C3M0120090J
VDS
900 V
ID @ 25˚C
Silicon Carbide Power MOSFET
TM
C3M MOSFET Technology
RDS(on)
22 A
120 mΩ
N-Channel Enhancement Mode
Features
Package
New C3M SiC MOSFET technology
High blocking voltage with low On-resistance
High speed switching with low capacitances
New low impedance package with driver source
Fast intrinsic diode with low reverse recovery (Qrr)
Halogen free, RoHS compliant
TAB
Drain
Benefits
Drain
(TAB)
Higher system efficiency
Reduced cooling requirements
Increased power density
Increased system switching frequency
1 2 3 4 5
G KS S S S
7
S
Gate
(Pin 1)
Applications
6
S
Driver
Source
(Pin 2)
Renewable energy
EV battery chargers
High voltage DC/DC converters
Switch Mode Power Supplies
Lighting
Power
Source
(Pin 3,4,5,6,7)
Part Number
Package
C3M0120090J
7L D2PAK
Maximum Ratings (TC = 25 ˚C unless otherwise specified)
Symbol
Parameter
Unit
Test Conditions
Note
VDSmax
Drain - Source Voltage
900
V
VGS = 0 V, ID = 100 μA
VGSmax
Gate - Source Voltage
-8/+18
V
Absolute maximum values
VGSop
-4/+15
V
Recommended operational values
Note (1)
VGS = 15 V, TC = 25˚C
Fig. 19
ID
Continuous Drain Current
ID(pulse)
PD
TJ , Tstg
TL
22
14
A
VGS = 15 V, TC = 100˚C
Pulsed Drain Current
50
A
Pulse width tP limited by Tjmax
Fig. 22
Power Dissipation
83
W
TC=25˚C, TJ = 150 ˚C
Fig. 20
-55 to
+150
˚C
260
˚C
Operating Junction and Storage Temperature
Solder Temperature
Note (1): MOSFET can also safely operate at 0/+15 V
1
Value
C3M0120090J Rev. - , 12-2015
1.6mm (0.063”) from case for 10s
Electrical Characteristics (TC = 25˚C unless otherwise specified)
Symbol
Parameter
V(BR)DSS
Drain-Source Breakdown Voltage
VGS(th)
Gate Threshold Voltage
Min.
Typ.
Max.
900
1.8
2.1
3.5
1.6
Unit
Test Conditions
V
V
VDS = VGS, ID = 3 mA
V
VDS = VGS, ID = 3 mA, TJ = 150ºC
IDSS
Zero Gate Voltage Drain Current
1
100
μA
VDS = 900 V, VGS = 0 V
IGSS
Gate-Source Leakage Current
10
250
nA
VGS = 15 V, VDS = 0 V
120
155
RDS(on)
Drain-Source On-State Resistance
170
7.7
gfs
Transconductance
Ciss
Input Capacitance
350
Coss
Output Capacitance
40
Crss
Reverse Transfer Capacitance
3
Eoss
Coss Stored Energy
9
EON
Turn-On Switching Energy
49
EOFF
Turn Off Switching Energy
16
td(on)
Turn-On Delay Time
tr
td(off)
tf
RG(int)
VGS = 15 V, ID = 15 A
mΩ
VGS = 15 V, ID = 15 A, TJ = 150ºC
VDS= 15 V, IDS= 15 A
S
6.7
Note
VDS= 15 V, IDS= 15 A, TJ = 150ºC
f = 1 MHz
VAC = 25 mV
μJ
Fig. 4,
5, 6
Fig. 7
Fig. 17,
18
VGS = 0 V, VDS = 600 V
pF
Fig. 11
Fig. 16
μJ
VDS = 400 V, VGS = -4 V/15 V, ID = 15 A,
RG(ext) = 2.5Ω, L= 142 μH, TJ = 150ºC
Fig. 26,
29
ns
VDD = 400 V, VGS = -4 V/15 V
ID = 15 A, RG(ext) = 2.5 Ω,
Timing relative to VDS
Inductive load
Fig. 27,
29
Ω
f = 1 MHz, VAC = 25 mV
nC
ID = 15 A
Per IEC60747-8-4 pg 21
12.5
Rise Time
9
Turn-Off Delay Time
15
Fall Time
5
Internal Gate Resistance
16
Qgs
Gate to Source Charge
4.8
Qgd
Gate to Drain Charge
5.0
Qg
Total Gate Charge
17.3
Fig. 12
Reverse Diode Characteristics (TC = 25˚C unless otherwise specified)
Symbol
VSD
IS
IS, pulse
Parameter
Typ.
