PXP6R7-30QLJ
PXP6R7-30QLJ
    NEXPERIA(安世)
    VDFN8
    PXP6R7-30QL/SOT8002/MLPAK33
PXP6R7-30QLJ 数据手册
PXP6R7-30QL 30 V, P-channel Trench MOSFET 5 January 2021 Product data sheet 1. General description P-channel enhancement mode Field-Effect Transistor (FET) in an MLPAK33 (SOT8002) SurfaceMounted Device (SMD) plastic package using Trench MOSFET technology. 2. Features and benefits • • • Logic level compatible Trench MOSFET technology MLPAK33 package (3.3 x 3.3 mm footprint) 3. Applications • • • • High-side load switch Battery management DC-to-DC conversion Switching circuits 4. Quick reference data Table 1. Quick reference data Symbol Parameter Conditions Min Typ Max Unit VDS drain-source voltage Tj = 25 °C - - -30 V VGS gate-source voltage -20 - 20 V ID drain current - - -20.7 A VGS = -10 V; ID = -12.6 A; Tj = 25 °C - 5.7 6.7 mΩ VGS = -4.5 V; ID = -10.5 A; Tj = 25 °C - 7.7 9.6 mΩ VGS = -10 V; Tamb = 25 °C; t ≤ 5 s [1] Static characteristics RDSon [1] drain-source on-state resistance 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and mounting pad for drain 6 cm . PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 5. Pinning information Table 2. Pinning information Pin Symbol Description 1 S source 2 S source 3 S source 4 G gate 5 D drain 6 D drain 7 D drain 8 D drain Simplified outline 1 2 3 Graphic symbol 4 D G S 017aaa257 8 7 6 5 MLPAK33 (SOT8002-1) 6. Ordering information Table 3. Ordering information Type number Package PXP6R7-30QL Name Description Version MLPAK33 plastic thermal enhanced surface mounted package; mini leads; 8 terminals; pitch 0.65 mm; 3.3 x 3.3 x 0.8 mm body SOT8002-1 7. Marking Table 4. Marking codes Type number Marking code PXP6R7-30QL 9AK PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 2 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 8. Limiting values Table 5. Limiting values In accordance with the Absolute Maximum Rating System (IEC 60134). Symbol Parameter Conditions Min Max Unit VDS drain-source voltage Tj = 25 °C - -30 V VGS gate-source voltage -20 20 V ID drain current VGS = -10 V; Tamb = 25 °C; t ≤ 5 s [1] - -20.7 A VGS = -10 V; Tamb = 25 °C [1] - -12.6 A VGS = -10 V; Tamb = 100 °C [1] - -8 A VGS = -10 V; Tsp = 25 °C - -66.6 A - -115 A IDM peak drain current Tamb = 25 °C; single pulse; tp ≤ 10 µs Ptot total power dissipation Tamb = 25 °C; t ≤ 5 s [1] - 4.8 W Tamb = 25 °C [1] - 1.8 W - 50 W Tsp = 25 °C Tj junction temperature -55 150 °C Tamb ambient temperature -55 150 °C Tstg storage temperature -65 150 °C - -1.7 A Source-drain diode IS [1] source current Tamb = 25 °C [1] 2 Device mounted on an FR4 Printed-Circuit Board (PCB), single-sided copper, tin-plated and mounting pad for drain 6 cm . aaa-030137 120 Pder (%) Ider (%) 80 80 40 40 0 -75 Fig. 1. aaa-030138 120 -25 25 75 Normalized total power dissipation as a function of ambient temperature PXP6R7-30QL Product data sheet 0 -75 125 175 Tamb (°C) Fig. 2. -25 75 125 175 Tamb (°C) Normalized continous drain current as a function of ambient temperature All information provided in this document is subject to legal disclaimers. 5 January 2021 25 © Nexperia B.V. 2021. All rights reserved 3 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET -103 ID (A) -102 aaa-032702 tp = 10 µs Limit RDSon = VDS / ID 100 µs -10 1 ms -1 10 ms DC; Tsp = 25 °C -10-1 -10-2 100 ms -10-3 -10-4 -10-1 Fig. 3. DC; Tamb = 25 °C; 6 cm2 -1 -10 -102 VDS (V) Safe operating area; junction to ambient; continuous and peak drain currents as a function of drainsource voltage PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 4 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 9. Thermal characteristics Table 6. Thermal characteristics Symbol Parameter Rth(j-a) Conditions thermal resistance from in free air junction to ambient in free air; t ≤ 5 s Rth(j-sp) [1] [2] thermal resistance from junction to solder point Min Typ Max Unit [1] - 145 185 K/W [2] - 55 70 K/W [2] - 21 26 K/W - 1.5 2.5 K/W Device mounted on an FR4 PCB, single-sided copper, tin-plated and standard footprint. 2 Device mounted on an FR4 PCB, single-sided copper, tin-plated and mounting pad for drain 6 cm . aaa-032703 103 Zth(j-a) (K/W) duty cycle = 1 102 0.5 0.25 0.1 10 0.02 1 0.75 0.33 0.2 0.05 0.01 0 10-1 10-3 10-2 10-1 1 10 102 tp (s) 103 FR4 PCB, standard footprint Fig. 4. Transient thermal impedance from junction to ambient as a function of pulse duration; typical values aaa-032704 102 duty cycle = 1 Zth(j-a) (K/W) 0.5 0.25 10 0.75 0.33 0.2 0.1 0.05 0.02 0.01 1 0 10-1 10-3 10-2 10-1 FR4 PCB, mounting pad for drain 6 cm Fig. 5. 