RF1S70N06
RF1S70N06
    L3HARRIS
    TO-262-3
    MOSFET N-CH 60V 70A I2PAK
RF1S70N06 数据手册
RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Data Sheet 70A, 60V, 0.014 Ohm, N-Channel Power MOSFETs These are N-Channel power MOSFETs manufactured using the MegaFET process. This process, which uses feature sizes approaching those of LSI circuits, gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers and relay drivers. These transistors can be operated directly from integrated circuits. Formerly developmental type TA78440. Ordering Information PART NUMBER PACKAGE BRAND RFG70N06 TO-247 RFG70N06 RFP70N06 TO-220AB RFP70N06 RF1S70N06 TO-262AA F1S70N06 RF1S70N06SM TO-263AB F1S70N06 February 2005 Features • 70A, 60V • rDS(on) = 0.014Ω • Temperature Compensated PSPICE® Model • Peak Current vs Pulse Width Curve • UIS Rating Curve (Single Pulse) • 175oC Operating Temperature • Related Literature - TB334 “Guidelines for Soldering Surface Mount Components to PC Boards” Symbol D G S NOTE: When ordering use the entire part number. Add the suffix 9A to obtain the TO-263AB variant in tape and reel, e.g. RF1S70N06SM9A. Packaging JEDEC STYLE TO-247 JEDEC TO-263AB SOURCE DRAIN GATE DRAIN (BOTTOM SIDE METAL) DRAIN (FLANGE) GATE SOURCE JEDEC TO-262AA JEDEC TO-220AB DRAIN (FLANGE) ©2005 Fairchild Semiconductor Corporation SOURCE DRAIN GATE DRAIN (FLANGE) SOURCE DRAIN GATE RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Absolute Maximum Ratings TC = 25oC, Unless Otherwise Specified RFG70N06, RFP70N06 RF1S70N06, RF1S70N06SM 60 60 70 Refer to Peak Current Curve ±20 Refer to UIS Curve 150 1.0 -55 to 175 Drain to Source Voltage (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VDSS Drain to Gate Voltage (RGS = 20kΩ) (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . VDGR Continuous Drain Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ID Pulsed Drain Current (Note 3) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .IDM Gate to Source Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VGS Single Pulse Avalanche Rating . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . EAS Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . PD Linear Derating Factor . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Operating and Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . TJ, TSTG Maximum Temperature for Soldering Leads at 0.063in (1.6mm) from Case for 10s. . . . . . . . . . . . . . . . . . . . . . . . . .TL Package Body for 10s, See Techbrief 334 . . . . . . . . . . . . . . . . . . . . . . . . . . Tpkg UNITS V V A V A W W/oC oC oC oC 300 260 CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. TJ = 25oC to 150oC. Electrical Specifications TC = 25oC, Unless Otherwise Specified PARAMETER SYMBOL TEST CONDITIONS MIN TYP MAX UNITS V Drain to Source Breakdown Voltage BVDSS ID = 250µA, VGS = 0V (Figure 11) 60 - - Gate Threshold Voltage VGS(TH) VGS = VDS, ID = 250µA (Figure 10) 2 - 4 V VDS = 60V, VGS = 0V - - 1 µA VDS = 0.8 x Rated BVDSS, TC = 150oC - - 25 µA VGS = ±20V - - ±100 nA ID = 70A, VGS = 10V (Figure 9) - - 0.014 Ω VDD = 30V, ID ≈ 70A, RL = 0.43Ω, VGS = 10V, RGS = 2.5Ω (Figure 13) - - 190 ns - 10 - ns tr - 137 - ns td(OFF) - 32 - ns tf - 24 - ns t(OFF) - - 73 ns - 120 156 nC - 65 85 nC - 5.0 6.5 nC - 2250 - pF - 792 - pF - 206 - pF Zero Gate Voltage Drain Current IDSS Gate to Source Leakage Current IGSS Drain to Source On Resistance (Note 2) rDS(ON) Turn-On Time t(ON) Turn-On Delay Time td(ON) Rise Time Turn-Off Delay Time Fall Time Turn-Off Time Qg(TOT) VGS = 0V to 20V Gate Charge at 10V Qg(10) VGS = 0V to 10V Threshold Gate Charge Qg(TH) VGS = 0V to 2V Total Gate Charge Input Capacitance CISS Output Capacitance COSS Reverse Transfer Capacitance CRSS Thermal Resistance, Junction to Case RθJC Thermal Resistance, Junction to Ambient RθJA VDD = 48V, ID = 70A, RL = 0.68Ω Ig(REF) = 2.2mA (Figure 13) VDS = 25V, VGS = 0V, f = 1MHz (Figure 12) - - 1.0 oC/W TO-220 and TO-263 - - 62 oC/W TO-247 - - 30 oC/W MIN TYP MAX UNITS ISD = 70A - 1.5 V ISD = 70A, dISD/dt = 100A/µs - 52 ns Source to Drain Diode Specifications PARAMETER Source to Drain Diode Voltage SYMBOL VSD Reverse Recovery Time trr TEST CONDITIONS NOTES: 2. Pulse test: pulse width ≤300ms, duty cycle ≤2%. 3. Repetitive rating: pulse width is limited by maximum junction temperature. See Transient Thermal Impedance curve (Figure 3) and Peak Current Capability Curve (Figure 5). ©2005 Fairchild Semiconductor Corporation RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Typical Performance Curves TC = 25oC, Unless Otherwise Specified 80 70 1.0 ID, DRAIN CURRENT (A) POWER DISSIPATION MULTIPLIER 1.2 0.8 0.6 0.4 0.2 60 50 40 30 20 10 0 25 0 0 25 150 50 75 100 125 TC , CASE TEMPERATURE (oC) 175 50 75 100 125 150 175 TC, CASE TEMPERATURE (oC) FIGURE 1. NORMALIZED POWER DISSIPATION vs CASE TEMPERATURE FIGURE 2. MAXIMUM CONTINUOUS DRAIN CURRENT vs CASE TEMPERATURE 1 THERMAL IMPEDANCE Zθ JC, NORMALIZED 0.5 0.2 0.1 PDM 0.1 0.05 t1 t2 NOTES: DUTY FACTOR: D = t1/t2 PEAK TJ = PDM x Zθ JC x Rθ JC + TC 0.02 0.01 SINGLE PULSE 0.01 10-5 10-4 10-3 10-2 10-1 100 101 t, RECTANGULAR PULSE DURATION (s) FIGURE 3. NORMALIZED MAXIMUM TRANSIENT THERMAL IMPEDANCE 1000 100µs 100 1ms OPERATION IN THIS AREA MAY BE LIMITED BY rDS(ON) 10 10ms TC = 25oC TJ = MAX RATED SINGLE PULSE 1 1 10 VDS, DRAIN TO SOURCE VOLTAGE (V) FIGURE 4. FORWARD BIAS SAFE OPERATING AREA ©2005 Fairchild Semiconductor Corporation 100 IDM, PEAK CURRENT (A) ID, DRAIN CURRENT (A) 500 TC = 25oC FOR TEMPERATURES ABOVE 25oC DERATE PEAK CURRENT AS FOLLOWS:  175 – T C I = I25  ---------------------- 150   VGS = 10V 100 TRANSCONDUCTANCE MAY LIMIT CURRENT IN THIS REGION 50 10-5 10-4 10-3 10-2 10-1 t, PULSE WIDTH (s) 100 101 FIGURE 5. PEAK CURRENT CAPABILITY RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM IAS, AVALANCHE CURRENT (A) 300 TC = 25oC, Unless Otherwise Specified (Continued) If R = 0 tAV = (L)(IAS)/(1.3*RATED BVDSS - VDD) If R ≠ 0 tAV = (L/R) ln [(IAS*R)/(1.3*RATED BVDSS-VDD) +1] 100 STARTING TJ = 25oC STARTING TJ = 150oC 200 VGS = 10V VGS = 20V ID, DRAIN CURRENT (A) Typical Performance Curves VGS = 8V VGS = 7V 160 PULSE DURATION = 80µs DUTY CYCLE = 0.5% MAX TC = 25oC 120 80 VGS = 6V 40 VGS = 5V VGS = 4.5V 10 0.01 1 0.1 tAV, TIME IN AVALANCHE (ms) 0 10 4 1 2 3 VDS, DRAIN TO SOURCE VOLTAGE (V) 0 5 NOTE: Refer to Fairchild Application Notes AN9321 and AN9322. 