RFD3055LESM9A
RFD3055LESM9A
    L3HARRIS
    TO-252(DPAK)
    MOSFET N-CH 60V 11A TO252AA
RFD3055LESM9A 数据手册
RFD3055LE, RFD3055LESM Data Sheet N-Channel Logic Level Power MOSFET 60V, 11A, 107 mΩ These N-Channel enhancement-mode power MOSFETs are manufactured using the latest manufacturing process technology. This process, which uses feature sizes approaching those of LSI circuits, gives optimum utilization of silicon, resulting in outstanding performance. They were designed for use in applications such as switching regulators, switching converters, motor drivers and relay drivers. These transistors can be operated directly from integrated circuits. Formerly developmental type TA49158. September 2013 Features • 11A, 60V • rDS(ON) = 0.107Ω • Temperature Compensating PSPICE® Model • Peak Current vs Pulse Width Curve • UIS Rating Curve • Related Literature - TB334 “Guidelines for Soldering Surface Mount Components to PC Boards” Symbol Ordering Information PART NUMBER D PACKAGE BRAND RFD3055LE TO-251AA F3055L RFD3055LESM9A TO-252AA F3055L G S Packaging JEDEC TO-251AA JEDEC TO-252AA SOURCE DRAIN GATE DRAIN (FLANGE) ©2002 Fairchild Semiconductor Corporation DRAIN (FLANGE) GATE SOURCE RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM Absolute Maximum Ratings TC = 25oC, Unless Otherwise Specified RFD3055LE, RFD3055LESM9A 60 60 ±16 11 Refer to Peak Current Curve Refer to UIS Curve 38 0.25 -55 to 175 Drain to Source Voltage (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . VDSS Drain to Gate Voltage (RGS = 20kΩ) (Note 1) . . . . . . . . . . . . . . . . . . . . . . . . . . VDGR Gate to Source Voltage . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .VGS Continuous Drain Current . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . ID Pulsed Drain Current (Note 3) . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . IDM Single Pulse Avalanche Rating . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .EAS Power Dissipation . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . .PD Derate Above 25oC . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . Operating and Storage Temperature . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . . TJ, TSTG Maximum Temperature for Soldering Leads at 0.063in (1.6mm) from Case for 10s. . . . . . . . . . . . . . . . . . . . . . . . . . . . TL Package Body for 10s, See Techbrief 334 . . . . . . . . . . . . . . . . . . . . . . . . . . . . Tpkg UNITS V V V A W W/oC oC oC oC 300 260 CAUTION: Stresses above those listed in “Absolute Maximum Ratings” may cause permanent damage to the device. This is a stress only rating and operation of the device at these or any other conditions above those indicated in the operational sections of this specification is not implied. NOTE: 1. TJ = 25oC to 150oC. Electrical Specifications TC = 25oC, Unless Otherwise Specified MIN