TSM70N380
Taiwan Semiconductor
N-Channel Power MOSFET
700V, 11A, 0.38Ω
FEATURES
KEY PERFORMANCE PARAMETERS
Super-Junction technology
High performance due to small figure-of-merit
High ruggedness performance
High commutation performance
PARAMETER
VALUE
UNIT
VDS
700
V
RDS(on) (max)
0.38
Ω
Qg
18.8
nC
IPAK/DPAK
UNIT
APPLICATION
Power Supply
Lighting
ITO-220
TO-251 (IPAK)
TO-252 (DPAK)
Notes: MSL 3 (Moisture Sensitivity Level) for TO-252 (D-PAK) per J-STD-020
ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted)
PARAMETER
SYMBOL
ITO-220
Drain-Source Voltage
VDS
700
V
Gate-Source Voltage
VGS
±30
V
Continuous Drain Current
Pulsed Drain Current
TC = 25°C
(Note 1)
11
ID
TC = 100°C
(Note 2)
IDM
Total Power Dissipation @ TC = 25°C
PDTOT
A
6.6
33
33
A
125
W
Single Pulsed Avalanche Energy
(Note 3)
EAS
156
mJ
Single Pulsed Avalanche Current
(Note 3)
IAS
2.5
A
TJ, TSTG
- 55 to +150
°C
Operating Junction and Storage Temperature Range
THERMAL PERFORMANCE
PARAMETER
SYMBOL
ITO-220
IPAK/DPAK
UNIT
Junction to Case Thermal Resistance
RӨJC
3.8
1
°C/W
Junction to Ambient Thermal Resistance
RӨJA
62
°C/W
Notes: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The case thermal reference is defined
at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board
design. RӨJA shown below for single device operation on FR-4 PCB in still air.
Document Number: DS_P0000137
1
Version: E1706
TSM70N380
ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted)
PARAMETER
Static
CONDITIONS
SYMBOL
MIN
TYP
MAX
UNIT
(Note 4)
Drain-Source Breakdown Voltage
VGS = 0V, ID = 250µA
BVDSS
700
V
Gate Threshold Voltage
VDS = VGS, ID = 250µA
VGS(TH)
2
3
4
V
Gate Body Leakage
VGS = ±30V, VDS = 0V
IGSS
±100
nA
Zero Gate Voltage Drain Current
VDS = 700V, VGS = 0V
IDSS
1
µA
Drain-Source On-State Resistance
VGS = 10V, ID = 3.3A
RDS(on)
0.33
0.38
Ω
Qg
18.8
Qgs
3.7
Qgd
5.6
Dynamic
(Note 5)
Total Gate Charge
VDS = 380V, ID = 11A,
Gate-Source Charge
VGS = 10V
Gate-Drain Charge
Input Capacitance
VDS = 100V, VGS = 0V,
Ciss
981
Output Capacitance
f = 1.0MHz
Coss
58
Gate Resistance
F = 1MHz, open drain
Rg
3.3
td(on)
32
tr
21
td(off)
62
tf
28
Switching
nC
pF
Ω
(Note 6)
Turn-On Delay Time
VDD = 380V,
Turn-On Rise Time
RGEN = 35Ω,
Turn-Off Delay Time
ID =11A, VGS = 10V,
Turn-Off Fall Time
Source-Drain Diode
ns
(Note 4)
Forward On Voltage
IS = 11A, VGS = 0V
VSD
1.4
V
Reverse Recovery Time
VR=200V, IS = 5.5A
trr
226
ns
Reverse Recovery Charge
dIF/dt = 100A/μs
Qrr
2.1
μC
Notes:
1.
Current limited by package
2.
Pulse width limited by the maximum junction temperature
3.
L = 50mH, IAS = 2.5A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C
4.
Pulse test: PW ≤ 300µs, duty cycle ≤ 2%
5.
For DESIGN AID ONLY, not subject to production testing.
6.
Switching time is essentially independent of operating temperature.
o
2
Version: E1706
TSM70N380
ORDERING INFORMATION
PART NO.
PACKAGE
PACKING
TSM70N380CI C0G
TSM70N380CH C5G
ITO-220
50pcs / Tube
TO-251 (IPAK)
75pcs / Tube
TSM70N380CP ROG
TO-252 (DPAK)
2,500pcs / 13” Reel
Note:
1. Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC
2. Halogen-free according to IEC 61249-2-21 definition
3
Version: E1706
TSM70N380
CHARACTERISTICS CURVES
(TC = 25°C unless otherwise noted)
Output Characteristics
Transfer Characteristics
On-Resistance vs. Drain Current
Gate-Source Voltage vs. Gate Charge
On-Resistance vs. Junction Temperature
Source-Drain Diode Forward Current vs. Voltage
4
Version: E1706
TSM70N380
Capacitance vs. Drain-Source Voltage
BVDSS vs. Junction Temperature
Maximum Safe Operating Area (DPAK/IPAK)
Maximum Safe Operating Area (ITO-220)
Normalized Effective Transient
Thermal Impedance
Normalized Thermal Transient Impedance, Junction-to-Case (ITO-220)
101
100
10-1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single pulse
10-2
10-3
10-4
10-7
10-6
10-5
10-4
10-3
10-2
10-1
100
101
Square Wave Pulse Duration (sec)
5
Version: E1706
TSM70N380
ELECTRICAL CHARACTERISTICS CURVES
Thermal Impedance
Normalized Thermal Transient Impedance, Junction-to-Case (DPAK/IPAK)
101
100
10-1
Duty=0.5
Duty=0.2
Duty=0.1
Duty=0.05
Duty=0.02
Duty=0.01
Single pulse
10-2
10-3
10-4
10-7
10-6
10-5
10-4
10-3
10-2
10-1
100
101
6
Version: E1706
TSM70N380
PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters)
ITO-220
MARKING DIAGRAM
G
Y
WW
F
= Halogen Free
= Year Code
= Week Code (01~52)
= Factory Code
7
Version: E1706
TSM70N380
TO-251
MARKING DIAGRAM
Y = Year Code
M = Month Code for Halogen Free Product
O =Jan P =Feb Q =Mar R =Apr
S =May T =Jun U =Jul
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
L = Lot Code (1~9, A~Z)
8
Version: E1706
TSM70N380
TO-252
SUGGESTED PAD LAYOUT (Unit: Millimeters)
MARKING DIAGRAM
Y = Year Code
V =Aug
W =Sep X =Oct
Y =Nov Z =Dec
9
Version: E1706
TSM70N380
Notice
Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf,
assumes no responsibility or liability for any errors or inaccuracies.
Information contained herein is intended to provide a product description only. No license, express or implied, to
any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of
sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty,
relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose,
merchantability, or infringement of any patent, copyright, or other intellectual property right.
The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications.
Customers using or selling these products for use in such applications do so at their own risk and agree to fully
indemnify TSC for any damages resulting from such improper use or sale.
10
Version: E1706
很抱歉,暂时无法提供与“TSM70N380CI C0G”相匹配的价格&库存,您可以联系我们找货