200 PULSE DURATION = 80µs DUTY CYCLE = 0.5% MAX VDD = 15V 160 2.5 -55oC 25oC 175oC 120 80 40 2 4 6 8 VGS, GATE TO SOURCE VOLTAGE (V) 1.5 1 0.5 0 -80 10 NORMALIZED DRAIN TO SOURCE BREAKDOWN VOLTAGE 1.0 0.5 0 40 80 120 160 TJ, JUNCTION TEMPERATURE (oC) 200 FIGURE 10. NORMALIZED GATE THRESHOLD VOLTAGE vs JUNCTION TEMPERATURE ©2005 Fairchild Semiconductor Corporation 40 80 120 160 200 2.0 1.5 -40 0 FIGURE 9. NORMALIZED DRAIN TO SOURCE ON RESISTANCE vs JUNCTION TEMPERATURE VGS = VDS, ID = 250µA 0 -80 -40 TJ, JUNCTION TEMPERATURE (oC) FIGURE 8. TRANSFER CHARACTERISTICS 2.0 PULSE DURATION = 250µs DUTY CYCLE = 0.5% MAX VGS = 10V, ID = 70A 2 0 0 NORMALIZED GATE THRESHOLD VOLTAGE FIGURE 7. SATURATION CHARACTERISTICS NORMALIZED DRAIN TO SOURCE ON RESISTANCE IDS(ON), DRAIN TO SOURCE CURRENT (A) FIGURE 6. UNCLAMPED INDUCTIVE SWITCHING CAPABILITY ID = 250µA 1.5 1.0 0.5 0 -80 -40 0 40 80 120 160 200 TJ, JUNCTION TEMPERATURE (oC) FIGURE 11. NORMALIZED DRAIN TO SOURCE BREAKDOWN VOLTAGE vs JUNCTION TEMPERATURE RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Typical Performance Curves TC = 25oC, Unless Otherwise Specified (Continued) 60 C, CAPACITANCE (pF) 4000 CISS 3000 2000 COSS 1000 CRSS 0 0 10 VDD = BVDSS VDD = BVDSS 45 7.5 RL = 0.86Ω IG(REF) = 2.2mA VGS = 10V 30 5 0.75 BVDSS 0.50 BVDSS 0.25 BVDSS 15 2.5 0 0 I 20 G(REF) IG(ACT) 25 5 10 15 20 VDS, DRAIN TO SOURCE VOLTAGE (V) VGS, GATE TO SOURCE VOLTAGE (V) VGS = 0V, f = 1MHz CISS = CGS + CGD CRSS = CGD COSS ≈ CDS + CGS VDS, DRAIN TO SOURCE VOLTAGE (V) 5000 t, TIME (µs) I 80 G(REF) IG(ACT) NOTE: Refer to Fairchild Application Notes AN7254 and AN7260. FIGURE 12. CAPACITANCE vs DRAIN TO SOURCE VOLTAGE FIGURE 13. NORMALIZED SWITCHING WAVEFORMS FOR CONSTANT GATE CURRENT Test Circuits and Waveforms VDS BVDSS L tP VARY tP TO OBTAIN REQUIRED PEAK IAS + RG VDS IAS VDD VDD - VGS DUT tP 0V IAS 0 0.01Ω tAV FIGURE 14. UNCLAMPED ENERGY TEST CIRCUIT FIGURE 15. UNCLAMPED ENERGY WAVEFORMS tON tOFF td(ON) VDS td(OFF) tr VDS tf 90% 90% RL VGS + DUT RGS VGS - VDD 90% VGS 0 FIGURE 16. SWITCHING TIME TEST CIRCUIT ©2005 Fairchild Semiconductor Corporation 10% 10% 0 10% 50% 50% PULSE WIDTH FIGURE 17. SWITCHING WAVEFORMS RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Test Circuits and Waveforms (Continued) VDS VDD RL Qg(TOT) VDS VGS = 20V VGS Qg(10) + VDD DUT Ig(REF) VGS = 10V VGS - VGS = 2V 0 Qg(TH) Ig(REF) 0 FIGURE 18. GATE CHARGE TEST CIRCUIT ©2005 Fairchild Semiconductor Corporation FIGURE 19. GATE CHARGE WAVEFORM RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM PSPICE Electrical Model .SUBCKT RFG70N06 2 1 3 ; rev 3/20/92 CA 12 8 5.56e-9 CB 15 14 5.30e-9 CIN 6 8 2.63e-9 RLDRAIN DPLCAP 10 LDRAIN DBODY 7 5 DBDMOD DBREAK 5 11 DBKMOD DPLCAP 10 5 DPLCAPMOD RSCL2 5 51 6 8 RLGATE GATE 1 9 LDRAIN 2 5 1e-9 LGATE 1 9 3.10e-9 LSOURCE 3 7 1.82e-9 MOS1 16 6 8 8 MOSMOD M = 0.99 MOS2 16 21 8 8 MOSMOD M = 0.01 RBREAK 17 18 RBKMOD 1 RDRAIN 50 16 RDSMOD 4.66e-3 RLDRAIN 2 5 10 RGATE 9 20 1.21 RLGATE 1 9 31 RIN 6 8 1e9 RSOURCE 8 7 RDSMOD 3.92e-3 RLSOURCE 3 7 18.2 RVTO 18 19 RVTOMOD 1 18 8 - LGATE 11 16 EVTO 20 + ESCL RDRAIN + RGATE S1A S1B S2A S2B DBREAK 50 ESG VTO + 21 6 DBODY + EBREAK 17 18 - MOS2 MOS1 RIN CIN RLSOURCE 8 S1A 12 2 DRAIN RSCL1 + 51 EBREAK 11 7 17 18 65.18 EDS 14 8 5 8 1 EGS 13 8 6 8 1 ESG 6 10 6 8 1 EVTO 20 6 18 8 1 IT 8 17 1 5 RSOURCE 7 3 SOURCE LSOURCE S2A 13 8 S1B RBREAK 15 14 13 17 18 S2B 13 CA RVTO CB + 6 8 EGS - EDS - IT 14 + 19 VBAT + 5 8 6 12 13 8 S1AMOD 13 12 13 8 S1BMOD 6 15 14 13 S2AMOD 13 15 14 13 