TSM60NB099CZ C0G
TSM60NB099CZ C0G
    TAIWANSEMICONDUCTOR(台湾半导体)
    TO-220-3
TSM60NB099CZ C0G 数据手册
TSM60NB099CZ Taiwan Semiconductor N-Channel Power MOSFET 600V, 38A, 99mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Super-Junction technology PARAMETER VALUE UNIT VDS 600 V RDS(on) (max) 99 mΩ Qg 62 nC ● High performance, small RDS(ON)*Qg figure of merit (FOM) ● High ruggedness performance ● 100% UIS and Rg tested ● Compliant to RoHS Directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 APPLICATIONS ● PFC stage ● Server/Telecom Power ● Charging Station ● Inverter ● Power Supply TO-220 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER SYMBOL LIMIT UNIT Drain-Source Voltage VDS 600 V Gate-Source Voltage VGS ±30 V 38 A 24 A IDM 114 A Continuous Drain Current Pulsed Drain Current TC = 25°C (Note 1) ID TC = 100°C (Note 2) Total Power Dissipation @ TC = 25°C PD 298 W Single Pulse Avalanche Energy (Note 3) EAS 784 mJ Single Pulse Avalanche Current (Note 3) IAS 5.6 A TJ, TSTG - 55 to +150 °C SYMBOL LIMIT UNIT Junction to Case Thermal Resistance RӨJC 0.42 °C/W Junction to Ambient Thermal Resistance RӨJA 62 °C/W Operating Junction and Storage Temperature Range THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. R ӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: A1705 TSM60NB099CZ Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 600 -- -- V Gate Threshold Voltage VDS = VGS, ID = 250µA VGS(TH) 2 3 4 V Gate Body Leakage VGS = ±30V, VDS = 0V IGSS -- -- ±100 nA Zero Gate Voltage Drain Current VDS = 600V, VGS = 0V IDSS -- -- 1 µA VGS = 10V, ID = 11.3A RDS(on) -- 86 99 mΩ Qg -- 62 -- Qgs -- 17 -- Qgd -- 25 -- Ciss -- 2587 -- Coss -- 123 -- Crss -- 20 -- Rg -- 3.3 6.6 td(on) -- 18 -- tr -- 24 -- td(off) -- 87 -- tf -- 25 -- Body-Diode Continuous Forward Current IS -- -- 38 A Body-Diode Pulsed Current ISM -- -- 114 A VSD -- -- 1.4 V Drain-Source On-State Resistance (Note 4) Dynamic (Note 5) Total Gate Charge VDS = 480V, ID = 34A, Gate-Source Charge VGS = 10V Gate-Drain Charge Input Capacitance VDS = 100V,VGS = 0V, Output Capacitance f = 1.0MHz Reverse Transfer Capacitance Gate Resistance Switching f = 1.0MHz nC pF Ω (Note 6) Turn-On Delay Time VDD = 300V, Turn-On Rise Time RGEN = 5Ω, Turn-Off Delay Time ID = 17A, VGS = 10V, Turn-Off Fall Time ns Source-Drain Diode Forward Voltage (Note 4) IS = 34A, VGS = 0V Reverse Recovery Time IS = 17A trr -- 342 -- ns Reverse Recovery Charge dIF/dt = 100A/μs Qrr -- 5.3 -- μC Notes: 1. Current limited by package. 2. Pulse width limited by the maximum junction temperature. 3. L = 50mH, IAS = 5.6A, VDD = 50V, RG = 25Ω, Starting TJ = 25 C 4. Pulse test: PW ≤ 300µs, duty cycle ≤ 2%. 5. For DESIGN AID ONLY, not subject to production testing. 6. Switching time is essentially independent of operating temperature. o ORDERING INFORMATION PART NO. TSM60NB099CZ C0G PACKAGE PACKING TO-220 50pcs / Tube 2 Version: A1705 TSM60NB099CZ Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) Output Characteristics Transfer Characteristics 45 45 VGS=10V VGS=9V VGS=8V VGS=7V VGS=6V 27 ID, Drain Current (A) ID, Drain Current (A) 36 18 9 36 27 25℃ 18 9 VGS=5V 150℃ -55℃ 0 0 0 2 4 6 8 0 4 6 8 VGS, Gate to Source Voltage (V) On-Resistance vs. Drain Current Gate-Source Voltage vs. Gate Charge 0.2 VGS, Gate to Source Voltage (V) 10 0.16 0.12 0.08 VGS=10V 0.04 VDS=480V ID=34A 8 6 4 2 0 0 0 9 18 27 36 0 45 10 20 30 40 50 60 ID, Drain Current (A) Qg, Gate Charge (nC) On-Resistance vs. Junction Temperature On-Resistance vs. Gate-Source Voltage 3 RDS(on), Drain-Source On-Resistance (Ω) RDS(on), Drain-Source On-Resistance (Normalized) RDS(on), Drain-Source On-Resistance (Ω) VDS, Drain to Source Voltage (V) 2 VGS=10V ID=11.3A 2.5 2 1.5 1 0.5 0 -75 -50 -25 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) 3 70 0.3 0.25 0.2 0.15 ID=11.3A 0.1 0.05 0 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) Version: A1705 TSM60NB099CZ Taiwan Semiconductor CHARACTERISTICS CURVES (TC = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage 1.2 BVDSS (Normalized) Drain-Source Breakdown Voltage C, Capacitance (pF) 100000 10000 CISS 1000 COSS 100 CRSS 10 1 ID=1mA 1.1 1 0.9 0.8 0 100 200 300 400 500 600 -75 VDS, Drain to Source Voltage (V) -25 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) Maximum Safe Operating Area, Junction-to-Case Source-Drain Diode Forward Current vs. Voltage 100 100 IS, Reverse Drain Current (A) 1000 ID, Drain Current (A) -50 RDS(ON) 10 1 SINGLE PULSE RӨJC=0.42°C/W TC=25°C 10 150℃ 1 25℃ -55℃ 0.1 0.1 1 10 100 0.2 1000 0.4 0.6 0.8 1 1.2 VSD, Body Diode Forward Voltage (V) VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=0.42°C/W 1 0.1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.01 0.001 0.00001 0.0001 0.001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.01 0.1 1 t, Square Wave Pulse Duration (sec) 4 Version: A1705 TSM60NB099CZ Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) TO-220 MARKING DIAGRAM TSC 60NB099 GYWWF G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code 5 Version: A1705 TSM60NB099CZ Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A1705
TSM60NB099CZ C0G 价格&库存
很抱歉,暂时无法提供与“TSM60NB099CZ C0G”相匹配的价格&库存,您可以联系我们找货
TSM60NB099CZ C0G
  • 4000+32.702534000+4.25053
