Important notice
Dear Customer,
On 7 February 2017 the former NXP Standard Product business became a new company with the
tradename Nexperia. Nexperia is an industry leading supplier of Discrete, Logic and PowerMOS
semiconductors with its focus on the automotive, industrial, computing, consumer and wearable
application markets
In data sheets and application notes which still contain NXP or Philips Semiconductors references, use
the references to Nexperia, as shown below.
Instead of http://www.nxp.com, http://www.philips.com/ or http://www.semiconductors.philips.com/,
use http://www.nexperia.com
Instead of sales.addresses@www.nxp.com or sales.addresses@www.semiconductors.philips.com, use
salesaddresses@nexperia.com (email)
Replace the copyright notice at the bottom of each page or elsewhere in the document, depending on
the version, as shown below:
- © NXP N.V. (year). All rights reserved or © Koninklijke Philips Electronics N.V. (year). All rights
reserved
Should be replaced with:
- © Nexperia B.V. (year). All rights reserved.
If you have any questions related to the data sheet, please contact our nearest sales office via e-mail
or telephone (details via salesaddresses@nexperia.com). Thank you for your cooperation and
understanding,
Kind regards,
Team Nexperia
TO
-22
0A
B
BUK9575-100A
N-channel TrenchMOS logic level FET
Rev. 3 — 26 April 2011
Product data sheet
1. Product profile
1.1 General description
Logic level N-channel enhancement mode Field-Effect Transistor (FET) in a plastic
package using TrenchMOS technology. This product has been designed and qualified to
the appropriate AEC standard for use in automotive critical applications.
1.2 Features and benefits
AEC Q101 compliant
Low conduction losses due to low
on-state resistance
1.3 Applications
Automotive and general purpose
power switching
1.4 Quick reference data
Table 1.
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
VDS
drain-source voltage
Tj ≥ 25 °C; Tj ≤ 175 °C
100
V
ID
drain current
Tmb = 25 °C
23
A
Ptot
total power dissipation
98
W
VGS = 10 V; ID = 10 A;
Tj = 25 °C
55
72
mΩ
VGS = 5 V; ID = 10 A;
Tj = 25 °C
60
75
mΩ
100
mJ
Static characteristics
RDSon
drain-source on-state
resistance
Avalanche ruggedness
EDS(AL)S
non-repetitive
ID = 14.2 A; Vsup ≤ 25 V;
drain-source avalanche RGS = 50 Ω; VGS = 5 V;
Tj(init) = 25 °C; unclamped
energy
BUK9575-100A
NXP Semiconductors
2. Pinning information
Table 2.
Pinning information
Pin
Symbol Description
1
G
gate
2
D
drain
3
S
source
mb
D
mounting base;
connected to drain
Simplified outline
Graphic symbol
D
mb
G
mbb076
S
1 2 3
SOT78A (TO-220AB)
3. Ordering information
Table 3.
Type number
BUK9575-100A
BUK9575-100A
Product data sheet
Package
Name
Description
Version
TO-220AB
plastic single-ended package; heatsink mounted;
1 mounting hole; 3-lead TO-220AB
SOT78A
All information provided in this document is subject to legal disclaimers.
© NXP B.V. 2011. All rights reserved.
2 of 12
BUK9575-100A
NXP Semiconductors
4. Limiting values
Table 4.
Limiting values
In accordance with the Absolute Maximum Rating System (IEC 60134).
Symbol
Parameter
Conditions
Min
Max
Unit
VDS
100
V
VDGR
drain-gate voltage
RGS = 20 kΩ
100
V
VGS
gate-source voltage
ID
drain current
-15
15
V
Tmb = 100 °C
16
A
Tmb = 25 °C
23
A
91
A
IDM
peak drain current
Tmb = 25 °C; pulsed
Ptot
Tmb = 25 °C
98
W
Tstg
storage temperature
-55
175
°C
Tj
junction temperature
-55
175
°C
Source-drain diode
IS
source current
Tmb = 25 °C
23
A
ISM
peak source current
pulsed; Tmb = 25 °C
92
A
ID = 14.2 A; Vsup ≤ 25 V; RGS = 50 Ω;
VGS = 5 V; Tj(init) = 25 °C; unclamped
100
mJ
non-repetitive drain-source
avalanche energy
EDS(AL)S
003aaf170
100
Pder
80
003aaf171
100
ID
80
60
60
40
40
100
150
200
Tmb (°C)
50
100
150
200
Tmb (°C)
VGS ≥ 5 V
Fig 1.
