MM5Z5V6T5GF
MM5Z5V6T5GF
    NEXPERIA(安世)
    SOD-523(SC-79)
    VOLTAGE REGULATOR DIODES
MM5Z5V6T5GF 数据手册
MM5Z series Voltage regulator diodes Rev. 1 — 7 April 2021 Product data sheet 1. General description General-purpose Zener diodes in an SOD523 (SC-79) ultra small flat lead Surface-Mounted Device (SMD) plastic package. 2. Features and benefits • • • • • Non-repetitive peak reverse power disspation: ≤ 40 W Total power dissipation: ≤ 300 mW Tolerance series: ± 2 % Wide working voltage range: nominal 2.4 V to 36 V Low differential resistance 3. Applications • General regulation functions 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions VF forward voltage IF = 100 mA PZSM non-repetitive peak reverse power dissipation [1] [2] Min Typ Max Unit [1] - - 1.1 V [2] - - 40 W Pulse test: tp ≤ 300 μs; δ ≤ 0.02 tp = 100 µs; square wave; Tj = 25 °C before surge 5. Pinning information Table 2. Pinning Pin Symbol Description 1 K cathode[1] 2 A anode Simplified outline 1 Graphic symbol 2 K A 006aaa152 [1] The marking bar indicates the cathode. MM5Z series Nexperia Voltage regulator diodes 6. Ordering information Table 3. Ordering information Type number Package MM5Z2V4T5G to MM5Z36VT5G[1] [1] Name Description Version SC-79 plastic surface-mounted package; 2 leads SOD523 The series consists of 29 types with nominal working voltages from 2.4 V to 36 V. 7. Marking Table 4. Marking Codes Type number Marking Code Type number Marking Code MM5Z2V4T5G C1 MM5Z10VT5G E6 MM5Z2V7T5G C2 MM5Z11VT5G E7 MM5Z3V0T5G C3 MM5Z12VT5G E8 MM5Z3V3T5G C4 MM5Z13VT5G E9 MM5Z3V6T5G C5 MM5Z15VT5G E0 MM5Z3V9T5G C6 MM5Z16VT5G EA MM5Z4V3T5G C7 MM5Z18VT5G EB MM5Z4V7T5G C8 MM5Z20VT5G EC MM5Z5V1T5G C9 MM5Z22VT5G ED MM5Z5V6T5G C0 MM5Z24VT5G EE MM5Z6V2T5G E1 MM5Z27VT5G EF MM5Z6V8T5G E2 MM5Z30VT5G EG MM5Z7V5T5G E3 MM5Z33VT5G EH MM5Z8V2T5G E4 MM5Z36VT5G EK MM5Z9V1T5G E5 - - MM5Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 2 / 10 MM5Z series Nexperia Voltage regulator diodes 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Min Max Unit IF forward current - 200 mA PZSM non-repetitive peak reverse power dissipation tp = 100 µs; square wave; Tamb = 25 °C; prior to surge - - 40 W Ptot total power dissipation Tamb = 25 °C [1] - 300 mW Tj junction temperature - 150 °C Tamb ambient temperature −55 +150 °C Tstg storage temperature −65 +150 °C [1] Conditions 2 Device mounted on an FR4 Printed-Circuit Board (PCB) with aproximately 35 mm Cu area at cathode tab 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Conditions Rth(j-a) thermal resistance from junction to ambient in free air Rth(j-sp) thermal resistance from junction to solder point [1] [2] Min Typ Max Unit [1] - - 350 K/W [2] - - 65 K/W 2 Device mounted on an FR4 Printed-Circuit Board (PCB) with aproximately 35 mm Cu area at cathode tab Soldering point of cathode tab 10. Characteristics Table 7. Electrical characteristics Tj = 25 °C unless otherwise specified. Symbol Parameter Conditions VF forward voltage IF = 10 mA IF = 100 mA [1] Max Unit [1] 0.9 V [1] 1.1 V Pulse test: tp ≤ 300 μs; δ ≤ 0.02 MM5Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 3 / 10 MM5Z