SZMM3Z series
Voltage regulator diodes
Rev. 2 — 30 March 2021
Product data sheet
1. General description
General-purpose Zener diodes in a very small SOD323 (SC-76) Surface-Mounted Device (SMD)
plastic package.
2. Features and benefits
Non-repetitive peak reverse power disspation: ≤ 40 W
Total power dissipation: ≤ 300 mW
Tolerance series: ± 5 %
Wide working voltage range: nominal 2.4 V to 75 V
Low differential resistance
AEC-Q101 qualified
3. Applications
General regulation functions
4. Quick reference data
Table 1. Quick reference data
Symbol
Parameter
Conditions
VF
forward voltage
IF = 100 mA
PZSM
non-repetitive peak reverse power
dissipation
[1]
[2]
Min
Typ
Max
Unit
[1] -
1.1
V
[2] -
40
W
Pulse test: tp ≤ 300 μs; δ ≤ 0.02
tp = 100 µs; square wave; Tj = 25 °C before surge
5. Pinning information
Table 2. Pinning
Pin
Symbol
Description
1
K
cathode[1]
2
A
anode
Simplified outline
1
2
Graphic symbol
K
A
006aaa152
[1]
The marking bar indicates the cathode.
SZMM3Z series
Nexperia
6. Ordering information
Table 3. Ordering information
Type number
Package
SZMM3Z2V4T1G to
SZMM3Z75VT1G[1]
[1]
Name
Description
Version
SC-76
plastic surface-mounted package; 2 leads
SOD323
The series consists of 37 types with nominal working voltages from 2.4 V to 75 V.
7. Marking
Table 4. Marking Codes
Type number
Marking Code
Type number
Marking Code
SZMM3Z2V4T1G
X8
SZMM3Z15VT1G
VV
SZMM3Z2V7T1G
X9
SZMM3Z16VT1G
VZ
SZMM3Z3V0T1G
XT
SZMM3Z18VT1G
X4
SZMM3Z3V3T1G
XW
SZMM3Z20VT1G
XC
SZMM3Z3V6T1G
XZ
SZMM3Z22VT1G
XG
SZMM3Z3V9T1G
ME
SZMM3Z24VT1G
XM
SZMM3Z4V3T1G
MM
SZMM3Z27VT1G
DK
SZMM3Z4V7T1G
MS
SZMM3Z30VT1G
DL
SZMM3Z5V1T1G
MW
SZMM3Z33VT1G
DM
SZMM3Z5V6T1G
LF
SZMM3Z36VT1G
DN
SZMM3Z6V2T1G
LL
SZMM3Z39VT1G
DP
SZMM3Z6V8T1G
LR
SZMM3Z43VT1G
DR
SZMM3Z7V5T1G
LV
SZMM3Z47VT1G
DS
SZMM3Z8V2T1G
LZ
SZMM3Z51VT1G
DT
SZMM3Z9V1T1G
CU
SZMM3Z56VT1G
DU
SZMM3Z10VT1G
VA
SZMM3Z62VT1G
DV
SZMM3Z11VT1G
VE
SZMM3Z68VT1G
DW
SZMM3Z12VT1G
VK
SZMM3Z75VT1G
DX
SZMM3Z13VT1G
VP
SZMM3Z_SER
Product data sheet
All information provided in this document is subject to legal disclaimers.
Nexperia B.V. 2021. All rights reserved
2 / 12
SZMM3Z series
Nexperia
8. Limiting values
Table 5. Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Min
Max
Unit
IF
forward current
200
mA
PZSM
dissipation
Tamb = 25 °C; prior to surge
40
W
Ptot
total power dissipation
Tamb = 25 °C
[1]
300
mW
Tj
junction temperature
150
°C
Tamb
ambient temperature
−55
+150
°C
Tstg
storage temperature
−65
+150
°C
[1]
Conditions
Device mounted on an FR4 Printed-Circuit Board (PCB) , single-sided copper, tin-plated and standard footprint.
