Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
BSP110
N-channel enhancement mode field-effect transistor
Rev. 03 — 26 July 2000
Product specification
1. Description
N-channel enhancement mode field-effect transistor in a plastic package using
TrenchMOS™1 technology.
Product availability:
BSP110 in SOT223.
2. Features
TrenchMOS™ technology
Very fast switching
Logic level compatible
Surface mount package.
3. Applications
c
c
■ Relay driver
■ High speed line driver
■ Logic level translator.
4. Pinning information
Table 1:
Pinning - SOT223, simplified outline and symbol
Pin
Description
1
gate (g)
2
drain (d)
3
source (s)
4
drain (d)
Simplified outline
Symbol
d
4
g
03ab45
1
2
3
SOT223
1.
TrenchMOS is a trademark of Royal Philips Electronics.
s
03ab30
N-channel MOSFET
BSP110
5. Quick reference data
Table 2:
Symbol Parameter
Conditions
Typ
Max
Unit
Tj = 25 to 150 °C
100
V
VDS
drain-source voltage (DC)
ID
drain current (DC)
Tsp = 25 °C; VGS = 5 V
520
mA
Ptot
total power dissipation
Tsp = 25 °C
6.25
W
Tj
junction temperature
150
°C
RDSon
drain-source on-state resistance
5
10
Ω
Conditions
Min
Max
Unit
VGS = 5 V; ID = 150 mA
6. Limiting values
Table 3: Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol Parameter
VDS
Tj = 25 to 150 °C
100
V
VDGR
drain-gate voltage (DC)
Tj = 25 to 150 °C; RGS = 20 kΩ
100
V
VGS
gate-source voltage (DC)
±20
V
ID
drain current (DC)
Tsp = 25 °C; VGS = 5 V; Figure 2 and 3
520
mA
Tsp = 100 °C; VGS = 5 V; Figure 2
330
mA
IDM
peak drain current
Tsp = 25 °C; pulsed; tp ≤ 10 µs;
Figure 3
2
A
Ptot
Tsp = 25 °C; Figure 1
6.25
W
Tstg
storage temperature
−65
+150
°C
Tj
operating junction temperature
−65
+150
°C
Source-drain diode
IS
source (diode forward) current (DC)
Tsp = 25 °C
520
mA
ISM
peak source (diode forward) current
2
A
© Philips Electronics N.V. 2000. All rights reserved.
9397 750 07256
2 of 13
BSP110
03aa17
03aa25
120
120
der
100
Ider
100
80
80
60
60
40
40
P
50
75
100
125
Tsp
150
(oC)
25
50
75
100
125
150 175
Tsp (oC)
VGS ≥ 5 V
P tot
P der = ---------------------- × 100%
P
ID
I der = ------------------- × 100%
I
tot ( 25 C )
D ( 25 C )
Fig 1. Normalized total power dissipation as a
function of solder point temperature.
Fig 2. Normalized continuous drain current as a
03aa61
10
ID
(A)
tp = 10 µs
RDSon = VDS/ ID
1
100 µs
10 -1
δ=
P
1 ms
10 ms
100 ms
tp
D.C.
T
t
tp
Tsp = 25oC
T
10-2
1
10
102
VDS (V)
103
Tsp = 25 °C; IDM is single pulse.
Fig 3. Safe operating area; continuous and peak drain currents as a function of drain-source voltage.
9397 750 07256
3 of 13
BSP110
7. Thermal characteristics
Table 4:
Symbol
Parameter
Conditions
Value
Unit
Rth(j-sp)
thermal resistance from junction to solder
point
mounted on a metal clad substrate;
Figure 4
K/W
Rth(j-a)
thermal resistance from junction to ambient
mounted on a printed circuit board;
minimum footprint
150
K/W
7.1 Transient thermal impedance
03aa58
102
Zth(j-sp)
(K/W)
δ = 0.5
10
0.2
0.1
0.05
δ=
P
0.02
1
tp
T
single pulse
t
tp
T
10-1
10-5
10-4
10-3
10-2
10-1
1
10
tp (s)
Mounted on a metal clad substrate.
Fig 4. Transient thermal impedance from junction to solder point as a function of
pulse duration.
