BZX55B2V4 - BZX55B75
Taiwan Semiconductor
500mW 2% Zener Diodes
FEATURES
KEY PARAMETERS
Wide zener voltage range selection: 2.4V to 75V
VZ Tolerance Selection of ± 2%
Hermetically sealed glasss
Compliant to RoHS directive 2011/65/EU and
in accordance to WEEE 2002/96/EC
● Halogen-free according to IEC 61249-2-21
PARAMETER
VALUE
UNIT
VZ
2.4-75
V
Test current IZT
2.5-5
mA
Ptot
500
mW
VF at IF=100mA
1
V
TJ MAX
175
°C
APPLICATIONS
Low voltage stabilzers or voltage references
Adapters
Lighting application
On-board DC/DC converter
Package
DO-35
Configuration
Single dice
MECHANICAL DATA
● Case: DO-35
● Packing code with suffix "G" means green compound
(halogen-free)
● Terminal: Matte tin plated leads, solderable per J-STD-002
● Polarity: Indicated by cathode band
● Weight: 109 ± 4 mg (approximately)
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
Forward voltage @ IF=100mA
SYMBOL
PART NUMBER
UNIT
VF
1
V
Total power dissipation
Ptot
500
mW
Junction temperature range
TJ
-55 ~ 175
°C
Storage temperature range
TSTG
-55 ~ 175
°C
SYMBOL
LIMIT
UNIT
RӨJA
240
°C/W
THERMAL PERFORMANCE
PARAMETER
Junction-to-ambient thermal resistance
1
Version:F1610
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
ZENER VOLTAGE
PART NUMBER
Min.
TEST
CURRENT
REGULAR IMPEDANCE
TEST CURRENT
VZ @ IZT
IZT
ZZT @ IZT
ZZK @ IZK
IZK
V
mA
Ω
Ω
mA
Max.
Max.
Nom.
Max.
LEAKAGE
CURRENT
IR @ VR
µA
V
Max.
BZX55B2V4
2.35
2.40
2.45
5
85
600
1.0
50
1.0
BZX55B2V7
2.65
2.70
2.75
5
85
600
1.0
10
1.0
BZX55B3V0
2.94
3.00
3.06
5
85
600
1.0
4.0
1.0
BZX55B3V3
3.23
3.30
3.37
5
85
600
1.0
2.0
1.0
BZX55B3V6
3.53
3.60
3.67
5
85
600
1.0
2.0
1.0
BZX55B3V9
3.82
3.90
3.98
5
85
600
1.0
2.0
1.0
BZX55B4V3
4.21
4.30
4.39
5
75
600
1.0
1.0
1.0
BZX55B4V7
4.61
4.70
4.79
5
60
600
1.0
0.5
1.0
BZX55B5V1
5.00
5.10
5.20
5
35
550
1.0
0.1
1.0
BZX55B5V6
5.49
5.60
5.71
5
25
450
1.0
0.1
1.0
BZX55B6V2
6.08
6.20
6.32
5
10
200
1.0
0.1
2.0
BZX55B6V8
6.66
6.80
6.94
5
8
150
1.0
0.1
3.0
BZX55B7V5
7.35
7.50
7.65
5
7
50
1.0
0.1
5.0
BZX55B8V2
8.04
8.20
8.36
5
7
50
1.0
0.1
6.2
BZX55B9V1
8.92
9.10
9.28
5
10
50
1.0
0.1
6.8
BZX55B10
9.80
10.00
10.20
5
15
70
1.0
0.1
7.5
BZX55B11
10.78
11.00
11.22
5
1.0
0.1
8.2
BZX55B12
11.76
12.00
12.24
5
1.0
0.1
9.1
BZX55B13
12.74
13.00
13.26
5
26
110
1.0
0.1
10
BZX55B15
14.70
15.00
15.30
5
30
110
1.0
0.1
11
BZX55B16
15.68
16.00
16.32
5
40
170
1.0
0.1
12
BZX55B18
17.64
18.00
18.36
5
50
170
1.0
0.1
14
BZX55B20
19.60
20.00
20.40
5
55
220
1.0
0.1
15
BZX55B22
21.56
22.00
22.44
5
55
220
1.0
0.1
17
BZX55B24
23.52
24.00
24.48
5
80
220
1.0
0.1
18
BZX55B27
26.46
27.00
27.54
5
80
220
1.0
0.1
BZX55B30