1 10 102 tp (s) 2 103 Transient thermal impedance from junction to ambient as a function of pulse duration; typical values PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 5 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 10. Characteristics Table 7. Characteristics Symbol Parameter Conditions Min Typ Max Unit Static characteristics V(BR)DSS drain-source breakdown voltage ID = -250 µA; VGS = 0 V; Tj = 25 °C -30 - - V VGSth gate-source threshold voltage ID = -250 µA; VDS = VGS; Tj = 25 °C -1 -1.4 -2.5 V IDSS drain leakage current VDS = -30 V; VGS = 0 V; Tj = 25 °C - - -1 µA IGSS gate leakage current VGS = -20 V; VDS = 0 V; Tj = 25 °C - - -0.1 µA VGS = 20 V; VDS = 0 V; Tj = 25 °C - - 0.1 µA RDSon drain-source on-state resistance VGS = -10 V; ID = -12.6 A; Tj = 25 °C - 5.7 6.7 mΩ VGS = -10 V; ID = -12.6 A; Tj = 150 °C - 9.6 11.3 mΩ VGS = -4.5 V; ID = -10.5 A; Tj = 25 °C - 7.7 9.6 mΩ gfs forward transconductance VDS = -10 V; ID = -12.6 A; Tj = 25 °C - 45 - S RG gate resistance f = 1 MHz - 3.7 - Ω VDS = -15 V; ID = -12.6 A; VGS = -10 V; Tj = 25 °C - 88.6 133 nC VDS = -15 V; ID = -10.5 A; VGS = -4.5 V; Tj = 25 °C - 44.3 66.5 nC - 10.2 - nC Dynamic characteristics QG(tot) total gate charge QGS gate-source charge QGS(th) pre-threshold gatesource charge - 3.9 - nC QGS(th-pl) post-threshold gatesource charge - 6.3 - nC QGD gate-drain charge - 17.6 - nC VGSpl gate-source plateau voltage VDS = -15 V; ID = -10.5 A; Tj = 25 °C - -2.4 - V Ciss input capacitance - 4400 - pF Coss output capacitance VDS = -15 V; f = 1 MHz; VGS = 0 V; Tj = 25 °C - 470 - pF Crss reverse transfer capacitance - 410 - pF td(on) turn-on delay time - 17 - ns tr rise time - 67 - ns td(off) turn-off delay time - 61 - ns tf fall time - 45 - ns VDS = -15 V; ID = -10.5 A; VGS = -4.5 V; RG(ext) = 5 Ω; Tj = 25 °C Source-drain diode VSD source-drain voltage IS = -1.7 A; VGS = 0 V; Tj = 25 °C - -0.7 -1.2 V trr reverse recovery time - 25 - ns Qr recovered charge IS = -1.7 A; dIS/dt = 100 A/µs; VGS = -4.5 V; VDS = -15 V; Tj = 25 °C - 15 - nC ta reverse recovery rise time - 11 - ns tb reverse recovery fall time - 14 - ns PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 6 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET aaa-032705 -35 ID (A) -30 -10 V ID (A) -4.5 V -3.5 V -25 aaa-032706 -10-3 -2.6 V -3 V -10-4 -20 min typ max -15 -10-5 -10 -5 0 Fig. 6. VGS = -2.2 V 0 -1 -2 -3 -4 VDS (V) -10-6 -5 -1 -2 VGS (V) -3 Tj = 25 °C Tj = 25 °C; VDS = -5 V Output characteristics: drain current as a Fig. 7. function of drain-source voltage; typical values Sub-threshold drain current as a function of gate-source voltage aaa-032707 100 aaa-032708 100 RDSon RDSon 80 80 -2.6 V 60 60 40 40 20 VGS = -3 V -3.5 V 0 0 -10 -20 20 -4.5 V -10 V -30 ID (A) 0 -40 Tj = 25 °C Fig. 8. 0 Product data sheet 0 -2 -4 -6 -8 -10 VGS (V) ID = -12.6 A Drain-source on-state resistance as a function of drain current; typical values PXP6R7-30QL Tj = 150 °C Tj = 25 °C Fig. 9. Drain-source on-state resistance as a function of gate-source voltage; typical values All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 7 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET aaa-032709 -60 aaa-030155 2.0 a ID (A) 1.5 -40 1.0 T j = 1 50 ° C -20 T j = 25 ° C 0 0 -1 -2 -3 VGS (V) 0.5 0 -60 -4 0 60 120 Tj (°C) 180 VDS = -5 V Fig. 10. Transfer characteristics: drain current as a function of gate-source voltage; typical values aaa-032710 -3 VGS(th) (V) Fig. 11. Normalized drain-source on-state resistance as a function of junction temperature; typical values aaa-032711 104 max Ciss C (pF) -2 103 typ 0 -60 Coss Crss min -1 0 60 120 Tj (°C) 102 -10-1 180 ID = -250 µA; VDS = VGS Product data sheet -10 VDS (V) -102 f = 1 MHz; VGS = 0 V Fig. 12. Gate-source threshold voltage as a function of junction temperature PXP6R7-30QL -1 Fig. 13. Input, output and reverse transfer capacitances as a function of drain-source voltage; typical values All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 8 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET aaa-032712 -10 VGS (V) VDS -8 ID -6 VGS(pl) -4 VGS(th) VGS QGS2 -2 QGS1 0 0 25 50 75 QG (nC) QGD QG(tot) aaa-030347 100 VDS = -15 V; ID = -10.5 A;Tj = 25 °C Fig. 15. Gate charge waveform definitions