9397 750 07256
4 of 13
BSP110
8. Characteristics
Table 5: Characteristics
Tj = 25 °C unless otherwise specified
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
Tj = 25 °C
100
130
V
Tj = −55 °C
89
V
Tj = 25 °C
1
2
V
Tj = 150 °C
0.6
V
Tj = −55 °C
3.5
V
Tj = 25 °C
0.01
1.0
µA
Tj = 150 °C
10
µA
10
100
nA
Tj = 25 °C
5
10
Ω
Tj = 150 °C
23
Ω
Static characteristics
V(BR)DSS
VGS(th)
IDSS
drain-source breakdown
voltage
ID = 10 µA; VGS = 0 V
gate-source threshold voltage ID = 1 mA; VDS = VGS;
Figure 9
drain-source leakage current
VDS = 60 V; VGS = 0 V
IGSS
gate-source leakage current
VGS = ±20 V; VDS = 0 V
RDSon
resistance
VGS = 5 V; ID = 150 mA;
Figure 7 and 8
Dynamic characteristics
gfs
forward transconductance
VDS = 5 V; ID = 175 mA;
Figure 11
350
mS
Ciss
input capacitance
25
40
pF
Coss
output capacitance
VGS = 0 V; VDS = 10 V;
f = 1 MHz; Figure 12
8.5
15
pF
Crss
reverse transfer capacitance
ton
turn-on time
toff
turn-off time
5
10
pF
VDD = 50 V; RD = 250 Ω;
VGS = 10 V; RG = 50 Ω;
RGS = 50 Ω
3
10
ns
12
15
ns
Source-drain diode
VSD
source-drain (diode forward)
voltage
IS = 300 mA; VGS = 0 V;
Figure 13
0.95
1.5
V
trr
reverse recovery time
30
ns
Qr
recovered charge
IS = 300 mA;
dIS/dt = −100 A/µs;
VGS = 0 V; VDS = 25 V
30
nC
9397 750 07256
5 of 13
BSP110
03aa63
0.5
ID
(A) 0.45
03aa65
0.7
Tj = 25oC
ID
(A)
VGS = 10V
5V
0.4
VDS > ID X RDSon
0.6
0.5
0.35
0.3
0.25
Tj = 25oC
0.4
4V
150oC
0.3
0.2
3.5 V
0.15
0.2
0.1
0.1
3V
0.05
1
1.2 1.4 1.6 1.8
2
2
3
4
5
6
7
8
VGS (V)
VDS (V)
Tj = 25 °C
Tj = 25 °C and 150 °C; VDS > ID × RDSon
Fig 5. Output characteristics: drain current as a
function of drain-source voltage; typical values.
03aa29
03aa64
12
3V
RDSon 11
(Ω)
10
Tj = 25oC
3.5V
9
Fig 6. Transfer characteristics: drain current as a
function of gate-source voltage; typical values.
3
a 2.8
2.6
2.4
2.2
2
1.8
1.6
1.4
1.2
1
0.8
0.6
0.4
0.2
4V
8
7
6
5V
5
4
VGS = 10V
3
2
1
0.2
0.3
0.4
ID (A)
-60
0.5
Tj = 25 °C
100
140
180
Tj (oC)
R DSon
a = --------------------------R DSon ( 25 °C )
Fig 7. Drain-source on-state resistance as a function
of drain current; typical values.
Fig 8. Normalized drain-source on-state resistance
factor as a function of junction temperature.
9397 750 07256
-20
6 of 13
BSP110
03aa34
3
03aa37
10-1
I
D
VGS(th)
(A)
10-2
(V) 2.5
typ
2
min
10-3
typ
1.5
10-4
min
1
10-5
0.5
10-6
-20
100
140
180
Tj (oC)
1
1.5
2
2.5
3
VGS (V)
Tj = 25 °C; VDS = 5 V
Fig 9. Gate-source threshold voltage as a function of
Fig 10. Sub-threshold drain current as a function of
gate-source voltage.
03aa66
0.5
gfs
0.45
(S)
03aa68
102
VDS > ID X RDSon
0.4
Ciss, Coss,
Crss (pF)
Tj = 25oC
Ciss
0.35
0.3
0.25
10
150oC
Coss
0.2
0.15
0.1
0.05
Crss
0.2
0.3
0.4
0.5
0.6
1
0.7
10-1
102
10
VGS = 0 V; f = 1 MHz
Fig 11. Forward transconductance as a function of
Fig 12. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values.
