TSM7P06CP ROG
TSM7P06CP ROG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-252(DPAK)
TSM7P06CP ROG 数据手册
TSM7P06CP 60V P-Channel Power MOSFET TO-252 Key Parameter Performance Pin Definition: 1. Gate 2. Drain 3. Source Parameter Value Unit VDS -60 V RDS(on) (max) VGS = -10V 180 VGS = -4.5V 220 Qg 8.2 nC Block Diagram Ordering Information Ordering code mΩ Package Packing TSM7P06CP ROG TO-252 2.5kpcs / 13” Reel Note: Halogen-free according to IEC 61249-2-21 definition P-Channel MOSFET Absolute Maximum Ratings (TC=25oC unless otherwise noted) Symbol Limit Unit Drain-Source Voltage VDS -60 V Gate-Source Voltage VGS ±20 V -7 A -4.4 A Parameter TC = 25ºC Continuous Drain Current ID TC = 100ºC (Note 1) IDM -28 A Single Pulse Avalanche Energy (Note 2) EAS 32 mJ Single Pulse Avalanche Current (Note 1) IAS -8 A Power Dissipation @ TC = 25 C PD 15.6 W Operating Junction Temperature TJ 150 ºC TSTG -50 to +150 Symbol Limit Thermal Resistance - Junction to Case RӨJC 8 Thermal Resistance - Junction to Ambient RӨJA 62 Pulsed Drain Current o Storage Temperature Range o C Thermal Performance Parameter 1/5 Unit o C/W Version: B1802 TSM7P06CP 60V P-Channel Power MOSFET Electrical Specifications (TC=25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit BVDSS -60 -- -- V -- 153 180 -- 198 220 -1.2 -1.6 -2.5 -- -- -1 -- -- -10 IGSS -- -- ±100 nA gfs -- 3 -- S Qg -- 8.2 -- Qgs -- 1.8 -- Qgd -- 1.5 -- Ciss -- 425 -- Coss -- 35 -- Crss -- 20 -- td(on) -- 5.2 -- tr -- 19 -- td(off) -- 35 -- tf -- 10.6 -- IS -- -- -7 A ISM -- -- -28 A VSD -- -- -1 V Static Drain-Source Breakdown Voltage Drain-Source On-State Resistance Gate Threshold Voltage VGS = 0V, ID = -250µA VGS = -10V, ID = -3A VGS = -4.5V, ID = -1.5A VDS = VGS, ID = -250µA RDS(ON) VGS(TH) VDS = -60V, VGS = 0V Zero Gate Voltage Drain Current VDS = -48V, VGS = 0V, IDSS TC = 125ºC Gate Body Leakage VGS = ±20V, VDS = 0V Forward Transconductance (Note 3) VDS = -10V, ID = -2A mΩ V µA Dynamic (Note 3,4) Total Gate Charge Gate-Source Charge Gate-Drain Charge (Note 3,4) (Note 3,4) VDS = -30V, ID = -3A, VGS = -10V Input Capacitance VDS = -30V, VGS = 0V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance nC pF Switching Turn-On Delay Time Turn-On Rise Time (Note 3,4) Turn-Off Delay Time Turn-Off Fall Time (Note 3,4) (Note 3,4) VDD = -30V, ID = -1A, RGEN =6Ω (Note 3,4) ns Source-Drain Diode Ratings and Characteristic Maximum Continuous Drain-Source Diode Forward Current Integral reverse diode in Maximum Pulse Drain-Source Diode the MOSFET Forward Current Diode-Source Forward Voltage VGS = 0V, IS = -1A Note: 1. Pulse width limited by safe operating area 2. L=1mH, IAS =-8A, VDD = -25V, RG = 25Ω, Starting TJ = 25ºC 3. Pulse test: pulse width ≤300µs, duty cycle ≤2% 4. Switching time is essentially independent of operating temperature. 2/5 Version: B1802 TSM7P06CP 60V P-Channel Power MOSFET Electrical Characteristics Curve Normalized Rds(on) vs. Tj Normalized On Resistance -ID , Continuous Drain Current (A) Continuous Drain Current vs. Tc TJ , Junction Temperature (ºC) Normalized Vth vs. Tj Gate Charge Waveform -VGS , Gate to Source Voltage (V) Normalized Gate Threshold Voltage TC , Case Temperature (ºC) Qg , Gate Charge (nC) Normalized Transient Impedance Maximum Safe Operation Area -ID , Drain Current (A) Normalized Thermal Response TJ , Junction Temperature (ºC) Square Wave Pulse Duration (s) -VDS , Drain to Source Voltage (V) 3/5 Version: B1802 TSM7P06CP 60V P-Channel Power MOSFET TO-252 Mechanical Drawing Unit: Millimeters SUGGESTED PAD LAYOUT (Unit: Millimeters) Marking Diagram Y = Year Code M = Month Code for Halogen Free Product (O=Jan, P=Feb, Q=Mar, R=Apl, S=May, T=Jun, U=Jul, V=Aug, W=Sep, X=Oct, Y=Nov, Z=Dec) L = Lot Code 4/5 Version: B1802 TSM7P06CP 60V P-Channel Power MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 5/5 Version: B1802
TSM7P06CP ROG 价格&库存
很抱歉,暂时无法提供与“TSM7P06CP ROG”相匹配的价格&库存,您可以联系我们找货
TSM7P06CP ROG
  • 1+7.856951+1.01700
  • 10+4.9149610+0.63619
  • 100+4.05943100+0.52545
TSM7P06CP ROG
  • 1+7.28622
  • 10+4.55404
  • 100+3.76588
TSM7P06CP ROG
  • 1+9.102741+1.17826
  • 10+5.6902810+0.73655
  • 100+3.70819100+0.47999
  • 500+2.85365500+0.36938
  • 1000+2.578251000+0.33373
库存:6093
TSM7P06CP ROG
  • 2500+2.279952500+0.29512
  • 5000+2.095525000+0.27125
  • 7500+2.001577500+0.25909
  • 12500+1.8959912500+0.24542
  • 17500+1.8334817500+0.23733
  • 25000+1.7727225000+0.22946
库存:6093
TSM7P06CP ROG
    库存:5000