Fig. 14. Gate-source voltage as a function of gate charge; typical values 003aal160 aaa-032713 -1.75 IS (A) -1.5 ID (A) -1.25 trr ta QGS tb -1 Tj = 150 °C 0 Tj = 25 °C -0.75 0.25 IRM -0.5 IRM -0.25 0 t (s) Fig. 16. Reverse recovery timing definition 0 -0.4 -0.8 VSD (V) -1.2 VGS = 0 V Fig. 17. Source current as a function of source-drain voltage; typical values 11. Test information P t2 duty cycle δ = t1 t2 t1 t 006aaa812 Fig. 18. Duty cycle definition PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 9 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 12. Package outline MLPAK33: plastic thermal enhanced surface mounted package; mini leads; 8 terminals; pitch 0.65 mm; 3.3 x 3.3 x 0.8 mm body SOT8002-1 X b (8x) 1 e (6x) v w C A B C y C 4 K L1 (4x) E2 L2 8 5 D2 B A A 8 5 θ E E1 E3 c 1 4 detail X D 0 5 mm scale Dimensions (mm are the original dimensions) A b max 0.90 0.35 nom 0.80 0.30 min 0.70 0.25 mm c D D1 Seating Plane y1 C D1 Unit C D2 e E E1 E2 E3 K 0.18 3.50 3.25 2.65 3.50 3.10 1.99 0.25 0.65 0.15 3.30 3.15 2.55 0.65 3.30 3.00 1.89 0.20 (ref) 0.12 3.10 3.05 2.45 3.10 2.90 1.79 0.15 L1 L2 θ 0.40 0.58 12° 0.25 0.43 10° 0.10 0.28 8° y y1 0.05 0.05 v w 0.1 0.05 sot8002-1_po Outline version References IEC JEDEC EIAJ European projection Issue date 19-12-19 20-01-09 SOT8002-1 Fig. 19. Package outline MLPAK33 (SOT8002-1) PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 10 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 13. Soldering Footprint information for reflow soldering of MLPAK33 package SOT8002-1 3.55 2.60 2.45 2.35 0.50 2.68 2.58 0.20 3.25 3.80 4.05 0.70 0.95 0.52 0.62 0.20 0.70 0.60 0.50 0.30 0.65 0.40 0.15 0.50 0.25 2.65 recommended stencil thickness: 0.1 mm occupied area solder resist solder lands solder paste Dimensions in mm Issue date 19-12-20 sot8002-1_fr Fig. 20. Reflow soldering footprint for MLPAK33 (SOT8002-1) PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 11 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 14. Revision history Table 8. Revision history Data sheet ID Release date Data sheet status Change notice Supersedes PXP6R7-30QL v.1 Product data sheet - - PXP6R7-30QL Product data sheet 20210105 All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 12 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET 15. Legal information injury, death or severe property or environmental damage. Nexperia and its suppliers accept no liability for inclusion and/or use of Nexperia products in such equipment or applications and therefore such inclusion and/or use is at the customer’s own risk. Data sheet status Quick reference data — The Quick reference data is an extract of the product data given in the Limiting values and Characteristics sections of this document, and as such is not complete, exhaustive or legally binding. Document status [1][2] Product status [3] Definition Objective [short] data sheet Development This document contains data from the objective specification for product development. Preliminary [short] data sheet Qualification This document contains data from the preliminary specification. Product [short] data sheet Production This document contains the product specification. [1] [2] [3] Please consult the most recently issued document before initiating or completing a design. The term 'short data sheet' is explained in section "Definitions". The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product status information is available on the internet at https://www.nexperia.com. Definitions Draft — The document is a draft version only. The content is still under internal review and subject to formal approval, which may result in modifications or additions. Nexperia does not give any representations or warranties as to the accuracy or completeness of information included herein and shall have no liability for the consequences of use of such information. Short data sheet — A short data sheet is an extract from a full data sheet with the same product type number(s) and title. A short data sheet is intended for quick reference only and should not be relied upon to contain detailed and full information. For detailed and full information see the relevant full data sheet, which is available on request via the local Nexperia sales office. In case of any inconsistency or conflict with the short data sheet, the full data sheet shall prevail. Product specification — The