TSM2N60S
Taiwan Semiconductor
N-Channel Power MOSFET
600V, 0.6A, 5Ω
FEATURES
KEY PERFORMANCE PARAMETERS
Robust high voltage termination
Avalanche energy specified
Diode is characterized for use in bridge circuits
Source to Drain diode recovery time comparable to a
PARAMETER
VALUE
UNIT
VDS
600
V
RDS(on) (max)
5
Ω
Qg
13
nC
en
de
d
discrete fast recovery diode.
APPLICATION
Power Supply
Lighting
Charger
mm
SOT-223
eco
Notes: MSL 3 (Moisture Sensitivity Level) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
No
tR
Drain-Source Voltage
Gate-Source Voltage
Continuous Drain Current
Pulsed Drain Current
TC = 25°C
(Note 1)
TC = 100°C
(Note 2)
Total Power Dissipation @ TC = 25°C
SYMBOL
LIMIT
UNIT
VDS
600
V
VGS
±30
V
ID
0.6
A
0.36
IDM
1.5
A
PDTOT
2.5
W
Single Pulsed Avalanche Energy
(Note 3)
EAS
62
mJ
Single Pulsed Avalanche Current
(Note 3)
IAS
2.5
A
TJ
150
°C
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
Junction to Case Thermal Resistance
RӨJC
15
°C/W
Junction to Ambient Thermal Resistance
RӨJA
55.8
°C/W
Operating Junction Temperature
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB with minimum recommended footprint in still air
Document Number: DS_P0000066
1
Version: C15
TSM2N60S
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
MIN
TYP
MAX
UNIT
VGS = 0V, ID = 250µA
BVDSS
600
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
2
4
V
Gate Body Leakage
VGS =±30V, VDS =0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS =600V, VGS =0V
IDSS
1
µA
Drain-Source On-State Resistance
VGS =10V, ID =0.6A
RDS(ON)
3.6
5
Ω
Forward Transconductance
VDS = 10V, ID = 0.2A
gfs
0.8
S
VDS =400V, ID =0.6A,
Dynamic
(Note 5)
Total Gate Charge
Gate-Source Charge
Gate-Drain Charge
Input Capacitance
VDS =25V, VGS =0V,
Reverse Transfer Capacitance
Switching
f =1.0MHz
(Note 6)
Turn-On Delay Time
VGS =10V, ID =0.6A,
Turn-Off Delay Time
VDD =300V, RG =18Ω,
Source-Drain Diode
Notes:
13
Qgs
2
Qgd
6
Ciss
435
Coss
56
Crss
9.2
td(on)
12
tr
21
td(off)
30
tf
24
VSD
0.85
1.15
nC
pF
ns
(Note 4)
IS = 0.6A, VGS = 0V
V
tR
Forward On Voltage
e co
Turn-On Rise Time
Turn-Off Fall Time
mm
Output Capacitance
Qg
en
VGS = 10V
d
Drain-Source Breakdown Voltage
de
Static
CONDITIONS
(Note 4)
Current limited by package
2.
Pulse width limited by the maximum junction temperature
3.
L = 20mH, IAS = 2.5A, VDD = 50V, RG = 25Ω, Starting TJ = 25°C
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
No
1.
2
Version: C15
TSM2N60S
ORDERING INFORMATION
PART NO.
TSM2N60SCW RPG
PACKAGE
PACKING
SOT-223
2,500pcs / 13” Reel
No
tR
e co
mm
en
de
d
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: C15
TSM2N60S
CHARACTERISTICS CURVES
(TC = 25°C unless otherwise noted)
Transfer Characteristics
en
de
d
Output Characteristics
Gate Charge
tR
e co
mm
On-Resistance vs. Drain Current
Source-Drain Diode Forward Voltage
No
On-Resistance vs. Junction Temperature
4
Version: C15
TSM2N60S
(Tc = 25°C unless otherwise noted)
Threshold Voltage
en
de
d
On-Resistance vs. Gate-Source Voltage
tR
e co
mm
Maximum Safe Operating Area
No
Normalized Thermal Transient Impedance, Junction-to-Ambient
5
Version: C15
TSM2N60S
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
en
de
d
SOT-223
tR
e co
mm
SUGGESTED PAD LAYOUT
No
MARKING DIAGRAM
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
6
Version: C15
TSM2N60S
No
tR
e co
mm
en
de
d
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: C15
很抱歉,暂时无法提供与“TSM2N60SCW RPG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 5000+5.941145000+0.76796
