TSM015NA03CR RLG
TSM015NA03CR RLG
    TAIWANSEMICONDUCTOR(台湾半导体)
    TDFN-8
    TSM015NA03CR RLG
TSM015NA03CR RLG 数据手册
TSM015NA03CR Taiwan Semiconductor N-Channel Power MOSFET 30V, 205A, 1.5mΩ FEATURES KEY PERFORMANCE PARAMETERS ● Low RDS(ON) to minimize conductive losses PARAMETER VALUE UNIT VDS 30 V ● Low gate charge for fast power switching ● 100% UIS and Rg tested ● Compliant to RoHS directive 2011/65/EU and in accordance to WEEE 2002/96/EC ● Halogen-free according to IEC 61249-2-21 RDS(on) (max) VGS = 10V 1.5 VGS = 4.5V 2.0 mΩ Qg nC en de d 33 APPLICATIONS ● DC-DC Converters ● Battery Power Management ● ORing FET/Load Switching eco mm PDFN56 Note: MSL 1 (Moisture Sensitivity Level) per J-STD-020 ABSOLUTE MAXIMUM RATINGS (TA = 25°C unless otherwise noted) PARAMETER No tR Drain-Source Voltage Gate-Source Voltage Continuous Drain Current TC = 25°C (Note 1) Pulsed Drain Current (Note 2) Single Pulse Avalanche Current (Note 2) Single Pulse Avalanche Energy Total Power Dissipation LIMIT UNIT VDS 30 V VGS ±20 V ID TA = 25°C Total Power Dissipation SYMBOL TC = 25°C TC = 125°C TA = 25°C TA = 125°C Operating Junction and Storage Temperature Range 205 32 A IDM 820 A IAS EAS 46 317 A mJ PD PD 104 21 2.6 0.5 W W TJ, TSTG - 55 to +150 °C SYMBOL LIMIT UNIT Junction to Case Thermal Resistance RӨJC 1.2 °C/W Junction to Ambient Thermal Resistance RӨJA 48 °C/W THERMAL PERFORMANCE PARAMETER Thermal Performance Note: RӨJA is the sum of the junction-to-case and case-to-ambient thermal resistances. The casethermal reference is defined at the solder mounting surface of the drain pins. RӨJA is guaranteed by design while RӨCA is determined by the user’s board design. 1 Version: A1612 TSM015NA03CR Taiwan Semiconductor ELECTRICAL SPECIFICATIONS (TA = 25°C unless otherwise noted) PARAMETER CONDITIONS SYMBOL MIN TYP MAX UNIT Static Drain-Source Breakdown Voltage VGS = 0V, ID = 250µA BVDSS 30 -- -- V Gate Threshold Voltage VGS = VDS, ID = 250µA VGS(TH) 1.2 1.8 2.5 V Gate-Source Leakage Current VGS = ±20V, VDS = 0V IGSS -- -- ±100 nA -- -- 1 -- -- 100 Drain-Source Leakage Current IDSS VGS = 0V, VDS = 30V TJ = 125°C VGS = 10V, ID = 32A (Note 3) VGS = 4.5V, ID = 28A Forward Transconductance VDS = 5V, ID = 32A gfs (Note 4) VGS = 10V, VDS = 15V, Total Gate Charge ID = 32A Total Gate Charge ID = 28A Gate-Drain Charge Input Capacitance VGS = 0V, VDS = 15V Output Capacitance f = 1.0MHz Gate Resistance Switching e co Reverse Transfer Capacitance f = 1.0MHz (Note 4) tR Turn-On Delay Time 1.3 1.5 -- 1.8 2.0 -- 60 -- Turn-On Rise Time VGS = 10V, VDS = 15V, Turn-Off Delay Time ID = 32A, RG = 2Ω, Turn-Off Fall Time mΩ S Qg -- 67 -- Qg -- 33 -- Qgs -- 12 -- Qgd -- 13 -- Ciss -- 4243 -- Coss -- 1014 -- Crss -- 252 -- Rg 0.4 1.3 2.6 td(on) -- 5.8 -- tr -- 17 -- td(off) -- 33 -- tf -- 11 -- VSD -- -- 1.2 V mm VGS = 4.5V, VDS = 15V, Gate-Source Charge -- en Dynamic (Note 3) RDS(on) de Drain-Source On-State Resistance µA d VGS = 0V, VDS = 30V nC pF Ω ns No Source-Drain Diode Forward Voltage (Note 3) VGS = 0V, IS = 32A Reverse Recovery Time IS = 32A, trr -- 38 -- ns Reverse Recovery Charge dI/dt = 100A/μs Qrr -- 36 -- nC Notes: 1. 2. 3. 