Normalized total power dissipation as a
function of mounting base temperature
BUK9575-100A
Product data sheet
Fig 2.
Normalized continuous drain current as a
3 of 12
BUK9575-100A
NXP Semiconductors
003aaf172
103
003aaf188
102
IDM
(A)
IAV
102
RDS(on) = VDS / ID
tp = 1 μs
10
10 μs
10
25 °C
100 μs
1 ms
D.C.
Tj prior to avalanche = 150 °C
10 ms
1
1
10
102
1
10−3
103
10−2
10−1
1
10
VDS (V)
tAV (ms)
Tmb = 25 °C; IDM is single pulse
Fig 3.
unclamped inductive load
Safe operating area; continuous and peak drain
currents as a function of drain-source voltage
Fig 4.
Single-shot avalanche rating; avalanche
current as a function of avalanche period
5. Thermal characteristics
Table 5.
Symbol
Parameter
Rth(j-mb)
thermal resistance from
junction to mounting base
Conditions
Rth(j-a)
junction to ambient
in free air
Min
Typ
Max
Unit
1.5
K/W
60
K/W
003aaf173
10
Zth(j-mb)
(K/W)
1
10−1
δ = 0.5
0.2
0.1
0.05
0.02
10−2
10−6
Fig 5.
δ=
P
tp
T
t
tp
T
10−5
10−4
10−3
10−2
10−1
1
tp (s)
Transient thermal impedance from junction to mounting base as a function of pulse duration
BUK9575-100A
Product data sheet
4 of 12
BUK9575-100A
NXP Semiconductors
6. Characteristics
Table 6.
Characteristics
Symbol
Parameter
Conditions
Min
Typ
Max
Unit
V
V(BR)DSS
drain-source
breakdown voltage
ID = 0.25 mA; VGS = 0 V; Tj = 25 °C
100
ID = 0.25 mA; VGS = 0 V; Tj = -55 °C
89
V
VGS(th)
gate-source threshold
voltage
ID = 1 mA; VDS = VGS; Tj = 175 °C
0.5
V
ID = 1 mA; VDS = VGS; Tj = 25 °C
1
1.5
2
V
ID = 1 mA; VDS = VGS; Tj = -55 °C
2.3
V
VDS = 100 V; VGS = 0 V; Tj = 175 °C
500
µA
VDS = 100 V; VGS = 0 V; Tj = 25 °C
0.05
10
µA
VGS = 10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
VGS = -10 V; VDS = 0 V; Tj = 25 °C
2
100
nA
IDSS
IGSS
RDSon
drain leakage current
gate leakage current
resistance
VGS = 10 V; ID = 10 A; Tj = 25 °C
55
72
mΩ
VGS = 5 V; ID = 10 A; Tj = 175 °C
188
mΩ
VGS = 4.5 V; ID = 10 A; Tj = 25 °C
61
84
mΩ
VGS = 5 V; ID = 10 A; Tj = 25 °C
60
75
mΩ
VGS = 0 V; VDS = 25 V; f = 1 MHz;
Tj = 25 °C
1278
1704
pF
129
155
pF
88
120
pF
13
ns
120
168
ns
58
87
ns
Dynamic characteristics
Ciss
input capacitance
Coss
output capacitance
Crss
reverse transfer
capacitance
td(on)
turn-on delay time
tr
rise time
td(off)
turn-off delay time
tf
fall time
LD
internal drain
inductance
LS
internal source
inductance
VDS = 30 V; RL = 1.2 Ω; VGS = 5 V;
RG(ext) = 10 Ω; Tj = 25 °C
57
86
ns
from drain lead 6 mm from package to
centre of die; Tj = 25 °C
4.5
nH
from contact screw on tab to centre of
die; Tj = 25 °C
3.5
nH
from source lead to source bond pad;
Tj = 25 °C
7.5
nH
IS = 10 A; VGS = 0 V; Tj = 25 °C
0.85
1.2
V
IS = 23 A; VGS = 0 V; Tj = 25 °C
1.1
V
IS = 23 A; dIS/dt = -100 A/µs;
VGS = -10 V; VDS = 30 V; Tj = 25 °C
63
ns
0.22
µC
Source-drain diode
VSD
source-drain voltage
trr
reverse recovery time
Qr
recovered charge
BUK9575-100A
Product data sheet
5 of 12
BUK9575-100A
NXP Semiconductors
003aaf174
60
5
ID
(A)
4
3.6
3.4
VGS (V) = 10
40
003aaf175
140
RDS(on)
(mΩ)
120
3.8
3.2
4
4.2
4.4
100
3
80
2.8
4.6
4.8
60
2.4
2.2
5
40
4
6
8
10
10
40
VDS (V)
ID (A)
Tj = 25 °C
Fig 6.
