TSM038N03PQ33 RGG
TSM038N03PQ33 RGG
    TAIWANSEMICONDUCTOR(台湾半导体)
    WDFN8
    MOSFET N-CH 30V 78A 8PDFN
TSM038N03PQ33 RGG 数据手册
TSM038N03PQ33 Taiwan Semiconductor N-Channel Power MOSFET 30V, 78A, 3.8mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive losses PARAMETER VALUE UNIT VDS 30 V ● Low gate charge for fast power switching ● 100% UIS and Rg tested ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 RDS(on) VGS = 10V 3.8 (max) VGS = 4.5V 5.5 mΩ Qg 24 nC APPLICATIONS ● DC-DC Converters ● Battery Power Management ● ORing FET/Load Switching PDFN33 Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) SYMBOL LIMIT UNIT Drain-Source Voltage PARAMETER VDS 30 V Gate-Source Voltage VGS ±20 V Continuous Drain Current TC = 25°C (Note 1) ID TA = 25°C Pulsed Drain Current (Note 2) Single Pulse Avalanche Current (Note 2) Single Pulse Avalanche Energy Total Power Dissipation Total Power Dissipation TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range 78 19 A IDM 312 A IAS EAS 26 101 A mJ PD PD 39 7.8 2.4 0.5 W W TJ, TSTG - 55 to +150 °C SYMBOL LIMIT UNIT Junction to Case Thermal Resistance RӨJC 3.2 °C/W Junction to Ambient Thermal Resistance RӨJA 53 °C/W THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: B1610 TSM038N03PQ33 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 30 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 1.2 1.6 2.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA -- -- 1 -- -- 100 -- 3 3.8 -- 4 5.5 gfs -- 48 -- Qg -- 48 -- Qg -- 24 -- Qgs -- 6.9 -- Qgd -- 11 -- Ciss -- 2557 -- Coss -- 380 -- Crss -- 276 -- Rg 0.5 1.5 3 td(on) -- 11 -- tr -- 80 -- td(off) -- 33 -- tf -- 65 -- VSD -- -- 1 V VGS = 0V, VDS = 30V Drain-Source Leakage Current IDSS VGS = 0V, VDS = 30V TJ = 125°C Drain-Source On-State Resistance VGS = 10V, ID = 19A (Note 3) VGS = 4.5V, ID = 16A Forward Transconductance Dynamic (Note 3) RDS(on) VDS = 5V, ID = 19A µA mΩ S (Note 4) VGS = 10V, VDS = 15V, Total Gate Charge ID = 19A Total Gate Charge VGS = 4.5V, VDS = 15V, Gate-Source Charge ID = 16A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 15V Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 4) Turn-On Delay Time Turn-On Rise Time VGS = 10V, VDS = 15V, Turn-Off Delay Time ID = 19A, RG = 2Ω, Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 3) VGS = 0V, IS = 19A Reverse Recovery Time IS = 19A , trr -- 33 -- ns Reverse Recovery Charge dI/dt = 100A/μs Qrr -- 19 -- nC Notes: 1. 2. 3. 4. Silicon limited current only. L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 26A, Starting TJ = 25°C Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. Switching time is essentially independent of operating temperature. ORDERING INFORMATION PART NO. PACKAGE PACKING TSM038N03PQ33 RGG PDFN33 5,000pcs / 13” Reel 2 Version: B1610 TSM038N03PQ33 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 40 VGS=10V VGS=7V VGS=5V VGS=4.5V VGS=4V VGS=3.5V VGS=3V 32 24 ID, Drain Current (A) ID, Drain Current (A) 40 16 8 32 24 25℃ 16 8 150℃ 0 0 1 2 3 4 0 1 On-Resistance vs. Drain Current 3 4 Gate-Source Voltage vs. Gate Charge 10 0.008 VGS, Gate to Source Voltage (V) RDS(ON), Drain-Source On-Resistance (Ω) 2 VGS, Gate to Source Voltage (V) VDS, Drain to Source Voltage (V) 0.007 0.006 0.005 VGS=4.5V 0.004 0.003 VGS=10V 0.002 0.001 0 VDS=15V ID=19A 8 6 4 2 0 0 8 16 24 32 40 0 10 VGS=10V ID=19A 1.4 1.2 1 0.8 0.6 -75 -50 -25 0 25 50 75 30 40 50 100 125 150 On-Resistance vs. Gate-Source Voltage RDS(on), Drain-Source On-Resistance (Ω) On-Resistance vs. Junction Temperature 1.8 1.6 20 Qg, Gate Charge (nC) ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) -55℃ 0 0.02 0.015 0.01 0.005 ID=19A 0 2 4 6 8 10 VGS, Gate to Source Voltage (V) TJ, Junction Temperature (°C) 3 Version: B1610 TSM038N03PQ33 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) BVDSS vs. Junction Temperature BVDSS (Normalized) Drain-Source Breakdown Voltage Capacitance vs. Drain-Source Voltage C, Capacitance (pF) 3500 3000 CISS 2500 2000 1500 1000 COSS 500 CRSS 0 0 5 10 15 20 25 1.2 ID=1mA 1.1 1 0.9 0.8 -75 30 -25 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) VDS, Drain to Source Voltage (V) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 1000 100 100 10us 10 100us SINGLE PULSE RӨJC=3.2°C/W TC=25°C 1ms 10ms DC 1 0.1 1 IS, Reverse Drain Current (A) RDS(ON) ID, Drain Current (A) -50 10 10 25℃ 150℃ 1 -55℃ 0.1 100 0.2 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=3.2°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.00001 0.0001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.001 0.01 0.1 t, Square Wave Pulse Duration (sec) 4 Version: B1610 TSM038N03PQ33 Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) PDFN33 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM 038N03 YML Y = Year Code M = Month Code O =Jan P =Feb ` S =May T =Jun W =Sep X =Oct L = Lot Code (1~9, A~Z) Q =Mar U =Jul Y =Nov R =Apr V =Aug Z =Dec 5 Version: B1610 TSM038N03PQ33 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: B1610
TSM038N03PQ33 RGG 价格&库存
很抱歉,暂时无法提供与“TSM038N03PQ33 RGG”相匹配的价格&库存,您可以联系我们找货
TSM038N03PQ33 RGG
  • 5000+2.499635000+0.32441
  • 15000+2.2309515000+0.28954
库存:10881
TSM038N03PQ33 RGG
  • 1+10.588811+1.37424
  • 10+6.6382910+0.86153
  • 50+4.9097150+0.63719
  • 100+4.35177100+0.56478
  • 500+3.37017500+0.43739
库存:10881
TSM038N03PQ33 RGG
    库存:10000