Diode Forward Voltage
Max.
Test Conditions
Unit
4.8
V
VGS = -4 V, ISD = 7.5 A
4.4
V
VGS = -4 V, ISD = 7.5 A, TJ = 150 °C
Note
Fig. 8, 9,
10
Continuous Diode Forward Current
17
A
VGS = -4 V
Note (2)
Diode pulse Current
50
A
VGS = -4 V, pulse width tP limited by Tjmax
Note (2)
VGS = -4 V, ISD = 15 A, VR = 400 V
dif/dt = 900 A/µs, TJ = 150 °C
Note (2)
trr
Reverse Recover time
24
ns
Qrr
Reverse Recovery Charge
115
nC
Irrm
Peak Reverse Recovery Current
6.2
A
Note (2): When using SiC Body Diode the maximum recommended VGS = -4V
Thermal Characteristics
Symbol
2
Parameter
Max.
RθJC
Thermal Resistance from Junction to Case
1.5
RθJA
Thermal Resistance From Junction to Ambient
40
Unit
°C/W
Test Conditions
Note
Fig. 21
Typical Performance
45
40
VGS = 15 V
35
VGS = 13 V
30
VGS = 11 V
25
VGS = 9 V
15
10
VGS = 7 V
5
VGS = 15 V
Conditions:
TJ = 25 °C
tp = < 200 µs
40
Drain-Source Current, IDS (A)
45
Conditions:
TJ = -55 °C
tp = < 200 µs
VGS = 13 V
35
VGS = 11 V
30
25
VGS = 9 V
15
10
VGS = 7 V
5
4
6
8
10
11
4
Drain-Source Voltage, VDS (V)
Figure 1. Output Characteristics TJ = -55 ºC
45
2.5
10
11
Conditions:
IDS = 15 A
VGS = 15 V
tp < 200 µs
VGS = 13 V
2.0
35
VGS = 11 V
On Resistance, RDS On (P.U.)
40
8
Figure 2. Output Characteristics TJ = 25 ºC
VGS = 15 V
Conditions:
TJ = 150 °C
tp = < 200 µs
6
30
25
VGS = 9 V
VGS = 7 V
10
1.5
1.0
0.5
5
0.0
4
6
8
10
-50
11
-25
Figure 3. Output Characteristics TJ = 150 ºC
Conditions:
VGS = 15 V
tp < 200 µs
225
250
150
On Resistance, RDS On (mOhms)
TJ = 150 °C
175
TJ = -55 °C
125
TJ = 25 °C
100
75
50
25
100
125
150
225
200
VGS = 11 V
175
150
VGS = 13 V
125
100
VGS = 15 V
75
50
25
10
15
30
35
Figure 5. On-Resistance vs. Drain Current
For Various Temperatures
3
75
Conditions:
IDS = 15 A
tp < 200 µs
275
200
50
Figure 4. Normalized On-Resistance vs. Temperature
300
250
25
Junction Temperature, TJ (°C)
40
45
-50
-25
50
75
100
Figure 6. On-Resistance vs. Temperature
For Various Gate Voltage
125
150
Typical Performance
35
30
-7
-6
-5
-4
-3
-2
-1
TJ = 150 °C
25
-8
Conditions:
VDS = 20 V
tp < 200 µs
TJ = 25 °C
TJ = -55 °C
15
10
VGS = -4 V
-10
VGS = 0 V
-15
-20
VGS = -2 V
-25
-30
5
-35
Conditions:
TJ = -55°C
tp < 200 µs
4
6
8
10
12
14
Figure 7. Transfer Characteristic for
Various Junction Temperatures
-7
-6
-5
-4
-3
-2
Figure 8. Body Diode Characteristic at -55 ºC
-1
-7
-6
-5
-4
-3
-2
-1
VGS = -2 V
-20
-25
-30
-5
-10
VGS = 0 V
VGS = -4 V
-10
VGS = 0 V
-15
-20
VGS = -2 V
-25
-30
-35
Conditions:
TJ = 25°C
tp < 200 µs
Drain-Source Voltage VDS (V)
-35
Conditions:
TJ = 150°C
tp < 200 µs
-40
-45
Figure 9. Body Diode Characteristic at 25 ºC