4. Silicon limited current only. L = 0.3mH, VGS = 10V, VDD = 25V, RG = 25Ω, IAS = 46A, Starting TJ = 25°C Pulse test: Pulse Width ≤ 300µs, duty cycle ≤ 2%. Switching time is essentially independent of operating temperature. ORDERING INFORMATION PART NO. TSM015NA03CR RLG PACKAGE PACKING PDFN56 2,500pcs / 13” Reel 2 Version: A1612 TSM015NA03CR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) Output Characteristics 20 10 40 30 d ID, Drain Current (A) 30 VGS=3V 20 25℃ de VGS=10V VGS=7V VGS=5V VGS=4.5V VGS=4V VGS=3.5V 40 Transfer Characteristics 50 ID, Drain Current (A) 50 10 150℃ 0 0 0.5 1 1.5 2 2.5 0 3 2 3 4 Gate-Source Voltage vs. Gate Charge mm On-Resistance vs. Drain Current 0.002 VDS=15V ID=32A 8 6 e co VGS=4.5V VGS, Gate to Source Voltage (V) 10 0.0025 0.0015 VGS=10V 0.001 0.0005 0 tR RDS(ON), Drain-Source On-Resistance (Ω) 1 VGS, Gate to Source Voltage (V) VDS, Drain to Source Voltage (V) 10 20 30 40 4 2 0 0 50 10 20 No On-Resistance vs. Junction Temperature RDS(on), Drain-Source On-Resistance (Ω) VGS=10V ID=32A 1.4 1.2 1 0.8 0.6 0.4 -75 -50 -25 0 25 50 75 40 50 60 70 On-Resistance vs. Gate-Source Voltage 1.8 1.6 30 Qg, Gate Charge (nC) ID, Drain Current (A) RDS(on), Drain-Source On-Resistance (Normalized) -55℃ en 0 100 125 150 0.004 0.0035 0.003 0.0025 0.002 ID=32A 0.0015 0.001 0.0005 3 4 5 6 7 8 9 10 VGS, Gate to Source Voltage (V) TJ, Junction Temperature (°C) 3 Version: A1612 TSM015NA03CR Taiwan Semiconductor CHARACTERISTICS CURVES (TA = 25°C unless otherwise noted) BVDSS vs. Junction Temperature Capacitance vs. Drain-Source Voltage 3000 2000 COSS CRSS 0 5 10 15 20 25 30 0.9 0.8 -75 -50 -25 0 25 50 75 100 125 150 TJ, Junction Temperature (°C) VDS, Drain to Source Voltage (V) Source-Drain Diode Forward Current vs. Voltage mm Maximum Safe Operating Area, Junction-to-Case 1000 100 RDS(ON) 10 1 0.1 tR SINGLE PULSE RӨJC=1.2°C/W TC=25°C 10 e co 100 IS, Reverse Drain Current (A) 10us ID, Drain Current (A) 1 en 0 1.1 d CISS 4000 ID=1mA de 5000 1000 1.2 BVDSS (Normalized) Drain-Source Breakdown Voltage C, Capacitance (pF) 6000 1 10 150℃ 25℃ -55℃ 1 0.1 100 0.2 0.3 0.4 0.5 0.6 0.7 0.8 0.9 1 VSD, Body Diode Forward Voltage (V) No VDS, Drain to Source Voltage (V) Normalized Thermal Transient Impedance, Junction-to-Case Normalized Effective Transient Thermal Impedance, ZӨJC 10 SINGLE PULSE RӨJC=1.2°C/W 1 0.1 Duty=0.5 Duty=0.2 Duty=0.1 Duty=0.05 Duty=0.02 Duty=0.01 Single 0.01 0.001 0.00001 0.0001 Notes: Duty = t1 / t2 TJ = TC + PDM x ZӨJC x RӨJC 0.001 0.01 0.1 t, Square Wave Pulse Duration (sec) 4 Version: A1612 TSM015NA03CR Taiwan Semiconductor PACKAGE OUTLINE DIMENSIONS (Unit: Millimeters) mm en de d PDFN56 No tR e co SUGGESTED PAD LAYOUT (Unit: Millimeters) MARKING DIAGRAM TSC 015NA03 GYWWF G Y WW F = Halogen Free = Year Code = Week Code (01~52) = Factory Code 5 Version: A1612 TSM015NA03CR No tR e co mm en de d Taiwan Semiconductor Notice Specifications of the products displayed herein are subject to change without notice. TSC or anyone on its behalf, assumes no responsibility or liability for any errors or inaccuracies. Information contained herein is intended to provide a product description only. No license, express or implied, to any intellectual property rights is granted by this document. Except as provided in TSC’s terms and conditions of sale for such products, TSC assumes no liability whatsoever, and disclaims any express or implied warranty, relating to sale and/or use of TSC products including liability or warranties relating to fitness for a particular purpose, merchantability, or infringement of any patent, copyright, or other intellectual property right. The products shown herein are not designed for use in medical, life-saving, or life-sustaining applications. Customers using or selling these products for use in such applications do so at their own risk and agree to fully indemnify TSC for any damages resulting from such improper use or sale. 6 Version: A1612
TSM015NA03CR RLG 价格&库存
很抱歉,暂时无法提供与“TSM015NA03CR RLG”相匹配的价格&库存,您可以联系我们找货
TSM015NA03CR RLG
  • 1+11.78280
  • 200+4.69800
  • 500+4.54680
  • 1000+4.47120
