1SMA5926 M2G
1SMA5926 M2G
    TAIWANSEMICONDUCTOR(台半)
    DO214AC
    DIODE ZENER 11V 1.5W DO214AC
1SMA5926 M2G 数据手册
1SMA5926 – 1SMA5956 Taiwan Semiconductor 1.5W, 11V - 200V Surface Mount Zener Diode FEATURES ● ● ● ● ● ● ● ● ● KEY PARAMETERS Low profile package Ideal for automated placement Glass passivated chip junction Low inductance Typical IR less than 0.5μA above 11V ESD Rating of Class 3B (HBM) per JEDEC Moisture sensitivity level: level 1, per J-STD-020 RoHS Compliant Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 11 - 200 V Test current IZT 1.9 - 34.1 mA PD 1.5 W TJ MAX 150 °C Package DO-214AC (SMA) Configuration Single die APPLICATIONS ● ● ● ● Switching mode power supply (SMPS) Adapters Lighting application On-board DC/DC converter MECHANICAL DATA ● ● ● ● ● ● Case: DO-214AC (SMA) Molding compound meets UL 94V-0 flammability rating Terminal: Matte tin plated leads, solderable per J-STD-002 Meet JESD 201 class 2 whisker test Polarity: Indicated by cathode band Weight: 0.060g (approximately) DO-214AC (SMA) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL VALUE UNIT 1.5 W 20 mW/°C DC power dissipation at TL = 75°C measure (1) at zero lead length derate above 75°C PD Peak forward surge current, 8.3ms single half sine-wave superimposed on rated load IFSM 10 A TJ -55 to +150 °C TSTG -55 to +150 °C Junction temperature Storage temperature Notes: 1. Mounted on 5mm x 5mm Cu pad test board 1 Version: L2102 1SMA5926 – 1SMA5956 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) Zener voltage (Note 2) Test current Regulator impedance Test current Leakage current Maximum DC Zener Current IZT mA IZK mA 34.1 ZZT @ IZT ZZK @ IZK Ω Ω Max Max 5.5 550 0.25 IR @ VR µA V Max 0.5 8.4 IZM mA Max 136 Part number (Note 1) Marking code 1SMA5926 926A VZ @ IZ V Min Nom Max 10.45 11 11.55 1SMA5927 927A 11.40 12 12.60 31.2 6.5 550 0.25 0.5 9.1 125 1SMA5928 928A 12.35 13 13.65 28.8 7.0 550 0.25 0.5 9.9 115 1SMA5929 929A 14.25 15 15.75 25.0 9.0 600 0.25 0.5 11.4 100 1SMA5930 930A 15.20 16 16.80 23.4 10.0 600 0.25 0.5 12.2 94 1SMA5931 931A 17.10 18 18.90 20.8 12.0 650 0.25 0.5 13.7 83 1SMA5932 932A 19.00 20 21.00 18.7 14.0 650 0.25 0.5 15.2 75 1SMA5933 933A 20.90 22 23.10 17.0 17.5 650 0.25 0.5 16.7 68 1SMA5934 934A 22.80 24 25.20 15.6 19.0 700 0.25 0.5 18.2 63 1SMA5935 935A 25.65 27 28.35 13.9 23.0 700 0.25 0.5 20.6 56 1SMA5936 936A 28.50 30 31.50 12.5 26.0 750 0.25 0.5 22.8 50 1SMA5937 937A 31.35 33 34.65 11.4 33.0 800 0.25 0.5 25.1 45 1SMA5938 938A 34.20 36 37.80 10.4 38.0 850 0.25 0.5 27.4 42 1SMA5939 939A 37.05 39 40.95 9.6 45.0 900 0.25 0.5 29.7 38 1SMA5940 940A 40.85 43 45.15 8.7 53.0 950 0.25 0.5 32.7 35 1SMA5941 941A 44.65 47 49.35 8.0 67.0 1000 0.25 0.5 35.8 32 1SMA5942 942A 48.45 51 53.55 7.3 70.0 1100 0.25 0.5 38.8 29 1SMA5943 943A 53.20 56 58.80 6.7 86.0 1300 0.25 0.5 42.6 27 1SMA5944 944A 58.90 62 65.10 6.0 100.0 1500 0.25 0.5 47.1 24 1SMA5945 945A 64.60 68 71.40 5.5 120.0 1700 0.25 0.5 51.7 22 1SMA5946 946A 71.25 75 78.75 5.0 140.0 2000 0.25 0.5 56.0 20 1SMA5947 947A 77.90 82 86.10 4.6 160.0 2500 0.25 0.5 62.2 18 1SMA5948 948A 86.45 91 95.55 4.1 200.0 3000 0.25 0.5 69.2 16 1SMA5949 949A 95.00 100 105.00 3.7 250.0 3100 0.25 0.5 76.0 15 1SMA5950 950A 104.50 110 115.50 3.4 300.0 4000 