Gate-Source Voltage, VGS (V)
Threshold Voltage, Vth (V)
2.0
1.5
1.0
0.5
0.0
50
75
100
125
Junction Temperature TJ (°C)
Figure 11. Threshold Voltage vs. Temperature
4
Conditions:
IDS = 15 A
IGS = 10 mA
VDS = 400 V
TJ = 25 °C
12
-25
-45
16
Conditons
VGS = VDS
IDS = 3 mA
-50
-40
Figure 10. Body Diode Characteristic at 150 ºC
3.0
2.5
VGS = -4 V
-45
-8
-40
150
8
4
8
12
16
Gate Charge, QG (nC)
Figure 12. Gate Charge Characteristics
Typical Performance
-6
-5
-4
-3
-2
-1
-5
-4
-3
-2
-1
VGS = 5 V
VGS = 10 V
-20
VGS = 15 V
VGS = 0 V
VGS = 0 V
VGS = 5 V
VGS = 10 V
-20
VGS = 15 V
-30
-30
Conditions:
TJ = -55 °C
tp < 200 µs
Conditions:
TJ = 25 °C
tp < 200 µs
-40
Figure 13. 3rd Quadrant Characteristic at -55 ºC
-6
-5
-4
-3
-2
-1
-40
Figure 14. 3rd Quadrant Characteristic at 25 ºC
VGS = 0 V
VGS = 5 V
VGS = 10 V
-20
VGS = 15 V
Stored Energy, EOSS (µJ)
15
-10
10
5
-30
Conditions:
TJ = 150 °C
tp < 200 µs
100
600
700
800
900
1000
Conditions:
TJ = 25 °C
VAC = 25 mV
f = 1 MHz
Ciss
Capacitance (pF)
Capacitance (pF)
10
500
1000
Coss
100
400
Figure 16. Output Capacitor Stored Energy
Conditions:
TJ = 25 °C
VAC = 25 mV
f = 1 MHz
Ciss
300
Drain to Source Voltage, VDS (V)
Figure 15. 3rd Quadrant Characteristic at 150 ºC
1000
200
Crss
100
Coss
10
Crss
1
1
100
150
Figure 17. Capacitances vs. Drain-Source
Voltage (0 - 200V)
5
200
200
300
400
500
600
700
Figure 18. Capacitances vs. Drain-Source
Voltage (0 - 900V)
800
900
Typical Performance
90
Conditions:
TJ ≤ 150 °C
Maximum Dissipated Power, Ptot (W)
Drain-Source Continous Current, IDS (DC) (A)
25
10
5
-30
-5
70
95
120
Conditions:
TJ ≤ 150 °C
80
70
60
50
40
30
-55
Case Temperature, TC (°C)
70
95
120
0.1
100E-3
0.05
0.02
0.01
10E-3
SinglePulse
Limited by RDS On
10.00
10E-6
100E-6
1E-3
10E-3
Time, tp (s)
100E-3
100 ms
1.00
0.10
Conditions:
TC = 25 °C
D = 0,
Parameter: tp
0.1
1
ETotal
120
EOn
80
1000
80
ETotal
60
EOn
40
EOff
EOff
40
100
Conditions:
TJ = 25 °C
VDD = 400 V
RG(ext) = 2.5 Ω
VGS = -4V/+15 V
FWD = C3M0120090J
L = 142 μH
100
Switching Loss (uJ)
160
10
Figure 22. Safe Operating Area
120
Conditions:
TJ = 25 °C
VDD = 600 V
RG(ext) = 2.5 Ω
VGS = -4V/+15 V
FWD = C3M0120090J
L = 142 μH
1
Figure 21. Transient Thermal Impedance
(Junction - Case)
200
100 µs
1 ms
0.01
1E-6
145
10 µs
Junction To Case Impedance, ZthJC (oC/W)
45
0.5
0.3
Switching Loss (uJ)
Figure 20. Maximum Power Dissipation Derating vs.
Case Temperature
1E-3
10
15
Drain to Source Current, IDS (A)
Figure 23. Clamped Inductive Switching Energy vs.
Drain Current (VDD = 600V)
6
-5
Figure 19. Continuous Drain Current Derating vs.
