E3M0280090D
E3M0280090D
    WOLFSPEED
    TO-247-3
    E3M0280090D
E3M0280090D 数据手册
E3M0280090D 900 V ID @ 25˚C 11.5 A Silicon Carbide Power MOSFET E-Series Automotive VDS RDS(on) 280 mΩ N-Channel Enhancement Mode Features • • • • • • Package 3rd generation SiC MOSFET technology High blocking voltage with low On-resistance High speed switching with low capacitances Fast intrinsic diode with low reverse recovery (Qrr) Halogen free, RoHS compliant Automotive Qualified (AEC-Q101) and PPAP Capable Benefits • • • • Higher system efficiency Reduced cooling requirements Increased power density Increased system switching frequency Applications • • • • Automotive EV battery chargers Renewable energy High voltage DC/DC converters Telecom Power Supplies Part Number Package Marking E3M0280090D TO-247-3 E3M0280090 Maximum Ratings (TC = 25 ˚C unless otherwise specified) Parameter Symbol Unit Test Conditions Note VDSmax Drain - Source Voltage 900 V VGSmax Gate - Source Voltage -8/+18 V Note: 1 VGSop Gate - Source Voltage (Recommended operating values) -4/+15 V Note: 2 ID Continuous Drain Current ID(pulse) PD TJ , Tstg 11.5 7.5 A VGS = 0 V, ID = 100 μA VGS = 15 V, TC = 25˚C Fig. 19 VGS = 15 V, TC = 100˚C Pulsed Drain Current 22 A Pulse width tP limited by Tjmax Fig. 22 Power Dissipation 54 W TC=25˚C, TJ = 150 ˚C Fig. 20 -55 to +150 ˚C Operating Junction and Storage Temperature TL Solder Temperature 260 ˚C Md Mounting Torque 1 8.8 Nm lbf-in Note (1): When using MOSFET Body Diode VGSmax = -4V/+18V Note (2): MOSFET can also safely operate at 0/+15 V 1 Value E3M0280090D Rev. - , 07-2018 1.6mm (0.063”) from case for 10s M3 or 6-32 screw Electrical Characteristics (TC = 25˚C unless otherwise specified) Symbol Parameter V(BR)DSS Drain-Source Breakdown Voltage VGS(th) Gate Threshold Voltage Min. Typ. Max. 900 1.7 2.1 3.5 1.6 Unit Test Conditions V VGS = 0 V, ID = 100 μA V VDS = VGS, ID = 1.2 mA V VDS = VGS, ID = 1.2 mA, TJ = 150ºC IDSS Zero Gate Voltage Drain Current 1 100 μA VDS = 900 V, VGS = 0 V IGSS Gate-Source Leakage Current 10 250 nA VGS = 15 V, VDS = 0 V 280 364 RDS(on) Drain-Source On-State Resistance 385 3.6 gfs Transconductance Ciss Input Capacitance 150 Coss Output Capacitance 20 Crss Reverse Transfer Capacitance 2 Eoss Coss Stored Energy 4.5 EON Turn-On Switching Energy (Body Diode FWD) 57 EOFF Turn Off Switching Energy (Body Diode FWD) 6 td(on) Turn-On Delay Time 26 Rise Time 10 tr td(off) tf RG(int) Turn-Off Delay Time 17.5 Fall Time 7.5 Internal Gate Resistance 26 Qgs Gate to Source Charge 2.8 Qgd Gate to Drain Charge 3.4 Qg Total Gate Charge 9.5 mΩ S 3.1 Note pF VGS = 15 V, ID = 7.5 A VGS = 15 V, ID = 7.5 A, TJ = 150ºC VDS= 15 V, IDS= 7.5 A VDS= 15 V, IDS= 7.5 A, TJ = 150ºC Fig. 4, 5, 6 Fig. 7 Fig. 17, 18 VGS = 0 V, VDS = 600 V f = 1 MHz μJ Fig. 11 VAC = 25 mV Fig. 16 μJ VDS = 400 V, VGS = -4 V/15 V, ID = 7.5 A, RG(ext) = 2.5Ω, L= 220 μH, TJ = 150ºC Fig. 26, 29 Note 3 ns VDD = 400 V, VGS = -4 V/15 V ID = 7.5 A, RG(ext) = 2.5 Ω, Timing relative to VDS Inductive load Fig. 27, 29 Note 3 Ω f = 1 MHz, VAC = 25 mV nC VDS = 400 V, VGS = -4 V/15 V ID = 7.5 A Per IEC60747-8-4 pg 21 Fig. 12 Reverse Diode Characteristics (TC = 25˚C unless otherwise specified) Symbol VSD IS IS, pulse Parameter Typ. Diode Forward Voltage Max. Unit Test Conditions 4.8 V VGS = -4 V, ISD = 4 A 4.4 V VGS = -4 V, ISD = 4 A, TJ = 150 °C Note Fig. 8, 9, 10 Continuous Diode Forward Current 9.6 A VGS = -4 V, TC = 25˚C Note 1 Diode pulse Current 22 A VGS = -4 V, pulse width tP limited by Tjmax Note 1 VGS = -4 V, ISD = 4 A, VR = 400 V dif/dt = 800 A/µs, TJ = 150 °C Note 1 trr Reverse Recover time 20 ns Qrr Reverse Recovery Charge 47 nC Irrm Peak Reverse Recovery Current 3.4 A Thermal Characteristics Symbol Parameter Max. RθJC Thermal Resistance from Junction to Case 2.3 RθJA Thermal Resistance From Junction to Ambient 40 Unit Test Conditions °C/W Note (3): Turn-off and Turn-on switching energy and timing values measured using SiC MOSFET Body Diode 2 E3M0280090D Rev. - , 07-2018 Note Fig. 21 Typical Performance Conditions: TJ = -55 °C tp = < 200 µs 18 VGS = 13 V 16 14 12 VGS = 15 V Conditions: TJ = 25 °C tp = < 200 µs 18 VGS = 13 V 16 Drain-Source Current, IDS (A) 20 VGS = 15 V VGS = 11 V 10 VGS = 9 V 8 6 VGS = 7 V 4 Drain-Source Current, IDS (A) 20 14 VGS = 11 V 12 VGS = 9 V 10 8 6 VGS = 7 V 4 2 2 0 0 0 2 4 6 8 0 10 2 4 Drain-Source Voltage, VDS (V) Figure 1. Output Characteristics TJ = -55 ºC 2.5 Conditions: TJ = 150 °C tp = < 200 µs 18 10 Conditions: IDS = 7 A VGS = 15 V tp < 200 µs VGS = 15 V VGS = 13 V 16 Drain-Source Current, IDS (A) 8 Figure 2. Output Characteristics TJ = 25 ºC 14 2.0 On Resistance, RDS On (P.U.) 20 6 Drain-Source Voltage, VDS (V) VGS = 11 V 12 VGS = 9 V 10 8 6 VGS = 7 V 4 1.5 1.0 0.5 2 0.0 0 0 2 4 6 8 -50 10 -25 0 Figure 3. Output Characteristics TJ = 150 ºC Conditions: VGS = 15 V tp < 200 µs 500 TJ = 150 °C 400 TJ = -55 °C 300 75 100 125 150 Conditions: IDS = 7 A tp < 200 µs 550 On Resistance, RDS On (mOhms) On Resistance, RDS On (mOhms) 500 50 Figure 4. Normalized On-Resistance vs. Temperature 600 600 25 Junction Temperature, TJ (°C) Drain-Source Voltage, VDS (V) TJ = 25 °C 200 100 450 VGS = 11 V 400 350 VGS = 13 V 300 250 VGS = 15 V 200 150 100 50 0 0 0 5 10 15 Drain-Source Current, IDS (A) Figure 5. On-Resistance vs. Drain Current For Various Temperatures 3 E3M0280090D Rev. - , 07-2018 20 -50 -25 0 25 50 75 100 Junction Temperature, TJ (°C) Figure 6. On-Resistance vs. Temperature For Various Gate Voltage 125 150 Typical Performance -8 Conditions: VDS = 20 V tp < 200 µs -7 -6 -5 -4 -3 -2 -1 0 0 TJ = 150 °C 10 VGS = -4 V Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) 15 TJ = 25 °C TJ = -55 °C 5 -5 VGS = 0 V VGS = -2 V -10 -15 Conditions: TJ = -55°C tp < 200 µs 0 0.00 2.00 4.00 6.00 8.00 10.00 12.00 14.00 Figure 7. Transfer Characteristic for Various Junction Temperatures -8 -7 -6 -5 -4 -3 -2 Figure 8. Body Diode Characteristic at -55 ºC -1 0 -8 -7 -6 -5 -4 -3 -2 -1 VGS = -4 V -5 VGS = 0 V VGS = -2 V -10 VGS = -4 V -5 VGS = 0 V VGS = -2 V -10 -15 Conditions: TJ = 25°C tp < 200 µs Drain-Source Voltage VDS (V) -15 Conditions: TJ = 150°C tp < 200 µs -20 Drain-Source Voltage VDS (V) Figure 9. Body Diode Characteristic at 25 ºC 2.0 1.5 1.0 0.5 0.0 0 25 50 75 100 125 Junction Temperature TJ (°C) Figure 11. Threshold