TSM3N100CP
Taiwan Semiconductor
N-Channel Power MOSFET
1000V, 2.5A, 6Ω
FEATURES
KEY PERFORMANCE PARAMETERS
100% avalanche tested
Advanced planar process
Compliant to RoHS Directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VDS
1000
V
RDS(on) (max)
6
Ω
Qg
19
nC
AC/DC LED Lighting
Power Supply
Power Meter
en
de
d
APPLICATIONS
mm
TO-252 (DPAK)
Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020
PARAMETER
Drain-Source Voltage
TC = 25°C
No
tR
Gate-Source Voltage
eco
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
Continuous Drain Current
Pulsed Drain Current
(Note 1)
SYMBOL
Limit
UNIT
VDS
1000
V
VGS
±30
V
ID
TC = 100°C
(Note 2)
2.5
1.57
A
IDM
10
A
PDTOT
99
W
Single Pulse Avalanche Energy
(Note 3)
EAS
mJ
Single Pulse Avalanche Current
(Note 3)
IAS
1.4
A
TJ, TSTG
- 55 to +150
°C
SYMBOL
Limit
UNIT
Junction to Case Thermal Resistance
RӨJC
1.26
°C/W
Junction to Ambient Thermal Resistance
RӨJA
62
°C/W
Total Power Dissipation @ TC = 25°C
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is
determined by the user’s board design. RӨJA shown below for single device operation on FR-4 PCB in still air.
1
Version: A1606
TSM3N100CP
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
VGS = 0V, ID = 250µA
BVDSS
1000
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
3.5
4.5
5.5
V
Gate Body Leakage
VGS = ±30V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = 1000V, VGS = 0V
IDSS
1
µA
RDS(on)
5.6
6
Ω
Drain-Source On-State Resistance
(Note 4)
Dynamic
VGS = 10V, ID = 1.25A
(Note 5)
Qg
VDS = 800V, ID = 2.5A,
Gate-Source Charge
Input Capacitance
VDS = 25V, VGS = 0V,
Output Capacitance
f = 1.0MHz
Gate Resistance
Switching
Turn-On Delay Time
Turn-On Rise Time
Source-Drain Diode
(Note 4)
ID = 1.25A, VGS = 10V
IS = 2.5A, VGS = 0V
tR
Forward Voltage
VDD = 500V, RG = 25Ω,
e co
Turn-Off Fall Time
Qgs
6
Qgd
10
nC
Ciss
664
Coss
40
pF
Ω
Crss
f = 1.0MHz, open drain
(Note 6)
Turn-Off Delay Time
mm
Reverse Transfer Capacitance
19
en
VGS = 10V
Gate-Drain Charge
de
Total Gate Charge
d
Drain-Source Breakdown Voltage
17
Rg
2.2
td(on)
45
tr
25
td(off)
70
tf
28
VSD
1.4
V
ns
Reverse Recovery Time
VR = 100V, IS = 2.5A
trr
378
ns
Reverse Recovery Charge
dIF/dt = 100A/μs
Qrr
1.62
μC
Notes:
Current limited by package
2.
Pulse width limited by the maximum junction temperature
3.
L = 20mH, IAS = 1.4A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C
No
1.
o
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
TSM3N100CP ROG
PACKAGE
PACKING
TO-252 (DPAK)
2,500pcs / 13” Reel
2
Version: A1606
TSM3N100CP
CHARACTERISTICS CURVES
(TC = 25°C unless otherwise noted)
de
ID, Continuous Drain Current (A)
en
VGS, Gate to Source Voltage (V)
Gate-Source Voltage vs. Gate Charge
e co
mm
On-Resistance vs. Drain Current
tR
RDS(on), Drain-Source On-Resistance (Ω)
VDS, Drain to Source Voltage (V)
d
Transfer Characteristics
Output Characteristics
Qg, Gate Charge (nC)
Source-Drain Diode Forward Current vs. Voltage
IS, Body Diode Forward Current (A)
(Normalized)
No
On-Resistance vs. Junction Temperature
VSD, Body Diode Forward Voltage (V)
TJ, Junction Temperature (°C)
3
Version: A1606
TSM3N100CP
de
en
BVDSS (Normalized)
Drain-Source Breakdown Voltage (V)
C, Capacitance (pF)
d
BVDSS vs. Junction Temperature
Capacitance vs. Drain-Source Voltage
tR
e co
mm
Maximum Safe Operating Area
No
Normalized Thermal Transient Impedance, Junction-to-Case (DPAK/IPAK)
Normalized Effective Transient
Thermal Impedance
101
SINGLE PULSE
RӨJC=1.26˚C/W
100
10-1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single pulse
10-2
10-3 -5
10
10-4
10-3
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
10-2
10-1
Square Wave Pulse Duration (s)
4
Version: A1606
TSM3N100CP
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
No
tR
e co
SUGGESTED PAD LAYOUT
mm
en
de
d
TO-252
MARKING DIAGRAM
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
5
Version: A1606
TSM3N100CP
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular
purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: A1606