Case Temperature
1
-30
25
10
15
Figure 24. Clamped Inductive Switching Energy vs.
Drain Current (VDD = 400V)
25
Typical Performance
120
Switching Loss (uJ)
100
Conditions:
TJ = 25 °C
VDD = 400 V
IDS = 15 A
VGS = -4V/+15 V
FWD = C3M0120090J
L = 142 μH
80
90
EOn
60
EOff
30
ETotal
60
EOn
40
EOff
10
15
Conditions:
TJ = 25 °C
VDD = 400 V
IDS = 15 A
VGS = -4V/+15 V
FWD = C3M0120090J
L = 142 μH
25
50
75
100
125
td(off)
td(on)
15
tr
10
tf
5
10
15
External Gate Resistor RG(ext) (Ohms)
Figure 27. Switching Times vs. RG(ext)
7
150
Figure 26. Clamped Inductive Switching Energy vs.
Temperature
Figure 25. Clamped Inductive Switching Energy vs. RG(ext)
30
Times (ns)
Conditions:
IDS = 15 A
VDD = 400 V
RG(ext) = 2.5 Ω
VGS = -4V/+15 V
FWD = C3M0120090J
L = 142 μH
ETotal
Switching Loss (uJ)
150
Figure 28. Switching Times Definition
175
Test Circuit Schematic
Q1
RG
VGS= - 4V
VDC
Q2
RG
D.U.T
Figure 29. Clamped Inductive Switching Test Circuit
Note (3): Turn-off and Turn-on switching energy and timing values measured using SiC MOSFET Body Diode as shown above.
8
Package Dimensions
Package 7L D2PAK
Dim
All Dimensions in Millimeters
Min
Max
4.570
A
4.300
4.435
A1
0.00
0.125
0.25
b
0.500
0.600
0.700
b2
0.600
0.800
1.000
c
0.330
0.490
0.650
C2
1.170
1.285
1.400
9.125
D
9.025
9.075
D1
4.700
4.800
4.900
E
10.130
10.180
10.230
E1
6.500
7.550
8.600
E2
6.778
7.223
7.665
e
9
typ
1.27
H
15.043
16.178
17.313
L
2.324
2.512
2.700
L1
0.968
1.418
1.868
Ø
0˚
4˚
8˚
Ø1
4.5˚
5˚
5.5˚
Notes
RoHS Compliance
The levels of RoHS restricted materials in this product are below the maximum concentration values (also referred to as the
threshold limits) permitted for such substances, or are used in an exempted application, in accordance with EU Directive 2011/65/
EC (RoHS2), as implemented January 2, 2013. RoHS Declarations for this product can be obtained from your Cree representative or
from the Product Documentation sections of www.cree.com.
REACh Compliance
REACh substances of high concern (SVHCs) information is available for this product. Since the European Chemical Agency (ECHA)
has published notice of their intent to frequently revise the SVHC listing for the foreseeable future,please contact a Cree representative to insure you get the most up-to-date REACh SVHC Declaration. REACh banned substance information (REACh Article 67) is
also available upon request.
This product has not been designed or tested for use in, and is not intended for use in, applications implanted into the human body
nor in applications in which failure of the product could lead to death, personal injury or property damage, including but not limited
to equipment used in the operation of nuclear facilities, life-support machines, cardiac defibrillators or similar emergency medical
equipment, aircraft navigation or communication or control systems, air traffic control systems.
Related Links
C2M PSPICE Models: http://wolfspeed.com/power/tools-and-support
SiC MOSFET Isolated Gate Driver reference design: http://wolfspeed.com/power/tools-and-support
SiC MOSFET Evaluation Board: http://wolfspeed.com/power/tools-and-support
Copyright © 2015 Cree, Inc. All rights reserved.
The information in this document is subject to change without notice.
Cree, the Cree logo, and Zero Recovery are registered trademarks of Cree, Inc.
10
C3M0120090J Rev. -, 12-2015
Cree, Inc.
4600 Silicon Drive
Durham, NC 27703
USA Tel: +1.919.313.5300
Fax: +1.919.313.5451
www.cree.com/power
Mouser Electronics
Authorized Distributor
Click to View Pricing, Inventory, Delivery & Lifecycle Information:
Cree, Inc.:
C3M0120090J C3M0120090J-TR
