TSM7ND65CI
TSM7ND65CI
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
TSM7ND65CI 数据手册
TSM7ND65CI Taiwan Semiconductor N-Channel Power MOSFET 650V, 7A, 1.35Ω FEATURES KEY PERFORMANCE PARAMETERS ● 100% UIS and Rg tested PARAMETER VALUE UNIT VDS 650 V RDS(on) (max) 1.35 Ω Qg 25 nC ● Advanced planar process ● Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● AC/DC LED Lighting ● Power Supply ITO-220 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL Limit UNIT Drain-Source Voltage VDS 650 V Gate-Source Voltage VGS ±30 V Continuous Drain Current TC = 25°C (Note 1) ID TC = 100°C (Note 2) 7 4.4 A IDM 28 A PDTOT 50 W Single Pulse Avalanche Energy (Note 3) EAS 270 mJ Single Pulse Avalanche Current (Note 3) IAS 5.2 A TJ, TSTG - 55 to +150 °C SYMBOL Limit UNIT Junction to Case Thermal Resistance RӨJC 2.5 °C/W Junction to Ambient Thermal Resistance RӨJA 62 °C/W Pulsed Drain Current Total Power Dissipation @ TC = 25°C Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: A1804 TSM7ND65CI Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 650 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 2.5 2.9 3.8 V Gate Body Leakage VGS = ±30V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 650V, VGS = 0V IDSS -- -- 1 µA RDS(on) -- 1 1.35 Ω Qg -- 25 -- Qgs -- 5.3 -- Qgd -- 8.1 -- Ciss -- 1124 -- Coss -- 68 -- Crss -- 3 -- Rg -- 1.1 2.2 td(on) -- 8 -- tr -- 19 -- td(off) -- 22 -- tf -- 23 -- Body-Diode Continuous Forward Current IS -- -- 7 A Body-Diode Pulsed Current ISM -- -- 28 A VSD -- -- 1.2 V Drain-Source On-State Resistance VGS = 10V, ID = 1.8A (Note 4) Dynamic (Note 5) Total Gate Charge VDS = 520V, ID = 3.6A, Gate-Source Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 50V, VGS = 0V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching nC pF Ω (Note 6) Turn-On Delay Time Turn-On Rise Time VDD = 325V, RG = 5Ω, Turn-Off Delay Time ID =3.6A, VGS = 10V Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 4) IS = 3.6A, VGS = 0V Reverse Recovery Time IS = 3.6A trr -- 220 -- ns Reverse Recovery Charge dIF/dt = 100A/μs Qrr -- 1.7 -- μC Notes: 1. Current limited by package 2. Pulse width limited by the maximum junction temperature 3. L = 20mH, IAS = 5.2A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2% 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. o ORDERING INFORMATION PART NO. TSM7ND65CI C0G PACKAGE PACKING ITO-220 50pcs / Tube 2 Version: A1804 TSM7ND65CI Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 7 VGS=10V VGS=7V VGS=5V 6 ID, Drain Current (A) ID, Drain Current (A) 7 5 4 3 VGS=4V 2 6 5 4 25℃ 3 2 1 1 0 0 0 2 4 6 8 10 150℃ 0 On-Resistance vs. Drain Current 4 6 8 Gate-Source Voltage vs. Gate Charge VGS, Gate to Source Voltage (V) 3 2.5 2 VGS=10V 1.5 2 VGS, Gate to Source Voltage (V) 1 0.5 10 VDS=520V ID=3.6A 8 6 4 2 0 0 0 1 2 3 4 5 6 0 7 5 10 15 20 25 ID, Drain Current (A) Qg, Gate Charge (nC) On-Resistance vs. Junction Temperature On-Resistance vs. Gate-Source Voltage RDS(on), Drain-Source On-Resistance (Ω) RDS(on), Drain-Source On-Resistance (Normalized) RDS(on), Drain-Source On-Resistance (Ω) VDS, Drain to Source Voltage (V) -55℃ 3 VGS=10V ID=1.8A 2.5 2 1.5 1 0.5 0 -75 -50 -25 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) 3 3 2.5 2 1.5 1 ID=1.8A 0.5 0 3 4 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) Version: A1804 TSM7ND65CI Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage 2000 BVDSS (Normalized) Drain-Source Breakdown Voltage 1.2 C, Capacitance (pF) 1800 1600 1400 CISS 1200 1000 800 600 400 200 COSS CRSS ID=250uA 1.1 1 0.9 0.8 0 0.1 1 10 100 -75 1000 -50 VDS, Drain to Source Voltage (V) 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 100 10 10 IS, Reverse Drain Current (A) ID, Drain Current (A) -25 RDS(ON) 1 SINGLE PULSE RӨJC=2.5°C/W TC=25°C 0.1 0.01 1 25℃ 150℃ -55℃ 0.1 1 10 100 1000 0 VDS, Drain to Source Voltage (V) 0.2 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) Normalized Effective Transient Thermal Impedance, ZӨJC Normalized Thermal Transient Impedance, Junction-to-Case 10 SINGLE PULSE RӨJC=2.5°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.0001 0.001 0.01 0.1 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 1 10 t, Square Wave Pulse Duration (sec) 4 Version: A1804 TSM7ND65CI Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) ITO-220 MARKING DIAGRAM TSC 7ND65 GYWWF G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code 5 Version: A1804 TSM7ND65CI Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A1804
TSM7ND65CI 价格&库存
很抱歉,暂时无法提供与“TSM7ND65CI”相匹配的价格&库存,您可以联系我们找货
