TSM060N03PQ33 RGG
TSM060N03PQ33 RGG
    TAIWANSEMICONDUCTOR(台湾半导体)
    WDFN8
    1个N沟道 耐压:30V 电流:62A
TSM060N03PQ33 RGG 数据手册
TSM060N03PQ33 Taiwan Semiconductor N-Channel Power MOSFET 30V, 62A, 6mΩ FEATURES PRODUCT SUMMARY ● Low RDS(ON) to minimize conductive Loss PARAMETER VALUE UNIT VDS 30 V ● Low gate charge for fast power switching ● 100% UIS and Rg tested ● Compliant to RoHS Directive 2011/65/EU and in RDS(on) (max) accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 definition VGS = 10V 6 VGS = 4.5V 9 Qg mΩ 12.9 nC APPLICATIONS ● DC-DC Converters ● Battery Power Management ● Oring FET/Load Switch PDFN33 Notes: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V Continuous Drain Current Pulsed Drain Current TC = 25°C (Note 1) TA = 25°C (Note 1) ID 62 15 A IDM 248 A Single Pulse Avalanche Current (Note 2) IAS 29 A Single Pulse Avalanche Energy (Note 2) EAS 42 mJ Total Power Dissipation Total Power Dissipation TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range PD PD 40 8 2.3 0.5 W W TJ, TSTG - 55 to +150 °C SYMBOL LIMIT UNIT Thermal Resistance – Junction to Case RӨJC 3.1 °C/W Thermal Resistance – Junction to Ambient RӨJA 53 °C/W THERMAL RESISTANCE PARAMETER Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case-thermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: C1608 TSM060N03PQ33 Taiwan Semiconductor ELECTRICAL CHARACTERISTICS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN. TYP. MAX. UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 30 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 1.2 1.6 2.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA Drain-Source Leakage Current VGS = 0V, VDS = 30V IDSS -- -- 1 µA Drain-Source On-State Resistance VGS = 10V, ID = 15A -- 4.8 6 (Note 3) VGS = 4.5V, ID = 15A -- 6.7 9 gfs -- 38 -- Qg -- 25.4 -- Forward Transconductance Dynamic (Note 3) RDS(on) VDS = 5V, ID = 15A mΩ S (Note 4) VGS = 10V, VDS = 15V, Total Gate Charge ID = 15A Total Gate Charge Qg VGS = 4.5V, VDS = 15V, Gate-Source Charge ID = 15A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 15V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz, open drain 12.9 nC Qgs -- 3.8 -- Qgd -- 5.7 -- Ciss -- 1342 -- Coss -- 227 -- Crss -- 169 -- Rg 0.8 2.7 5.4 td(on) -- 7.5 -- tr -- 14.5 -- td(off) -- 35.2 -- tf -- 9.6 -- VSD -- -- 1 V pF Ω (Note 4) Turn-On Delay Time Rise Time VGS = 10V, VDS = 15V, Turn-Off Delay Time ID = 15A, RG = 3.3Ω, Fall Time ns Source-Drain Diode Diode Forward Voltage (Note 3) VGS = 0V, IS = 15A Reverse Recovery Time IS = 15A, trr -- 8.8 -- ns Reverse Recovery Charge di/dt = 100A/μs Qrr -- 26 -- nC Notes: 1. Current limited by package. 2. L = 0.1mH, VGS = 10V, VDS = 25V, RG = 25Ω, IAS = 29A, Starting TJ = 25°C 3. Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. 4. Switching time is essentially independent of operating temperature. ORDERING INFORMATION PART NO. TSM060N03PQ33 RGG PACKAGE PACKING PDFN33 5,000pcs / 13” Reel 2 Version: C1608 TSM060N03PQ33 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) On-Resistance vs. Junction Temperature Normalized Gate Threshold 1.2 1 0.8 0.6 0.4 -75 -50 -25 0 25 50 75 100 125 150 RDS(on), Drain-Source On-Resistance (Normalized) Normalized Vth vs. TJ 2 VGS=10V ID=15A 1.8 1.6 1.4 1.2 1 0.8 0.6 -75 Capacitance vs. Drain-Source Voltage 0 25 50 75 100 125 150 VGS, Gate to Source Voltage (V) 10 1800 1600 C, Capacitance (pF) -25 Gate-Source Voltage vs. Gate Charge 2000 CISS 1400 1200 1000 800 600 400 COSS 200 CRSS 0 0 5 10 15 VDS=15V ID=15A 8 6 4 2 0 20 25 30 0 VDS, Drain to Source Voltage (V) 5 10 15 20 25 30 Qg, Gate Charge (nC) Normalized Thermal Transient Impedance, Junctionto-Case Maximum Safe Operating Area, Junction-to-Case 1000 10 SINGLE PULSE RӨJC=3.1°C/W ID, Drain Current (A) Normalized Effective Transient Thermal Impedance -50 TJ, Junction Temperature (°C) TJ, Junction Temperature (℃) 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.001 0.00001 RDS(ON) 100 10 SINGLE PULSE RӨJC=3.1°C/W TC=25°C 1 0.0001 0.001 0.01 0.1 0.1 1 10 100 VDS, Drain to Source Voltage (V) t, Square Wave Pulse Duration (sec) 3 Version: C1608 TSM060N03PQ33 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) PDFN33 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM Y = Year Code M = Month Code for Halogen Free Product O =Jan P =Feb Q =Mar R =Apr S =May T =Jun U =Jul V =Aug W =Sep X =Oct Y =Nov Z =Dec L = Lot Code (1~9, A~Z) 4 Version: C1608 TSM060N03PQ33 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5 Version: C1608
TSM060N03PQ33 RGG 价格&库存
很抱歉,暂时无法提供与“TSM060N03PQ33 RGG”相匹配的价格&库存,您可以联系我们找货
TSM060N03PQ33 RGG
  • 1+8.891251+1.14929
  • 10+5.5647510+0.71931
  • 100+3.62092100+0.46805
  • 500+2.78457500+0.35994
  • 1000+2.515021000+0.32510
  • 2000+2.288062000+0.29576
库存:11995
TSM060N03PQ33 RGG
  • 5000+2.042325000+0.26399
  • 10000+1.8904510000+0.24436
  • 15000+1.8131215000+0.23437
  • 25000+1.7262125000+0.22313
  • 35000+1.6747535000+0.21648
  • 50000+1.6378850000+0.21172
库存:11995
TSM060N03PQ33 RGG