9. Thermal characteristics
Table 6. Thermal characteristics
Symbol
Parameter
Conditions
Rth(j-a)
thermal resistance from junction
to ambient
in free air
Rth(j-sp)
to solder point
[1]
[2]
Min
Typ
Max
Unit
[1]
415
K/W
[2]
110
K/W
Soldering point of cathode tab
10. Characteristics
Table 7. Electrical characteristics
Tj = 25 °C unless otherwise specified.
Symbol
Parameter
Conditions
VF
forward voltage
IF = 10 mA
IF = 100 mA
[1]
Max
Unit
[1]
0.9
V
[1]
1.1
V
SZMM3Z_SER
Product data sheet
3 / 12
SZMM3Z series
Nexperia
Table 8. Electrical characteristics per type: SZMM3Z2V4T1G to SZMM3Z24VT1G
SZMM3ZxxxT1G
Working voltage Reverse current
VZ (V)
IR (µA)
IZ = 5 mA
Differential
resistance
rdiff (Ω)
IZ = 0.5 IZ = 5
mA
mA
Temperature
coefficient
SZ (mV/K)
IZ = 5 mA
Diode
capacitance
Cd (pF)[1]
Min
Max
Max
Max
Min
Max
Max
2.30
2.60
50.0
VR (V)
1.0
Max
2V4
1000
100
-3.5
2V7
2.50
2.90
20.0
1.0
1000
100
-3.5
3V0
2.80
3.20
10.0
1.0
1000
95
-3.5
3V3
3.10
3.50
5.0
1.0
1000
95
-3.5
3V6
3.40
3.80
5.0
1.0
1000
90
-3.5
3V9
3.70
4.10
3.0
1.0
1000
90
-3.5
4V3
4.01
4.48
3.0
1.0
1000
90
-3.5
4V7
4.42
4.90
2.0
1.0
800
80
-3.5
0.2
325
5V1
4.84
5.37
2.0
1.5
250
60
-2.7
1.2
300
5V6
5.31
5.92
1.0
2.5
100
40
-2.0
2.5
275
6V2
5.86
6.53
0.5
3.0
80
30
0.4
3.7
250
6V8
6.47
7.14
0.5
3.5
60
4.5
215
7V5
7.06
7.84
0.5
4.0
60
10
2.5
5.3
170
8V2
7.76
8.64
0.5
5.0
60
10
3.2
6.2
150
9V1
8.56
9.55
0.5
6.0
60
10
3.8
7.0
120
10V
9.45
10.55
0.1
7.0
60
10
4.5
8.0
110
11V
10.44
11.56
0.1
8.0
60
10
5.4
9.0
108
12V
11.42
12.60
0.1
9.0
80
10
6.0
10.0
105
13V
12.47
13.96
0.1
10.0
80
10
7.0
11.0
103
15V
13.84
15.52
0.05
11.0
80
15
9.2
13.0
99
16V
15.37
17.09
0.05
12.0
80
14.0
97
18V
16.94
19.03
0.05
13.0
80
16.0
93
20V
18.86
21.08
0.05
15.0
100
18.0
88
22V
20.88
23.17
0.05
17.0
100
25
16.4
20.0
84
24V
22.93
25.57
0.05
19.0
120
30
18.4
22.0
80
[1]
f = 1 MHz; VR = 0 V
SZMM3Z_SER
Product data sheet
4 / 12
SZMM3Z series
Nexperia
Table 9. Electrical characteristics per type: SZMM3Z27VT1G to SZMM3Z75VT1G
SZMM3ZxxxT1G
VZ (V)
IR (µA)
IZ = 2 mA
Differential
resistance
rdiff (Ω)
IZ = 0.5 IZ = 2
mA
mA
Temperature
coefficient
SZ (mV/K)
IZ = 2 mA
Diode
capacitance
Cd (pF)[1]
Min
Max
Max
Max
Min
Max
Max
25.10
28.90
0.05
VR (V)
18.9
Max
27V
300
80