Tj = 25 °C
Output characteristics: drain current as a
function of drain-source voltage; typical values
003aaf176
75
RDS(on)
(mΩ)
70
Fig 7.
Drain-source on-state resistance as a function
of drain current; typical values
65
15
60
10
55
5
50
Tj = 175 °C
Tj = 25 °C
4
5
6
7
8
9
10
VGS (V)
2
3
4
VGS (V)
Tj = 25 °C; ID = 25 A
Fig 8.
003aaf178
25
ID
(A)
VDS > ID x RDSon
of gate-source voltage; typical values
Fig 9.
003aaf179
40
Transfer characteristics: drain current as a
function of gate-source voltage; typical values
003aaf180
3.0
gfs
(S)
a
2.5
30
2.0
10
1.0
60
VGS (V)
0.5
−100
200
Tmb (°C)
VDS > ID x RDSon
Fig 10. Forward transconductance as a function of
BUK9575-100A
Product data sheet
Fig 11. Normalized drain-source on-state resistance
factor as a function of junction temperature
6 of 12
BUK9575-100A
NXP Semiconductors
003aaf181
2.5
VGS(th)
(V)
2.0
maximum
typical
10−3
minimum
10−4
1.5
1.0
003aaf182
10−1
ID
(A)
10−2
2%
typical
98 %
1
1.5
2
10−5
0.5
10−6
−100
200
Tj (°C)
2.5
VGS (V)
Tj = 25 °C; VDS = VGS
Fig 12. Gate-source threshold voltage as a function of
Fig 13. Sub-threshold drain current as a function of
gate-source voltage
003aaf183
3
003aaf184
5
Ciss
VGS
(V)
C
(nF)
4
2
Coss
VDS = 44 V
2
Crss
1
VDS = 14 V
3
1
10−2
10−1
1
102
10
10
15
VDS (V)
VGS = 0 V; f = 1 MHz
QG (nC)
Fig 14. Input, output and reverse transfer capacitances
as a function of drain-source voltage; typical
values
003aaf185
40
Fig 15. Gate-source voltage as a function of gate
charge; typical values
003aaf186
100
WDSS
80
IF
(A)
30
60
Tj = 150 °C
Tj = 25 °C
10
0.8
1.2
1.6
VGS = 0 V
Product data sheet
100
140
180
ID = 75 A
Fig 16. Source (diode forward) current as a function of
source-drain (diode forward) voltage; typical
values
BUK9575-100A
60
Tmb (°C)
VSDS (V)
Fig 17. Normalised drain-source avalanche energy as a
function of mounting-base temperature.
7 of 12
BUK9575-100A
NXP Semiconductors
7. Package outline
Plastic single-ended package; heatsink mounted; 1 mounting hole; 3-lead TO-220AB
E
SOT78A
A
A1
p
q
mounting
base
D1
D
L2
L1(1)
Q
b1
L
1
2
3
c
b
e
e
10 mm
scale
DIMENSIONS (mm are the original dimensions)
UNIT
A
A1
b
b1
c
D
D1
E
e
L
L1(1)
L2
max.
p
q
Q
mm
4.5
4.1
1.39
1.27
0.9
0.6
1.3
1.0
0.7
0.4
15.8
15.2
6.4
5.9
10.3
9.7
2.54
15.0
13.5
3.30
2.79
3.0
3.8
3.6
3.0
2.7
2.6
2.2
Note
1. Terminals in this zone are not tinned.
OUTLINE
VERSION
SOT78A
REFERENCES
IEC
JEDEC
JEITA
3-lead TO-220AB
SC-46
EUROPEAN
PROJECTION
ISSUE DATE
03-01-22
05-03-14
Fig 18. Package outline SOT78A (TO-220AB)
BUK9575-100A
Product data sheet
8 of 12
BUK9575-100A
NXP Semiconductors
8. Revision history
Table 7.
Revision history
Document ID
Release date
Data sheet status
Change notice
Supersedes
BUK9575-100A v.3
20110426
Product data sheet
BUK9575_9675-100A_2
Modifications:
BUK9575_9675-100A_2
BUK9575-100A
Product data sheet
The format of this data sheet has been redesigned to comply with the new identity
guidelines of NXP Semiconductors.
