BZT52C2V7K - BZT52C75K
Taiwan Semiconductor
200mW 5% Zener Diodes
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 2.7V to 75V
VZ Tolerance Selection of ± 5%
Surface device type mounting
Moisture sensitivity level: level 1, per J-STD-020
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
PARAMETER
VALUE
UNIT
VZ
2.7-75
V
Test current IZT
5
mA
PD
200
mW
TJ Max.
150
°C
APPLICATIONS
Package
SOD-523F
Configuration
Single die
● Constant Voltage control
MECHANICAL DATA
● Case: SOD-523F
● Molding compound: UL flammability classification
rating 94V-0
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Meet JESD 201 class 1A whisker test
● Polarity: Indicated by cathode band
● Weight: 1.47 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Power dissipation
SYMBOL
VALUE
UNIT
PD
200
mW
Junction temperature range
TJ
-65 ~ 150
°C
Storage temperature range
TSTG
-65 ~ 150
°C
SYMBOL
TYP
UNIT
RӨJA
625
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version: F1806
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART
MARKING
NUMBER
CODE
VZ @ IZT
TEST
REGULAR
TEST
LEAKAGE
CURRENT
IMPEDANCE
CURRENT
CURRENT
ZZK @ IZK
IZK
IR @ V R
mA
IZT
V
mA
Min.
Nom.
Max.
ZZT @ IZT
Ω
Ω
Max.
Max.
µA
V
Max.
BZT52C2V7K
A8
2.5
2.7
2.9
5
100
1000
1
120
1
BZT52C3V0K
B8
2.8
3
3.2
5
100
1000
1
50
1
BZT52C3V3K
C8
3.1
3.3
3.5
5
95
1000
1
BZT52C3V6K
D8
3.4
3.6
3.8
5
90
1000
1
10
1
BZT52C3V9K
E8
3.7
3.9
4.1
5
90
1000
1
5
1
BZT52C4V3K
F8
4
4.3
4.6
5
90
1000
1
5
1
BZT52C4V7K
G8
4.4
4.7
5
5
80
800
1
2
1
BZT52C5V1K
H8
4.8
5.1
5.4
5
60
500
1
2
1.5
BZT52C5V6K
I8
5.2
5.6
6
5
40
200
1
1
2.5
BZT52C6V2K
J8
5.8
6.2
6.6
5
10
100
1
1
3
BZT52C6V8K
K8
6.4
6.8
7.2
5
15
160
1
0.5
3.5
BZT52C7V5K
L8
7
7.5
7.9
5
15
160
1
0.5
4
BZT52C8V2K
M8
7.7
8.2
8.7
5
15
160
1
0.5
5
BZT52C9V1K
N8
8.5
9.1
9.6
5
15
160
1
0.5
6
BZT52C10K
O8
9.4
10
10.6
5
1
0.1
7
BZT52C11K
P8
10.4
11
11.6
5
1
0.1
8
BZT52C12K
Q8
11.4
12
12.7
5
25
80
1
0.1
9
BZT52C13K
R8
12.4
13
14.1
5
30
80
1
0.1
10
BZT52C15K
S8
14.3
15
15.8
5
30
80
1
0.1
11
BZT52C16K
T8
15.3
16
17.1
5
40
80
1
0.1
12
BZT52C18K
U8
16.8
18
19.1
5
45
80
1
0.1
13
BZT52C20K
V8
18.8
5
55
100
1
0.1
15
BZT52C22K
W8
20.8
22
23.3
5
55
100
1
0.1
17
BZT52C24K
X8
22.8
24
25.6
5
70
120
1
0.1
19
BZT52C27K
Y8
25.1
27
28.9
5
80
300
1
0.1
21
BZT52C30K
Z8
28
30
32
5
80
300
1
0.1
23
BZT52C33K
A9
31
33
35
5
80
300
1
0.1
25
BZT52C36K
B9
34
36
38
5
90
500
1
0.1
27
BZT52C39K
C9
37
39
41
5
130
500
1
2
30
BZT52C43K
D9
40
43
46
5
150
500
1
2
33
BZT52C47K
E9
44
47
50
5
170
500
1
2
36
BZT52C51K
F9
48
51
54
5
180
500
1
1
39
BZT52C56K
G9
52
56
60
5
200
500
1
1
43
BZT52C62K
H9
58
62
66
5
215
500
1
0.2
47
BZT52C68K
I9
64
68
72
5
240
500
1
0.2
52
BZT52C75K
J9
70
75
79
5
255
500
1
0.2
57
2
Version: F1806
Notes:
1. The Zener Voltage (VZ) is tested under pulse condition of 30ms
2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5%
ORDERING INFORMATION
ORDERING CODE
(Note 1, 2)
PACKAGE
PACKING
BZT52CxxxK RK
SOD-523F
3K / 7" Reel
BZT52CxxxK RKG
SOD-523F
3K / 7" Reel
BZT52CxxxK RS
SOD-523F
8K / 7" Reel
BZT52CxxxK RSG
SOD-523F
8K / 7" Reel
Note 1: "xxx" defines voltage from 2.7V (BZT52C2V7K) to 75V (BZT52C75K)
Note 2: “G” means green compound (Halogen free)
3
Version: F1806
CHARACTERISTICS CURVES
Fig. 1 Derating Curve
Power Dissipation : PD (mW)
300
200
100
100
150
Ambient Temperature: TA(oC)
4
Version: F1806
PACKAGE OUTLINE DIMENSION
SOD-523F
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
0.70
0.90
0.028
0.035
B
1.50
1.70
0.059
0.067
C
0.25
0.40
0.010
0.016
D
1.10
1.30
0.043
0.051
E
0.50
0.77
0.020
0.030
F
0.07
0.20
0.003
0.008
SUGGEST PAD LAYOUT
DIM.
5
Unit(mm)
Unit(inch)
Typ.
Typ.
X
0.60
0.024
X1
2.30
0.091
Y
0.80
0.031
Version: F1806
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
6
Version: F1806
很抱歉,暂时无法提供与“BZT52C11K RKG”相匹配的价格&库存,您可以联系我们找货