9397 750 07256
1
VDS (V)
ID (A)
7 of 13
BSP110
03aa67
1
IS
(A) 0.9
VGS = 0 V
0.8
0.7
0.6
150oC
0.5
0.4
Tj = 25oC
0.3
0.2
0.1
0.4
0.6
0.8
1
1.2
1.4
VSD (V)
Tj = 25 °C and 150 °C; VGS = 0 V
Fig 13. Source (diode forward) current as a function of source-drain (diode forward)
9397 750 07256
8 of 13
BSP110
9. Package outline
Plastic surface mounted package; collector pad for good heat transfer; 4 leads
D
SOT223
E
B
A
X
c
y
HE
v M A
b1
4
Q
A
A1
1
2
3
Lp
bp
e1
w M B
detail X
e
4 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
bp
b1
c
D
E
e
e1
HE
Lp
Q
v
w
y
mm
1.8
1.5
0.10
0.01
0.80
0.60
3.1
2.9
0.32
0.22
6.7
6.3
3.7
3.3
4.6
2.3
7.3
6.7
1.1
0.7
0.95
0.85
0.2
0.1
0.1
OUTLINE
VERSION
SOT223
REFERENCES
IEC
JEDEC
EIAJ
SC-73
EUROPEAN
PROJECTION
ISSUE DATE
97-02-28
99-09-13
Fig 14. SOT223.
9397 750 07256
9 of 13
BSP110
10. Revision history
Table 6:
Revision history
Rev Date
03
20000726
CPCN
Description
HZG303
Product specification; third version; supersedes BSP110_CNV_2 of 970623.
Converted from VDMOS (Nijmegen) to TrenchMOS™ technology (Hazel Grove).
02
19970623
Product specification; second version.
01
19901031
Product specification; initial version.
9397 750 07256
10 of 13
BSP110
11. Data sheet status
Datasheet status
Product status
Definition [1]
Objective specification
Development
This data sheet contains the design target or goal specifications for product development. Specification may
change in any manner without notice.
Preliminary specification
Qualification
This data sheet contains preliminary data, and supplementary data will be published at a later date. Philips
Semiconductors reserves the right to make changes at any time without notice in order to improve design and
supply the best possible product.
Production
This data sheet contains final specifications. Philips Semiconductors reserves the right to make changes at any
time without notice in order to improve design and supply the best possible product.
[1]
Please consult the most recently issued data sheet before initiating or completing a design.
12. Definitions
13. Disclaimers
Short-form specification — The data in a short-form specification is
extracted from a full data sheet with the same type number and title. For
detailed information see the relevant data sheet or data handbook.
Life support — These products are not designed for use in life support
appliances, devices, or systems where malfunction of these products can
reasonably be expected to result in personal injury. Philips Semiconductors
customers using or selling these products for use in such applications do so
at their own risk and agree to fully indemnify Philips Semiconductors for any
damages resulting from such application.
Limiting values definition — Limiting values given are in accordance with
the Absolute Maximum Rating System (IEC 60134). Stress above one or
more of the limiting values may cause permanent damage to the device.
These are stress ratings only and operation of the device at these or at any
other conditions above those given in the Characteristics sections of the
specification is not implied. Exposure to limiting values for extended periods
may affect device reliability.
Application information — Applications that are described herein for any
of these products are for illustrative purposes only. Philips Semiconductors
make no representation or warranty that such applications will be suitable for
the specified use without further testing or modification.
Right to make changes — Philips Semiconductors reserves the right to
make changes, without notice, in the products, including circuits, standard
cells, and/or software, described or contained herein in order to improve
design and/or performance. Philips Semiconductors assumes no
responsibility or liability for the use of any of these products, conveys no
licence or title under any patent, copyright, or mask work right to these
products, and makes no representations or warranties that these products
are free from patent, copyright, or mask work right infringement, unless
otherwise specified.
© Philips Electronics N.V. 2000 All rights reserved.