TYP MAX UNITS Drain to Source Breakdown Voltage PARAMETER SYMBOL BVDSS ID = 250µA, VGS = 0V 60 - - V Gate Threshold Voltage VGS(TH) VGS = VDS, ID = 250µA 1 - 3 V VDS = 55V, VGS = 0V - - 1 µA VDS = 50V, VGS = 0V, TC = 150oC - - 250 µA VGS = ±16V - - ±100 nA ID = 8A, VGS = 5V (Figure 11) - - 0.107 Ω VDD ≈ 30V, ID = 8A, VGS = 4.5V, RGS = 32Ω (Figures 10, 18, 19) - - 170 ns Zero Gate Voltage Drain Current IDSS Gate to Source Leakage Current IGSS Drain to Source On Resistance (Note 2) rDS(ON) Turn-On Time tON Turn-On Delay Time - 8 - ns tr - 105 - ns td(OFF) - 22 - ns tf - 39 - ns td(ON) Rise Time Turn-Off Delay Time Fall Time Turn-Off Time TEST CONDITIONS tOFF Total Gate Charge Gate Charge at 5V Threshold Gate Charge VDD = 30V, ID = 8A, Ig(REF) = 1.0mA (Figures 20, 21) - - 92 ns - 9.4 11.3 nC Qg(TOT) VGS = 0V to 10V Qg(5) VGS = 0V to 5V - 5.2 6.2 nC Qg(TH) VGS = 0V to 1V - 0.36 0.43 nC VDS = 25V, VGS = 0V, f = 1MHz (Figure 14) - 350 - pF - 105 - pF Input Capacitance CISS Output Capacitance COSS Reverse Transfer Capacitance CRSS - 23 - pF Thermal Resistance Junction to Case RθJC - - 3.94 oC/W Thermal Resistance Junction to Ambient RθJA TO-220AB - - 62 oC/W TO-251AA, TO-252AA - - 100 oC/W TYP MAX UNITS ISD = 8A - 1.25 V ISD = 8A, dISD/dt = 100A/µs - 66 ns Source to Drain Diode Specifications PARAMETER SYMBOL Source to Drain Diode Voltage VSD Diode Reverse Recovery Time trr TEST CONDITIONS MIN NOTES: 2. Pulse Test: Pulse Width ≤ 300ms, Duty Cycle ≤ 2%. 3. Repetitive Rating: Pulse Width limited by max junction temperature. See Transient Thermal Impedance Curve (Figure 3) and Peak Current Capability Curve (Figure 5). ©2002 Fairchild Semiconductor Corporation RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM Typical Performance Curves Unless Otherwise Specified POWER DISSIPATION MULTIPLIER 1.2 15 ID, DRAIN CURRENT (A) 1.0 0.8 0.6 0.4 VGS = 10V 10 VGS = 4.5V 5 0.2 0 0 25 0 125 50 75 100 TC , CASE TEMPERATURE (oC) 150 25 175 50 75 100 125 150 175 TC, CASE TEMPERATURE (oC) FIGURE 1. NORMALIZED POWER DISSIPATION vs CASE TEMPERATURE FIGURE 2. MAXIMUM CONTINUOUS DRAIN CURRENT vs CASE TEMPERATURE 2 ZθJC, NORMALIZED THERMAL IMPEDANCE 1 DUTY CYCLE - DESCENDING ORDER 0.5 0.2 0.1 0.05 0.02 0.01 PDM 0.1 t1 t2 NOTES: DUTY FACTOR: D = t1/t2 PEAK TJ = PDM x ZθJC x RθJC + TC SINGLE PULSE 0.01 10-5 10-4 10-3 10-2 10-1 100 101 t, RECTANGULAR PULSE DURATION (s) FIGURE 3. NORMALIZED TRANSIENT THERMAL IMPEDANCE 200 10 IDM, PEAK CURRENT (A) ID, DRAIN CURRENT (A) 100 100µs OPERATION IN THIS AREA MAY BE LIMITED BY rDS(ON) 1 1ms 10ms SINGLE PULSE TJ = MAX RATED TC = 25oC 0.1 10 100 VDS, DRAIN TO SOURCE VOLTAGE (V) FIGURE 4. FORWARD BIAS SAFE OPERATING AREA ©2002 Fairchild Semiconductor Corporation 200 FOR TEMPERATURES ABOVE 25oC DERATE PEAK CURRENT AS FOLLOWS: 100 I = I25 175 - TC 150 VGS = 5V 10 1 TC = 25oC TRANSCONDUCTANCE MAY LIMIT CURRENT