TPH3208PD
TPH3208PD
    TRANSPHORM
    TO-220-3
    GANFET N-CH 650V 20A TO220AB
TPH3208PD 数据手册
TPH3208PS Discontinued 650V GaN FET TO-220 Series Description Features The TPH3208PS 650V, 110mΩ Gallium Nitride (GaN) FET is a normally-off device. It combines state-of-the-art high voltage GaN HEMT and low voltage silicon MOSFET technologies—offering superior reliability and performance. Transphorm GaN offers improved efficiency over silicon, through lower gate charge, lower crossover loss, and smaller reverse recovery charge. Related Literature • AN0009: Recommended External Circuitry for GaN FETs • AN0003: Printed Circuit Board Layout and Probing • AN0010: Paralleling GaN FETs Product Series and Ordering Information Package Package Configuration 3 lead TO-220 Source Part Number TPH3208PS • JEDEC qualified GaN technology • Dynamic RDS(on)eff production tested • Robust design, defined by — Intrinsic lifetime tests — Wide gate safety margin — Transient over-voltage capability • Very low QRR • Reduced crossover loss • RoHS compliant and Halogen-free packaging Benefits • Enables AC-DC bridgeless totem-pole PFC designs — Increased power density — Reduced system size and weight — Overall lower system cost • Achieves increased efficiency in both hard- and softswitched circuits • Easy to drive with commonly-used gate drivers • GSD pin layout improves high speed design Applications TPH3208PS TO-220 (top view) S • • • • Datacom Broad industrial PV inverter Servo motor Key Specifications G S D VDSS (V) 650 V(TR)DSS (V) 800 RDS(on)eff (mΩ) max* 130 QRR (nC) typ 54 QG (nC) typ 14 * Dynamic on-resistance; see Figures 19 and 20 Common Topology Power Recommendations Cascode Schematic Symbol Cascode Device Structure CCM bridgeless totem-pole* 1816W max Hard-switched inverter** 2064W max Conditions: FSW=45kHz; TJ=115°C; THEATSINK=90°C; insulator between device and heatsink (6 mil Sil-Pad® K-10); power de-rates at lower voltages with constant current * VIN=230VAC; VOUT=390VDC ** VIN=380VDC; VOUT=240VAC March 7, 2021 © 2018 Transphorm Inc. Subject to change without notice. tph3208ps.17 1 TPH3208PS (Discontinued) Absolute Maximum Ratings (Tc=25°C unless otherwise stated.) Symbol VDSS V(TR)DSS VGSS PD ID IDM Parameter Limit Value Unit Drain to source voltage (TJ = -55°C to 150°C) 650 Transient drain to source voltage a 800 Gate to source voltage ±18 Maximum power dissipation @TC=25°C 96 W Continuous drain current @TC=25°C b 20 A Continuous drain current @TC=100°C b 13 A Pulsed drain current (pulse width: 10µs) 80 A V (di/dt)RDMC Reverse diode di/dt, repetitive c 1250 A/µs (di/dt)RDMT Reverse diode di/dt, transient d 2500 A/µs Case -55 to +150 °C Junction -55 to +150 °C -55 to +150 °C 260 °C Typical Unit TC TJ TS TSOLD Operating temperature Storage temperature Soldering peak temperature e Notes: a. In off-state, spike duty cycle D
TPH3208PD 价格&库存
很抱歉,暂时无法提供与“TPH3208PD”相匹配的价格&库存,您可以联系我们找货