0.25 0.5 83.6 13 1SMA5951 951A 114.00 120 126.00 3.1 360.0 4500 0.25 0.5 91.2 12 1SMA5952 952A 123.50 130 136.50 2.9 450.0 5000 0.25 0.5 98.8 11 1SMA5953 953A 142.50 150 157.50 2.5 600.0 6000 0.25 0.5 114.0 10 1SMA5954 954A 152.00 160 168.00 2.3 700.0 6500 0.25 0.5 121.6 9 1SMA5955 955A 171.00 180 189.00 2.1 900.0 7000 0.25 0.5 136.8 8 1SMA5956 956A 190.00 200 210.00 1.9 1200.0 8000 0.25 0.5 152.0 7 Notes: 1. Tolerance and Voltage Regulation Designation. The type number listed indicates a tolerance of ±5% 2. Vz limits are to be guaranteed at thermal equilibrium ORDERING INFORMATION ORDERING CODE(1) PACKAGE PACKING 1SMA59x DO-214AC (SMA) 7,500 / Tape & Reel Notes: 1. “x” defines voltage from 11V(1SMA5926) to 200V(1SMA5956) 2 Version: L2102 1SMA5926 – 1SMA5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.1 Steady State Power Derating Fig.2 Capacitance Curve 1000 MEASURED @ ZERO BIAS 3.2 2.8 C, CAPACITANCE (pF) PD, MAXIMUM POWER DISSIPATION (W) 3.6 2.4 2 1.6 TL 1.2 0.8 100 MEASURED @ Vz/2 TA 0.4 0 0 25 50 75 100 125 10 150 1 T, TEMPERATURE (°C) Fig.4 Effect Of Zener Voltage 1000 Zz, DYNAMIC IMPEDANCE (Ω) 100 IZ, ZENER CURRENT (mA) 100 BREAKDOWN VOLTAGE (V) Fig.3 Vz = 12 - 68 Volts 10 1 Iz=1mA 100 Iz=10mA 10 Iz=20mA 1 0.1 0 10 20 30 40 50 60 70 10 80 Vz, ZENER VOLTAGE (V) 100 Vz, ZENER VOLTAGE (V) Fig.5 Zener Voltage 12 - 68 Volts Fig.6 Typical Pulse Rating Curve 10 100 PPK, PEAK POWER (kW) Vz, TEMPERATURE COEFFICIENT (mV/°C) @IZT 10 10 10 NONREPETITIVE, EXPONENTIAL PULSE WAVEFORM, TA=25℃ 1 0.1 0.01 100 0.0 Vz, ZENER VOLTAGE @IZT (V) 0.1 1.0 10.0 Tp. PULSE WIDTH (ms) 3 Version: L2102 1SMA5926 – 1SMA5956 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig.7 Pulse Waveform 120 IPPM, PEAK PULSE CURRENT (%) 110 Peak value IPPM 100 Pulse width(td) is defined as the point where the peak current decays to 50% of IPPM 90 Rise time tr=10μs to 100% of IPPM 80 70 Half value-IPPM/2 10/1000μs, waveform as defined by R.E.A. 60 50 40 30 20 td 10 0 0 0.5 1 1.5 2 2.5 3 3.5 4 4.5 5 t, TIME (ms) Fig.8 Pulse Waveform 120 IPPM, PEAK PULSE CURRENT (%) 110 100 90 0.9 IPEAK 80 70 60 0.5 IPEAK 50 40 8/20 μs WAVEFORM 30 t=8µs 20 10 0.1 IPEAK 0 0 0.01 0.02 0.03 0.04 0.05 0.06 0.07 0.08 0.09 0.1 t, TIME (ms) 4 Version: L2102 1SMA5926 – 1SMA5956 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS DO-214AC (SMA) SUGGESTED PAD LAYOUT MARKING DIAGRAM 5 P/N = Marking Code G = Green Compound YW = Date Code F = Factory Code Version: L2102 1SMA5926 – 1SMA5956 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: L2102
1SMA5926 M2G
物料型号:1SMA5926 – 1SMA5956,由台湾半导体生产。
器件简介:这是一系列1.5W,11V至200V的表面安装Zener二极管,具有低轮廓封装,适合自动化放置,玻璃钝化芯片结,低电感,典型IR小于0.5μA(在11V以上),静电放电等级为JEDEC 3B级,符合RoHS标准,无卤素,符合IEC 61249-2-21标准。
引脚分配:文档中未明确提供引脚分配图,但通常SMA封装的二极管具有阳极和阴极两个引脚。
参数特性: - 工作电压范围:11V至200V - 典型测试电流:1.9mA至34.1mA - 最大功耗:1.5W - 最大结温:150°C - 封装类型:DO-214AC (SMA) - 配置:单芯片
功能详解:这些Zener二极管适用于开关电源(SMPS)、适配器、照明应用和板上DC/DC转换器。
应用信息:适用于开关电源、适配器、照明应用和板上DC/DC转换器。
封装信息:封装类型为DO-214AC (SMA),符合UL 94V-0可燃性等级,端子为镀锡的哑光引线,可按照J-STD-002进行焊接,符合JESD 201二级晶须测试,极性通过阴极带表示,重量约为0.060g。
绝对最大额定值和电气规格详细列出了不同型号的Zener电压、测试电流、最大直流Zener电流、漏电流等参数。特性曲线图提供了稳态功率降额、电容特性、Zener电压影响、动态阻抗和典型脉冲等级曲线等信息。
订购信息提供了订购代码、封装类型和包装方式。
1SMA5926 M2G 价格&库存
很抱歉,暂时无法提供与“1SMA5926 M2G”相匹配的价格&库存,您可以联系我们找货