IN THIS REGION 10-5 10-4 10-3 10-2 10-1 100 101 t, PULSE WIDTH (s) FIGURE 5. PEAK CURRENT CAPABILITY RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM Typical Performance Curves Unless Otherwise Specified (Continued) 15 VGS = 10V If R = 0 tAV = (L)(IAS)/(1.3*RATED BVDSS - VDD) If R ≠ 0 tAV = (L/R)ln[(IAS*R)/(1.3*RATED BVDSS - VDD) +1] ID, DRAIN CURRENT (A) IAS, AVALANCHE CURRENT (A) 100 STARTING TJ = 25oC 10 STARTING TJ = 150oC 1 VGS = 5V 12 9 VGS = 3.5V 6 PULSE DURATION = 80µs DUTY CYCLE = 0.5% MAX 3 0.01 0.1 1 10 VGS = 3V TC = 25oC 0 0.001 VGS = 4V 0 1 2 3 VDS, DRAIN TO SOURCE VOLTAGE (V) tAV, TIME IN AVALANCHE (ms) 4 NOTE: Refer to Fairchild Application Notes AN9321 and AN9322 FIGURE 7. SATURATION CHARACTERISTICS FIGURE 6. UNCLAMPED INDUCTIVE SWITCHING 150 15 ID, DRAIN CURRENT (A) 12 rDS(ON), DRAIN TO SOURCE ON RESISTANCE (mΩ) PULSE DURATION = 80µs DUTY CYCLE = 0.5% MAX VDD = 15V 9 TJ = 25oC 6 3 TJ = 175oC ID = 3A ID = 5A PULSE DURATION = 80µs DUTY CYCLE = 0.5% MAX TC = 25oC 120 90 TJ = -55oC 0 60 2 3 4 5 2 4 6 8 VGS, GATE TO SOURCE VOLTAGE (V) VGS, GATE TO SOURCE VOLTAGE (V) FIGURE 8. TRANSFER CHARACTERISTICS 10 FIGURE 9. DRAIN TO SOURCE ON RESISTANCE vs GATE VOLTAGE AND DRAIN CURRENT 150 2.5 NORMALIZED DRAIN TO SOURCE ON RESISTANCE VGS = 4.5V, VDD = 30V, ID = 8A SWITCHING TIME (ns) ID = 11A tr 100 tf 50 td(OFF) td(ON) PULSE DURATION = 80µs DUTY CYCLE = 0.5% MAX 2.0 1.5 1.0 VGS = 10V, ID = 11A 0.5 0 0 10 20 30 40 RGS, GATE TO SOURCE RESISTANCE (Ω) FIGURE 10. SWITCHING TIME vs GATE RESISTANCE ©2002 Fairchild Semiconductor Corporation 50 -80 -40 0 40 80 120 160 200 TJ, JUNCTION TEMPERATURE (oC) FIGURE 11. NORMALIZED DRAIN TO SOURCE ON RESISTANCE vs JUNCTION TEMPERATURE RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM Typical Performance Curves Unless Otherwise Specified (Continued) 1.2 1.2 NORMALIZED DRAIN TO SOURCE BREAKDOWN VOLTAGE NORMALIZED GATE THRESHOLD VOLTAGE VGS = VDS, ID = 250µA 1.0 0.8 1.1 1.0 0.9 0.6 -80 -40 0 40 80 120 160 TJ, JUNCTION TEMPERATURE (oC) -80 200 -40 0 40 80 120 160 200 TJ , JUNCTION TEMPERATURE (oC) FIGURE 12. NORMALIZED GATE THRESHOLD VOLTAGE vs JUNCTION TEMPERATURE FIGURE 13. NORMALIZED DRAIN TO SOURCE BREAKDOWN VOLTAGE vs JUNCTION TEMPERATURE 10 VGS , GATE TO SOURCE VOLTAGE (V) 1000 CISS = CGS + CGD C, CAPACITANCE (pF) ID = 250µA COSS ≅ CDS + CGD 100 VGS = 0V, f = 1MHz CRSS = CGD 6 4 WAVEFORMS IN DESCENDING ORDER: ID = 11A ID = 5A ID = 3A 2 0 60 1 10 VDS , DRAIN TO SOURCE VOLTAGE (V) 8 0 10 0.1 VDD = 30V 2 4 6 Qg, GATE CHARGE (nC) 8 10 NOTE: Refer to Fairchild Application Notes AN7254 and AN7260. FIGURE 14. CAPACITANCE vs DRAIN TO SOURCE VOLTAGE FIGURE 15. NORMALIZED SWITCHING WAVEFORMS FOR CONSTANT GATE CURRENT Test Circuits and Waveforms VDS BVDSS L VARY tP TO OBTAIN REQUIRED PEAK IAS tP + RG VDS IAS VDD VDD - VGS DUT 0V tP IAS 0 0.01Ω tAV FIGURE 16. UNCLAMPED