1SMA4737 – 1SMA200Z
Taiwan Semiconductor
1W, 7.5V - 200V Surface Mount Zener Diode
FEATURES
KEY PARAMETERS
Ideal for automated placement
Glass passivated chip junction
Low inductance
Typical IR less than 1μA above 11V
Moisture sensitivity level: level 1, per J-STD-020
RoHS Compliant
Halogen-free according to IEC 61249-2-21
APPLICATIONS
PARAMETER
VALUE
UNIT
VZ
7.5 - 200
V
Test current IZT
1.2 - 34
mA
PD
1
W
TJ MAX
175
°C
Package
DO-214AC (SMA)
Configuration
Single die
● For general purpose regulation and protection applications
MECHANICAL DATA
Case: DO-214AC (SMA)
Molding compound meets UL 94V-0 flammability rating
Terminal: Matte tin plated leads, solderable per J-STD-002
Meet JESD 201 class 2 whisker test
Polarity: Indicated by cathode band
Weight: 0.060g (approximately)
DO-214AC (SMA)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
VALUE
UNIT
Power dissipation, RTHJA
很抱歉,暂时无法提供与“1SMA4745 M2G”相匹配的价格&库存,您可以联系我们找货