information and data provided in a Product data sheet shall define the specification of the product as agreed between Nexperia and its customer, unless Nexperia and customer have explicitly agreed otherwise in writing. In no event however, shall an agreement be valid in which the Nexperia product is deemed to offer functions and qualities beyond those described in the Product data sheet. Disclaimers Limited warranty and liability — Information in this document is believed to be accurate and reliable. However, Nexperia does not give any representations or warranties, expressed or implied, as to the accuracy or completeness of such information and shall have no liability for the consequences of use of such information. Nexperia takes no responsibility for the content in this document if provided by an information source outside of Nexperia. In no event shall Nexperia be liable for any indirect, incidental, punitive, special or consequential damages (including - without limitation - lost profits, lost savings, business interruption, costs related to the removal or replacement of any products or rework charges) whether or not such damages are based on tort (including negligence), warranty, breach of contract or any other legal theory. Notwithstanding any damages that customer might incur for any reason whatsoever, Nexperia’s aggregate and cumulative liability towards customer for the products described herein shall be limited in accordance with the Terms and conditions of commercial sale of Nexperia. Right to make changes — Nexperia reserves the right to make changes to information published in this document, including without limitation specifications and product descriptions, at any time and without notice. This document supersedes and replaces all information supplied prior to the publication hereof. Suitability for use — Nexperia products are not designed, authorized or warranted to be suitable for use in life support, life-critical or safety-critical systems or equipment, nor in applications where failure or malfunction of an Nexperia product can reasonably be expected to result in personal PXP6R7-30QL Product data sheet Applications — Applications that are described herein for any of these products are for illustrative purposes only. Nexperia makes no representation or warranty that such applications will be suitable for the specified use without further testing or modification. Customers are responsible for the design and operation of their applications and products using Nexperia products, and Nexperia accepts no liability for any assistance with applications or customer product design. It is customer’s sole responsibility to determine whether the Nexperia product is suitable and fit for the customer’s applications and products planned, as well as for the planned application and use of customer’s third party customer(s). Customers should provide appropriate design and operating safeguards to minimize the risks associated with their applications and products. Nexperia does not accept any liability related to any default, damage, costs or problem which is based on any weakness or default in the customer’s applications or products, or the application or use by customer’s third party customer(s). Customer is responsible for doing all necessary testing for the customer’s applications and products using Nexperia products in order to avoid a default of the applications and the products or of the application or use by customer’s third party customer(s). Nexperia does not accept any liability in this respect. Limiting values — Stress above one or more limiting values (as defined in the Absolute Maximum Ratings System of IEC 60134) will cause permanent damage to the device. Limiting values are stress ratings only and (proper) operation of the device at these or any other conditions above those given in the Recommended operating conditions section (if present) or the Characteristics sections of this document is not warranted. Constant or repeated exposure to limiting values will permanently and irreversibly affect the quality and reliability of the device. Terms and conditions of commercial sale — Nexperia products are sold subject to the general terms and conditions of commercial sale, as published at http://www.nexperia.com/profile/terms, unless otherwise agreed in a valid written individual agreement. In case an individual