BZT55B5V1 L0G
BZT55B5V1 L0G
    TAIWANSEMICONDUCTOR(台半)
    SOD-80
    DIODE ZENER 5.1V 500MW MINI MELF
BZT55B5V1 L0G 数据手册
BZT55B2V4 - BZT55B75 Taiwan Semiconductor 500mW 2% Zener Diodes FEATURES KEY PARAMETERS ● ● ● ● Wide zener voltage range selection: 2.4V to 75V VZ Tolerance Selection of ± 2% Surface device type mountin Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 PARAMETER VALUE UNIT VZ 2.4-75 V Test current IZT 5 mA Ptot 500 mW VF at IF=10mA 1 V TJ Max. 175 °C APPLICATIONS ● ● ● ● Low voltage stabilzers or voltage references Adapters Lighting application On-board DC/DC converter Package LS34 Configuration Single dice MECHANICAL DATA ● Case: Mini-MELF (Glass Seal) ● Packing code with suffix "G" means green compound (halogen-free) ● Terminal: Matte tin plated leads, solderable per J-STD-002 ● Polarity: Indicated by cathode band ● Weight: 29 ± 2.5mg (approximately) ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER Forward voltage @ IF=10mA SYMBOL PART NUMBER UNIT VF 1 V Total power dissipation Ptot 500 mW Junction temperature range TJ -65 to +175 °C Storage temperature range TSTG -65 to +175 °C SYMBOL LIMIT UNIT RӨJA 500 °C/W THERMAL PERFORMANCE PARAMETER Junction-to-ambient thermal resistance 1 Version:H1610 BZT55B2V4 - BZT55B75 Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) ZENER VOLTAGE PART NUMBER Min. TEST REGULAR TEST CURRENT IMPEDANCE CURRENT VZ @ IZT IZT ZZT @ IZT ZZK @ IZK IZK V mA Ω Ω mA LEAKAGE CURRENT IR @ VR µA V Nom. Max. Max. Max. BZT55B2V4 2.35 2.4 2.45 5 85 600 1.0 50 1 BZT55B2V7 2.65 2.7 2.75 5 85 600 1.0 10 1 BZT55B3V0 2.94 3.0 3.06 5 85 600 1.0 4 1 BZT55B3V3 3.23 3.3 3.37 5 85 600 1.0 2 1 BZT55B3V6 3.53 3.6 3.67 5 85 600 1.0 2 1 BZT55B3V9 3.82 3.9 3.98 5 85 600 1.0 2 1 BZT55B4V3 4.21 4.3 4.39 5 75 600 1.0 1 1 BZT55B4V7 4.61 4.7 4.79 5 60 600 1.0 0.5 1 BZT55B5V1 5.00 5.1 5.20 5 35 550 1.0 0.1 1 BZT55B5V6 5..49 5.6 5.71 5 25 450 1.0 0.1 1 BZT55B6V2 6.08 6.2 6.32 5 10 200 1.0 0.1 2 BZT55B6V8 6.66 6.8 6.94 5 8 150 1.0 0.1 3 BZT55B7V5 7.35 7.5 7.65 5 7 50 1.0 0.1 5 BZT55B8V2 8.04 8.2 8.36 5 7 50 1.0 0.1 6.2 BZT55B9V1 8.92 9.1 9.28 5 10 50 1.0 0.1 6.8 BZT55B10 9.80 10.0 10.20 5 15 70 1.0 0.1 7.5 BZT55B11 10.78 11.0 11.22 5 20 70 1.0 0.1 8.2 BZT55B12 11.76 12.0 12.24 5 20 90 1.0 0.1 9.1 BZT55B13 12.74 13.0 13.26 5 26 110 1.0 0.1 10 BZT55B15 14.70 15.0 15.30 5 30 110 1.0 0.1 11 BZT55B16 15.68 16.0 16.32 5 40 170 1.0 0.1 12 BZT55B18 17.64 18.0 18.36 5 50 170 1.0 0.1 13 BZT55B20 19.60 20.0 20.40 5 55 220 1.0 0.1 15 BZT55B22 21.56 22.0 22.44 5 55 220 1.0 0.1 16 BZT55B24 23.52 24.0 24.48 5 80 220 1.0 0.1 18 BZT55B27 26.46 27.0 27.54 5 80 220 1.0 0.1 20 BZT55B30 29.40 30.0 30.60 5 80 220 1.0 0.1 22 BZT55B33 32.34 33.0 