Legal texts have been adapted to the new company name where appropriate.
Type number BUK9575-100A separated from data sheet BUK9575_9675-100A_2.
20001001
Product specification
BUK9575_9675-100A_1
9 of 12
BUK9575-100A
NXP Semiconductors
9. Legal information
9.1
Data sheet status
Document status [1] [2]
Product status [3]
Definition
Objective [short] data sheet
Development
This document contains data from the objective specification for product development.
Preliminary [short] data sheet
Qualification
This document contains data from the preliminary specification.
Product [short] data sheet
Production
This document contains the product specification.
[1]
Please consult the most recently issued document before initiating or completing a design.
[2]
The term 'short data sheet' is explained in section "Definitions".
[3]
The product status of device(s) described in this document may have changed since this document was published and may differ in case of multiple devices. The latest product
status information is available on the Internet at URL http://www.nxp.com.
9.2
Definitions
Preview — The document is a preview version only. The document is still
subject to formal approval, which may result in modifications or additions.
NXP Semiconductors does not give any representations or warranties as to
the accuracy or completeness of information included herein and shall have
no liability for the consequences of use of such information.
Draft — The document is a draft version only. The content is still under
internal review and subject to formal approval, which may result in
modifications or additions. NXP Semiconductors does not give any
representations or warranties as to the accuracy or completeness of
information included herein and shall have no liability for the consequences of
Short data sheet — A short data sheet is an extract from a full data sheet
with the same product type number(s) and title. A short data sheet is intended
for quick reference only and should not be relied upon to contain detailed and
full information. For detailed and full information see the relevant full data
sheet, which is available on request via the local NXP Semiconductors sales
office. In case of any inconsistency or conflict with the short data sheet, the
full data sheet shall prevail.
Product specification — The information and data provided in a Product
data sheet shall define the specification of the product as agreed between
NXP Semiconductors and its customer, unless NXP Semiconductors and
customer have explicitly agreed otherwise in writing. In no event however,
shall an agreement be valid in which the NXP Semiconductors product is
deemed to offer functions and qualities beyond those described in the
Product data sheet.
9.3
Disclaimers
Limited warranty and liability — Information in this document is believed to
be accurate and reliable. However, NXP Semiconductors does not give any
representations or warranties, expressed or implied, as to the accuracy or
completeness of such information and shall have no liability for the
In no event shall NXP Semiconductors be liable for any indirect, incidental,
punitive, special or consequential damages (including - without limitation - lost
profits, lost savings, business interruption, costs related to the removal or
replacement of any products or rework charges) whether or not such
damages are based on tort (including negligence), warranty, breach of
contract or any other legal theory.
Notwithstanding any damages that customer might incur for any reason
whatsoever, NXP Semiconductors’ aggregate and cumulative liability towards
customer for the products described herein shall be limited in accordance
with the Terms and conditions of commercial sale of NXP Semiconductors.
BUK9575-100A
Product data sheet
Right to make changes — NXP Semiconductors reserves the right to make
changes to information published in this document, including without
limitation specifications and product descriptions, at any time and without
notice. This document supersedes and replaces all information supplied prior
to the publication hereof.
Suitability for use in automotive applications — This NXP
Semiconductors product has been qualified for use in automotive
applications. The product is not designed, authorized or warranted to be
suitable for use in medical, military, aircraft, space or life support equipment,
nor in applications where failure or malfunction of an NXP Semiconductors
product can reasonably be expected to result in personal injury, death or
severe property or environmental damage. NXP Semiconductors accepts no
liability for inclusion and/or use of NXP Semiconductors products in such
equipment or applications and therefore such inclusion and/or use is at the
customer’s own risk.
Quick reference data — The Quick reference data is an extract of the
product data given in the Limiting values and Characteristics sections of this
document, and as such is not complete, exhaustive or legally binding.
Applications — Applications that are described herein for any of these
products are for illustrative purposes only. NXP Semiconductors makes no
representation or warranty that such applications will be suitable for the
specified use without further testing or modification.
Customers are responsible for the design and operation of their applications
and products using NXP Semiconductors products, and NXP Semiconductors
accepts no liability for any assistance with applications or customer product
design. It is customer’s sole responsibility to determine whether the NXP
Semiconductors product is suitable and fit for the customer’s applications and
products planned, as well as for the planned application and use of
customer’s third party customer(s). Customers should provide appropriate
design and operating safeguards to minimize the risks associated with their
applications and products.