series Nexperia Voltage regulator diodes Table 8. Electrical characteristics per type: MM5Z2V4T5G to MM5Z24VT5G Tj = 25 °C unless otherwise specified. MM5ZxxxT5G Working voltage Reverse current VZ (V) IR (µA) IZ = 5 mA Differential resistance rdiff (Ω) IZ = 1 IZ = 5 mA mA Temperature coefficient SZ (mV/K) IZ = 5 mA Diode capacitance Cd (pF)[1] Min Max Max Max Min Max Max 2.35 2.45 50.0 VR (V) 1.0 Max 2V4 400 100 -3.5 0 450 2V7 2.65 2.75 20.0 1.0 450 100 -3.5 0 440 3V0 2.94 3.06 10.0 1.0 500 95 -3.5 0 425 3V3 3.23 3.37 5.0 1.0 500 95 -3.5 0 410 3V6 3.53 3.67 5.0 1.0 500 90 -3.5 0 390 3V9 3.82 3.98 3.0 1.0 500 90 -3.5 0 370 4V3 4.21 4.39 3.0 1.0 600 90 -3.5 0 350 4V7 4.61 4.79 3.0 2.0 500 80 -3.5 0.2 325 5V1 5.00 5.20 2.0 2.0 480 60 -2.7 1.2 300 5V6 5.49 5.71 1.0 2.0 400 40 -2.0 2.5 275 6V2 6.08 6.32 3.0 4.0 150 10 0.4 3.7 250 6V8 6.66 6.94 2.0 4.0 80 15 1.2 4.5 215 7V5 7.35 7.65 1.0 5.0 80 10 2.5 5.3 170 8V2 8.04 8.36 0.7 5.0 80 10 3.2 6.2 150 9V1 8.92 9.28 0.5 6.0 100 10 3.8 7.0 120 10V 9.80 10.20 0.2 7.0 150 10 4.5 8.0 110 11V 10.78 11.22 0.1 8.0 150 10 5.4 9.0 110 12V 11.76 12.24 0.1 8.0 150 10 6.0 10.0 105 13V 12.74 13.26 0.1 8.0 170 10 7.0 11.0 105 15V 14.70 15.30 0.05 10.5 200 15 9.2 13.0 100 16V 15.68 16.32 0.05 11.2 200 40 10.4 14.0 90 18V 17.64 18.36 0.05 12.6 225 45 12.4 16.0 80 20V 19.60 20.40 0.05 14.0 225 55 14.4 18.0 70 22V 21.56 22.44 0.05 15.4 250 55 16.4 20.0 60 24V 23.52 24.48 0.05 16.8 250 70 18.4 22.0 55 [1] f = 1 MHz; VR = 0 V MM5Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 4 / 10 MM5Z series Nexperia Voltage regulator diodes Table 9. Electrical characteristics per type: MM5Z27VT5G to MM5Z36VT5G Tj = 25 °C unless otherwise specified. MM5ZxxxT5G Working voltage Reverse current VZ (V) IR (µA) IZ =2 mA Differential resistance rdiff (Ω) IZ = 0.5 IZ = 2 mA mA Temperature coefficient SZ (mV/K) IZ = 2 mA Diode capacitance Cd (pF)[1] Min Max Max Max Min Max Max 26.46 27.54 0.05 VR (V) 18.9 Max 27V 300 80 21.4 25.3 50 30V 29.40 30.60 0.05 21.0 300 80 24.4 29.4 50 33V 32.34 33.66 0.05 23.1 325 80 27.4 33.4 45 36V 35.28 36.72 0.05 25.2 350 90 30.4 37.4 45 [1] f = 1 MHz; VR = 0 V aaa-028550 103 IF (mA) 102 10 10 1 1 10-1 10-1 10-2 10-2 10-3 0.4 0.6 0.8 VF (V) 1.0 10-3 0.4 Tj = 25 ° C Fig. 1. aaa-028551 103 IF (mA) 102 0.6 0.8 VF (V) 1.0 Tj = 25 ° C Forward current as a function of forward voltage; typical values (MM5Z2V4T5G) Forward current as a function of forward voltage; typical values (MM5Z6V8T5G) mld444 0.5 aaa-028552 103 Fig. 2. SZ (mV/K) IF (mA) 102 4V7 0 4V3 - 0.5 10 2V4 1 2V7 3V9 -1 10-1 3V6 - 1.5 3V3 3V0 10-2 10-3 0.4 -2 10- 1 0.6 0.8 VF (V) Forward current as a function of forward voltage; typical values (MM5Z7V5T5G) MM5Z_SER Product data sheet 10 IZ (mA) 102 Tj = 25 °C to 150 °C Tj = 25 ° C Fig. 3. 