Is Now Part of
To learn more about ON Semiconductor, please visit our website at
www.onsemi.com
Please note: As part of the Fairchild Semiconductor integration, some of the Fairchild orderable part numbers
will need to change in order to meet ON Semiconductor’s system requirements. Since the ON Semiconductor
product management systems do not have the ability to manage part nomenclature that utilizes an underscore
(_), the underscore (_) in the Fairchild part numbers will be changed to a dash (-). This document may contain
device numbers with an underscore (_). Please check the ON Semiconductor website to verify the updated
device numbers. The most current and up-to-date ordering information can be found at www.onsemi.com. Please
email any questions regarding the system integration to Fairchild_questions@onsemi.com.
ON Semiconductor and the ON Semiconductor logo are trademarks of Semiconductor Components Industries, LLC dba ON Semiconductor or its subsidiaries in the United States and/or other countries. ON Semiconductor owns the rights to a number
of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of ON Semiconductor’s product/patent coverage may be accessed at www.onsemi.com/site/pdf/Patent-Marking.pdf. ON Semiconductor reserves the right
to make changes without further notice to any products herein. ON Semiconductor makes no warranty, representation or guarantee regarding the suitability of its products for any particular purpose, nor does ON Semiconductor assume any liability
arising out of the application or use of any product or circuit, and specifically disclaims any and all liability, including without limitation special, consequential or incidental damages. Buyer is responsible for its products and applications using ON
Semiconductor products, including compliance with all laws, regulations and safety requirements or standards, regardless of any support or applications information provided by ON Semiconductor. “Typical” parameters which may be provided in ON
Semiconductor data sheets and/or specifications can and do vary in different applications and actual performance may vary over time. All operating parameters, including “Typicals” must be validated for each customer application by customer’s
technical experts. ON Semiconductor does not convey any license under its patent rights nor the rights of others. ON Semiconductor products are not designed, intended, or authorized for use as a critical component in life support systems or any FDA
Class 3 medical devices or medical devices with a same or similar classification in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use ON Semiconductor products for any such unintended
or unauthorized application, Buyer shall indemnify and hold ON Semiconductor and its officers, employees, subsidiaries, affiliates, and distributors harmless against all claims, costs, damages, and expenses, and reasonable attorney fees arising out
of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such claim alleges that ON Semiconductor was negligent regarding the design or manufacture of the part. ON Semiconductor
is an Equal Opportunity/Affirmative Action Employer. This literature is subject to all applicable copyright laws and is not for resale in any manner.
RFP12N10L
October 2013
Data Sheet
N-Channel Logic Level Power MOSFET
100 V, 12 A, 200 mΩ
Features
• 12A, 100V
These are N-Channel enhancement mode silicon gate
power field effect transistors specifically designed for use
with logic level (5V) driving sources in applications such as
programmable controllers, automotive switching and
solenoid drivers. This performance is accomplished
through a special gate oxide design which provides full
rated conduction at gate biases in the 3V to 5V range,
thereby facilitating true on-off power control directly from
logic circuit supply voltages.
• rDS(ON) = 0.200Ω
• Design Optimized for 5V Gate Drives
• Can be Driven Directly from QMOS, NMOS,
TTL Circuits
• Compatible with Automotive Drive Requirements
• SOA is Power-Dissipation Limited
• Nanosecond Switching Speeds
Formerly developmental type TA09526.
• Linear Transfer Characteristics
Ordering Information
• High Input Impedance
PART NUMBER
RFP12N10L
PACKAGE
TO-220AB
BRAND
F12N10L
• Majority Carrier Device
• Related Literature
- TB334 “Guidelines for Soldering Surface Mount
Components to PC Boards
Symbol
D
G
S
Packaging
JEDEC TO-220AB
DRAIN
(TAB)
©2005 Fairchild Semiconductor Corporation
SOURCE
DRAIN
GATE
RFP12N10L Rev. C0
RFP12N10L
Absolute Maximum Ratings
TC = 25oC, Unless Otherwise Specified
RFP12N10L
UNITS
Drain to Source Voltage (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .VDS
100
V
Drain to Gate Voltage (RGS = 1MΩ) (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VDGR
100
V
Continuous Drain Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ID
12
A
Pulsed Drain Current (Note 3) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IDM
30
A
Gate to Source Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .VGS
±10
V
Maximum Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . PD
60
W
0.48
W/oC
Operating and Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . TJ, TSTG
-55 to 150
oC
Maximum Temperature for Soldering
Leads at 0.063in (1.6mm) from Case for 10s. . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . TL
Package Body for 10s, See Techbrief 334 . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tpkg
300
260
oC
oC
Above TC = 25oC, Derate Linearly . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .
CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the
device at these or any other conditions above those indicated in the operational sections of this specification is not implied.
NOTE:
1. TJ = 25oC to 125oC.
Electrical Specifications
PARAMETER
SYMBOL
TEST CONDITIONS
MIN
TYP
MAX
UNITS
100
V
Drain to Source Breakdown Voltage
BVDSS
ID = 250µA, VGS = 0V
Gate to Threshold Voltage
VGS(TH)
VGS = VDS, ID = 250µA (Figure 7)
1
2
V
VDS = 80V
1
µA
50
µA
VGS = 10V, VDS = 0V
100
nA
ID = 12A, VGS = 5V (Figures 5, 6)
0.200
Ω
VGS = 0V, VDS = 25V, f = 1MHz
(Figure 8)
900
pF
Zero Gate Voltage Drain Current
Gate to Source Leakage Current
Drain to Source On Resistance (Note 2)
IDSS
IGSS
rDS(ON)
TC = 125oC
VGS = 0V
Input Capacitance
CISS
Output Capacitance
COSS
325
pF
Reverse-Transfer Capacitance
CRSS
170
pF
Turn-On Delay Time
td(ON)
15
50
ns
70
150
ns
td(OFF)
100
130
ns
tf
80
150
ns
2.083
oC/W
Rise Time
tr
Turn-Off Delay Time
Fall Time
Thermal Resistance Junction to Case
Rθ JC
ID = 6A, VDD = 50V, RG = 6.25Ω,
VGS = 5V
(Figures 9, 10, 11)
TO-220
Source to Drain Diode Specifications
PARAMETER
SYMBOL
Source to Drain Diode Voltage (Note 2)
Diode Reverse Recovery Time
VSD
trr
TEST CONDITIONS
MIN
TYP
MAX
UNITS
ISD = 6A
1.4
V
ISD = 4A, dISD/dt = 50A/µs
150
ns
NOTES:
2. Pulsed: pulse duration = 80µs max, duty cycle = 2%.
3. Repetitive rating: pulse width limited by maximum junction temperature.
RFP12N10L Rev. C0
RFP12N10L
Typical Performance Curves
100
1.0
ID, DRAIN CURRENT (A)
POWER DISSIPATION MULTIPLIER
1.2
0.8
0.6
0.4
ID(MAX) CONTINUOUS
10
DC OPERATION
1
60W
0.2
100
0.1
1
150
TC, CASE TEMPERATURE (oC)
10
100
VDS, DRAIN TO SOURCE VOLTAGE (V)
FIGURE 1. NORMALIZED POWER DISSIPATION vs CASE
TEMPERATURE
VG S
30
ID(ON), ON-STATE DRAIN CURRENT (A)
PULSE DURATION = 80µs
DUTY CYCLE ≤0.5%
TC = 25oC
V
= 10
5V
4V
10
3V
2V
VDS = 10V
DUTY CYCLE ≤0.5%
15
25oC
10
125oC
5
125oC
2
3
4
-40oC
5
-40oC
2
3
4
5
VGS, GATE TO SOURCE VOLTAGE (V)
FIGURE 3. SATURATION CHARACTERISTICS
FIGURE 4. TRANSFER CHARACTERISTICS
2.0
0.3
125oC
0.2
NORMALIZED DRAIN TO SOURCE
ON RESISTANCE
rDS(ON), DRAIN TO SOURCE ON
RESISTANCE (Ω)
1000
FIGURE 2. FORWARD BIAS OPERATING AREA
40
TC = 25oC
TJ = MAX RATED
OPERATION IN THIS
REGION IS LIMITED
BY rDS(ON)
25oC
-40oC
0.1
VGS = 5V
DUTY CYCLE ≤0.5%
10
15
25
30
FIGURE 5. DRAIN TO SOURCE ON RESISTANCE vs DRAIN
CURRENT
VGS = 5V, ID = 12A
DUTY CYCLE ≤0.5%
1.5
1.0
0.5
100
TJ, JUNCTION TEMPERATURE (oC)
150
FIGURE 6. NORMALIZED DRAIN TO SOURCE ON
