TSM018NB03CR RLG
TSM018NB03CR RLG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TDFN-8
    1个N沟道 耐压:30V 电流:29A 电流:194A
TSM018NB03CR RLG 数据手册
TSM018NB03CR Taiwan Semiconductor N-Channel Power MOSFET 30V, 194A, 1.8mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive losses PARAMETER VALUE UNIT VDS 30 V ● Low gate charge for fast power switching ● 100% UIS and Rg tested ● 175°C Operating Junction Temperature ● RoHS Compliant ● Halogen-free according to IEC 61249-2-21 RDS(on) VGS = 10V 1.8 (max) VGS = 4.5V 2.8 mΩ Qg 62 nC APPLICATIONS ● DC-DC Converter ● Battery Management ● Load Switch ● Motor Drive PDFN56 Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 30 V Gate-Source Voltage VGS ±20 V Continuous Drain Current TC = 25°C (Note 1) ID TA = 25°C Pulsed Drain Current (Note 2) Single Pulse Avalanche Current (Note 2) Single Pulse Avalanche Energy Total Power Dissipation Total Power Dissipation TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range 194 29 A IDM 776 A IAS EAS 52 406 A mJ PD PD 136 45 3.1 1 W W TJ, TSTG - 55 to +175 °C THERMAL PERFORMANCE PARAMETER SYMBOL MAXIMUM UNIT Junction to Case Thermal Resistance RӨJC 1.1 °C/W Junction to Ambient Thermal Resistance RӨJA 48 °C/W Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJC is guaranteed by design while RӨCA is 2 determined by the user’s board design. The RӨJA limit presented here is based on mounting on a 1 in pad of 2 oz copper. 1 Version: A1910 TSM018NB03CR Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 30 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 1 1.8 2.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA -- -- 1 -- -- 100 -- 1.4 1.8 -- 2.1 2.8 gfs -- 70 -- Qg -- 120 -- Qg -- 62 -- Qgs -- 21 -- Qgd -- 28 -- Ciss -- 7252 -- Coss -- 1056 -- Crss -- 673 -- Rg 0.5 1.8 3.6 td(on) -- 9 -- tr -- 50 -- td(off) -- 80 -- tf -- 45 -- VSD -- -- 1 V VGS = 0V, VDS = 30V Drain-Source Leakage Current IDSS VGS = 0V, VDS = 30V TJ = 125°C Drain-Source On-State Resistance VGS = 10V, ID = 29A (Note 3) VGS = 4.5V, ID = 24A Forward Transconductance Dynamic (Note 3) RDS(on) VDS = 10V, ID = 29A µA mΩ S (Note 4) VGS = 10V, VDS = 15V, Total Gate Charge ID = 29A Total Gate Charge VGS = 4.5V, VDS = 15V, Gate-Source Charge ID = 24A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 15V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 4) Turn-On Delay Time Turn-On Rise Time VGS = 10V, VDS = 15V, Turn-Off Delay Time ID = 29A, RG = 2Ω Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 3) VGS = 0V, IS = 29A Reverse Recovery Time IS = 29A, trr -- 48 -- ns Reverse Recovery Charge dI/dt = 100A/μs Qrr -- 50 -- nC Notes: 1. 2. 3. 4. Silicon limited current only. L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 52A, Starting TJ = 25°C Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. Switching time is essentially independent of operating temperature. ORDERING INFORMATION ORDERING CODE TSM018NB03CR RLG PACKAGE PACKING PDFN56 2,500pcs / 13” Reel 2 Version: A1910 TSM018NB03CR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 60 60 ID, Drain Current (A) 40 ID, Drain Current (A) VGS=10V VGS=7V VGS=5V VGS=4.5V VGS=4V VGS=3.5V 50 30 20 VGS=3V 50 40 30 25℃ 20 -55℃ 10 10 0 0 175℃ 0 1 2 3 4 0 On-Resistance vs. Drain Current 0.003 0.0025 VGS=4.5V 0.002 0.0015 VGS=10V 0.001 0.0005 4 0 VDS=15V ID=29A 8 6 4 2 0 0 10 20 30 40 50 60 0 25 On-Resistance vs. Junction Temperature RDS(on), Drain-Source On-Resistance (Ω) VGS=10V ID=29A 1.6 1.4 1.2 1 0.8 0.6 0 25 50 75 100 125 On-Resistance vs. Gate-Source Voltage 2 -75 -50 -25 50 Qg, Gate Charge (nC) ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) 3 10 0.0035 1.8 2 Gate-Source Voltage vs. Gate Charge 0.004 VGS, Gate to Source Voltage (V) RDS(ON), Drain-Source On-Resistance (Ω) 1 VGS, Gate to Source Voltage (V) VDS, Drain to Source Voltage (V) 75 100 125 150 175 0.01 0.008 0.006 0.004 ID=29A 0.002 0 3 4 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) TJ, Junction Temperature (°C) 3 Version: A1910 TSM018NB03CR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) BVDSS vs. Junction Temperature BVDSS (Normalized) Drain-Source Breakdown Voltage Capacitance vs. Drain-Source Voltage 10000 C, Capacitance (pF) 9000 8000 CISS 7000 6000 5000 4000 3000 2000 COSS 1000 CRSS 0 0 10 20 1.2 ID=5mA 1.1 1 0.9 0.8 -75 -50 -25 30 25 50 75 100 125 150 175 TJ, Junction Temperature (°C) VDS, Drain to Source Voltage (V) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 100 IS, Reverse Drain Current (A) 1000 RDS(ON) ID, Drain Current (A) 0 100 10 SINGLE PULSE RӨJC=1.1°C/W TC=25°C 10 175℃ -55℃ 25℃ 1 0.1 1 0.1 1 10 0.2 100 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=1.1°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.0001 0.001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.01 0.1 1 t, Square Wave Pulse Duration (sec) 4 Version: A1910 TSM018NB03CR Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) PDFN56 SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM TSC 018NB03 YWWLF Y WW L F = Year Code = Week Code (01~52) = Lot Code (1~9,A~Z) = Factory Code 5 Version: A1910 TSM018NB03CR Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Purchasers are solely responsible for the choice, selection, and use of TSC products and TSC assumes no liability for application assistance or the design of Purchasers’ products. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A1910
TSM018NB03CR RLG 价格&库存
很抱歉,暂时无法提供与“TSM018NB03CR RLG”相匹配的价格&库存,您可以联系我们找货
TSM018NB03CR RLG
    TSM018NB03CR RLG
    • 1+22.840821+2.96994
    • 10+14.6993810+1.91133
    • 50+11.1743050+1.45297
    • 100+10.03578100+1.30493
    • 500+8.03925500+1.04533
    库存:1775