agreement is concluded only the terms and conditions of the respective agreement shall apply. Nexperia hereby expressly objects to applying the customer’s general terms and conditions with regard to the purchase of Nexperia products by customer. No offer to sell or license — Nothing in this document may be interpreted or construed as an offer to sell products that is open for acceptance or the grant, conveyance or implication of any license under any copyrights, patents or other industrial or intellectual property rights. Export control — This document as well as the item(s) described herein may be subject to export control regulations. Export might require a prior authorization from competent authorities. Non-automotive qualified products — Unless this data sheet expressly states that this specific Nexperia product is automotive qualified, the product is not suitable for automotive use. It is neither qualified nor tested in accordance with automotive testing or application requirements. Nexperia accepts no liability for inclusion and/or use of non-automotive qualified products in automotive equipment or applications. In the event that customer uses the product for design-in and use in automotive applications to automotive specifications and standards, customer (a) shall use the product without Nexperia’s warranty of the product for such automotive applications, use and specifications, and (b) whenever customer uses the product for automotive applications beyond Nexperia’s specifications such use shall be solely at customer’s own risk, and (c) customer fully indemnifies Nexperia for any liability, damages or failed product claims resulting from customer design and use of the product for automotive applications beyond Nexperia’s standard warranty and Nexperia’s product specifications. Translations — A non-English (translated) version of a document is for reference only. The English version shall prevail in case of any discrepancy between the translated and English versions. Trademarks Notice: All referenced brands, product names, service names and trademarks are the property of their respective owners. All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 13 / 14 PXP6R7-30QL Nexperia 30 V, P-channel Trench MOSFET Contents 1. General description...................................................... 1 2. Features and benefits.................................................. 1 3. Applications.................................................................. 1 4. Quick reference data....................................................1 5. Pinning information......................................................2 6. Ordering information....................................................2 7. Marking.......................................................................... 2 8. Limiting values............................................................. 3 9. Thermal characteristics............................................... 5 10. Characteristics............................................................ 6 11. Test information.......................................................... 9 12. Package outline........................................................ 10 13. Soldering................................................................... 11 14. Revision history........................................................12 15. Legal information......................................................13 © Nexperia B.V. 2021. All rights reserved For more information, please visit: http://www.nexperia.com For sales office addresses, please send an email to: salesaddresses@nexperia.com Date of release: 5 January 2021 PXP6R7-30QL Product data sheet All information provided in this document is subject to legal disclaimers. 5 January 2021 © Nexperia B.V. 2021. All rights reserved 14 / 14
PXP6R7-30QLJ
物料型号:PXP6R7-30QL
器件简介: - 这是一款30V P-channel增强型场效应晶体管(FET),采用Trench MOSFET技术和MLPAK33(SOT8002)表面贴装设备(SMD)塑料封装。
引脚分配: - 该器件有8个引脚,其中1、2、3脚为源极(S),4脚为栅极(G),5、6、7、8脚为漏极(D)。
参数特性: - 漏源电压(VDS):30V - 栅源电压(VGS):在25°C时,-20V至20V - 漏极电流(ID):在VGS=-10V,环境温度25°C,且t≤5s条件下,最大20.7A
功能详解: - 该MOSFET具有逻辑电平兼容、Trench MOSFET技术、MLPAK33封装(3.3 x 3.3 mm)等特点。 - 适用于高侧负载开关、电池管理、DC-DC转换和开关电路等应用。
应用信息: - 适用于高侧负载开关、电池管理、DC-DC转换和开关电路。
封装信息: - MLPAK33塑料热增强表面贴装封装;迷你引线;8个终端;间距0.65mm;3.3 x 3.3 x 0.8 mm的封装体。
PXP6R7-30QLJ 价格&库存
很抱歉,暂时无法提供与“PXP6R7-30QLJ”相匹配的价格&库存,您可以联系我们找货