RESISTANCE vs JUNCTION TEMPERATURE
RFP12N10L Rev. C0
RFP12N10L
NORMALIZED GATE
THRESHOLD VOLTAGE (V)
1.2
800
VDS = VGS
VGS = 0V, f = 1MHz
CISS = CGS + CGD
CRSS = CGD
COSS ≈ CDS + CGD
ID = 250µA
C, CAPACITANCE (pF)
1.3
Unless Otherwise Specified (Continued)
1.1
1.0
0.9
0.8
600
CISS
400
COSS
200
0.7
CRSS
0.6
100
40
FIGURE 7. NORMALIZED GATE THRESHOLD VOLTAGE vs
100
FIGURE 8. CAPACITANCE vs DRAIN TO SOURCE VOLTAGE
10
BVDSS
RL = 8.33Ω
IG (REF) = 0.56mA
VGS = 5V
8
GATE
VDD = BVDSS SOURCE V
= BVDSS
VOLTAGE DD
6
75
50
4
0.75BVDSS
0.50BVDSS
0.25BVDSS
DRAIN SOURCE
VOLTAGE
25
2
IG (REF)
IG (ACT)
0.5
-50
80
t, TIME (µs)
IG (REF)
IG (ACT)
NOTE: Refer to Fairchild Applications Notes AN7254 and AN7260
FIGURE 9. NORMALIZED SWITCHING WAVEFORMS FOR CONSTANT GATE CURRENT
Test Circuits and Waveforms
tON
tOFF
td(ON)
td(OFF)
tr
RL
VDS
tf
90%
90%
VDD
10%
10%
DUT
90%
RGS
VGS
VGS
FIGURE 10. SWITCHING TIME TEST CIRCUIT
10%
50%
50%
PULSE WIDTH
FIGURE 11. RESISTIVE SWITCHING WAVEFORMS
RFP12N10L Rev. C0
RFP12N10L
(Continued)
VDS
VDD
RL
Qg(TOT)
VDS
VGS = 10V
VGS
Qg(5)
VDD
DUT
IG(REF)
VGS = 5V
VGS
VGS = 1V
Qg(TH)
IG(REF)
FIGURE 12. GATE CHARGE TEST CIRCUIT
FIGURE 13. GATE CHARGE WAVEFORMS
RFP12N10L Rev. C0
RFP12N10L
TRADEMARKS
The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not
intended to be an exhaustive list of all such trademarks.
Sync-Lock™
F-PFS™
AccuPower™
FRFET®
AX-CAP®*
SM
BitSiC™
Global Power Resource
PowerTrench
GreenBridge™
PowerXS™
Build it Now™
TinyBoost®
Green FPS™
Programmable Active Droop™
CorePLUS™
TinyBuck®
Green FPS™ e-Series™
QFET
CorePOWER™
TinyCalc™
QS™
Gmax™
CROSSVOLT™
TinyLogic®
GTO™
Quiet Series™
CTL™
TINYOPTO™
IntelliMAX™
RapidConfigure™
Current Transfer Logic™
TinyPower™
ISOPLANAR™
DEUXPEED®
TinyPWM™
Dual Cool™
Marking Small Speakers Sound Louder
TinyWire™
EcoSPARK®
Saving our world, 1mW/W/kW at a time™
and Better™
TranSiC™
EfficentMax™
SignalWise™
MegaBuck™
TriFault Detect™
ESBC™
SmartMax™
MICROCOUPLER™
TRUECURRENT®*
SMART START™
MicroFET™
SerDes™
Solutions for Your Success™
MicroPak™
SPM®
MicroPak2™
Fairchild®
STEALTH™
MillerDrive™
Fairchild Semiconductor®
UHC®
SuperFET®
MotionMax™
FACT Quiet Series™
Ultra FRFET™
SuperSOT™-3
mWSaver
FACT®
UniFET™
SuperSOT™-6
OptoHiT™
FAST®
VCX™
SuperSOT™-8
OPTOLOGIC®
FastvCore™
VisualMax™
OPTOPLANAR®
SupreMOS®
FETBench™
VoltagePlus™
SyncFET™
FPS™
XS™
tm
*Trademarks of System General Corporation, used under license by Fairchild Semiconductor.
