1PGSMA4750HR3G
1PGSMA4750HR3G
    TAIWANSEMICONDUCTOR(台湾半导体)
    DO-214AC
    DIODE ZENER 27V 1.25W DO214AC
1PGSMA4750HR3G 数据手册
1PGSMA4740 – 1PGSMA200Z Taiwan Semiconductor 1W, 10V - 200V Surface Mount Zener Diode FEATURES ● ● ● ● ● ● ● KEY PARAMETERS Photo Glass passivated chip junction Ideal for automated placement Low inductance Typical IR less than 1μA above 11V Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 APPLICATIONS PARAMETER VALUE UNIT VZ 10 - 200 V Test current IZT 1.2 - 25 mA Ptot 1 W TJ MAX 175 °C Package DO-214AC (SMA) Configuration Single die ● For general purpose regulation and protection applications MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT VF 1.2 V Ptot 1.25 W Total power dissipation at TA = 75°C Ptot 1 W Junction temperature TJ -55 to +175 °C TSTG -55 to +175 °C SYMBOL TYP UNIT Junction-to-lead thermal resistance RӨJL 29 °C/W Junction-to-ambient thermal resistance RӨJA 120 °C/W Junction-to-case thermal resistance RӨJC 31 °C/W Forward voltage @ IF = 200mA Total power dissipation at TA = 50°C, derate above 50°C (1) Storage temperature Notes: 1. Mounted on 5mm x 5mm Cu pad test board THERMAL PERFORMANCE PARAMETER Thermal Performance Note: Units mounted on PCB (5mm x 5mm Cu pad test board) 1 Version: B2102 1PGSMA4740 – 1PGSMA200Z Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Part number (Note 1) Marking code 1PGSMA4740 1PGSMA4741 1PGSMA4742 1PGSMA4743 1PGSMA4744 1PGSMA4745 1PGSMA4746 1PGSMA4747 1PGSMA4748 1PGSMA4749 1PGSMA4750 1PGSMA4751 1PGSMA4752 1PGSMA4753 1PGSMA4754 1PGSMA4755 1PGSMA4756 1PGSMA4757 1PGSMA4758 1PGSMA4759 1PGSMA4760 1PGSMA4761 1PGSMA4762 1PGSMA4763 1PGSMA4764 1PGSMA110Z 1PGSMA120Z 1PGSMA130Z 1PGSMA150Z 1PGSMA160Z 1PGSMA180Z 1PGSMA200Z P740A P741A P742A P743A P744A P745A P746A P747A P748A P749A P750A P751A P752A P753A P754A P755A P756A P757A P758A P759A P760A P761A P762A P763A P764A P110A P120A P130A P150A P160A P180A P200A Zener voltage VZ @ IZ V Min Nom Max 9.5 10 10.5 10.5 11 11.6 11.4 12 12.6 12.4 13 13.7 14.3 15 15.8 15.2 16 16.8 17.1 18 18.9 19 20 21 20.9 22 23.1 22.8 24 25.2 25.7 27 28.4 28.5 30 31.5 31.4 33 34.7 34.2 36 37.8 37.1 39 41 40.9 43 45.2 44.7 47 49.4 48.5 51 53.6 53.2 56 58.8 58.9 62 65.1 64.6 68 71.4 71.3 75 78.8 77.9 82 86.1 86.5 91 95.6 95 100 105 104.5 110 115.5 114 120 126 123.5 130 136.5 142.5 150 157.5 152 160 168 171 180 189 190 200 210 Test current Regulator impedance Test current Leakage current Maximum DC Zener Current IZT mA ZZT @ IZT ZZK @ IZK Ω Ω Max