Voltage vs. Temperature 4 E3M0280090D Rev. - , 07-2018 Conditions: IDS = 7.5 A IGS = 10 mA VDS = 400 V TJ = 25 °C 12 Gate-Source Voltage, VGS (V) Threshold Voltage, Vth (V) 16 Conditons VGS = VDS IDS = 1.2 mA -25 -20 Figure 10. Body Diode Characteristic at 150 ºC 3.0 2.5 0 0 Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) 0 -50 -20 Drain-Source Voltage VDS (V) Gate-Source Voltage, VGS (V) 150 8 4 0 -4 0 2 4 6 8 Gate Charge, QG (nC) Figure 12. Gate Charge Characteristics 10 Typical Performance -6 -5 -4 -3 -2 -1 0 -6 -5 -4 -3 -2 -1 0 0 -5 VGS = 5 V VGS = 10 V -10 VGS = 15 V VGS = 0 V Drain-Source Current, IDS (A) Drain-Source Current, IDS (A) VGS = 0 V 0 -5 VGS = 5 V VGS = 10 V -10 VGS = 15 V -15 -15 Conditions: TJ = -55 °C tp < 200 µs Conditions: TJ = 25 °C tp < 200 µs -20 Drain-Source Voltage VDS (V) Figure 13. 3rd Quadrant Characteristic at -55 ºC -6 -5 -4 -3 -2 -1 -20 Drain-Source Voltage VDS (V) Figure 14. 3rd Quadrant Characteristic at 25 ºC 10 0 0 8 -5 VGS = 5 V VGS = 10 V -10 VGS = 15 V Stored Energy, EOSS (µJ) Drain-Source Current, IDS (A) VGS = 0 V 4 2 -15 Conditions: TJ = 150 °C tp < 200 µs 0 0 -20 Drain-Source Voltage VDS (V) 6 100 300 600 700 800 1000 Conditions: TJ = 25 °C VAC = 25 mV f = 1 MHz 900 1000 Conditions: TJ = 25 °C VAC = 25 mV f = 1 MHz Ciss 100 Capacitance (pF) Capacitance (pF) 500 Figure 16. Output Capacitor Stored Energy Ciss Coss 10 100 Coss 10 Crss Crss 1 1 0 50 100 Drain-Source Voltage, VDS (V) 150 Figure 17. Capacitances vs. Drain-Source Voltage (0 - 200V) 5 400 Drain to Source Voltage, VDS (V) Figure 15. 3rd Quadrant Characteristic at 150 ºC 1000 200 E3M0280090D Rev. - , 07-2018 200 0 100 200 300 400 500 600 Drain-Source Voltage, VDS (V) 700 800 Figure 18. Capacitances vs. Drain-Source Voltage (0 - 900V) 900 Typical Performance 60 Conditions: TJ ≤ 150 °C Conditions: TJ ≤ 150 °C 10 Maximum Dissipated Power, Ptot (W) Drain-Source Continous Current, IDS (DC) (A) 12 8 6 4 2 0 -55 -30 -5 20 45 70 95 120 50 40 30 20 10 0 145 -55 Case Temperature, TC (°C) Drain-Source Current, IDS (A) Junction To Case Impedance, ZthJC (oC/W) 10.00 0.3 0.1 0.05 0.02 0.01 SinglePulse 10E-6 100E-6 1E-3 10E-3 Time, tp (s) 100E-3 145 10 µs 0.10 Conditions: TC = 25 °C D = 0, Parameter: tp 1 10 100 1000 Drain-Source Voltage, VDS (V) Figure 22. Safe Operating Area 180 Conditions: TJ = 25 °C VDD = 400 V RG(ext) = 2.5 Ω VGS = -4V/+15 V FWD = E3M0280090D L = 220 μH 160 140 ETotal 150 EOn 100 120 ETotal 100 80 EOn 60 40 50 EOff 20 EOff 0 0 0 2 4 6 8 10 12 14 Drain to Source Current, IDS (A) Figure 23. Clamped Inductive Switching Energy vs. Drain Current (VDD = 600V) 6 120 100 ms 0.1 Switching Loss (uJ) Switching Loss (uJ) 200 95 100 µs 1.00 1 Conditions: TJ = 25 °C VDD = 600 V RG(ext) = 2.5 Ω VGS = -4V/+15 V FWD = EM0280090D L = 220 μH 250 70 Limited by RDS On Figure 21. Transient Thermal Impedance (Junction - Case) 300 45 1 ms 0.01 10E-3 1E-6 20 Figure 20. Maximum Power Dissipation Derating vs. Case Temperature 0.5 100E-3 -5 Case Temperature, TC (°C) Figure 19. Continuous Drain Current Derating vs. Case Temperature 1 -30 E3M0280090D Rev. - , 07-2018 16 0 2 4 6 8 10 12 14 Drain to Source