DISCLAIMER
FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE
RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY
PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS.
THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY
THEREIN, WHICH COVERS THESE PRODUCTS.
LIFE SUPPORT POLICY
FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE
EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION.
As used here in:
1. Life support devices or systems are devices or systems which, (a) are
intended for surgical implant into the body or (b) support or sustain life,
and (c) whose failure to perform when properly used in accordance with
instructions for use provided in the labeling, can be reasonably
expected to result in a significant injury of the user.
2.
A critical component in any component of a life support, device, or
system whose failure to perform can be reasonably expected to cause
the failure of the life support device or system, or to affect its safety or
effectiveness.
ANTI-COUNTERFEITING POLICY
Fairchild Semiconductor Corporation’s Anti-Counterfeiting Policy. Fairchild’s Anti-Counterfeiting Policy is also stated on our external website,
www.Fairchildsemi.com, under Sales Support.
Counterfeiting of semiconductor parts is a growing problem in the industry. All manufactures of semiconductor products are experiencing counterfeiting of their
parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed
application, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the
proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild
Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild
Distributors are genuine parts, have full traceability, meet Fairchild’s quality standards for handing and storage and provide access to Fairchild’s full range of
up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address and
warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is
committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors.
PRODUCT STATUS DEFINITIONS
Definition of Terms
Datasheet Identification
Product Status
Definition
Advance Information
Formative / In Design
Datasheet contains the design specifications for product development. Specifications
may change in any manner without notice.
Preliminary
First Production
Datasheet contains preliminary data; supplementary data will be published at a later
date. Fairchild Semiconductor reserves the right to make changes at any time without
notice to improve design.
No Identification Needed
Full Production
Datasheet contains final specifications. Fairchild Semiconductor reserves the right to
make changes at any time without notice to improve the design.
Obsolete
Not In Production
Datasheet contains specifications on a product that is discontinued by Fairchild
Semiconductor. The datasheet is for reference information only.
Rev. I66
RFP12N10L Rev. C0
ON Semiconductor owns the rights to a number of patents, trademarks, copyrights, trade secrets, and other intellectual property. A listing of ON Semiconductor’s product/patent
coverage may be accessed at www.onsemi.com/site/pdf/Patent−Marking.pdf. ON Semiconductor reserves the right to make changes without further notice to any products herein.
Buyer is responsible for its products and applications using ON Semiconductor products, including compliance with all laws, regulations and safety requirements or standards,
regardless of any support or applications information provided by ON Semiconductor. “Typical” parameters which may be provided in ON Semiconductor data sheets and/or
application by customer’s technical experts. ON Semiconductor does not convey any license under its patent rights nor the rights of others. ON Semiconductor products are not
designed, intended, or authorized for use as a critical component in life support systems or any FDA Class 3 medical devices or medical devices with a same or similar classification
in a foreign jurisdiction or any devices intended for implantation in the human body. Should Buyer purchase or use ON Semiconductor products for any such unintended or unauthorized
expenses, and reasonable attorney fees arising out of, directly or indirectly, any claim of personal injury or death associated with such unintended or unauthorized use, even if such
claim alleges that ON Semiconductor was negligent regarding the design or manufacture of the part. ON Semiconductor is an Equal Opportunity/Affirmative Action Employer. This
PUBLICATION ORDERING INFORMATION
LITERATURE FULFILLMENT:
Literature Distribution Center for ON Semiconductor
19521 E. 32nd Pkwy, Aurora, Colorado 80011 USA
Phone: 303−675−2175 or 800−344−3860 Toll Free USA/Canada
Fax: 303−675−2176 or 800−344−3867 Toll Free USA/Canada
Email: orderlit@onsemi.com
© Semiconductor Components Industries, LLC
N. American Technical Support: 800−282−9855 Toll Free
USA/Canada
Europe, Middle East and Africa Technical Support:
Phone: 421 33 790 2910
Japan Customer Focus Center
Phone: 81−3−5817−1050
www.onsemi.com
1
ON Semiconductor Website: www.onsemi.com
Order Literature: http://www.onsemi.com/orderlit
For additional information, please contact your local
Sales Representative
www.onsemi.com
