, Tstg PD , MAXIMUM POWER DISSIPATION (WATTS) * Some part number series have lower JEDEC registered ratings. 0.7 HEAT SINKS 0.6 0.5 0.4 3/8” 3/8” 0.3 0.2 0.1 0 0 20 40 60 80 100 120 140 160 180 200 TL, LEAD TEMPERATURE (°C) Figure 1. Steady State Power Derating Motorola TVS/Zener Device Data 500 mW DO-35 Glass Data Sheet 6-1 GENERAL DATA — 500 mW DO-35 GLASS ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted. Based on dc measurements at thermal equilibrium; lead length = 3/8″; thermal resistance of heat sink = 30°C/W) VF = 1.1 Max @ IF = 200 mA for all types. JEDEC Type No. (Note 1) Nominal Zener Voltage VZ @ IZT Volts (Note 3) Test Current IZT mA ZZT @ IZT Ohms ZZK @ IZK = 0.25 mA Ohms IR µA VR Volts Max Zener Voltage Temperature Coeff. Coeff θVZ (%/°C) (Note 2) 1N5221B 1N5222B 1N5223B 1N5224B 1N5225B 2.4 2.5 2.7 2.8 3 20 20 20 20 20 30 30 30 30 29 1200 1250 1300 1400 1600 100 100 75 75 50 1 1 1 1 1 –0.085 –0.085 –0.08 –0.08 –0.075 1N5226B 1N5227B 1N5228B 1N5229B 1N5230B 3.3 3.6 3.9 4.3 4.7 20 20 20 20 20 28 24 23 22 19 1600 1700 1900 2000 1900 25 15 10 5 5 1 1 1 1 2 –0.07 –0.065 –0.06 ± 0.055 ± 0.03 1N5231B 1N5232B 1N5233B 1N5234B 1N5235B 5.1 5.6 6 6.2 6.8 20 20 20 20 20 17 11 7 7 5 1600 1600 1600 1000 750 5 5 5 5 3 2 3 3.5 4 5 ± 0.03 +0.038 +0.038 +0.045 +0.05 1N5236B 1N5237B 1N5238B 1N5239B 1N5240B 7.5 8.2 8.7 9.1 10 20 20 20 20 20 6 8 8 10 17 500 500 600 600 600 3 3 3 3 3 6 6.5 6.5 7 8 +0.058 +0.062 +0.065 +0.068 +0.075 1N5241B 1N5242B 1N5243B 1N5244B 1N5245B 11 12 13 14 15 20 20 9.5 9 8.5 22 30 13 15 16 600 600 600 600 600 2 1 0.5 0.1 0.1 8.4 9.1 9.9 10 11 +0.076 +0.077 +0.079 +0.082 +0.082 1N5246B 1N5247B 1N5248B 1N5249B 1N5250B 16 17 18 19 20 7.8 7.4 7 6.6 6.2 17 19 21 23 25 600 600 600 600 600 0.1 0.1 0.1 0.1 0.1 12 13 14 14 15 +0.083 +0.084 +0.085 +0.086 +0.086 1N5251B 1N5252B 1N5253B 1N5254B 1N5255B 22 24 25 27 28 5.6 5.2 5 4.6 4.5 29 33 35 41 44 600 600 600 600 600 0.1 0.1 0.1 0.1 0.1 17 18 19 21 21 +0.087 +0.088 +0.089 +0.09 +0.091 1N5256B 1N5257B 1N5258B 1N5259B 1N5260B 30 33 36 39 43 4.2 3.8 3.4 3.2 3 49 58 70 80 93 600 700 700 800 900 0.1 0.1 0.1 0.1 0.1 23 25 27 30 33 +0.091 +0.092 +0.093 +0.094 +0.095 1N5261B 1N5262B 1N5263B 1N5264B 1N5265B 47 51 56 60 62 2.7 2.5 2.2 2.1 2 105 125 150 170 185 1000 1100 1300 1400 1400 0.1 0.1 0.1 0.1 0.1 36 39 43 46 47 +0.095 +0.096 +0.096 +0.097 +0.097 Max Zener Impedance (Note 4) Max Reverse Leakage Current (continued) 500 mW DO-35 Glass Data Sheet 6-2 Motorola TVS/Zener Device Data GENERAL DATA — 500 mW DO-35 GLASS ELECTRICAL CHARACTERISTICS — continued (TA = 25°C unless otherwise noted. Based on dc measurements at thermal equilibrium; lead length = 3/8″; thermal resistance of heat sink = 30°C/W) VF = 1.1 Max @ IF = 200 mA for all types. JEDEC Type No. (Note 1) Nominal Zener Voltage VZ @ IZT Volts (Note 3) Test Current IZT mA ZZT @ IZT Ohms ZZK @ IZK = 0.25 mA Ohms IR µA VR Volts Max Zener Voltage Temperature Coeff. Coeff θVZ (%/°C) (Note 2) 1N5266B 1N5267B 1N5268B 1N5270B 68 75 82 91 1.8 1.7 1.5 1.4 230 270 330 400 1600 1700 2000 2300 0.1 0.1 0.1 0.1 52 56 62 69 +0.097 +0.098 +0.098 +0.099 1N5271B 1N5272B 1N5273B 