1 1.0 Fig. 4. Temperature coefficient as a function of working current; typical values (MM5Z2V4T5G to 4V7T5G) All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 5 / 10 MM5Z series Nexperia Voltage regulator diodes mld445 12 IR (A) 15 SZ (mV/K) 13 12 11 10 9V1 8V2 7V5 6V8 6V2 5V6 5V1 8 4 0 aaa-006665 10-1 2V4 10-2 2V7 10-3 3V0 3V3 3V6 3V9 4V3 4V7 5V1 10-4 10-5 5V6 10-6 6V2 6V8 10-7 10-8 -4 10- 1 1 10 IZ (mA) 10-9 102 Tj = 25 °C to 150 °C Fig. 5. IR (A) Fig. 6. aaa-006666 10-1 IR (A) 7V5 10 12 15 18 22 8V2 10-3 2 11 13 6 VR (V) 8 Reverse current as a function of reverse voltage; typical values (MM5Z2V4T5G to 6V8T5G) aaa-032242 10-1 10-2 27 10-3 9V1 4 Tj = 25 °C Temperature coefficient as a function of working current; typical values (MM5Z5V1T5G to 15VT5G) 10-2 0 16 20 24 30 33 36 10-4 10-4 10-5 10-5 10-6 10-6 10-7 10-7 10-8 10-8 0 5 10 15 20 VR (V) 25 10-9 Tj = 25 °C Fig. 7. Product data sheet 24 28 32 36 VR (V) 40 Tj = 25 °C Reverse current as a function of reverse voltage; typical values (MM5Z7V5T5G to 24VT5G) MM5Z_SER 20 Fig. 8. Reverse current as a function of reverse voltage; typical values (MM5Z27VT5G to 36VT5G) All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 6 / 10 MM5Z series Nexperia Voltage regulator diodes 11. Package outline 0.85 0.75 0.65 0.58 1 1.65 1.25 1.55 1.15 2 0.34 0.26 0.17 0.11 Dimensions in mm Fig. 9. 02-12-13 Package outline SOD523 (SC-79) 12. Soldering 2.15 1.4 solder lands solder resist 0.5 0.6 (2×) (2×) 1.2 solder paste occupied area Dimensions in mm 0.4 (2×) 0.5 (2×) sod523_fr Fig. 10. Reflow soldering footprint SOD523 (SC-79) MM5Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 7 / 10 MM5Z series Nexperia Voltage regulator diodes 13. Revision history Table 10. Revision history Document ID Release date Data sheet status Change notice Supersedes MM5Z_SER v.1 20210407 Product data sheet - MM5Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 - © Nexperia B.V. 2021. All rights reserved 8 / 10 MM5Z series Nexperia Voltage regulator diodes 14. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal MM5Z_SER Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 9 / 10 MM5Z series Nexperia Voltage regulator diodes Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................1 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 3 10. Characteristics............................................................ 3 11. Package outline.......................................................... 7 12. Soldering..................................................................... 7 13. Revision history..........................................................8 14. Legal information........................................................9 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 7 April 2021 MM5Z_SER Product data sheet All information provided in this document is subject to legal disclaimers. Rev. 1 — 7 April 2021 © Nexperia B.V. 2021. All rights reserved 10 / 10
MM5Z5V6T5GF 价格&库存
很抱歉,暂时无法提供与“MM5Z5V6T5GF”相匹配的价格&库存,您可以联系我们找货
MM5Z5V6T5GF
库存:48
MM5Z5V6T5GF
  • 1+1.923961+0.24127
  • 10+1.1797510+0.14795
  • 100+0.72994100+0.09154
  • 500+0.53359500+0.06692
  • 1000+0.469971000+0.05894
库存:5317
MM5Z5V6T5GF
  • 3000+0.388843000+0.04877
  • 6000+0.347846000+0.04362
  • 9000+0.326919000+0.04100
  • 15000+0.3033815000+0.03805
  • 21000+0.2894321000+0.03630
  • 30000+0.2758730000+0.03460
  • 75000+0.2460875000+0.03086
  • 150000+0.22766150000+0.02855
  • 300000+0.21219300000+0.02661
库存:5317
