TSM2301A
Taiwan Semiconductor
P-Channel Power MOSFET
-20V, -2.8A, 130mΩ
KEY PERFORMANCE PARAMETERS
Features
Advance Trench Process Technology
High Density Cell Design for Ultra Low On-
PARAMETER
VALUE
UNIT
VDS
-20
V
resistance
RDS(on) (max)
Application
VGS = -4.5V
130
VGS = -2.5V
190
mΩ
Qg
Telecom power
Consumer Electronics
7.2
nC
SOT-23
Notes: Moisture sensitivity level: level 3. Per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
LIMIT
UNIT
Drain-Source Voltage
VDS
-20
V
Gate-Source Voltage
VGS
±12
V
Continuous Drain Current
Pulsed Drain Current
(Note 1)
TC = 25°C
ID
TC = 100°C
(Note 2)
Continuous Source Current (Diode Conduction)
Total Power Dissipation
(Note 3)
TA = 25°C
TA = 70°C
Operating Junction and Storage Temperature Range
-2.8
-1.6
A
IDM
-10
A
IS
-1
A
PDTOT
0.7
0.45
W
TJ, TSTG
- 55 to +150
°C
SYMBOL
LIMIT
UNIT
RӨJA
175
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction to Ambient Thermal Resistance (PCB mounted)
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000043
1
Version: C15
TSM2301A
ELECTRICAL SPECIFICATIONS (TC = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 4)
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
-20
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(th)
-0.6
-0.7
-1
V
Gate Body Leakage
VGS = ±12V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = -20V, VGS = 0V
IDSS
1.0
µA
90
130
120
190
Rg
7.5
Qg
7.2
Qgs
2.2
Qgd
1.2
Ciss
480
Coss
460
Crss
10
td(on)
38
tr
25
td(off)
43
tf
5
VSD
-0.7
-1.3
Drain-Source On-State Resistance
Dynamic
VGS = -4.5V, ID = -2.8A
VGS = -2.5V, ID = -2.0A
RDS(on)
mΩ
(Note 5)
Gate Resistance
VGS = VDS =0V, f=1MHz
Total Gate Charge
VDS = -6V, ID = -2.8A,
Gate-Source Charge
VGS = -4.5V
Gate-Drain Charge
Input Capacitance
VDS = -15V, VGS = 0V,
Output Capacitance
Reverse Transfer Capacitance
Switching
f = 1.0MHz
Ω
nC
pF
(Note 6)
Turn-On Delay Time
VDD = -6V, RL = 6Ω,
Turn-On Rise Time
VGEN = -4.5V,
Turn-Off Delay Time
RG = 6Ω
Turn-Off Fall Time
Source-Drain Diode
ns
(Note 4)
Forward On Voltage
IS = -1A, VGS = 0V
V
Notes:
1.
Current limited by package.
2.
Pulse width limited by the maximum junction temperature.
3.
Surface Mounted on a 1 in pad of 2OZ Cu, t ≤ 10 sec.
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%.
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
2
2
Version: C15
TSM2301A
ORDERING INFORMATION
PART NO.
TSM2301ACX RFG
PACKAGE
SOT-23
PACKING
3,000 pcs / 7” Reel
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: C15
TSM2301A
CHARACTERISTICS CURVES
Output Characteristics
Transfer Characteristics
On-Resistance vs. Drain Current
Gate Charge
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Voltage
4
Version: C15
TSM2301A
Electrical Characteristics Curve
o
(Tc= 25 C, unless otherwise noted)
On-Resistance vs. Gate-Source Voltage
Threshold Voltage
Single Pulse Power
Normalized Thermal Response (RθJA)
Normalized Thermal Transient Impedance, Junction-to-Ambient
Square Wave Pulse Duration (s)
5
Version: C15
TSM2301A
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
SOT-23
SUGGESTED PAD LAYOUT (Unit: Millimeters)
Marking Diagram
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code
6
Version: C15
TSM2301A
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version: C15
很抱歉,暂时无法提供与“TSM2301ACX RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+1.469513000+0.18337
- 6000+1.394776000+0.17404
- 9000+1.295159000+0.16161
- 30000+1.2652630000+0.15788
