TSM190N08CZ C0G
TSM190N08CZ C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    1个N沟道 耐压:75V 电流:190A
TSM190N08CZ C0G 数据手册
TSM190N08 75V N-Channel Power MOSFET TO-220 PRODUCT SUMMARY Pin Definition: 1. Gate 2. Drain 3. Source Features ● ● ● ● VDS (V) RDS(on)(mΩ) ID (A) 75 4.2 @ VGS =10V 190 Block Diagram Advanced Trench Technology Low RDS(ON) 4.2mΩ (Max.) Low gate charge typical @ 160nC (Typ.) Low Crss typical @ 300pF (Typ.) Ordering Information Part No. TSM190N08CZ C0G Package Packing TO-220 50pcs / Tube Note: “G” denote for Halogen Free Product. N-Channel MOSFET Absolute Maximum Rating (Ta = 25oC unless otherwise noted) Parameter Drain-Source Voltage Gate-Source Voltage Continuous Drain Current TC=25°C TC=70°C TA=25°C Symbol Limit Unit VDS VGS 75 ±20 190 150 17 V V ID TA=70°C Drain Current-Pulsed Note 1 Avalanche Current, L=0.3mH Avalanche Energy, L=0.3mH Maximum Power Dissipation IDM IAS, IAR EAS, EAR TC=25°C TC=70°C TA=25°C TA=70°C Storage Temperature Range Operating Junction Temperature Range PD 14 600 113 1900 250 160 A A A mJ W TSTG TJ 2 1.3 -55 to +150 -55 to +150 °C °C Symbol Limit Unit RӨJC RӨJA 0.5 62.5 °C/W °C/W * Limited by maximum junction temperature Thermal Performance Parameter Thermal Resistance - Junction to Case Thermal Resistance - Junction to Ambient Notes: Surface mounted on FR4 board t ≤ 10sec Document Number: DS_P0000033 1 Version: B15 TSM190N08 75V N-Channel Power MOSFET Electrical Specifications (Ta = 25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250uA BVDSS 75 -- -- V Drain-Source On-State Resistance VGS = 10V, ID = 90A RDS(ON) -- 3.4 4.2 mΩ Gate Threshold Voltage VDS = VGS, ID = 250uA VGS(TH) 2 3 4 V Zero Gate Voltage Drain Current VDS = 75V, VGS = 0V IDSS -- -- 1 uA Gate Body Leakage VGS = ±25V, VDS = 0V IGSS -- -- ±100 nA Qg -- 160 -- Qgs -- 35 -- Qgd -- 40 -- Dynamic Total Gate Charge Gate-Source Charge Gate-Drain Charge Input Capacitance Output Capacitance Reverse Transfer Capacitance VDS = 30V, ID = 90A, VGS = 10V VDS = 30V, VGS = 0V, f = 1.0MHz Ciss -- 8600 -- Coss -- 780 -- Crss -- 300 -- td(on) -- 25 -- tr -- 40 -- td(off) -- 85 -- tf -- 45 -- VSD - 0.8 1.3 nC pF Switching Turn-On Delay Time Turn-On Rise Time VGS = 10V, VDS = 30V, Turn-Off Delay Time RG = 3.3Ω Turn-Off Fall Time Drain-Source Diode Characteristics and Maximum Rating Drain-Source Diode Forward VGS=0V, IS=90A Voltage nS V Reverse Recovery Time IS = 90A, TJ=25 C tfr 70 nS Reverse Recovery Charge dI/dt = 100A/us Qfr 115 nC o Notes: 1. Pulse Test: Pulse Width ≤ 300µs, Duty Cycle ≤ 2%. 2. RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal reference is defined as the solder mounting surface of the drain pins. RӨJC is guaranteed by design while RӨCA is determined by the user's board design. RӨJA shown below for single device operation on FR-4 in still air Document Number: DS_P0000033 2 Version: B15 TSM190N08 75V N-Channel Power MOSFET TO-220 Mechanical Drawing DIM A B C D E F G H J K L M N O P Document Number: DS_P0000033 3 TO-220 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 10.000 10.500 0.394 0.413 3.740 3.910 0.147 0.154 2.440 2.940 0.096 0.116 6.350 0.250 0.381 1.106 0.015 0.040 2.345 2.715 0.092 0.058 4.690 5.430 0.092 0.107 12.700 14.732 0.500 0.581 14.224 16.510 0.560 0.650 3.556 4.826 0.140 0.190 0.508 1.397 0.020 0.055 27.700 29.620 1.060 1.230 2.032 2.921 0.080 0.115 0.255 0.610 0.010 0.024 5.842 6.858 0.230 0.270 Version: B15 TSM190N08 75V N-Channel Power MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. Document Number: DS_P0000033 4 Version: B15
TSM190N08CZ C0G 价格&库存
很抱歉,暂时无法提供与“TSM190N08CZ C0G”相匹配的价格&库存,您可以联系我们找货
TSM190N08CZ C0G