9397 750 07256
11 of 13
BSP110
Philips Semiconductors - a worldwide company
Argentina: see South America
Australia: Tel. +61 2 9704 8141, Fax. +61 2 9704 8139
Austria: Tel. +43 160 101, Fax. +43 160 101 1210
Belarus: Tel. +375 17 220 0733, Fax. +375 17 220 0773
Belgium: see The Netherlands
Brazil: see South America
Bulgaria: Tel. +359 268 9211, Fax. +359 268 9102
Canada: Tel. +1 800 234 7381
China/Hong Kong: Tel. +852 2 319 7888, Fax. +852 2 319 7700
Colombia: see South America
Czech Republic: see Austria
Denmark: Tel. +45 3 288 2636, Fax. +45 3 157 0044
Finland: Tel. +358 961 5800, Fax. +358 96 158 0920
France: Tel. +33 14 099 6161, Fax. +33 14 099 6427
Germany: Tel. +49 40 23 5360, Fax. +49 402 353 6300
Hungary: see Austria
India: Tel. +91 22 493 8541, Fax. +91 22 493 8722
Indonesia: see Singapore
Ireland: Tel. +353 17 64 0000, Fax. +353 17 64 0200
Israel: Tel. +972 36 45 0444, Fax. +972 36 49 1007
Italy: Tel. +39 039 203 6838, Fax +39 039 203 6800
Japan: Tel. +81 33 740 5130, Fax. +81 3 3740 5057
Korea: Tel. +82 27 09 1412, Fax. +82 27 09 1415
Malaysia: Tel. +60 37 50 5214, Fax. +60 37 57 4880
Mexico: Tel. +9-5 800 234 7381
Middle East: see Italy
Netherlands: Tel. +31 40 278 2785, Fax. +31 40 278 8399
New Zealand: Tel. +64 98 49 4160, Fax. +64 98 49 7811
Norway: Tel. +47 22 74 8000, Fax. +47 22 74 8341
Philippines: Tel. +63 28 16 6380, Fax. +63 28 17 3474
Poland: Tel. +48 22 5710 000, Fax. +48 22 5710 001
Portugal: see Spain
Romania: see Italy
Russia: Tel. +7 095 755 6918, Fax. +7 095 755 6919
Singapore: Tel. +65 350 2538, Fax. +65 251 6500
Slovakia: see Austria
Slovenia: see Italy
South Africa: Tel. +27 11 471 5401, Fax. +27 11 471 5398
South America: Tel. +55 11 821 2333, Fax. +55 11 829 1849
Spain: Tel. +34 33 01 6312, Fax. +34 33 01 4107
Sweden: Tel. +46 86 32 2000, Fax. +46 86 32 2745
Switzerland: Tel. +41 14 88 2686, Fax. +41 14 81 7730
Taiwan: Tel. +886 22 134 2451, Fax. +886 22 134 2874
Thailand: Tel. +66 23 61 7910, Fax. +66 23 98 3447
Turkey: Tel. +90 216 522 1500, Fax. +90 216 522 1813
Ukraine: Tel. +380 44 264 2776, Fax. +380 44 268 0461
United Kingdom: Tel. +44 208 730 5000, Fax. +44 208 754 8421
United States: Tel. +1 800 234 7381
Uruguay: see South America
Vietnam: see Singapore
Yugoslavia: Tel. +381 11 3341 299, Fax. +381 11 3342 553
For all other countries apply to: Philips Semiconductors,
Marketing Communications,
Building BE, P.O. Box 218, 5600 MD EINDHOVEN,
The Netherlands, Fax. +31 40 272 4825
Internet: http://www.semiconductors.philips.com
(SCA70)
9397 750 07256
12 of 13
BSP110
Contents
1
2
3
4
5
6
7
7.1
8
9
10
11
12
13
Description . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Features . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . . 1
Pinning information . . . . . . . . . . . . . . . . . . . . . . 1
Quick reference data . . . . . . . . . . . . . . . . . . . . . 2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . 2
Thermal characteristics. . . . . . . . . . . . . . . . . . . 4
Transient thermal impedance . . . . . . . . . . . . . . 4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . 5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . 9
Revision history . . . . . . . . . . . . . . . . . . . . . . . . 10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . . 11
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Disclaimers. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Printed in The Netherlands
All rights are reserved. Reproduction in whole or in part is prohibited without the prior
written consent of the copyright owner.
The information presented in this document does not form part of any quotation or
contract, is believed to be accurate and reliable and may be changed without notice. No
liability will be accepted by the publisher for any consequence of its use. Publication
thereof does not convey nor imply any license under patent- or other industrial or
intellectual property rights.
Date of release: 26 July 2000
Document order number: 9397 750 07256