S2BMOD VBAT 8 19 DC 1 VTO 21 6 0.605 .MODEL DBDMOD D (IS = 7.91e-12 RS = 3.87e-3 TRS1 = 2.71e-3 TRS2 = 2.50e-7 CJO = 4.84e-9 TT = 4.51e-8) .MODEL DBKMOD D (RS = 3.9e-2 TRS1 =1.05e-4 TRS2 = 3.11e-5) .MODEL DPLCAPMOD D (CJO = 4.8e-9 IS = 1e-30 N = 10) .MODEL MOSMOD NMOS (VTO = 3.46 KP = 47 IS = 1e-30 N = 10 TOX = 1 L = 1u W = 1u) .MODEL RBKMOD RES (TC1 = 8.46e-4 TC2 = -8.48e-7) .MODEL RDSMOD RES (TC1 = 2.23e-3 TC2 = 6.56e-6) .MODEL RVTOMOD RES (TC1 = -3.29e-3 TC2 = 3.49e-7) .MODEL S1AMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = -8.35 VOFF= -6.35) .MODEL S1BMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = -6.35 VOFF= -8.35) .MODEL S2AMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = -2.0 VOFF= 3.0) .MODEL S2BMOD VSWITCH (RON = 1e-5 ROFF = 0.1 VON = 3.0 VOFF= -2.0) .ENDS NOTE: For further discussion of the PSPICE model, consult A New PSPICE Sub-circuit for the Power MOSFET Featuring Global Temperature Options; written by William J. Hepp and C. Frank Wheatley. ©2005 Fairchild Semiconductor Corporation RFG70N06, RFP70N06, RF1S70N06, RF1S70N06SM Rev. D TRADEMARKS The following are registered and unregistered trademarks Fairchild Semiconductor owns or is authorized to use and is not intended to be an exhaustive list of all such trademarks. ACEx™ FAST ActiveArray™ FASTr™ Bottomless™ FPS™ CoolFET™ FRFET™ CROSSVOLT™ GlobalOptoisolator™ DOME™ GTO™ EcoSPARK™ HiSeC™ E2CMOS™ I2C™ EnSigna™ i-Lo™ FACT™ ImpliedDisconnect™ FACT Quiet Series™ IntelliMAX™ ISOPLANAR™ LittleFET™ MICROCOUPLER™ MicroFET™ MicroPak™ MICROWIRE™ MSX™ MSXPro™ OCX™ OCXPro™  Across the board. Around the world.™ OPTOLOGIC OPTOPLANAR™ The Power Franchise PACMAN™ Programmable Active Droop™ POP™ Power247™ PowerEdge™ PowerSaver™ PowerTrench QFET QS™ QT Optoelectronics™ Quiet Series™ RapidConfigure™ RapidConnect™ µSerDes™ SILENT SWITCHER SMART START™ SPM™ Stealth™ SuperFET™ SuperSOT™-3 SuperSOT™-6 SuperSOT™-8 SyncFET™ TinyLogic TINYOPTO™ TruTranslation™ UHC™ UltraFET UniFET™ VCX™ DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used herein: 2. A critical component is any component of a life 1. Life support devices or systems are devices or support device or system whose failure to perform can systems which, (a) are intended for surgical implant into be reasonably expected to cause the failure of the life the body, or (b) support or sustain life, or (c) whose support device or system, or to affect its safety or failure to perform when properly used in accordance with instructions for use provided in the labeling, can be effectiveness. reasonably expected to result in significant injury to the user. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition Advance Information Formative or In Design This datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary First Production This datasheet contains preliminary data, and supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. No Identification Needed Full Production This datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice in order to improve design. Obsolete Not In Production This datasheet contains specifications on a product that has been discontinued by Fairchild semiconductor. The datasheet is printed for reference information only. Rev. I15
RF1S70N06 价格&库存
很抱歉,暂时无法提供与“RF1S70N06”相匹配的价格&库存,您可以联系我们找货