ENERGY TEST CIRCUIT ©2002 Fairchild Semiconductor Corporation FIGURE 17. UNCLAMPED ENERGY WAVEFORMS RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM Test Circuits and Waveforms (Continued) tON tOFF td(ON) VDS td(OFF) tf tr VDS 90% 90% RL VGS + - DUT 10% 0 VDD 10% 90% RGS VGS VGS 0 10% FIGURE 18. SWITCHING TEST CIRCUIT 50% 50% PULSE WIDTH FIGURE 19. RESISTIVE SWITCHING WAVEFORMS VDS VDD RL Qg(TOT) VDS Qg(10) OR Qg(5) VGS + VDD VGS DUT Ig(REF) VGS = 2V 0 VGS = 1V FOR L2 DEVICES Qg(TH) VGS = 20V VGS = 10V FOR L2 DEVICES VGS = 10V VGS = 5V FOR L2 DEVICES Ig(REF) 0 FIGURE 20. GATE CHARGE TEST CIRCUIT ©2002 Fairchild Semiconductor Corporation FIGURE 21. GATE CHARGE WAVEFORMS RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM PSPICE Electrical Model .SUBCKT RFD3055LE 2 1 3 ; rev 1/30/95 CA 12 8 3.9e-9 CB 15 14 4.9e-9 CIN 6 8 3.25e-10 DBODY 7 5 DBODYMOD DBREAK 5 11 DBREAKMOD DPLCAP 10 5 DPLCAPMOD LDRAIN DPLCAP DRAIN 2 5 10 5 51 ESLC 11 - RDRAIN 6 8 EVTHRES + 19 8 + LGATE GATE 1 MMED 16 6 8 8 MMEDMOD MSTRO 16 6 8 8 MSTROMOD MWEAK 16 21 8 8 MWEAKMOD + 17 EBREAK 18 50 ESG EVTEMP RGATE + 18 22 9 20 21 DBODY - 16 MWEAK 6 MMED MSTRO RLGATE LSOURCE CIN 8 SOURCE 3 7 RSOURCE RBREAK 17 18 RBREAKMOD 1 RDRAIN 50 16 RDRAINMOD 3.7e-2 RGATE 9 20 3.37 RLDRAIN 2 5 10 RLGATE 1 9 54.2 RLSOURCE 3 7 25.7 RSLC1 5 51 RSLCMOD 1e-6 RSLC2 5 50 1e3 RSOURCE 8 7 RSOURCEMOD 2.50e-2 RVTHRES 22 8 RVTHRESMOD 1 RVTEMP 18 19 RVTEMPMOD 1 S1A S1B S2A S2B DBREAK + RSLC2 IT 8 17 1 LDRAIN 2 5 1.0e-9 LGATE 1 9 5.42e-9 LSOURCE 3 7 2.57e-9 RLDRAIN RSLC1 51 EBREAK 11 7 17 18 67.8 EDS 14 8 5 8 1 EGS 13 8 6 8 1 ESG 6 10 6 8 1 EVTHRES 6 21 19 8 1 EVTEMP 20 6 18 22 1 RLSOURCE S1A 12 S2A 13 8 14 13 S1B CA RBREAK 15 17 18 RVTEMP S2B 13 CB 6 8 EGS - 6 12 13 8 S1AMOD 13 12 13 8 S1BMOD 6 15 14 13 S2AMOD 13 15 14 13 S2BMOD 19 - IT 14 + + VBAT 5 8 EDS - + 8 22 RVTHRES VBAT 22 19 DC 1 ESLC 51 50 VALUE={(V(5,51)/ABS(V(5,51)))*(PWR(V(5,51)/(1e-6*30),3))} .MODEL DBODYMOD D (IS = 1.75e-13 RS = 1.75e-2 TRS1 = 1e-4 TRS2 = 5e-6 CJO = 5.9e-10 TT = 5.45e-8 N = 1.03 M = 0.6) .MODEL DBREAKMOD D (RS = 6.50e-1 TRS1 = 1.25e-4 TRS2 = 1.34e-6) .MODEL DPLCAPMOD D (CJO = 3.21e-10 IS = 1e-30 N = 10 M = 0.81) .MODEL MMEDMOD NMOS (VTO = 2.02 KP = .83 IS = 1e-30 N = 10 TOX = 1 L = 1u W = 1u RG = 3.37) .MODEL MSTROMOD NMOS (VTO = 2.39 KP = 14 IS = 1e-30 N = 10 TOX = 1 L = 1u W = 1u) .MODEL MWEAKMOD NMOS (VTO = 1.78 KP = 0.02 IS = 1e-30 N = 10 TOX = 1 L = 1u W = 1u RG = 33.7 RS = 0.1) .MODEL RBREAKMOD RES (TC1 = 1.06e-3 TC2 = 0) .MODEL RDRAINMOD RES (TC1 = 1.23e-2 TC2 = 2.58e-5) .MODEL RSLCMOD RES (TC1 = 0 TC2 = 0) .MODEL RSOURCEMOD RES (TC1 = 1e-3 TC2 = 0) .MODEL RVTHRESMOD RES (TC1 = -2.19e-3 TC2 = -4.97e-6) .MODEL RVTEMPMOD RES (TC1 = -1.6e-3 TC2 = 1e-7) .MODEL S1AMOD VSWITCH (RON = 1e-5 .MODEL S1BMOD VSWITCH (RON = 1e-5 .MODEL S2AMOD VSWITCH (RON = 1e-5 .MODEL S2BMOD VSWITCH (RON = 