BZX84C2V4- BZX84C39
Taiwan Semiconductor
Small Signal Product
Surface Mount Zener Diode
FEATURES
- Zener voltages from : 2.4V - 39V
- Planar die construction
- Ideally suited for automated assembly processes
- Moisture sensitivity : Level 1 per J-STD-020
MECHANICAL DATA
SOT-23
- Case : SOT-23, molding plastic
- Case material - UL flammibility rating 94V-0
- Polarity : See diagram
- Lead free plating
- Marking : Marking code
- Weight : 0.008 g (approximately)
MAXIMUM RATINGS AND ELECTRICAL CHARACTERISTICS (TA=25℃ unless otherwise noted)
PARAMETER
Power Dissipation
Forward Voltage
IF = 10 mA
Thermal Resistance (Junction to Ambient)
Junction and Storage Temperature Range
(Note 1)
SYMBOL
PD
VALUE
UNIT
300
mW
VF
0.9
RθJA
417
TJ, TSTG
- 65 to +150
V
o
C/W
o
C
Note 1: Valid provided that device terminals are kept at ambient temerature .
Version: E1604
BZX84C2V4-BZX84C39
ELECTRICAL CHARACTERISTICS ( TA= 25oC unless otherwise noted )
Zener Voltage Range
(Note 2)
Type Number
(Note 1)
Marking
code
Nom
Min
Max
BZX84C2V4
Z11
2.4
2.2
2.6
BZX84C2V7
Z12
2.7
2.5
BZX84C3V0
Z13
3.0
2.8
BZX84C3V3
Z14
3.3
BZX84C3V6
Z15
3.6
BZX84C3V9
Z16
BZX84C4V3
Z17
BZX84C4V7
BZX84C5V1
VZ
@ IZT
Maximum Zener Impedance
(Note 3)
IZT
ZZK @ IZK
Maximum Reverse
Current
IR
Typical Temperature
Coefficient @ IZT
(mV/oC)
VR
mA
ZZT @ IZT
Ohms
Ohms
mA
μA
V
Min
Max
5
100
600
1.0
50
1.0
-3.5
5
100
600
1.0
-3.5
5
95
600
1.0
10
1.0
-3.5
3.5
5
95
600
1.0
5.0
1.0
-3.5
3.8
5
90
600
1.0
5.0
1.0
-3.5
3.7
4.1
5
90
600
1.0
3.0
1.0
-3.5
4.0
4.6
5
90
600
1.0
3.0
1.0
-3.5
0.0
Z1
4.7
4.4
5.0
5
80
500
1.0
3.0
2.0
-3.5
0.2
Z2
5.1
4.8
5.4
5
60
480
1.0
2.0
2.0
-2.7
1.2
BZX84C5V6
Z3
5.6
5.2
6.0
5
40
400
1.0
1.0
2.0
-2.0
2.5
BZX84C6V2
Z4
6.2
5.8
6.6
5
10
150
1.0
3.0
4.0
0.4
3.7
BZX84C6V8
Z5
6.8
6.4
7.2
5
15
80
1.0
2.0
4.0
1.2
4.5
BZX84C7V5
Z6
7.5
7.0
7.9
5
15
80
1.0
1.0
5.0
2.5
5.3
BZX84C8V2
Z7
8.2
7.7
8.7
5
15
80
1.0
0.7
5.0
3.2
6.1
BZX84C9V1
Z8
9.1
8.5
9.6
5
15
100
1.0
0.5
6.0
3.8
7.0
BZX84C10
Z9
10
9.4
10.6
5
1.0
0.2
7.0
4.5
8.0
BZX84C11
Y1.
11
10.4
11.6
5
1.0
0.1
8.0
5.4
9.0
BZX84C12
Y2.