Current, IDS (A) Figure 24. Clamped Inductive Switching Energy vs. Drain Current (VDD = 400V) 16 Typical Performance 80 Switching Loss (uJ) 100 Conditions: TJ = 25 °C VDD = 400 V IDS = 7.5 A VGS = -4V/+15 V FWD = E3M0280090D L = 220 μH Conditions: IDS = 7.5 A VDD = 400 V RG(ext) = 2.5 Ω VGS = -4V/+15 V FWD = E3M0280090D L = 220 μH 80 ETotal Switching Loss (uJ) 100 60 EOn 40 20 ETotal 60 EOn 40 20 EOff EOff 0 0 0 5 10 15 20 25 External Gate Resistor RG(ext) (Ohms) Conditions: TJ = 25 °C VDD = 400 V IDS = 7.5 A VGS = -4V/+15 V FWD = E3M0280090D L = 220 μH 40 Times (ns) 35 30 25 50 75 100 125 Figure 26. Clamped Inductive Switching Energy vs. Temperature td(on) 25 20 td(off) 15 tr 10 tf 5 0 0 5 10 15 20 25 External Gate Resistor RG(ext) (Ohms) Figure 27. Switching Times vs. RG(ext) 7 E3M0280090D Rev. - , 07-2018 150 Junction Temperature, TJ (°C) Figure 25. Clamped Inductive Switching Energy vs. RG(ext) 45 0 Figure 28. Switching Times Definition 175 Test Circuit Schematic Figure 29. Clamped Inductive Switching Test Circuit Note (3): Turn-off and Turn-on switching energy and timing values measured using SiC MOSFET Body Diode as shown above. 8 E3M0280090D Rev. - , 07-2018 Package Dimensions POS Package TO-247-3 A T V U W Pinout Information: • • • Pin 1 = Gate Pin 2, 4 = Drain Pin 3 = Source Recommended Solder Pad Layout TO-247-3 9 E3M0280090D Rev. - , 07-2018 Inches Millimeters Min Max Min Max .190 .205 4.83 5.21 A1 .090 .100 2.29 2.54 A2 .075 .085 1.91 2.16 b .042 .052 1.07 1.33 b1 .075 .095 1.91 2.41 b2 .075 .085 1.91 2.16 b3 .113 .133 2.87 3.38 b4 .113 .123 2.87 3.13 c .022 .027 0.55 0.68 D .819 .831 20.80 21.10 D1 .640 .695 16.25 17.65 D2 .037 .049 0.95 1.25 E .620 .635 15.75 16.13 E1 .516 .557 13.10 14.15 E2 .145 .201 3.68 5.10 E3 .039 .075 1.00 1.90 E4 .487 .529 12.38 13.43 e .214 BSC N 3 5.44 BSC 3 L .780 .800 19.81 20.32 L1 .161 .173 4.10 4.40 ØP .138 .144 3.51 3.65 Q .216 .236 5.49 6.00 S .238 .248 6.04 6.30 T 9˚ 11˚ 9˚ 11˚ U 9˚ 11˚ 9˚ 11˚ V 2˚ 8˚ 2˚ 8˚ W 2˚ 8˚ 2˚ 8˚ Notes • RoHS Compliance The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/ EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or from the Product Documentation sections of www.cree.com. • REACh Compliance REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA) has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is also available upon request. • This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical equipment, aircraft navigation or communication or control systems, air traffic control systems. Related Links • • • LTSPICE Models: http://wolfspeed.com/power/tools-and-support SiC MOSFET Isolated Gate Driver reference design: http://wolfspeed.com/power/tools-and-support SiC MOSFET Evaluation Board: http://wolfspeed.com/power/tools-and-support Copyright © 2018 Cree, Inc. All rights reserved. The information in this document is subject to change without notice. Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc. 10 E3M0280090D Rev. -, 07-2018 Cree, Inc. 4600 Silicon Drive Durham, NC 27703 USA Tel: +1.919.313.5300 Fax: +1.919.313.5451 www.cree.com/power
E3M0280090D 价格&库存
很抱歉,暂时无法提供与“E3M0280090D”相匹配的价格&库存,您可以联系我们找货
