TSM061NA03CV RGG
TSM061NA03CV RGG
    TAIWANSEMICONDUCTOR(台湾半导体)
    WDFN8
    MOSFET N-CH 30V 66A 8PDFN
TSM061NA03CV RGG 数据手册
TSM061NA03CV Taiwan Semiconductor N-Channel Power MOSFET 30V, 66A, 6.1mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive loss PARAMETER VALUE UNIT VDS 30 V ● Low gate charge for fast power switching ● 100% UIS and Rg tested ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 RDS(on) VGS = 10V 6.1 (max) VGS = 4.5V 8.1 mΩ Qg nC en de d 9.6 APPLICATIONS ● DC-DC Converters ● Battery Power Management ● ORing FET/Load Switching mm PDFN33 eco Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER No tR Drain-Source Voltage Gate-Source Voltage Continuous Drain Current TC = 25°C (Note 1) Pulsed Drain Current (Note 2) Single Pulse Avalanche Current (Note 2) Single Pulse Avalanche Energy Total Power Dissipation LIMIT UNIT VDS 30 V VGS ±20 V ID TA = 25°C Total Power Dissipation SYMBOL TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range 66 15 A IDM 264 A IAS EAS 20.5 63 A mJ PD PD 44.6 8.9 2.3 0.5 W W TJ, TSTG - 55 to +150 °C SYMBOL LIMIT UNIT Junction to Case Thermal Resistance RӨJC 2.8 °C/W Junction to Ambient Thermal Resistance RӨJA 53 °C/W THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: B1610 TSM061NA03CV Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 30 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 1.2 1.9 2.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA -- -- 1 -- -- 100 Drain-Source Leakage Current IDSS VGS = 0V, VDS = 30V TJ = 125°C VGS = 10V, ID = 15A (Note 3) VGS = 4.5V, ID = 15A Forward Transconductance VDS = 5V, ID = 15A gfs (Note 4) VGS = 10V, VDS = 15V, Total Gate Charge ID = 15A Total Gate Charge ID = 15A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 15V Output Capacitance f = 1.0MHz Gate Resistance Switching e co Reverse Transfer Capacitance f = 1.0MHz (Note 4) VGS = 10V, VDS = 15V, tR Turn-On Delay Time Turn-On Rise Time ID = 7.5A, RG = 10Ω, Turn-Off Delay Time 4.8 6.1 -- 6.7 8.1 -- 51 -- RL = 2Ω Turn-Off Fall Time mΩ S Qg -- 19.3 -- Qg -- 9.6 -- Qgs -- 4 -- Qgd -- 3.7 -- Ciss -- 1136 -- Coss -- 273 -- Crss -- 106 -- Rg 0.3 1 2 td(on) -- 11.6 -- tr -- 5.8 -- td(off) -- 34.4 -- tf -- 7.8 -- VSD -- -- 1.2 V mm VGS = 4.5V, VDS = 15V, Gate-Source Charge -- en Dynamic (Note 3) RDS(on) de Drain-Source On-State Resistance µA d VGS = 0V, VDS = 30V nC pF Ω ns No Source-Drain Diode Forward Voltage (Note 3) VGS = 0V, IS = 15A Reverse Recovery Time IS = 15A , trr -- 23 -- ns Reverse Recovery Charge dI/dt = 100A/μs Qrr -- 16 -- nC Notes: 1. 2. 3. 4. Silicon limited current only. L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 20.5A, Starting TJ = 25°C Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. Switching time is essentially independent of operating temperature. ORDERING INFORMATION PART NO. PACKAGE PACKING TSM061NA03CV RGG PDFN33 5,000pcs / 13” Reel 2 Version: B1610 TSM061NA03CV Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 40 40 16 VGS=3V 8 24 25℃ d 24 32 16 de ID, Drain Current (A) 32 ID, Drain Current (A) VGS=10V VGS=5V VGS=4.5V VGS=4V VGS=3.5V 8 150℃ 0 0 1 2 3 4 0 2 3 4 Gate-Source Voltage vs. Gate Charge mm On-Resistance vs. Drain Current 0.012 VDS=15V ID=15A 8 6 e co 0.01 VGS, Gate to Source Voltage (V) 10 0.014 0.008 VGS=4.5V 0.006 0.004 VGS=10V 0.002 0 tR RDS(ON), Drain-Source On-Resistance (Ω) 1 VGS, Gate to Source Voltage (V) VDS, Drain to Source Voltage (V) 8 16 24 32 4 2 0 40 0 4 No On-Resistance vs. Junction Temperature RDS(on), Drain-Source On-Resistance (Ω) 1.8 1.6 1.4 1.2 VGS=10V ID=15A 0.8 0.6 -75 -50 -25 0 25 50 75 12 16 20 On-Resistance vs. Gate-Source Voltage 2 1 8 Qg, Gate Charge (nC) ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) -55℃ en 0 100 125 150 0.03 0.025 0.02 0.015 0.01 ID=15A 0.005 0 3 4 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) TJ, Junction Temperature (°C) 3 Version: B1610 TSM061NA03CV Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) BVDSS vs. Junction Temperature CISS 1200 1000 800 600 400 COSS CRSS 200 0 5 10 15 20 25 0.9 0.8 -75 30 -50 -25 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) VDS, Drain to Source Voltage (V) Source-Drain Diode Forward Current vs. Voltage mm Maximum Safe Operating Area, Junction-to-Case RDS(ON) 10 1 0.1 tR SINGLE PULSE RӨJC=2.8°C/W TC=25°C 1 10 25℃ 10 e co 100 IS, Reverse Drain Current (A) 100 1000 ID, Drain Current (A) 1 en 0 ID=1mA 1.1 d C, Capacitance (pF) 1400 1.2 de BVDSS (Normalized) Drain-Source Breakdown Voltage Capacitance vs. Drain-Source Voltage 1600 150℃ -55℃ 1 0.1 0 100 0.2 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) No VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=2.8°C/W 1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.1 0.01 0.001 0.00001 0.0001 0.001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.01 0.1 t, Square Wave Pulse Duration (sec) 4 Version: B1610 TSM061NA03CV Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) en de d PDFN33 tR e co mm SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM Y = Year Code M = Month Code O =Jan P =Feb S =May T =Jun W =Sep X =Oct L = Lot Code (1~9, A~Z) No TSC 061NA03 YML Q =Mar U =Jul Y =Nov R =Apr V =Aug Z =Dec 5 Version: B1610 TSM061NA03CV No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: B1610
TSM061NA03CV RGG 价格&库存
很抱歉,暂时无法提供与“TSM061NA03CV RGG”相匹配的价格&库存,您可以联系我们找货
TSM061NA03CV RGG
  • 10000+3.7732710000+0.48557