33.66 5 80 220 1.0 0.1 24 BZT55B36 35.28 36.0 36.72 5 80 220 1.0 0.1 27 BZT55B39 38.22 39.0 39.78 2.5 90 500 0.5 0.1 28 BZT55B43 42.14 43.0 43.86 2.5 90 600 0.5 0.1 32 BZT55B47 46.06 47.0 47.94 2.5 110 700 0.5 0.1 35 BZT55B51 49.98 51.0 52.02 2.5 125 700 0.5 0.1 38 BZT55B56 54.88 56.0 57.12 2.5 135 1000 0.5 0.1 42 BZT55B62 60.76 62.0 63.24 2.5 150 1000 0.5 0.1 47 BZT55B68 66.64 68.0 69.36 2.5 160 1000 0.5 0.1 51 BZT55B75 73.50 75.0 76.50 2.5 170 1000 0.5 0.1 56 2 Max. Version:H1610 BZT55B2V4 - BZT55B75 Taiwan Semiconductor Notes: 1. The Zener Voltage (VZ) is tested under pulse condition of 10ms 2. The device numbers listed have a standard tolerance on the nomial zener voltage of ±2% 3. For detailed information on price, availability and delivery of nominal zener voltages between the voltages shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative 4. The zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an RMS value equal to 10% of the dc zener current(IZT or IZK) is superimposed to IZT or IZK ORDERING INFORMATION PART NO. PACKING PACKING CODE CODE SUFFIX BZT55BXXX L0 (Note 1&2) L1 G PACKAGE Mini-MELF (Glass Seal) PACKING 10K / 13" Reel 2.5K / 7" Reel Notes: 1. "xxx" defines voltage from 2.4V (BZT55B2V4) to 75V (BZT55B75) 2. Whole series with green compound EXAMPLE EXAMPLE P/N PART NO. PACKING CODE BZT55B2V4 L0G BZT55B2V4 L0 PACKING CODE SUFFIX G 3 DESCRIPTION Green compound Version:H1610 BZT55B2V4 - BZT55B75 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig. 1 Typical Forward Characteristics Fig. 2 Zener Breakdown Characteristics 100 TA=25oC Zener Current (mA) Forward Current (mA) 1000 100 10 TA=25oC 10 1 0.1 1 0.4 0.5 0.6 0.7 0.8 0.9 1.0 1.1 0.01 1.2 0 1 2 3 4 5 6 7 8 9 10 11 12 Zener Voltage (V) Forward Voltage (V) Fig. 3 Zener Breakdown Characteristics Fig. 4 Admissible Power Dissipation Curve 600 100 500 Power Dissipation (mW) Zener Current (mA) 10 1 0.1 400 300 200 100 0 0.01 10 20 30 40 50 60 70 0 80 40 80 120 160 200 Ambient Temperature (oC) Zener Voltage (V) 4 Version:H1610 BZT55B2V4 - BZT55B75 Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Fig. 5 Typical Capacitance Fig. 6 Effect of Zener Voltage on Impedence 1000 Dynamic Impedence(Ohm) Capacitance (pF) 1000 100 10 100 10 IZ=5mA IZ=20mA 1 1 1 10 1 100 10 100 Zener Voltage (V) Zener Voltage (V) 5 Version:H1610 BZT55B2V4 - BZT55B75 Taiwan Semiconductor PACKAGE OUTLINE DIMENSION LS34 DIM. C Unit(mm) Unit(inch) Min Max Min Max A 3.30 3.70 0.130 0.146 B 1.40 1.60 0.055 0.063 C 0.20 0.50 0.008 0.020 B A 6 Version:H1610 BZT55B2V4 - BZT55B75 Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 7 Version:H1610
BZT55B5V1 L0G 价格&库存
很抱歉,暂时无法提供与“BZT55B5V1 L0G”相匹配的价格&库存,您可以联系我们找货
