TSM15N50CI C0G
TSM15N50CI C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
    1个N沟道 耐压:500V 电流:14A
TSM15N50CI C0G 数据手册
TSM15N50 500V N-Channel Power MOSFET TO-220 ITO-220 PRODUCT SUMMARY VDS (V) RDS(on)(Ω) Pin Definition: 1. Gate 2. Drain 3. Source 500 ID (A) 0.44 @ VGS =10V 14 General Description en de d The TSM15N50 N-Channel enhancement mode Power MOSFET is produced by planar stripe DMOS technology. This advanced technology has been especially tailored to minimize on-state resistance, provide superior switching performance, and withstand high energy pulse in the avalanche and commutation mode. These devices are well suited for high efficiency switch mode power supply, electronic lamp ballast based on half bridge. Features Block Diagram ● Low RDS(ON) 0.44Ω (Max.) ● Improve dv/dt capability Ordering Information Part No. Package TO-220 TSM15N50CZ C0G TO-220 TSM15N50CI C0 TSM15N50CI C0G Packing 50pcs / Tube 50pcs / Tube eco TSM15N50CZ C0 mm ● Low gate charge typical @ 39nC (Typ.) ITO-220 50pcs / Tube ITO-220 50pcs / Tube N-Channel MOSFET Note: “G” denotes Halogen Free Product. No tR Absolute Maximum Rating (Ta = 25oC unless otherwise noted) Parameter Symbol Limit Unit Drain-Source Voltage VDS 500 V Gate-Source Voltage VGS ±30 V Continuous Drain Current(TC=25℃) ID 14 A Pulsed Drain Current * IDM 56 A dv/dt 4.5 V/ns Single Pulse Avalanche Energy (Note 2) EAS 630 mJ Avalanche Current (Repetitive) (Note 1) IAR 14 A Repetitive Avalanche Energy (Note 1) EAR 23.1 mJ TJ 150 ºC TSTG -55 to +150 Peak Diode Recovery dv/dt (Note 3) Operating Junction Temperature Storage Temperature Range * Limited by maximum junction temperature 1/10 o C Version: D1702 TSM15N50 500V N-Channel Power MOSFET Thermal Performance Parameter Thermal Resistance - Junction to Case Thermal Resistance - Junction to Ambient Notes: Surface mounted on FR4 board t ≤ 10sec Symbol TO-220 ITO-220 RӨJC 0.54 2.34 Unit o C/W RӨJA 62.5 Electrical Specifications (Tc = 25oC unless otherwise noted) Conditions Symbol Static Drain-Source On-State Resistance VGS = 10V, ID = 7.0A Gate Threshold Voltage VDS = VGS, ID = 250uA Zero Gate Voltage Drain Current VDS = 500V, VGS = 0V Gate Body Leakage VGS = ±30V, VDS = 0V Forward Transconductance VDS = 30V, ID = 7.0A Diode Forward Voltage IS = 14A, VGS = 0V b Total Gate Charge VDS = 400V, ID = 14A, Gate-Source Charge VGS = 10V Input Capacitance Output Capacitance e co Gate-Drain Charge Reverse Transfer Capacitance f = 1.0MHz tR Switching c VDS = 25V, VGS = 0V, Turn-On Delay Time VDD = 250V, ID = 14A, Turn-Off Delay Time RG = 25Ω No Turn-On Rise Time Turn-Off Fall Time Reverse Recovery Time VGS = 0V, IS = 14A, -- -- V RDS(ON) -- 0.35 0.44 Ω VGS(TH) 2.0 -- 4.0 V IDSS -- -- 1 uA IGSS -- -- ±100 nA gfs -- 10 -- S VSD -- -- 1.5 V Qg -- 39 -- Qgs -- 11 -- Qgd -- 8.6 -- Ciss -- 2263 -- Coss -- 211 -- Crss -- 6.4 -- td(on) -- 65 -- tr -- 55 -- td(off) -- 144 -- tf -- 58 -- tfr -- 381 -- nS -- uC dIF/dt = 100A/us Reverse Recovery Charge Qfr -4.4 Notes: 1. Repetitive Rating: Pulse Width Limited by Maximum Junction Temperature 2. Max Rating EAS Test Condition: VDD = 50V, IAS=14A, L=5.9mH, RG=25Ω, Starting TJ=25℃ 3. Guaranteed 100% EAS Test Condition: VDD = 50V, IAS=14A, L=1mH, RG=25Ω, Starting TJ=25℃ 4. ISD ≤14A, di/dt ≤ 200A/uS, VDD ≤ BV, Starting TJ=25℃ 5. Pulse test: pulse width ≤300uS, duty cycle ≤2% 6. b For design reference only, not subject to production testing. 7. c Switching time is essentially independent of operating temperature. 2/10 Unit 500 mm Dynamic BVDSS Max de VGS = 0V, ID = 250uA Typ en Drain-Source Breakdown Voltage Min d Parameter nC pF nS Version: D1702 TSM15N50 500V N-Channel Power MOSFET Electrical Characteristics Curve (Tc = 25oC, unless otherwise noted) Transfer Characteristics Gate Charge tR e co mm On-Resistance vs. Drain Current en de d Output Characteristics Source-Drain Diode Forward Voltage No On-Resistance vs. Junction Temperature 3/10 Version: D1702 TSM15N50 500V N-Channel Power MOSFET Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage tR e co mm Maximum Safe Operating Area en de d Drain Current vs. Case Temperature No Maximum Safe Operating Area (ITO-220) 4/10 Version: D1702 TSM15N50 500V N-Channel Power MOSFET Electrical Characteristics Curve (Ta = 25oC, unless otherwise noted) en de d Normalized Thermal Transient Impedance, Junction-to-Ambient No tR e co mm Normalized Thermal Transient Impedance, Junction-to-Ambient(ITO-220) 5/10 Version: D1702 TSM15N50 500V N-Channel Power MOSFET tR e co mm Resistive Switching Test Circuit & Waveform en de d Gate Charge Test Circuit & Waveform No EAS Test Circuit & Waveform 6/10 Version: D1702 TSM15N50 500V N-Channel Power MOSFET No tR e co mm en de d Diode Reverse Recovery Time Test Circuit & Waveform 7/10 Version: D1702 TSM15N50 500V N-Channel Power MOSFET e co mm en de d TO-220 Mechanical Drawing Unit: Millimeters G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code No TSC 15N50 GYWWF tR MARKING DIAGRAM 8/10 Version: D1702 TSM15N50 500V N-Channel Power MOSFET e co mm en de d ITO-220 Mechanical Drawing Unit: Millimeters G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code No TSC 15N50 GYWWF tR MARKING DIAGRAM 9/10 Version: D1702 TSM15N50 No tR e co mm en de d 500V N-Channel Power MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 10/10 Version: D1702
TSM15N50CI C0G 价格&库存
很抱歉,暂时无法提供与“TSM15N50CI C0G”相匹配的价格&库存,您可以联系我们找货