Max 7 700 8 700 9 700 10 700 14 700 16 700 20 750 22 750 23 750 25 750 35 750 40 1000 45 1000 50 1000 60 1000 70 1500 80 1500 95 1500 110 2000 125 2000 150 2000 175 2000 200 3000 250 3000 350 3000 450 4000 550 4500 700 5000 1000 6000 1100 6500 1200 7000 1500 8000 IZK mA IR @ V R µA V Max 5 7.6 1 8.4 1 9.1 1 9.9 1 11.4 1 12.2 1 13.7 1 15.2 1 16.7 1 18.2 1 20.6 1 22.8 1 25.1 1 27.4 1 29.7 1 32.7 1 35.8 1 38.8 1 42.6 1 47.1 1 51.7 1 56.0 1 62.2 1 69.2 1 76.0 1 83.6 1 91.2 1 98.8 1 114.0 1 121.6 1 136.8 1 152.0 IZM mA Max 91 83 76 69 61 57 50 45 41 38 34 30 27 25 23 22 19 18 16 14 13 12 11 10 9 8.9 8.3 7.7 6.7 6.3 5.6 5.0 25 23 21 19 17 15.5 14.0 12.5 11.5 10.5 9.5 8.5 7.5 7.0 6.5 6.0 5.5 5.0 4.5 4.0 3.7 3.3 3.0 2.8 2.5 2.3 2.0 1.9 1.7 1.6 1.4 1.2 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 0.25 Note: 1. Tolerance and Voltage Regulation Designation. The type number listed indicates a tolerance of ±5%. ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING 1PGSMAx DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 10V(1PGSMA4740) to 200V(1PGSMA200Z) 2 Version: B2102 1PGSMA4740 – 1PGSMA200Z Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.2 Typical Junction Capacitance 1.5 1000 1 100 CAPACITANCE (pF) Ptot - Total Power Dissipation (W) Fig.1 Steady State Power Derating 0.5 0 25 50 75 100 125 150 1PGSMA4742 1PGSMA4756 10 1PGSMA200Z f=1.0MHz Vsig=50mVp-p 1 175 1 AMBIENT TEMPERATURE (°C) 10 100 REVERSE VOLTAGE (V) Fig.3 Typical Zener Impedance Zz - DYNAMIC IMPEDANCE (Ω) 10000 1000 1PGSMA4742 100 1PGSMA4756 10 1PGSMA200Z 1 0.1 1 10 100 Iz - ZENER TEST CURRENT (mA) 3 Version: B2102 1PGSMA4740 – 1PGSMA200Z Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 4 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: B2102 1PGSMA4740 – 1PGSMA200Z Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: B2102
1PGSMA4750HR3G
物料型号:1PGSMA4740 – 1PGSMA200Z,这是一系列表面安装的稳压二极管,由台湾半导体公司生产。
器件简介:这些稳压二极管具有光电玻璃钝化芯片结、适合自动化放置、低电感、在11V以上时典型IR小于1μA、符合J-STD-020标准的1级湿度敏感度、符合RoHS标准、根据IEC 61249-2-21为无卤素。
引脚分配:文档中提到了阳极和阴极的标记,但没有提供具体的引脚分配图。
参数特性:包括工作电压(Vz)从10V到200V,测试电流(lzr)从1.2mA到25mA,总功耗(Ptot)为1W,最大结温(TJ MAX)为175°C。封装类型为DO-214AC (SMA),配置为单芯片。
功能详解:这些稳压二极管适用于一般用途的稳压和保护应用。
应用信息:适用于一般用途的稳压和保护。
封装信息:封装类型为DO-214AC (SMA),封装材料满足UL 94V-0可燃性等级,端子为镀锡的引线,可焊性符合J-STD-002标准,符合JESD 201的2级晶须测试,极性由阴极带指示,重量约为0.060g。
1PGSMA4750HR3G 价格&库存
很抱歉,暂时无法提供与“1PGSMA4750HR3G”相匹配的价格&库存,您可以联系我们找货
1PGSMA4750HR3G
  • 1+6.249531+0.78371
  • 10+3.8476710+0.48251
  • 100+2.47479100+0.31035
库存:135
