TSM80N08
75V N-Channel Power MOSFET
TO-220
PRODUCT SUMMARY
Pin Definition:
1. Gate
2. Drain
3. Source
RDS(on)(mΩ)
ID (A)
75
8 @ VGS =10V
80
Block Diagram
Advanced Trench Technology
Low RDS(ON) 8mΩ (Max.)
Low gate charge typical @ 91.5nC (Typ.)
Low Crss typical @ 203pF (Typ.)
en
de
d
Features
VDS (V)
Ordering Information
Part No.
Package
Packing
TSM80N08CZ C0G
TO-220
50pcs / Tube
mm
Note: “G” denotes for Halogen Free
N-Channel MOSFET
Absolute Maximum Rating (Ta = 25oC unless otherwise noted)
Parameter
Gate-Source Voltage
eco
Drain-Source Voltage
No
tR
Continuous Drain Current
TC=25°C
TC=70°C
TA=25°C
TA=70°C
Symbol
Limit
Unit
VDS
75
V
VGS
±25
80
60
12
9
320
V
35
183
113.6
72.7
2
1.3
A
mJ
TSTG
TJ
-55 to +150
-55 to +150
°C
°C
Symbol
Limit
Unit
RӨJC
RӨJA
1.1
62.5
°C/W
°C/W
ID
Drain Current-Pulsed Note 1
IDM
Avalanche Current, L=0.3mH
Avalanche Energy, L=0.3mH
IAS
EAS
Maximum Power Dissipation
TC=25°C
TC=70°C
TA=25°C
TA=70°C
Storage Temperature Range
Operating Junction Temperature Range
PD
A
A
W
* Limited by maximum junction temperature
Thermal Performance
Parameter
Thermal Resistance - Junction to Case
Thermal Resistance - Junction to Ambient
Notes: Surface mounted on FR4 board t ≤ 10sec
Document Number: DS_P0000146
1
Version: C15
TSM80N08
Electrical Specifications (Ta = 25oC unless otherwise noted)
Parameter
Conditions
Symbol
Min
Typ
Max
Unit
Static
VGS = 0V, ID = 250uA
BVDSS
75
V
Drain-Source On-State Resistance
VGS = 10V, ID = 40A
RDS(ON)
6
8
mΩ
Gate Threshold Voltage
VDS = VGS, ID = 250uA
VGS(TH)
2
3
4
V
Zero Gate Voltage Drain Current
VDS = 60V, VGS = 0V
IDSS
1
uA
Gate Body Leakage
VGS = ±25V, VDS = 0V
IGSS
±100
nA
Dynamic
VDS = 30V, ID = 40A,
Gate-Source Charge
VGS = 10V
Gate-Drain Charge
Input Capacitance
Reverse Transfer Capacitance
f = 1.0MHz
Turn-On Rise Time
VGS = 10V, VDS = 30V,
Turn-Off Delay Time
ID = 1A, RG = 3.3Ω
Turn-Off Fall Time
e co
Drain-Source Diode Characteristics and Maximum Rating
Drain-Source Diode Forward
VGS=0V, IS=20A
Voltage
Reverse Recovery Time
34
Qgd
19.9
Ciss
3905
Coss
371
Crss
203
td(on)
21.5
tr
11
td(off)
73
tf
66
VSD
0.8
1.3
nC
pF
nS
V
IS = 40A, TJ=25 °C
tfr
36
nS
dI/dt = 100A/us
Qfr
45
nC
tR
Reverse Recovery Charge
91.5
Qgs
mm
Switching
Turn-On Delay Time
en
VDS = 30V, VGS = 0V,
Output Capacitance
Qg
de
Total Gate Charge
d
Drain-Source Breakdown Voltage
No
Notes:
1. Pulse Test: Pulse Width ≤ 300μs, Duty Cycle ≤ 2%.
2. RθJA is the sum of the junction-to-case and case-to-ambient thermal resistance where the case thermal
reference is defined as the solder mounting surface of the drain pins. Rθ JC is guaranteed by design while Rθ CA
is determined by the user's board design. RθJA shown below for single device operation on FR-4 in still air
2
Version: C15
TSM80N08
Electrical Characteristics Curve (Ta = 25°C, unless otherwise noted)
en
de
d
Output Characteristics
Drain-Source On Resistance
tR
e co
mm
Gate Source On Resistance
Source-Drain Diode Forward Voltage
No
Drain-Source On-Resistance
3
Version: C15
TSM80N08
Drain Current vs. Junction Temperature
en
de
d
Power Derating
Transient Thermal Impedance
tR
e co
mm
Safe Operation Area
Gate Charge
No
Capacitance
4
Version: C15
TSM80N08
TO-220 Mechanical Drawing
d
No
tR
e co
mm
en
A
B
C
D
E
F
G
H
J
K
L
M
N
O
P
de
DIM
TO-220 DIMENSION
MILLIMETERS
INCHES
MIN
MAX
MIN
MAX
10.000
10.500
0.394
0.413
3.740
3.910
0.147
0.154
2.440
2.940
0.096
0.116
6.350
0.250
0.381
1.106
0.015
0.040
2.345
2.715
0.092
0.058
4.690
5.430
0.092
0.107
12.700
14.732
0.500
0.581
14.224
16.510
0.560
0.650
3.556
4.826
0.140
0.190
0.508
1.397
0.020
0.055
27.700
29.620
1.060
1.230
2.032
2.921
0.080
0.115
0.255
0.610
0.010
0.024
5.842
6.858
0.230
0.270
5
Version: C15
TSM80N08
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: C15
很抱歉,暂时无法提供与“TSM80N08CZ C0G”相匹配的价格&库存,您可以联系我们找货
