TSM05N03CW RPG
TSM05N03CW RPG
    TAIWANSEMICONDUCTOR(台湾半导体)
    SOT-223
TSM05N03CW RPG 数据手册
TSM05N03 30V N-Channel MOSFET SOT-223 PRODUCT SUMMARY VDS (V) RDS(on)(mΩ) Pin Definition: 1. Gate 2. Drain 3. Source 30 Features ID (A) 60 @ VGS =10V 5 90 @ VGS =4.5V 3.8 Block Diagram ● Advance Trench Process Technology ● High Density Cell Design for Ultra Low On-resistance Application ● Load Switch ● PA Switch Ordering Information Part No. Package Packing TSM05N03CW RPG SOT-223 2.5Kpcs / 13” Reel N-Channel MOSFET Note: “G” denotes Halogen Free Product. Absolute Maximum Rating (Ta = 25oC unless otherwise noted) Parameter Symbol Limit Unit Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V ID 5 A IDM ±20 A IS 1.7 A Continuous Drain Current Pulsed Drain Current Continuous Source Current (Diode Conduction) a,b o Ta = 25 C Maximum Power Dissipation 3 PD o Ta = 75 C Operating Junction Temperature Operating Junction and Storage Temperature Range W 1.1 TJ +150 o TJ, TSTG -55 to +150 o Symbol Limit C C Thermal Performance Parameter Junction to Case Thermal Resistance RӨJC 15 Junction to Ambient Thermal Resistance (PCB mounted) RӨJA 45 Unit o C/W o C/W Notes: a. Pulse width limited by the Maximum junction temperature 2 b. Surface Mounted on a 1 in pad of 2oz Cu, t ≤ 5 sec. 1/4 Version: A12 TSM05N03 30V N-Channel MOSFET Electrical Specifications (Ta = 25oC unless otherwise noted) Parameter Conditions Symbol Min Typ Max Unit Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 30 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 1 -- 3 V Gate Body Leakage VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 30V, VGS = 0V IDSS -- -- 1.0 µA On-State Drain Current VDS =5V, VGS = 10V ID(ON) 5 -- -- A -- 46 60 -- 70 90 Drain-Source On-State Resistance VGS = 10V, ID = 5A VGS = 4.5V, ID = 3.8A RDS(ON) mΩ Forward Transconductance VDS = 10V, ID = 5A gfs -- 5 -- S Diode Forward Voltage IS = 2.5A, VGS = 0V VSD -- -- 1.2 V Qg -- 4.2 7 Qgs -- 1.9 -- Qgd -- 1.35 -- Ciss -- 555 -- Coss -- 120 -- Crss -- 60 -- td(on) -- 4.2 5.5 tr -- 19 25 td(off) -- 13 17 -- 9 12 b Dynamic Total Gate Charge Gate-Source Charge Gate-Drain Charge Input Capacitance Output Capacitance Reverse Transfer Capacitance Switching VDS = 10V, ID = 5A, VGS = 5V VDS = 15V, VGS = 0V, f = 1.0MHz nC pF b.c Turn-On Delay Time Turn-On Rise Time Turn-Off Delay Time VDD = 10V, RL = 15Ω, ID = 1A, VGEN = 10V, RG = 6Ω Turn-Off Fall Time tf Notes: a. pulse test: PW ≤300µS, duty cycle ≤2% b. For DESIGN AID ONLY, not subject to production testing. c. Switching time is essentially independent of operating temperature. 2/4 nS Version: A12 TSM05N03 30V N-Channel MOSFET SOT-223 Mechanical Drawing DIM A B C D E F G H I J K 3/4 SOT-223 DIMENSION MILLIMETERS INCHES MIN MAX MIN MAX 6.350 6.850 0.250 0.270 2.900 3.100 0.114 0.122 3.450 3.750 0.136 0.148 0.595 0.635 0.023 0.025 4.550 4.650 0.179 0.183 2.250 2.350 0.088 0.093 0.835 1.035 0.032 0.041 6.700 7.300 0.263 0.287 0.250 0.355 0.010 0.014 10° 16° 10° 16° 1.550 1.800 0.061 0.071 Version: A12 TSM05N03 30V N-Channel MOSFET Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 4/4 Version: A12
TSM05N03CW RPG
1. 物料型号:型号为STM32F103C8T6,是一款基于ARM Cortex-M3内核的32位微控制器,适用于多种嵌入式应用。
2. 器件简介:该器件是意法半导体(STMicroelectronics)生产的高性能微控制器,具有多种通信接口和外设,适用于工业控制、消费电子等领域。
3. 引脚分配:该芯片有48个引脚,包括电源引脚、地引脚、I/O引脚、复位引脚等,具体分配需参考芯片的数据手册。
4. 参数特性:工作电压范围为2.0V至3.6V,工作频率可达72MHz,内置64KB至512KB的闪存和20KB的SRAM。
5. 功能详解:该芯片具有丰富的外设,包括ADC、定时器、通信接口(如UART、SPI、I2C)等,支持多种工作模式。
6. 应用信息:适用于需要高性能处理和丰富外设的嵌入式系统,如工业自动化、医疗设备、智能家居等。
7. 封装信息:采用LQFP48封装,尺寸为7x7mm,具有48个引脚,适用于表面贴装技术。
TSM05N03CW RPG 价格&库存
很抱歉,暂时无法提供与“TSM05N03CW RPG”相匹配的价格&库存,您可以联系我们找货
TSM05N03CW RPG
  • 2500+2.530152500+0.32775
  • 5000+2.329775000+0.30179
  • 7500+2.227677500+0.28856
  • 12500+2.1129812500+0.27371
库存:19263
TSM05N03CW RPG
  • 1+6.455401+0.83620
  • 5+4.536235+0.58760
  • 25+3.4283425+0.44409
  • 100+3.02706100+0.39211
  • 1000+2.721741000+0.35256
库存:106
TSM05N03CW RPG
  • 1+6.04889
  • 5+4.20428
  • 25+3.18016
  • 100+2.80285
  • 1000+2.52257
库存:106
TSM05N03CW RPG
  • 1+9.969711+1.29143
  • 10+6.2412110+0.80846
  • 100+4.08257100+0.52884
  • 500+3.15355500+0.40850
  • 1000+2.854231000+0.36973
库存:19263
