TSM089N08LCR
Taiwan Semiconductor
N-Channel Power MOSFET
80V, 67A, 8.9mΩ
FEATURES
KEY PERFORMANCE PARAMETERS
● Low RDS(ON) to minimize conductive losses
● Logic level
● Low gate charge for fast power switching
● 100% UIS and Rg tested
● Compliant to RoHS directive 2011/65/EU and in
accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VDS
80
V
RDS(on)
VGS = 10V
8.9
(max)
VGS = 4.5V
11
mΩ
Qg
45
nC
APPLICATIONS
BLDC Motor Control
Telecom power
Primary and Secondary Side Switch
PDFN56
Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
80
V
Gate-Source Voltage
VGS
±20
V
Continuous Drain Current
TC = 25°C
(Note 1)
ID
TA = 25°C
Pulsed Drain Current
(Note 2)
Single Pulse Avalanche Current
(Note 2)
Single Pulse Avalanche Energy
Total Power Dissipation
TC = 25°C
TC = 125°C
TA = 25°C
TA = 125°C
Operating Junction and Storage Temperature Range
67
12
A
IDM
268
A
IAS
EAS
36
194
A
mJ
PD
PD
83
17
2.6
0.5
W
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
1.5
°C/W
Junction to Ambient Thermal Resistance
RӨJA
48
°C/W
THERMAL PERFORMANCE
PARAMETER
Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is
determined by the user’s board design.
1
Version: A1608
TSM089N08LCR
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
Static
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
80
V
Gate Threshold Voltage
VGS = VDS, ID = 250µA
VGS(TH)
1
1.9
2.5
V
Gate-Source Leakage Current
VGS = ±20V, VDS = 0V
IGSS
±100
nA
1
100
6.4
8.9
8
11
gfs
49
Qg
90
Qg
45
Qgs
16
Qgd
23
Ciss
6119
Coss
304
Crss
116
Rg
0.5
1.5
3
td(on)
8
tr
21
td(off)
45
tf
24
VSD
1
V
VGS = 0V, VDS = 80V
Drain-Source Leakage Current
IDSS
VGS = 0V, VDS = 80V
TJ = 125°C
Drain-Source On-State Resistance
VGS = 10V, ID = 12A
(Note 3)
VGS = 4.5V, ID = 12A
Forward Transconductance
Dynamic
(Note 3)
RDS(on)
VDS = 5V, ID = 12A
µA
mΩ
S
(Note 4)
VGS = 10V, VDS = 40V,
Total Gate Charge
ID = 12A
Total Gate Charge
VGS = 4.5V, VDS = 40V,
Gate-Source Charge
ID = 12A
Gate-Drain Charge
Input Capacitance
VGS = 0V, VDS = 40V
Output Capacitance
f = 1.0MHz
Reverse Transfer Capacitance
Gate Resistance
Switching
f = 1.0MHz
nC
pF
Ω
(Note 4)
Turn-On Delay Time
Turn-On Rise Time
Turn-Off Delay Time
ID = 12A, RG = 2Ω
Turn-Off Fall Time
ns
Source-Drain Diode
Forward Voltage
(Note 3)
VGS = 0V, IS = 12A
Reverse Recovery Time
IS = 12A ,
trr
33
ns
Reverse Recovery Charge
dI/dt = 100A/μs
Qrr
35
nC
Notes:
1.
2.
3.
4.
Silicon limited current only.
L = 0.3mH, VGS = 10V, VDD = 30V, RG = 25Ω, IAS = 36A, Starting TJ = 25°C
Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%.
Switching time is essentially independent of operating temperature.
ORDERING INFORMATION
PART NO.
TSM089N08LCR RLG
PACKAGE
PACKING
PDFN56
2,500pcs / 13”Reel
2
Version: A1608
TSM089N08LCR
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
30
VGS=10V
VGS=7V
VGS=5V
VGS=4.5V
VGS=4V
24
ID, Drain Current (A)
30
18
12
6
VGS=3.5V
24
18
12
25℃
6
150℃
-55℃
2
3
4
1
3
4
5
Gate-Source Voltage vs. Gate Charge
0.012
10
VGS, Gate to Source Voltage (V)
RDS(ON), Drain-Source On-Resistance (Ω)
On-Resistance vs. Drain Current
0.01
VGS=4.5V
0.008
0.006
VGS=10V
0.004
0.002
12
18
24
30
VDS=40V
ID=12A
8
6
4
2
VGS=10V
ID=12A
1.5
1
0.5
-50
-25
50
75
60
80
100
100 125 150
On-Resistance vs. Gate-Source Voltage
RDS(on), Drain-Source On-Resistance (Ω)
On-Resistance vs. Junction Temperature
2
40
Qg, Gate Charge (nC)
(Normalized)
2
VDS, Drain to Source Voltage (V)
TJ, Junction Temperature (°C)
0.01
0.009
0.008
0.007
0.006
ID=12A
0.005
0.004
0.003
3
4
5
6
7
8
9
10
3
Version: A1608
TSM089N08LCR
BVDSS vs. Junction Temperature
BVDSS (Normalized)
Capacitance vs. Drain-Source Voltage
C, Capacitance (pF)
8000
7000
CISS
6000
5000
4000
3000
2000
CRSS
1000
COSS
ID=1mA
1.1
1
0.9
0.8
60
80
-75
-50
Maximum Safe Operating Area, Junction-to-Case
50
75
100 125 150
Source-Drain Diode Forward Current vs. Voltage
100
IS, Reverse Drain Current (A)
1000
-25
RDS(ON)
100
10
1
SINGLE PULSE
RӨJC=1.5°C/W
TC=25°C
0.1
10
25℃
150℃
1
-55℃
0.1
0.1
1
10
100
0.2
0.4
0.6
0.8
1
1.2
VSD, Body Diode Forward Voltage (V)
Normalized Thermal Transient Impedance, Junction-to-Case
Normalized Effective Transient
Thermal Impedance, ZӨJC
10
SINGLE PULSE
RӨJC=1.5°C/W
1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single
0.1
0.01
0.0001
0.001
Notes:
Duty = t1 / t2
TJ = TC + PDM x ZӨJC x RӨJC
0.01
0.1
t, Square Wave Pulse Duration (sec)
4
Version: A1608
TSM089N08LCR
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
PDFN56
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
TSC
089N08L
GYWWF
G
Y
WW
F
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
5
Version: A1608
TSM089N08LCR
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: A1608