1e-5 ROFF = 0.1 ROFF = 0.1 ROFF = 0.1 ROFF = 0.1 VON = -4 VOFF= -2.5) VON = -2.5 VOFF= -4) VON = -0.5 VOFF= 0) VON = 0 VOFF= -0.5) .ENDS For further discussion of the PSPICE model, consult A New PSPICE Sub-Circuit for the Power MOSFET Featuring Global Temperature Options; IEEE Power Electronics Specialist Conference Records, 1991, written by William J. Hepp and C. Frank Wheatley. ©2002 Fairchild Semiconductor Corporation RFD3055LE, RFD3055LESM Rev. C0 RFD3055LE, RFD3055LESM TRADEMARKS The following includes registered and unregistered trademarks and service marks, owned by Fairchild Semiconductor and/or its global subsidiaries, and is not intended to be an exhaustive list of all such trademarks. Sync-Lock™ F-PFS™ AccuPower™ ® FRFET® AX-CAP®* ®* ® SM BitSiC™ Global Power Resource PowerTrench GreenBridge™ PowerXS™ Build it Now™ TinyBoost® Green FPS™ Programmable Active Droop™ CorePLUS™ TinyBuck® ® Green FPS™ e-Series™ QFET CorePOWER™ TinyCalc™ QS™ Gmax™ CROSSVOLT™ TinyLogic® GTO™ Quiet Series™ CTL™ TINYOPTO™ IntelliMAX™ RapidConfigure™ Current Transfer Logic™ TinyPower™ ISOPLANAR™ DEUXPEED® ™ TinyPWM™ Dual Cool™ Marking Small Speakers Sound Louder TinyWire™ EcoSPARK® Saving our world, 1mW/W/kW at a time™ and Better™ TranSiC™ EfficentMax™ SignalWise™ MegaBuck™ TriFault Detect™ ESBC™ SmartMax™ MICROCOUPLER™ TRUECURRENT®* SMART START™ MicroFET™ ® SerDes™ Solutions for Your Success™ MicroPak™ SPM® MicroPak2™ Fairchild® STEALTH™ MillerDrive™ Fairchild Semiconductor® UHC® SuperFET® MotionMax™ FACT Quiet Series™ ® Ultra FRFET™ SuperSOT™-3 mWSaver FACT® UniFET™ SuperSOT™-6 OptoHiT™ FAST® VCX™ SuperSOT™-8 OPTOLOGIC® FastvCore™ VisualMax™ OPTOPLANAR® SupreMOS® FETBench™ VoltagePlus™ SyncFET™ FPS™ XS™ tm *Trademarks of System General Corporation, used under license by Fairchild Semiconductor. DISCLAIMER FAIRCHILD SEMICONDUCTOR RESERVES THE RIGHT TO MAKE CHANGES WITHOUT FURTHER NOTICE TO ANY PRODUCTS HEREIN TO IMPROVE RELIABILITY, FUNCTION, OR DESIGN. FAIRCHILD DOES NOT ASSUME ANY LIABILITY ARISING OUT OF THE APPLICATION OR USE OF ANY PRODUCT OR CIRCUIT DESCRIBED HEREIN; NEITHER DOES IT CONVEY ANY LICENSE UNDER ITS PATENT RIGHTS, NOR THE RIGHTS OF OTHERS. THESE SPECIFICATIONS DO NOT EXPAND THE TERMS OF FAIRCHILD’S WORLDWIDE TERMS AND CONDITIONS, SPECIFICALLY THE WARRANTY THEREIN, WHICH COVERS THESE PRODUCTS. LIFE SUPPORT POLICY FAIRCHILD’S PRODUCTS ARE NOT AUTHORIZED FOR USE AS CRITICAL COMPONENTS IN LIFE SUPPORT DEVICES OR SYSTEMS WITHOUT THE EXPRESS WRITTEN APPROVAL OF FAIRCHILD SEMICONDUCTOR CORPORATION. As used here in: 1. Life support devices or systems are devices or systems which, (a) are intended for surgical implant into the body or (b) support or sustain life, and (c) whose failure to perform when properly used in accordance with instructions for use provided in the labeling, can be reasonably expected to result in