21.4
25.3
50
30V
28.00
32.00
0.05
21.0
300
80
24.4
29.4
50
33V
31.00
35.00
0.05
23.1
325
80
27.4
33.4
45
36V
34.00
38.00
0.05
25.2
350
90
30.4
37.4
45
39V
37.00
41.00
0.05
27.3
350
130
33.4
41.2
45
43V
40.00
46.00
0.05
30.1
375
150
37.6
46.6
40
47V
44.00
50.00
0.05
32.9
375
170
42.0
51.8
40
51V
48.00
54.00
0.05
35.7
400
180
46.6
57.2
40
56V
52.00
60.00
0.05
39.2
425
200
52.2
63.8
40
62V
58.00
66.00
0.05
43.4
450
215
58.8
71.6
35
68V
64.00
72.00
0.05
47.6
475
240
65.6
79.8
35
75V
70.00
79.00
0.05
52.5
500
255
73.4
88.6
35
[1]
f = 1 MHz; VR = 0 V
SZMM3Z_SER
Product data sheet
5 / 12
SZMM3Z series
Nexperia
aaa-032515
103
IF
(mA)
102
10
10
1
1
10-1
10-1
10-2
10-2
10-3
0.4
0.6
0.8
VF (V)
1.0
10-3
0.4
Tj = 25 ° C
Fig. 1.
aaa-032517
103
IF
(mA)
102
Fig. 2.
1
1
10-1
10-1
10-2
10-2
0.6
0.8
VF (V)
1.0
10-3
0.4
Tj = 25 ° C
1.0
aaa-028553
0.6
0.8
VF (V)
1.0
Tj = 25 ° C
Forward current as a function of forward
voltage; typical values (SZMM3Z7V5T1G)
Product data sheet
VF (V)
103
IF
(mA)
102
10
SZMM3Z_SER
0.8
voltage; typical values (SZMM3Z6V8T1G)
10
Fig. 3.
0.6
Tj = 25 ° C
voltage; typical values (SZMM3Z2V4T1G)
10-3
0.4
aaa-032516
103
IF
(mA)
102
Fig. 4.
voltage; typical values (SZMM3Z75VT1G)
6 / 12
SZMM3Z series
Nexperia
mgl273
SZ
(mV/K)
12
SZ
(mV/K)
4.3
-1
mgl274
10
11
10
9.1
8.2
7.5
6.8
5
3.9
3.6
-2
3.3
6.2
5.6
5.1
3.0
2.4
2.7
-3
IZ (mA)
-5
60
Tj = 25 °C to 150 °C
VZ = 2.4 V to 4.3 V
Fig. 5.
8
12
IZ (mA)
VZ = 4.7 V to 12 V
Temperature coefficient as a function
of working current; typical values
(SZMM3Z2V4T1G to 4V3T1G)
Fig. 6.
aaa-032523
10-1
IR
(A)
(SZMM3Z4V7T1G to 12VT1G)
aaa-032524
10-1
IR
(A)
2.4
2.7
10-2
3.0
3.6
3.3
3.9
4.3
10-2
4.7 5.6 6.8
6.2
10-3
10-3
10-4
10-4
10-5
10-5
10-6
2
3
4
VR (V)
5
10-6
Tj = 25 °C
Fig. 7.
16
Product data sheet
4
6
8.2
7.5
8
11
10
10
12
12
14
VR (V)
Tj = 25 °C
Reverse current as a function of reverse
voltage; typical values (SZMM3Z2V4T1G to
4V3T1G)
SZMM3Z_SER
5.1
9.1
Fig. 8.
voltage; typical values (SZMM3Z4V7T1G to
12VT1G)
7 / 12
SZMM3Z series
Nexperia
aaa-032251
10-1
IR
(A)
IR
(A)
10-2
aaa-006667
10-1
30 36
10-2
27
33
43
39
51
47
62
56
75
68
10-3
13
10-3
15 16
18
24
10-4
10-5
10-4
10-6
10-7
10-5
10-8
10-6
10
13
16
19
22
VR (V)
10-9
25
Tj = 25 °C
Fig. 9.