29.40
30.00
30.6
5
80
220
1.0
0.1
22
BZX55B33
32.34
33.00
33.66
5
80
220
1.0
0.1
24
BZX55B36
35.28
36.00
36.72
5
80
220
1.0
0.1
27
BZX55B39
38.22
39.00
39.78
2.5
90
500
0.5
0.1
28
BZX55B43
42.14
43.00
43.86
2.5
90
600
0.5
0.1
32
BZX55B47
46.06
47.00
47.94
2.5
110
700
0.5
0.1
35
BZX55B51
49.98
51.00
52.02
2.5
125
700
0.5
0.1
38
BZX55B56
54.88
56.00
57.12
2.5
135
1000
0.5
0.1
42
BZX55B62
60.76
62.00
63.24
2.5
150
1000
0.5
0.1
47
BZX55B68
66.64
68.00
69.36
2.5
160
1000
0.5
0.1
51
BZX55B75
73.50
75.00
76.50
2.5
170
1000
0.5
0.1
56
2
Version:F1610
Notes:
1. Tolerance and voltage designation : the type numbers listed have Zener voltage as shown
2. The device numbers listed have a standard tolerance on the nominal Zener voltage of ±2%
3. For detailed information on price, availability and delivery of nominal Zener voltages between the voltages
shown and tighter voltage tolerances, contact your nearest Taiwan Semiconductor representative
4. The Zener impedance is derived from the 60-cycle ac voltage, which results when an ac current having an
RMS value equal to 10% of the dc Zener current(IZT or IZK) is superimposed to IZT or IZK
ORDERING INFORMATION
PART NO.
PACKING
PACKING CODE
CODE
SUFFIX
BZX55BXXX
R0
(Note 1&2)
A0
PACKAGE
PACKING
10K / 14" Reel
G
DO-35
5K / Box (Ammo)
Notes:
1. "xxx" defines voltage from 2.4V (BZX55B2V4) to 75V (BZX55B75)
2. Whole series with green compound
EXAMPLE
EXAMPLE P/N
PART NO.
PACKING CODE
BZX55B75 R0G
BZX55B75
R0
PACKING CODE
SUFFIX
G
3
DESCRIPTION
Green compound
Version:F1610
CHARACTERISTICS CURVES
Forward Current Derating Curve
Typical Junction Capacitance
1000
500
400
100
Capactiance (pF)
Average Forward Current (A)
600
300
200
1V Bias
10
Bias at 50% of VZ (Nom)
100
80
120
160
1
200
1
10
Reverse Voltage (V)
Lead Temperature (°C)
Zener Breakdown Characteristics
100
100
TA=25oC
IZener Current (mA)
10
IZener Current (mA)
100
1
0.1
10
1
0.1
0.01
0.01
2
3
4
5
6
7
8
9
10 11 12
10
40
50
60
70
80
Zener Voltage (V)
Zener Voltage (V)
4
Version:F1610
Typical Forward Characteristics
Effect of Zener Voltage on Impedance
1000
Dynamic Impedance(Ohm)
Forward Current (mA)
1000
100
10
IZ=5mA
100
1
10
IZ=20mA
1
0.4
0.5
0.6
0.7
0.8
0.9
1.0
1.1
1.2
1
10
100
Zener Voltage (V)
Forward Voltage (V)
5
Version:F1610
PACKAGE OUTLINE DIMENSION
DO-35
DIM.
Unit(mm)
Unit(inch)
Min
Max
Min
Max
A
0.34
0.60
0.013
0.024
B
2.90
5.08
0.114
0.200
C
25.40
38.10
1.000
1.500
D
1.30
2.28
0.051
0.090
MARKING DIAGRAM
6
Version:F1610
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
7
Version:F1610
很抱歉,暂时无法提供与“BZX55B9V1 A0G”相匹配的价格&库存,您可以联系我们找货