NXP Semiconductors does not accept any liability related to any default,
damage, costs or problem which is based on any weakness or default in the
customer’s applications or products, or the application or use by customer’s
third party customer(s). Customer is responsible for doing all necessary
testing for the customer’s applications and products using NXP
Semiconductors products in order to avoid a default of the applications and
the products or of the application or use by customer’s third party
customer(s). NXP does not accept any liability in this respect.
Limiting values — Stress above one or more limiting values (as defined in
the Absolute Maximum Ratings System of IEC 60134) will cause permanent
damage to the device. Limiting values are stress ratings only and (proper)
operation of the device at these or any other conditions above those given in
the Recommended operating conditions section (if present) or the
10 of 12
BUK9575-100A
NXP Semiconductors
Characteristics sections of this document is not warranted. Constant or
repeated exposure to limiting values will permanently and irreversibly affect
the quality and reliability of the device.
Terms and conditions of commercial sale — NXP Semiconductors
products are sold subject to the general terms and conditions of commercial
sale, as published at http://www.nxp.com/profile/terms, unless otherwise
agreed in a valid written individual agreement. In case an individual
agreement is concluded only the terms and conditions of the respective
agreement shall apply. NXP Semiconductors hereby expressly objects to
applying the customer’s general terms and conditions with regard to the
purchase of NXP Semiconductors products by customer.
No offer to sell or license — Nothing in this document may be interpreted or
construed as an offer to sell products that is open for acceptance or the grant,
conveyance or implication of any license under any copyrights, patents or
other industrial or intellectual property rights.
Export control — This document as well as the item(s) described herein may
be subject to export control regulations. Export might require a prior
authorization from national authorities.
9.4
Trademarks
Notice: All referenced brands, product names, service names and trademarks
are the property of their respective owners.
Adelante, Bitport, Bitsound, CoolFlux, CoReUse, DESFire, EZ-HV,
FabKey, GreenChip, HiPerSmart, HITAG, I²C-bus logo, ICODE, I-CODE,
ITEC, Labelution, MIFARE, MIFARE Plus, MIFARE Ultralight, MoReUse,
QLPAK, Silicon Tuner, SiliconMAX, SmartXA, STARplug, TOPFET,
TrenchMOS, TriMedia and UCODE — are trademarks of NXP B.V.
HD Radio and HD Radio logo — are trademarks of iBiquity Digital
Corporation.
10. Contact information
For more information, please visit: http://www.nxp.com
For sales office addresses, please send an email to: salesaddresses@nxp.com
BUK9575-100A
Product data sheet
11 of 12
BUK9575-100A
NXP Semiconductors
11. Contents
1
1.1
1.2
1.3
1.4
2
3
4
5
6
7
8
9
9.1
9.2
9.3
9.4
10
Product profile . . . . . . . . . . . . . . . . . . . . . . . . . . .1
General description . . . . . . . . . . . . . . . . . . . . . .1
Features and benefits . . . . . . . . . . . . . . . . . . . . .1
Applications . . . . . . . . . . . . . . . . . . . . . . . . . . . .1
Quick reference data . . . . . . . . . . . . . . . . . . . . .1
Pinning information . . . . . . . . . . . . . . . . . . . . . . .2
Ordering information . . . . . . . . . . . . . . . . . . . . . .2
Limiting values. . . . . . . . . . . . . . . . . . . . . . . . . . .3
Thermal characteristics . . . . . . . . . . . . . . . . . . .4
Characteristics . . . . . . . . . . . . . . . . . . . . . . . . . . .5
Package outline . . . . . . . . . . . . . . . . . . . . . . . . . .8
Revision history . . . . . . . . . . . . . . . . . . . . . . . . . .9
Legal information. . . . . . . . . . . . . . . . . . . . . . . .10
Data sheet status . . . . . . . . . . . . . . . . . . . . . . .10
Definitions . . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Disclaimers . . . . . . . . . . . . . . . . . . . . . . . . . . . .10
Trademarks. . . . . . . . . . . . . . . . . . . . . . . . . . . . 11
Contact information. . . . . . . . . . . . . . . . . . . . . . 11
Please be aware that important notices concerning this document and the product(s)
described herein, have been included in section ‘Legal information’.
© NXP B.V. 2011.
Date of release: 26 April 2011
Document identifier: BUK9575-100A