1N5274B 1N5275B 100 110 120 130 140 1.3 1.1 1 0.95 0.9 500 750 900 1100 1300 2600 3000 4000 4500 4500 0.1 0.1 0.1 0.1 0.1 76 84 91 99 106 +0.11 +0.11 +0.11 +0.11 +0.11 1N5276B 1N5278B 1N5279B 1N5280B 1N5281B 150 170 180 190 200 0.85 0.74 0.68 0.66 0.65 1500 1900 2200 2400 2500 5000 5500 6000 6500 7000 0.1 0.1 0.1 0.1 0.1 114 129 137 144 152 +0.11 +0.11 +0.11 +0.11 +0.11 Max Zener Impedance (Note 4) NOTE 1. TOLERANCE The JEDEC type numbers shown indicate a tolerance of ±5%. For tighter tolerance devices use suffixes “C” for ±2% and “D” for ±1%. NOTE 2. TEMPERATURE COEFFICIENT (θVZ) Test conditions for temperature coefficient are as follows: a. IZT = 7.5 mA, T1 = 25°C, a. T2 = 125°C (1N5221B through 1N5242B). b. IZT = Rated IZT, T1 = 25°C, a. T2 = 125°C (1N5243B through 1N5281B). Device to be temperature stabilized with current applied prior to reading breakdown voltage at the specified ambient temperature. Motorola TVS/Zener Device Data Max Reverse Leakage Current NOTE 3. ZENER VOLTAGE (VZ) MEASUREMENT Nominal zener voltage is measured with the device junction in thermal equilibrium at the lead temperature of 30°C ±1°C and 3/8″ lead length. NOTE 4. ZENER IMPEDANCE (ZZ) DERIVATION ZZT and ZZK are measured by dividing the ac voltage drop across the device by the ac current applied. The specified limits are for IZ(ac) = 0.1 IZ(dc) with the ac frequency = 60 Hz. For more information on special selections contact your nearest Motorola representative. 500 mW DO-35 Glass Data Sheet 6-3 APPLICATION NOTE — ZENER VOLTAGE Since the actual voltage available from a given zener diode is temperature dependent, it is necessary to determine junction temperature under any set of operating conditions in order to calculate its value. The following procedure is recommended: Lead Temperature, TL, should be determined from: TL = θLAPD + TA. θLA is the lead-to-ambient thermal resistance (°C/W) and PD is the power dissipation. The value for θLA will vary and depends on the device mounting method. θLA is generally 30 to 40°C/W for the various clips and tie points in common use and for printed circuit board wiring. The temperature of the lead can also be measured using a thermocouple placed on the lead as close as possible to the tie point. The thermal mass connected to the tie point is normally large enough so that it will not significantly respond to heat surges generated in the diode as a result of pulsed operation once steady-state conditions are achieved. Using the measured value of TL, the junction temperature may be determined by: θ JL , JUNCTION-TO-LEAD THERMAL RESISTANCE (°C/W) GENERAL DATA — 500 mW DO-35 GLASS θVZ, the zener voltage temperature coefficient, is found from Figures 4 and 5. Under high power-pulse operation, the zener voltage will vary with time and may also be affected significantly by the zener resistance. For best regulation, keep current excursions as low as possible. Surge limitations are given in Figure 7. They are lower than would be expected by considering only junction temperature, as current crowding effects cause temperatures to be extremely high in small spots, resulting in device degradation should the limits of Figure 7 be exceeded. L L 300 2.4–60 V 200 62–200 V 100 0 0 0.2 0.4 0.6 0.8 1 L, LEAD LENGTH TO HEAT SINK (INCH) 1000 7000 5000 TYPICAL LEAKAGE CURRENT AT 80% OF NOMINAL BREAKDOWN VOLTAGE 2000 1000 700 500 200 I R , LEAKAGE CURRENT ( µ A) ∆V = θVZTJ. 