60
VR (V)
80
Tj = 25 °C
voltage; typical values (SZMM3Z13VT1G to
24VT1G)
Fig. 10. Reverse current as a function of reverse
voltage; typical values (SZMM3Z27VT1G to
75VT1G)
11. Test information
Quality information
This product has been qualified in accordance with the Automotive Electronics Council (AEC)
standard Q101 - Stress test qualification for discrete semiconductors, and is suitable for use in
automotive applications.
12. Package outline
1.35
1.15
1.1
0.8
0.45
0.15
1
2.7
2.3
1.8
1.6
2
0.40
0.25
0.25
0.10
Dimensions in mm
03-12-17
Fig. 11. Package outline SOD323 (SC-76)
SZMM3Z_SER
Product data sheet
8 / 12
SZMM3Z series
Nexperia
13. Soldering
3.05
2.1
solder lands
solder resist
1.65 0.95
0.5 (2×)
0.6 (2×)
solder paste
occupied area
2.2
Dimensions in mm
0.5
(2×)
0.6
(2×)
sod323_fr
Fig. 12. Reflow soldering footprint SOD323 (SC-76)
5
2.9
1.5 (2×)
solder lands
solder resist
occupied area
2.75
1.2
(2×)
Dimensions in mm
preferred transport
direction during soldering
sod323_fw
Fig. 13. Wave soldering footprint SOD323 (SC-76)
SZMM3Z_SER
Product data sheet
9 / 12
SZMM3Z series
Nexperia
14. Revision history
Table 10. Revision history
Document ID
Release date
Data sheet status
Change notice Supersedes
SZMM3Z_SER v.2
20210330
Product data sheet
SZMM3Z_SER v.1
Modifications:
SZMM3Z_SER v.1
20201210
SZMM3Z_SER
Product data sheet
Ordering information corrected
Product data sheet
10 / 12
SZMM3Z series
Nexperia
equipment, nor in applications where failure or malfunction of an Nexperia
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. Nexperia and its suppliers accept
no liability for inclusion and/or use of Nexperia products in such equipment or
applications and therefore such inclusion and/or use is at the customer's own
risk.
15. Legal information
Data sheet status
Document status
[1][2]
Product
status [3]
Definition
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Objective [short]
data sheet
Development
This document contains data from
the objective specification for
product development.
Preliminary [short]
data sheet
Qualification
the preliminary specification.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. Nexperia makes no representation
or warranty that such applications will be suitable for the specified use
without further testing or modification.
Product [short]
data sheet
Production
This document contains the product
specification.
[1]
[2]
[3]
Please consult the most recently issued document before initiating or
completing a design.
The term 'short data sheet' is explained in section "Definitions".
The product status of device(s) described in this document may have
changed since this document was published and may differ in case of
multiple devices. The latest product status information is available on
the internet at https://www.nexperia.com.
Definitions
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. Nexperia does not give any representations or
warranties as to the accuracy or completeness of information included herein
and shall have no liability for the consequences of use of such information.
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is
intended for quick reference only and should not be relied upon to contain
detailed and full information. For detailed and full information see the relevant
full data sheet, which is available on request via the local Nexperia sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
Nexperia and its customer, unless Nexperia and customer have explicitly
agreed otherwise in writing. In no event however, shall an agreement be
valid in which the Nexperia product is deemed to offer functions and qualities
beyond those described in the Product data sheet.
Disclaimers
Limited warranty and liability — Information in this document is believed
to be accurate and reliable. However, Nexperia does not give any
representations or warranties, expressed or implied, as to the accuracy
or completeness of such information and shall have no liability for the
consequences of use of such information. Nexperia takes no responsibility
for the content in this document if provided by an information source outside
of Nexperia.