a significant injury of the user. 2. A critical component in any component of a life support, device, or system whose failure to perform can be reasonably expected to cause the failure of the life support device or system, or to affect its safety or effectiveness. ANTI-COUNTERFEITING POLICY Fairchild Semiconductor Corporation’s Anti-Counterfeiting Policy. Fairchild’s Anti-Counterfeiting Policy is also stated on our external website, www.Fairchildsemi.com, under Sales Support. Counterfeiting of semiconductor parts is a growing problem in the industry. All manufactures of semiconductor products are experiencing counterfeiting of their parts. Customers who inadvertently purchase counterfeit parts experience many problems such as loss of brand reputation, substandard performance, failed application, and increased cost of production and manufacturing delays. Fairchild is taking strong measures to protect ourselves and our customers from the proliferation of counterfeit parts. Fairchild strongly encourages customers to purchase Fairchild parts either directly from Fairchild or from Authorized Fairchild Distributors who are listed by country on our web page cited above. Products customers buy either from Fairchild directly or from Authorized Fairchild Distributors are genuine parts, have full traceability, meet Fairchild’s quality standards for handing and storage and provide access to Fairchild’s full range of up-to-date technical and product information. Fairchild and our Authorized Distributors will stand behind all warranties and will appropriately address and warranty issues that may arise. Fairchild will not provide any warranty coverage or other assistance for parts bought from Unauthorized Sources. Fairchild is committed to combat this global problem and encourage our customers to do their part in stopping this practice by buying direct or from authorized distributors. PRODUCT STATUS DEFINITIONS Definition of Terms Datasheet Identification Product Status Definition Advance Information Formative / In Design Datasheet contains the design specifications for product development. Specifications may change in any manner without notice. Preliminary First Production Datasheet contains preliminary data; supplementary data will be published at a later date. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve design. No Identification Needed Full Production Datasheet contains final specifications. Fairchild Semiconductor reserves the right to make changes at any time without notice to improve the design. Obsolete Not In Production Datasheet contains specifications on a product that is discontinued by Fairchild Semiconductor. The datasheet is for reference information only. Rev. I66 ©2002 Fairchild Semiconductor Corporation RFD3055LE, RFD3055LESM Rev. C0
RFD3055LESM9A 价格&库存
很抱歉,暂时无法提供与“RFD3055LESM9A”相匹配的价格&库存,您可以联系我们找货
