TSM080NB03CR
Taiwan Semiconductor
N-Channel Power MOSFET
30V, 59A, 8mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive losses
PARAMETER
VALUE
UNIT
VDS
30
V
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● 175°C Operating Junction Temperature
● RoHS Compliant
● Halogen-free according to IEC 61249-2-21
RDS(on)
VGS = 10V
8
(max)
VGS = 4.5V
15
mΩ
Qg
10
nC
APPLICATIONS
● DC-DC Converter
● Battery Management
● Load Switch
● Motor Drive
PDFN56
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
30
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
TC = 25°C
(Note 1)
ID
TA = 25°C
Pulsed Drain Current
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
59
14
A
IDM
236
A
IAS
EAS
17
43
A
mJ
PD
PD
55.6
18.5
3.1
1
W
W
TJ, TSTG
- 55 to +175
°C
THERMAL PERFORMANCE
PARAMETER
SYMBOL
MAXIMUM
UNIT
Junction to Case Thermal Resistance
RӨJC
2.7
°C/W
Junction to Ambient Thermal Resistance
RӨJA
48
°C/W
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJC is guaranteed by design while RӨCA is
2
determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper.
1
Version: A1910
TSM080NB03CR
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
30
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
1
1.8
2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
1
100
5.8
8
10
15
gfs
36
Qg
Qg
10
Qgs
4
Qgd
5
Ciss
1097
Coss
180
Crss
106
Rg
0.8
2.5
5
td(on)
5
tr
22
td(off)
14
tf
5
VSD
1
V
VGS = 0V, VDS = 30V
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 30V
TJ = 125°C
Drain-Source On-State Resistance
VGS = 10V, ID = 14A
(Note 3)
VGS = 4.5V, ID = 10A
Forward Transconductance
Dynamic
(Note 3)
RDS(on)
VDS = 10V, ID = 14A
µA
mΩ
S
(Note 4)
VGS = 10V, VDS = 15V,
Total Gate Charge
ID = 14A
Total Gate Charge
VGS = 4.5V, VDS = 15V,
Gate-Source Charge
ID = 10A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 15V,
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Gate Resistance
Switching
f = 1.0MHz
nC
pF
Ω
(Note 4)
Turn-On Delay Time
Turn-On Rise Time
Turn-Off Delay Time
ID = 14A, RG = 2Ω
Turn-Off Fall Time
ns
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = 14A
Reverse Recovery Time
IS = 14A,
trr
16
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
8
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 17A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
ORDERING CODE
TSM080NB03CR RLG
PACKAGE
PACKING
PDFN56
2,500pcs / 13” Reel
2
Version: A1910
TSM080NB03CR
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
40
VGS=10V
VGS=7V
VGS=5V
VGS=4.5V
VGS=4V
VGS=3.5V
30
ID, Drain Current (A)
40
VGS=3V
10
30
25℃
10
-55℃
175℃
2
3
4
On-Resistance vs. Drain Current
4
5
Gate-Source Voltage vs. Gate Charge
0.014
0.012
VGS=4.5V
0.01
0.008
0.006
VGS=10V
0.004
0.002
VDS=15V
ID=14A
8
6
4
2
5
RDS(on), Drain-Source On-Resistance (Ω)
VGS=10V
ID=14A
1.6
1.4
1.2
1
0.8
0.6
50
15
On-Resistance vs. Gate-Source Voltage
2
-75 -50 -25
10
Qg, Gate Charge (nC)
On-Resistance vs. Junction Temperature
(Normalized)
3
10
0.016
1.8
2
VGS, Gate to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
VDS, Drain to Source Voltage (V)
75 100 125 150 175
0.03
0.025
0.02
0.015
0.01
ID=14A
0.005
4
5
6
7
8
9
10
TJ, Junction Temperature (°C)
3
Version: A1910
TSM080NB03CR
BVDSS vs. Junction Temperature
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
1600
C, Capacitance (pF)
1400
1200
CISS
1000
800
600
400
COSS
200
CRSS
1.2
ID=5mA
1.1
1
0.9
0.8
-75 -50 -25
25
50
75 100 125 150 175
Maximum Safe Operating Area, Junction-to-Case
Source-Drain Diode Forward Current vs. Voltage
100
IS, Reverse Drain Current (A)
1000
RDS(ON)
100
10
SINGLE PULSE
RӨJC=2.7°C/W
TC=25°C
10
175℃
25℃
1
-55℃
0.1
1
0.1
1
10
0.2
100
0.4
0.6
0.8
1
1.2
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=2.7°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.01
0.1
t, Square Wave Pulse Duration (sec)
4
Version: A1910
TSM080NB03CR
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
PDFN56
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSC
080NB03
YWWLF
Y
WW
L
F
= Year Code
= Week Code (01~52)
= Lot Code (1~9,A~Z)
= Factory Code
5
Version: A1910
TSM080NB03CR
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability
for application assistance or the design of Purchasers’ products.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: A1910