In no event shall Nexperia be liable for any indirect, incidental, punitive,
special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal
or replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Customers are responsible for the design and operation of their applications
and products using Nexperia products, and Nexperia accepts no liability for
any assistance with applications or customer product design. It is customer’s
sole responsibility to determine whether the Nexperia product is suitable
and fit for the customer’s applications and products planned, as well as
for the planned application and use of customer’s third party customer(s).
Customers should provide appropriate design and operating safeguards to
minimize the risks associated with their applications and products.
Nexperia does not accept any liability related to any default, damage, costs
or problem which is based on any weakness or default in the customer’s
applications or products, or the application or use by customer’s third party
customer(s). Customer is responsible for doing all necessary testing for the
customer’s applications and products using Nexperia products in order to
avoid a default of the applications and the products or of the application or
use by customer’s third party customer(s). Nexperia does not accept any
liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those
given in the Recommended operating conditions section (if present) or the
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — Nexperia products are
sold subject to the general terms and conditions of commercial sale, as
published at http://www.nexperia.com/profile/terms, unless otherwise agreed
in a valid written individual agreement. In case an individual agreement is
concluded only the terms and conditions of the respective agreement shall
apply. Nexperia hereby expressly objects to applying the customer’s general
terms and conditions with regard to the purchase of Nexperia products by
customer.
No offer to sell or license — Nothing in this document may be interpreted
or construed as an offer to sell products that is open for acceptance or the
grant, conveyance or implication of any license under any copyrights, patents
or other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein
may be subject to export control regulations. Export might require a prior
authorization from competent authorities.
Translations — A non-English (translated) version of a document is for
reference only. The English version shall prevail in case of any discrepancy
between the translated and English versions.
Trademarks
Notice: All referenced brands, product names, service names and
trademarks are the property of their respective owners.
Notwithstanding any damages that customer might incur for any reason
whatsoever, Nexperia’s aggregate and cumulative liability towards customer
for the products described herein shall be limited in accordance with the
Terms and conditions of commercial sale of Nexperia.
Right to make changes — Nexperia reserves the right to make changes
to information published in this document, including without limitation
specifications and product descriptions, at any time and without notice. This
document supersedes and replaces all information supplied prior to the
publication hereof.
Suitability for use in automotive applications — This Nexperia product
has been qualified for use in automotive applications. Unless otherwise
agreed in writing, the product is not designed, authorized or warranted to
be suitable for use in life support, life-critical or safety-critical systems or
SZMM3Z_SER
Product data sheet
11 / 12
SZMM3Z series
Nexperia
Contents
1. General description...................................................... 1
2. Features and benefits.................................................. 1
3. Applications.................................................................. 1
4. Quick reference data....................................................1
5. Pinning information......................................................1
6. Ordering information....................................................2
7. Marking.......................................................................... 2
8. Limiting values............................................................. 3
9. Thermal characteristics............................................... 3
10. Characteristics............................................................ 3
11. Test information.......................................................... 8
12. Package outline.......................................................... 8
13. Soldering..................................................................... 9
14. Revision history........................................................10
15. Legal information......................................................11
For more information, please visit: http://www.nexperia.com
For sales office addresses, please send an email to: salesaddresses@nexperia.com
Date of release: 30 March 2021
SZMM3Z_SER
Product data sheet
12 / 12
很抱歉,暂时无法提供与“SZMM3Z3V6T1GX”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 1+2.289681+0.28436
- 10+1.4089610+0.17498
- 50+1.0040550+0.12470
- 100+0.87189100+0.10829
- 国内价格 香港价格
- 1+2.455501+0.30500
- 10+1.4733010+0.18300
- 50+1.0517050+0.13060
- 100+0.91150100+0.11320
- 1000+0.631201000+0.07840
- 3000+0.482703000+0.06000
- 6000+0.430006000+0.05340
- 国内价格 香港价格
- 1+2.001751+0.24860
- 5+1.674195+0.20792
- 10+1.4194210+0.17628
- 国内价格 香港价格
- 3000+0.465523000+0.05782
- 6000+0.416686000+0.05175