12
11.4
12.7
5
25
150
1.0
0.1
8.0
6
10.0
BZX84C13
Y3
13
12.4
14.1
5
30
170
1.0
0.1
8.0
7
11.0
BZX84C15
Y4
15
13.8
15.6
5
30
200
1.0
0.1
10.5
9.2
13.0
BZX84C16
Y5
16
15.3
17.1
5
40
200
1.0
0.1
11.2
10.4
14.0
BZX84C18
Y6
18
16.8
19.1
5
45
225
1.0
0.1
12.6
12.4
16.0
BZX84C20
Y7
21.2
5
55
225
1.0
0.1
14.0
14.4
18.0
BZX84C22
Y8
22
20.8
23.3
5
55
250
1.0
0.1
15.4
16.4
20.0
BZX84C24
Y9
24
22.8
25.6
5
70
250
1.0
0.1
16.8
18.4
22.0
BZX84C27
Y10
27
25.1
28.9
2
80
300
0.5
0.1
18.9
21.4
25.3
BZX84C30
Y11
30
28
32
2
80
300
0.5
0.1
21.0
24.4
29.4
BZX84C33
Y12
33
31
35
2
80
325
0.5
0.1
23.1
27.4
33.4
BZX84C36
Y13
36
34
38
2
90
350
0.5
0.1
25.2
30.4
37.4
BZX84C39
Y14
39
37
41
2
130
350
0.5
0.1
27.3
33.4
41.2
Notes: 1. Valid provided that device terminals are kept at ambient temerature.
2. Tested with pulses period = 5 ms, pulse width = 300 μs
3. f = 1KHz
Version: E1604
BZX84C2V4 -BZX84C39
RATINGS AND CHARACTERISTICS CURVES
Fig. 2 Zener Breakdown Characteristics
Fig. 1 Power Derating Curve
50
PD - Power Passipation (mW)
500
C2V7
Tj=25o
C3V9 C5V6
40
IZ , Zener Current (mA)
400
300
200
100
C3V3
30
C4V7
C6V8
C8V2
Test
Current IZ
5.0 mA
line 7
TA , Ambient Temperature (oC)
2
3
4
5
6
7
8
9
10
VZ - Zener Voltage (V)
Fig. 3
line 1
line 2
Fig. 4 Junction Capacitance VS. Nomial Zener
Fig. 3 Zener Breakdown Characteristics
30
line 3
1000
C10
Tj=25oC
C12
Test Current IZ
2 mA
IZ, Zener Current (mA)
C15
Test Current
IZ
5 mA
10
C1
C22
C27
C33
C36
C39
30
40
CJ, Junction Capacitance (pF)
Tj=25oC
line 4
VR = 1 V
line 5
VR = 2
100
line 6
VR = 1 V
line 7
VR = 2 V
10
1.0
10.0
100.0
VZ - Nominal Zener Voltage (V)
line 8
line 9
Fig. 4
line 1
line 1 end
line 2
line 2 end
line 3 head
Version: E1604
BZX84C2V4 - BZX84C39
ORDERING INFORMATION
PART NO.
PACKING CODE
PACKAGE
PACKING
BZX84Cxxx
(Note1)
RF
SOT-23
3K / 7" Reel
Note 1: "xxx" defines voltage from 2.4V (BZX84C2V4) to 39V (BZX84C39)
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
DESCRIPTION
BZX84C39 RFG
BZX84C39
RF
Green compound
PACKAGE OUTLINE DIMENSION
A
F
DIM.
B
E
G
C
D
H
Unit (mm)
Unit (inch)
Min
Max
Min
Max
A
2.70
3.10
0.106
0.122
B
1.10
1.50
0.043
0.059
C
0.30
0.51
0.012
0.020
D
1.78
2.04
0.070
0.080
E
2.10
2.64
0.083
0.104
F
G
0.89
1.30
0.55 REF
0.035 0.051
0.022 REF
H
0.10 REF
0.004 REF
Unit (mm)
Unit (inch)
SUGGEST PAD LAYOUT
DIM.
Typ.
Typ.
Z
2.90
0.114
X
0.80
0.031
Y
0.90
0.035
C
2.00
0.079
E
1.35
0.053
Version: E1604
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC's terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
Version: E1604
很抱歉,暂时无法提供与“BZX84C9V1 RFG”相匹配的价格&库存,您可以联系我们找货
免费人工找货- 国内价格 香港价格
- 3000+0.442773000+0.05745
- 6000+0.396406000+0.05144
- 9000+0.372729000+0.04836
- 15000+0.3461015000+0.04491
- 21000+0.3303321000+0.04286
- 30000+0.3149930000+0.04087
- 国内价格 香港价格
- 1+2.202671+0.28580
- 10+1.3375610+0.17355
- 100+0.82808100+0.10745
- 500+0.60664500+0.07871
- 1000+0.534581000+0.06936
- 国内价格
- 20+0.22724
- 200+0.17864
- 600+0.15153