400 Figure 2. Typical Thermal Resistance TJ = TL + ∆TJL. ∆TJL is the increase in junction temperature above the lead temperature and may be found from Figure 2 for dc power: ∆TJL = θJLPD. For worst-case design, using expected limits of IZ, limits of PD and the extremes of TJ(∆TJ) may be estimated. Changes in voltage, VZ, can then be found from: 500 100 70 50 20 10 7 5 2 1 0.7 0.5 +125°C 0.2 0.1 0.07 0.05 0.02 0.01 0.007 0.005 +25°C 0.002 0.001 3 4 5 6 7 8 9 10 11 12 13 14 15 VZ, NOMINAL ZENER VOLTAGE (VOLTS) Figure 3. Typical Leakage Current 500 mW DO-35 Glass Data Sheet 6-4 Motorola TVS/Zener Device Data GENERAL DATA — 500 mW DO-35 GLASS TEMPERATURE COEFFICIENTS θVZ , TEMPERATURE COEFFICIENT (mV/ °C) θVZ , TEMPERATURE COEFFICIENT (mV/ °C) (–55°C to +150°C temperature range; 90% of the units are in the ranges indicated.) +12 +10 +8 +6 +4 +2 RANGE VZ @ IZT (NOTE 2) 0 –2 –4 2 3 4 5 6 7 8 9 VZ, ZENER VOLTAGE (VOLTS) 10 11 12 100 70 50 30 20 3 2 1 10 200 180 160 140 VZ @ IZT (NOTE 2) 100 120 130 140 150 160 170 180 190 20 +2 20 mA 0 0.01 mA 1 mA NOTE: BELOW 3 VOLTS AND ABOVE 8 VOLTS NOTE: CHANGES IN ZENER CURRENT DO NOT NOTE: AFFECT TEMPERATURE COEFFICIENTS –2 –4 200 3 4 100 70 50 C, CAPACITANCE (pF) C, CAPACITANCE (pF) 200 1 V BIAS 20 10 50% OF VZ BIAS 5 6 7 8 Figure 5. Effect of Zener Current 0 V BIAS 50 5 VZ, ZENER VOLTAGE (VOLTS) TA = 25°C 100 100 VZ @ IZ TA = 25°C +4 Figure 4c. Range for Units 120 to 200 Volts 500 70 +6 VZ, ZENER VOLTAGE (VOLTS) 1000 30 50 VZ, ZENER VOLTAGE (VOLTS) Figure 4b. Range for Units 12 to 100 Volts θVZ , TEMPERATURE COEFFICIENT (mV/ °C) θVZ , TEMPERATURE COEFFICIENT (mV/ °C) Figure 4a. Range for Units to 12 Volts 120 VZ @ IZ (NOTE 2) RANGE 10 7 5 TA = 25°C 0 BIAS 30 20 1 VOLT BIAS 10 7 5 50% OF VZ BIAS 3 2 2 1 1 1 2 5 10 20 50 100 VZ, ZENER VOLTAGE (VOLTS) Figure 6a. Typical Capacitance 2.4–100 Volts Motorola TVS/Zener Device Data 120 140 160 180 190 200 220 VZ, ZENER VOLTAGE (VOLTS) Figure 6b. Typical Capacitance 120–200 Volts 500 mW DO-35 Glass Data Sheet 6-5 Ppk , PEAK SURGE POWER (WATTS) GENERAL DATA — 500 mW DO-35 GLASS 100 70 50 RECTANGULAR WAVEFORM TJ = 25°C PRIOR TO INITIAL PULSE 11 V–91 V NONREPETITIVE 30 5% DUTY CYCLE 1.8 V–10 V NONREPETITIVE 20 10 7 5 10% DUTY CYCLE 20% DUTY CYCLE 3 2 1 0.01 0.02 0.05 0.1 0.2 0.5 1 2 5 10 20 50 100 200 500 1000 PW, PULSE WIDTH (ms) 1000 500 1000 700 500 300 200 RECTANGULAR WAVEFORM, TJ = 25°C 100 70 50 30 20 100–200 VOLTS NONREPETITIVE 10 7 5 3 2 1 0.01 ZZ , DYNAMIC IMPEDANCE (OHMS) Ppk , PEAK SURGE POWER (WATTS) Figure 7a. Maximum Surge Power 1.8–91 Volts 200 47 V 100 27 V 50 20 6.2 V 10 5 2 1 0.1 1 10 100 0.1 1000 0.2 0.5 PW, PULSE WIDTH (ms) 100 70 50 5 mA 20 20 mA 1000 TJ = 25°C iZ(rms) = 0.1 IZ(dc) f = 60 Hz IZ = 1 mA 2 5 10 20 50 100 Figure 8. Effect of Zener Current on Zener Impedance MAXIMUM MINIMUM 500 I F , FORWARD CURRENT (mA) ZZ , DYNAMIC IMPEDANCE (OHMS) 1000 700 500 1 IZ, ZENER CURRENT (mA) Figure 7b. Maximum Surge Power DO-204AH 100–200 Volts 200 TJ = 25°C iZ(rms) = 0.1 IZ(dc) f = 60 Hz VZ = 2.7 V 10 7 5 2 200 100 50 20 75°C 10 25°C 5 150°C 0°C 2 1 1 1 2 3 5 7 10 20 30 50 70 100 VZ, ZENER VOLTAGE (VOLTS) Figure 9. Effect of Zener Voltage on Zener Impedance 500 mW DO-35 Glass Data Sheet 6-6 0.4 0.5 0.6 0.7 0.8 0.9 1 1.1 VF, FORWARD VOLTAGE (VOLTS) Figure 10. Typical Forward Characteristics Motorola TVS/Zener Device Data GENERAL DATA — 500 mW DO-35 GLASS 20 10 I Z , ZENER CURRENT (mA) TA = 25° 1 0.1 0.01 1 2 3 4 5 6 7 8 9 10 11 12 13 14 15 16 29 30 VZ, ZENER VOLTAGE (VOLTS) Figure 11. Zener Voltage versus Zener Current — VZ = 1 thru 16 Volts 10 I Z , ZENER CURRENT (mA) TA = 25° 1 0.1 0.01 15 16 17 18 19 20 21 22 23 24 25 26 27 28 VZ, ZENER VOLTAGE (VOLTS) Figure 12. Zener Voltage versus Zener Current — VZ = 15 thru 30 Volts Motorola TVS/Zener Device Data 500 mW DO-35 Glass Data Sheet 6-7 GENERAL DATA — 500 mW DO-35 GLASS I Z , ZENER CURRENT (mA) 10 TA = 25° 1 0.1 0.01 30 35 40 45 50 55 60 65 70 75 80 85 90 95 100 105 250 260 VZ, ZENER VOLTAGE (VOLTS) Figure 13. Zener Voltage versus Zener Current — VZ = 30 thru 105 Volts I Z , ZENER CURRENT (mA) 10 1 0.1 0.01 110 120 130 140 150 160 170 180 190 200 210 220 230 240 VZ, ZENER VOLTAGE (VOLTS) Figure 14. Zener Voltage versus Zener Current — VZ = 110 thru 220 Volts 500 mW DO-35 Glass Data Sheet 6-8 Motorola TVS/Zener Device Data GENERAL DATA — 500 mW DO-35 GLASS Zener Voltage Regulator Diodes — Axial Leaded 500 mW DO-35 Glass NOTES: 1. PACKAGE CONTOUR OPTIONAL WITHIN A AND B HEAT SLUGS, IF ANY, SHALL BE INCLUDED WITHIN THIS CYLINDER, BUT NOT SUBJECT TO THE MINIMUM LIMIT OF B. 2. LEAD DIAMETER NOT CONTROLLED IN ZONE F TO ALLOW FOR FLASH, LEAD FINISH BUILDUP AND MINOR IRREGULARITIES OTHER THAN HEAT SLUGS. 3. POLARITY DENOTED BY CATHODE BAND. 4. DIMENSIONING AND TOLERANCING PER ANSI Y14.5M, 1982. B D F K A K DIM A B D F K F MILLIMETERS MIN MAX 3.05 5.08 1.52 2.29 0.46 0.56 — 1.27 25.40 38.10 INCHES MIN MAX 0.120 0.200 0.060 0.090 0.018 0.022 — 0.050 1.000 1.500 All JEDEC dimensions and notes apply. CASE 299-02 DO-204AH GLASS (Refer to Section 10 for Surface Mount, Thermal Data and Footprint Information.) MULTIPLE PACKAGE QUANTITY (MPQ) REQUIREMENTS Package Option Type No. Suffix MPQ (Units) Tape and Reel RL, RL2(1) 5K Tape and Ammo TA, TA2(1) 5K NOTES: 1. The “2” suffix refers to 26 mm tape spacing. NOTES: 2. Radial Tape and Reel may be available. Please contact your Motorola NOTES: 2. representative. Refer to Section 10 for more information on Packaging Specifications. Motorola TVS/Zener Device Data 500 mW DO-35 Glass Data Sheet 6-9 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5231B Zener 5.1V 0.5W 5% Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily sol leads POLARITY: Cathode indicated by color band. When operated in zen cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • • • • Complete Voltage Range - 1.8 to 200 Volts DO-204AH Package - Smaller than Conventional DO-204AA P Double Slug Type Construction Metallurgically Bonded Construction Orderable Parts Action N/A Orderable Part 1N5231B Package Pin Case Status Desc. Count Outline Zener 5.1V DO-204 2 299-02 Active Short Desc. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog N/A N/A N/A 0.5W 5% 1N5231BRA1 Radial DO-204 2 Tape and Ammo 1N5231BRL Tape and DO-204 2 Reel 1N5231BTA Tape and DO-204 2 Ammunition Box Page 2 of 2 299-02 Active 299-02 Active 299-02 Active Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5231BRR2 Zener 5.1V 0.5W 5% Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 230°C, 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily solderable leads POLARITY: Cathode indicated by color band. When operated in zen mode, cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • Complete Voltage Range - 1.8 to 200 Volts • DO-204AH Package - Smaller than Conventional DO-204AA Package • Double Slug Type Construction • Metallurgically Bonded Construction Orderable Parts Action Orderable Part Short Package Pin Case Status Price/Unit Desc. Desc. Count Outline file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog N/A 1N5231BRR2 Zener DO-204 2 5.1V 0.5W 5% Page 2 of 2 299-02 Active $0.033 Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5234BRR1 Zener Diode Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 230°C, 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily solderable leads POLARITY: Cathode indicated by color band. When operated in zen mode, cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • Complete Voltage Range - 1.8 to 200 Volts • DO-204AH Package - Smaller than Conventional DO-204AA Package • Double Slug Type Construction • Metallurgically Bonded Construction Orderable Parts file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Action N/A Page 2 of 2 Orderable Short Package Pin Case Status Price/Unit Part Desc. Desc. Count Outline 1N5234BRR1 Zener DO-204 2 299-02 Active $0.033 Diode Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5237BRR1 Zener Diode Glass Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 230°C, 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily solderable leads POLARITY: Cathode indicated by color band. When operated in zen mode, cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • Complete Voltage Range - 1.8 to 200 Volts • DO-204AH Package - Smaller than Conventional DO-204AA Package • Double Slug Type Construction • Metallurgically Bonded Construction Orderable Parts file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Action N/A Page 2 of 2 Orderable Short Package Pin Case Status Price/Unit Part Desc. Desc. Count Outline 1N5237BRR1 Zener DO-204 2 299-02 Active $0.033 Diode Glass Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5240BS Zener 10V 0.5W 5% Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 230°C, 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily solderable leads POLARITY: Cathode indicated by color band. When operated in zen mode, cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • Complete Voltage Range - 1.8 to 200 Volts • DO-204AH Package - Smaller than Conventional DO-204AA Package • Double Slug Type Construction • Metallurgically Bonded Construction Orderable Parts Action Orderable Part Short Package Pin Case Status Desc. Desc. Count Outline file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog N/A N/A 1N5240BS Zener N/A 10V 0.5W 5% 1N5240BSRL Tape N/A and Reel Page 2 of 2 N/A N/A Obsolete N/A N/A Active Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5244B Zener 14V 0.5W 5% Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 230°C, 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily solderable leads POLARITY: Cathode indicated by color band. When operated in zen mode, cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • Complete Voltage Range - 1.8 to 200 Volts • DO-204AH Package - Smaller than Conventional DO-204AA Package • Double Slug Type Construction • Metallurgically Bonded Construction Orderable Parts Action Orderable Part Short Package Pin Case Status Price/Unit Desc. Desc. Count Outline file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog N/A N/A N/A 1N5244B Zener DO-204 2 14V 0.5W 5% 1N5244BRA2 Radial DO-204 2 Tape and Ammo 1N5244BRL Tape DO-204 2 and Reel Page 2 of 2 299-02 Active $0.033 299-02 Active $0.033 299-02 Active $0.033 Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog Page 1 of 2 Register | Site Index | Contact Us | Home | China Site Press Room Sales & Distribution About Us Quality Trade Shows Investor Relations Employment Products Product Catalog New Products ON/Cherry Products Documentation Selector Guide On-line Ordering Models Reliability Data PCN Samples Search Order Status Tech Support Product Quick Links Associated Documents Item Short Desc Data Sheet 500 Milliwatt Hermetically Sealed Glass Silicon Zener Diodes Device 1N5246B Zener 16V 0.5W 5% Mechanical Characteristics: CASE: Double slug type, hermetically sealed glass MAXIMUM LEAD TEMPERATURE FOR SOLDERING PURPOSES 1/16 from case for 10 seconds FINISH: All external surfaces are corrosion resistant with readily sol leads POLARITY: Cathode indicated by color band. When operated in zen cathode will be positive with respect to anode MOUNTING POSITION: Any WAFER FAB LOCATION: Phoenix, Arizona ASSEMBLY/TEST LOCATION: Seoul, Korea Features: • • • • Complete Voltage Range - 1.8 to 200 Volts DO-204AH Package - Smaller than Conventional DO-204AA P Double Slug Type Construction Metallurgically Bonded Construction Orderable Parts Action N/A Orderable Part 1N5246B Package Pin Case Status Desc. Count Outline Zener 16V DO-204 2 299-02 Active Short Desc. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00 ON Semiconductor - Product Catalog N/A N/A N/A 0.5W 5% 1N5246BRA1 Radial DO-204 2 Tape and Ammo 1N5246BRL Tape and DO-204 2 Reel 1N5246BTA Tape and N/A N/A Ammunition Box Page 2 of 2 299-02 Active 299-02 Active N/A Obsolete Register | Site Index | Contact Us | Home | China Site Products | Press Room | Sales | About | Investor | Employment © Semiconductor Components Industries, L.L.C., 1999, 2000. All rights reserved. Terms of use. file:\\Roarer\root\data13\imaging\BITTING\cpl_mismatch\20000817\08162000_3\ONSM\08032000 8/19/00
1N5236D 价格&库存
很抱歉,暂时无法提供与“1N5236D”相匹配的价格&库存,您可以联系我们找货
