BZT52C15K RKG
BZT52C15K RKG
    TAIWANSEMICONDUCTOR(台半)
    SOD523(SC-79)
    DIODE ZENER 15V 200MW SOD523F
BZT52C15K RKG 数据手册
BZT52C2V7K - BZT52C75K Taiwan Semiconductor 200mW 5% Zener Diodes FEATURES ● ● ● ● ● KEY PARAMETERS Wide zener voltage range selection: 2.7V to 75V VZ Tolerance Selection of ± 5% Surface device type mounting Moisture sensitivity level: level 1, per J-STD-020 Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC PARAMETER VALUE UNIT VZ 2.7-75 V Test current IZT 5 mA PD 200 mW TJ Max. 150 °C APPLICATIONS Package SOD-523F Configuration Single die ● Constant Voltage control MECHANICAL DATA ● Case: SOD-523F ● Molding compound: UL flammability classification rating 94V-0 ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Meet JESD 201 class 1A whisker test ● Polarity: Indicated by cathode band ● Weight: 1.47 mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Power dissipation SYMBOL VALUE UNIT PD 200 mW Junction temperature range TJ -65 ~ 150 °C Storage temperature range TSTG -65 ~ 150 °C SYMBOL TYP UNIT RӨJA 625 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version: F1806 BZT52C2V7K - BZT52C75K Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE PART MARKING NUMBER CODE VZ @ IZT TEST REGULAR TEST LEAKAGE CURRENT IMPEDANCE CURRENT CURRENT ZZK @ IZK IZK IR @ V R mA IZT V mA Min. Nom. Max. ZZT @ IZT Ω Ω Max. Max. µA V Max. BZT52C2V7K A8 2.5 2.7 2.9 5 100 1000 1 120 1 BZT52C3V0K B8 2.8 3 3.2 5 100 1000 1 50 1 BZT52C3V3K C8 3.1 3.3 3.5 5 95 1000 1 20 1 BZT52C3V6K D8 3.4 3.6 3.8 5 90 1000 1 10 1 BZT52C3V9K E8 3.7 3.9 4.1 5 90 1000 1 5 1 BZT52C4V3K F8 4 4.3 4.6 5 90 1000 1 5 1 BZT52C4V7K G8 4.4 4.7 5 5 80 800 1 2 1 BZT52C5V1K H8 4.8 5.1 5.4 5 60 500 1 2 1.5 BZT52C5V6K I8 5.2 5.6 6 5 40 200 1 1 2.5 BZT52C6V2K J8 5.8 6.2 6.6 5 10 100 1 1 3 BZT52C6V8K K8 6.4 6.8 7.2 5 15 160 1 0.5 3.5 BZT52C7V5K L8 7 7.5 7.9 5 15 160 1 0.5 4 BZT52C8V2K M8 7.7 8.2 8.7 5 15 160 1 0.5 5 BZT52C9V1K N8 8.5 9.1 9.6 5 15 160 1 0.5 6 BZT52C10K O8 9.4 10 10.6 5 20 160 1 0.1 7 BZT52C11K P8 10.4 11 11.6 5 20 160 1 0.1 8 BZT52C12K Q8 11.4 12 12.7 5 25 80 1 0.1 9 BZT52C13K R8 12.4 13 14.1 5 30 80 1 0.1 10 BZT52C15K S8 14.3 15 15.8 5 30 80 1 0.1 11 BZT52C16K T8 15.3 16 17.1 5 40 80 1 0.1 12 BZT52C18K U8 16.8 18 19.1 5 45 80 1 0.1 13 BZT52C20K V8 18.8 20 21.2 5 55 100 1 0.1 15 BZT52C22K W8 20.8 22 23.3 5 55 100 1 0.1 17 BZT52C24K X8 22.8 24 25.6 5 70 120 1 0.1 19 BZT52C27K Y8 25.1 27 28.9 5 80 300 1 0.1 21 BZT52C30K Z8 28 30 32 5 80 300 1 0.1 23 BZT52C33K A9 31 33 35 5 80 300 1 0.1 25 BZT52C36K B9 34 36 38 5 90 500 1 0.1 27 BZT52C39K C9 37 39 41 5 130 500 1 2 30 BZT52C43K D9 40 43 46 5 150 500 1 2 33 BZT52C47K E9 44 47 50 5 170 500 1 2 36 BZT52C51K F9 48 51 54 5 180 500 1 1 39 BZT52C56K G9 52 56 60 5 200 500 1 1 43 BZT52C62K H9 58 62 66 5 215 500 1 0.2 47 BZT52C68K I9 64 68 72 5 240 500 1 0.2 52 BZT52C75K J9 70 75 79 5 255 500 1 0.2 57 2 Version: F1806 BZT52C2V7K - BZT52C75K Taiwan Semiconductor Notes: 1. The Zener Voltage (VZ) is tested under pulse condition of 30ms 2. The device numbers listed have a standard tolerance on the normal zener voltage of ±5% ORDERING INFORMATION ORDERING CODE (Note 1, 2) PACKAGE PACKING BZT52CxxxK RK SOD-523F 3K / 7" Reel BZT52CxxxK RKG SOD-523F 3K / 7" Reel BZT52CxxxK RS SOD-523F 8K / 7" Reel BZT52CxxxK RSG SOD-523F 8K / 7" Reel Note 1: "xxx" defines voltage from 2.7V (BZT52C2V7K) to 75V (BZT52C75K) Note 2: “G” means green compound (Halogen free) 3 Version: F1806 BZT52C2V7K - BZT52C75K Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig. 1 Derating Curve Power Dissipation : PD (mW) 300 200 100 0 0 50 100 150 Ambient Temperature: TA(oC) 4 Version: F1806 BZT52C2V7K - BZT52C75K Taiwan Semiconductor PACKAGE OUTLINE DIMENSION SOD-523F DIM. Unit(mm) Unit(inch) Min Max Min Max A 0.70 0.90 0.028 0.035 B 1.50 1.70 0.059 0.067 C 0.25 0.40 0.010 0.016 D 1.10 1.30 0.043 0.051 E 0.50 0.77 0.020 0.030 F 0.07 0.20 0.003 0.008 SUGGEST PAD LAYOUT DIM. 5 Unit(mm) Unit(inch) Typ. Typ. X 0.60 0.024 X1 2.30 0.091 Y 0.80 0.031 Version: F1806 BZT52C2V7K - BZT52C75K Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: F1806
BZT52C15K RKG 价格&库存
很抱歉,暂时无法提供与“BZT52C15K RKG”相匹配的价格&库存,您可以联系我们找货
